[U-Boot] [PATCH v2 0/4] move rockchip sdram driver to driver/ram
move all the Rockchip sdram driver which support CONFIG_RAM into driver/ram folder
Series 2 is a rebase based on u-boot-rockchip master branch.
Kever Yang (4): rockchip: rk3399: move sdram driver to driver/ram rockchip: rk3188: move sdram driver to driver/ram rockchip: rk3288: move sdram driver to driver/ram rockchip: rk3328: move sdram driver to driver/ram
arch/arm/mach-rockchip/rk3188/Makefile | 1 - arch/arm/mach-rockchip/rk3288/Makefile | 1 - arch/arm/mach-rockchip/rk3328/Makefile | 1 - arch/arm/mach-rockchip/rk3399/Makefile | 1 - drivers/ram/rockchip/Makefile | 4 ++++ .../arm/mach-rockchip/rk3188 => drivers/ram/rockchip}/sdram_rk3188.c | 0 .../arm/mach-rockchip/rk3288 => drivers/ram/rockchip}/sdram_rk3288.c | 0 .../arm/mach-rockchip/rk3328 => drivers/ram/rockchip}/sdram_rk3328.c | 0 .../arm/mach-rockchip/rk3399 => drivers/ram/rockchip}/sdram_rk3399.c | 0 9 files changed, 4 insertions(+), 4 deletions(-) rename {arch/arm/mach-rockchip/rk3188 => drivers/ram/rockchip}/sdram_rk3188.c (100%) rename {arch/arm/mach-rockchip/rk3288 => drivers/ram/rockchip}/sdram_rk3288.c (100%) rename {arch/arm/mach-rockchip/rk3328 => drivers/ram/rockchip}/sdram_rk3328.c (100%) rename {arch/arm/mach-rockchip/rk3399 => drivers/ram/rockchip}/sdram_rk3399.c (100%)
Since we have CONFIG_RAM framwork and its driver folder, move the driver into it.
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com ---
arch/arm/mach-rockchip/rk3399/Makefile | 1 - drivers/ram/rockchip/Makefile | 1 + {arch/arm/mach-rockchip/rk3399 => drivers/ram/rockchip}/sdram_rk3399.c | 0 3 files changed, 1 insertion(+), 1 deletion(-) rename {arch/arm/mach-rockchip/rk3399 => drivers/ram/rockchip}/sdram_rk3399.c (100%)
diff --git a/arch/arm/mach-rockchip/rk3399/Makefile b/arch/arm/mach-rockchip/rk3399/Makefile index 793ce31..98ebeac 100644 --- a/arch/arm/mach-rockchip/rk3399/Makefile +++ b/arch/arm/mach-rockchip/rk3399/Makefile @@ -6,5 +6,4 @@
obj-y += clk_rk3399.o obj-y += rk3399.o -obj-y += sdram_rk3399.o obj-y += syscon_rk3399.o diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index b09d03c..bfc016f 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -5,3 +5,4 @@ #
obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o +obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o diff --git a/arch/arm/mach-rockchip/rk3399/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c similarity index 100% rename from arch/arm/mach-rockchip/rk3399/sdram_rk3399.c rename to drivers/ram/rockchip/sdram_rk3399.c
Applied to u-boot-rockchip, thanks!
arch/arm/mach-rockchip/rk3188/Makefile | 1 - drivers/ram/rockchip/Makefile | 1 + {arch/arm/mach-rockchip/rk3188 => drivers/ram/rockchip}/sdram_rk3188.c | 0 3 files changed, 1 insertion(+), 1 deletion(-) rename {arch/arm/mach-rockchip/rk3188 => drivers/ram/rockchip}/sdram_rk3188.c (100%)
diff --git a/arch/arm/mach-rockchip/rk3188/Makefile b/arch/arm/mach-rockchip/rk3188/Makefile index 2dc9511..7fa0104 100644 --- a/arch/arm/mach-rockchip/rk3188/Makefile +++ b/arch/arm/mach-rockchip/rk3188/Makefile @@ -6,6 +6,5 @@
ifndef CONFIG_TPL_BUILD obj-y += clk_rk3188.o -obj-y += sdram_rk3188.o obj-y += syscon_rk3188.o endif diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index bfc016f..50b9d51 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -5,4 +5,5 @@ #
obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o +obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o diff --git a/arch/arm/mach-rockchip/rk3188/sdram_rk3188.c b/drivers/ram/rockchip/sdram_rk3188.c similarity index 100% rename from arch/arm/mach-rockchip/rk3188/sdram_rk3188.c rename to drivers/ram/rockchip/sdram_rk3188.c
arch/arm/mach-rockchip/rk3288/Makefile | 1 - drivers/ram/rockchip/Makefile | 1 + {arch/arm/mach-rockchip/rk3288 => drivers/ram/rockchip}/sdram_rk3288.c | 0 3 files changed, 1 insertion(+), 1 deletion(-) rename {arch/arm/mach-rockchip/rk3288 => drivers/ram/rockchip}/sdram_rk3288.c (100%)
diff --git a/arch/arm/mach-rockchip/rk3288/Makefile b/arch/arm/mach-rockchip/rk3288/Makefile index b5b28ef..a0033a0 100644 --- a/arch/arm/mach-rockchip/rk3288/Makefile +++ b/arch/arm/mach-rockchip/rk3288/Makefile @@ -6,5 +6,4 @@
obj-y += clk_rk3288.o obj-y += rk3288.o -obj-y += sdram_rk3288.o obj-y += syscon_rk3288.o diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 50b9d51..95aae48 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -6,4 +6,5 @@
obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o +obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o diff --git a/arch/arm/mach-rockchip/rk3288/sdram_rk3288.c b/drivers/ram/rockchip/sdram_rk3288.c similarity index 100% rename from arch/arm/mach-rockchip/rk3288/sdram_rk3288.c rename to drivers/ram/rockchip/sdram_rk3288.c
arch/arm/mach-rockchip/rk3328/Makefile | 1 - drivers/ram/rockchip/Makefile | 1 + {arch/arm/mach-rockchip/rk3328 => drivers/ram/rockchip}/sdram_rk3328.c | 0 3 files changed, 1 insertion(+), 1 deletion(-) rename {arch/arm/mach-rockchip/rk3328 => drivers/ram/rockchip}/sdram_rk3328.c (100%)
diff --git a/arch/arm/mach-rockchip/rk3328/Makefile b/arch/arm/mach-rockchip/rk3328/Makefile index 72873e2..bbab036 100644 --- a/arch/arm/mach-rockchip/rk3328/Makefile +++ b/arch/arm/mach-rockchip/rk3328/Makefile @@ -6,5 +6,4 @@
obj-y += clk_rk3328.o obj-y += rk3328.o -obj-y += sdram_rk3328.o obj-y += syscon_rk3328.o diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 95aae48..6c78eff 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -7,4 +7,5 @@ obj-$(CONFIG_ROCKCHIP_RK3368) = dmc-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3188) = sdram_rk3188.o obj-$(CONFIG_ROCKCHIP_RK3288) = sdram_rk3288.o +obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o obj-$(CONFIG_ROCKCHIP_RK3399) = sdram_rk3399.o diff --git a/arch/arm/mach-rockchip/rk3328/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c similarity index 100% rename from arch/arm/mach-rockchip/rk3328/sdram_rk3328.c rename to drivers/ram/rockchip/sdram_rk3328.c
Kever Yang
Philipp Tomsich
