[PATCH 0/6] Use -ENOSYS consistently
A few places use -ENOTSUPP when they should use -ENOSYS. In two cases both are used. This little series tidies this up.
Simon Glass (6): usb: Return -ENOSYS when system call is not available spi: Return -ENOSYS when system call is not available tlv_eeprom: Return -ENOSYS when system call is not available clk: Return -ENOSYS when system call is not available simple-pm-bus: Use -ENOSYS for checking missing system call pinctrl: Return -ENOSYS when system call is not available
drivers/clk/clk-composite.c | 8 ++++---- drivers/core/simple-pm-bus.c | 4 ++-- drivers/pinctrl/pinctrl-uclass.c | 10 ++++++---- drivers/usb/gadget/udc/udc-uclass.c | 2 +- include/spi-mem.h | 2 +- include/tlv_eeprom.h | 6 +++--- 6 files changed, 17 insertions(+), 15 deletions(-)
Update usb_gadget_release() to use -ENOSYS, which is the correct error code for U-Boot.
drivers/usb/gadget/udc/udc-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/usb/gadget/udc/udc-uclass.c b/drivers/usb/gadget/udc/udc-uclass.c index 3053ccf7d97..dbc354e84f9 100644 --- a/drivers/usb/gadget/udc/udc-uclass.c +++ b/drivers/usb/gadget/udc/udc-uclass.c @@ -45,7 +45,7 @@ int usb_gadget_release(int index) dev_array[index] = NULL; return ret; #else - return -ENOTSUPP; + return -ENOSYS; #endif }
It would be good if you could explain _why_ this change is required. Why is ENOSYS the correct return value ? It is not clear from the patch description, sorry.
Hi Marek,
That is the value used throughout driver model, so it is a convention. As per the cover letter and one on the patches, people are not sure which one to use, because -ENOTSUPP has crept in in a few places.
On 3/21/21 5:12 AM, Simon Glass wrote:
Hi Marek,
I agree with Tom, this needs to be documented first, then the document should be agreed upon, and only then should these fixes follow.
Update spi_controller_dma_map_mem_op_data() to use -ENOSYS, which is the correct error code for U-Boot.
include/spi-mem.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/spi-mem.h b/include/spi-mem.h index 8be3e2bf6b5..e354c388979 100644 --- a/include/spi-mem.h +++ b/include/spi-mem.h @@ -222,7 +222,7 @@ spi_controller_dma_map_mem_op_data(struct spi_controller *ctlr, const struct spi_mem_op *op, struct sg_table *sg) { - return -ENOTSUPP; + return -ENOSYS; }
static inline void
When CMD_TLV_EEPROM is not enabled, use -ENOSYS, which is the correct error code for U-Boot.
include/tlv_eeprom.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/tlv_eeprom.h b/include/tlv_eeprom.h index 1de2fe2337c..a2c333e7446 100644 --- a/include/tlv_eeprom.h +++ b/include/tlv_eeprom.h @@ -114,19 +114,19 @@ int read_tlvinfo_tlv_eeprom(void *eeprom, struct tlvinfo_header **hdr,
static inline int read_tlv_eeprom(void *eeprom, int offset, int len, int dev) { - return -ENOTSUPP; + return -ENOSYS; }
static inline int write_tlv_eeprom(void *eeprom, int len) { - return -ENOTSUPP; + return -ENOSYS; }
static inline int read_tlvinfo_tlv_eeprom(void *eeprom, struct tlvinfo_header **hdr, struct tlvinfo_tlv **first_entry, int dev) { - return -ENOTSUPP; + return -ENOSYS; }
#endif /* CONFIG_IS_ENABLED(CMD_TLV_EEPROM) */
Update clk_composite_set_parent() to use -ENOSYS, which is the correct error code for U-Boot. Also rearrange the code so that the error condition is clearly indicated and the function runs to the end in the normal case, since this is the common style in U-Boot.
drivers/clk/clk-composite.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/clk/clk-composite.c b/drivers/clk/clk-composite.c index 7e99c5b910d..bb5351ebc0b 100644 --- a/drivers/clk/clk-composite.c +++ b/drivers/clk/clk-composite.c @@ -37,10 +37,10 @@ static int clk_composite_set_parent(struct clk *clk, struct clk *parent) const struct clk_ops *mux_ops = composite->mux_ops; struct clk *mux = composite->mux;
- if (mux && mux_ops) - return mux_ops->set_parent(mux, parent); - else - return -ENOTSUPP; + if (!mux || !mux_ops) + return -ENOSYS; + + return mux_ops->set_parent(mux, parent); }
static unsigned long clk_composite_recalc_rate(struct clk *clk)
- else
return -ENOTSUPP;
return -ENOSYS;
Reviewed-by: Sean Anderson seanga2@gmail.com
Will this be applied to the whole clock subsystem? From what I can tell, the clock subsystem returns ENOSYS in these situations, and drivers return ENOTSUPP. It would be great if we could unified all these so callers could check for one return value.
--Sean
Hi Seam,
if (mux && mux_ops)
else
return -ENOTSUPP;
return -ENOSYS;
Most drivers use -EINVAL for an invalid / unknown clock, whereas -ENOSYS is for an unimplemented method or sub-method.
So I'll add a patch to use -EINVAL consistently.
We don't need to check -ENOTSUPP since this is not used for this purpose in U-Boot. Update the code accordingly.
drivers/core/simple-pm-bus.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/core/simple-pm-bus.c b/drivers/core/simple-pm-bus.c index 7a18953cba1..1bb0d86e289 100644 --- a/drivers/core/simple-pm-bus.c +++ b/drivers/core/simple-pm-bus.c @@ -21,7 +21,7 @@ static int simple_pm_bus_probe(struct udevice *dev) return ret;
ret = clk_enable_bulk(bulk); - if (ret && ret != -ENOSYS && ret != -ENOTSUPP) { + if (ret && ret != -ENOSYS) { clk_release_bulk(bulk); return ret; } @@ -34,7 +34,7 @@ static int simple_pm_bus_remove(struct udevice *dev) struct clk_bulk *bulk = dev_get_priv(dev);
ret = clk_release_bulk(bulk); - if (ret && ret != -ENOSYS && ret != -ENOTSUPP) + if (ret && ret != -ENOSYS) return ret; else return 0;
- if (ret && ret != -ENOSYS) { clk_release_bulk(bulk); return ret; }
- if (ret && ret != -ENOSYS) return ret; else return 0;
Nak. This cannot be removed until all drivers have been converted to use -ENOSYS.
--Sean
Update the code to use -ENOSYS, which is the correct error code for an unimplemented system call in U-Boot.
Also we should not check for a missing operations array as this is not permitted. For now this can be covered by an assert().
drivers/pinctrl/pinctrl-uclass.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-uclass.c b/drivers/pinctrl/pinctrl-uclass.c index b0f30aa1f75..6e68e52c32c 100644 --- a/drivers/pinctrl/pinctrl-uclass.c +++ b/drivers/pinctrl/pinctrl-uclass.c @@ -235,8 +235,9 @@ int pinctrl_gpio_request(struct udevice *dev, unsigned offset) return ret;
ops = pinctrl_get_ops(pctldev); - if (!ops || !ops->gpio_request_enable) - return -ENOTSUPP; + assert(ops); + if (!ops->gpio_request_enable) + return -ENOSYS;
return ops->gpio_request_enable(pctldev, pin_selector); } @@ -261,8 +262,9 @@ int pinctrl_gpio_free(struct udevice *dev, unsigned offset) return ret;
ops = pinctrl_get_ops(pctldev); - if (!ops || !ops->gpio_disable_free) - return -ENOTSUPP; + assert(ops); + if (!ops->gpio_disable_free) + return -ENOSYS;
return ops->gpio_disable_free(pctldev, pin_selector); }
I think we need to start this series with a doc update that makes it clear why this is correct and when it should be used. There's two instances of "ENOSYS" in doc/driver-model/ today and neither explains why this series is correct (which I'm sure it is). Thanks.
Sean Anderson
