[U-Boot] [PATCH] mxs_ocotp: Shift the HBUS divider correctly
When the original HBUS divider value is retrieved in mxs_ocotp_scale_hclk() for the purpose or restoring it back later, the value is not shifted by the HBUS divider offset in that register. This is not a problem, since the shift is zero on all MXS hardware. Add the shift anyway, for completeness and in case FSL ever decides to re-use this driver on future designs.
Signed-off-by: Chris Smith chris@zxdesign.info Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de --- drivers/misc/mxs_ocotp.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/misc/mxs_ocotp.c b/drivers/misc/mxs_ocotp.c index 6f0a1d3..6c0d247 100644 --- a/drivers/misc/mxs_ocotp.c +++ b/drivers/misc/mxs_ocotp.c @@ -152,6 +152,7 @@ static int mxs_ocotp_scale_hclk(bool enter, uint32_t *val) /* Return the original HCLK clock speed. */ *val = readl(&clkctrl_regs->hw_clkctrl_hbus); *val &= CLKCTRL_HBUS_DIV_MASK; + *val >>= CLKCTRL_HBUS_DIV_OFFSET;
/* Scale the HCLK to 454/19 = 23.9 MHz . */ scale_val = (~19) << CLKCTRL_HBUS_DIV_OFFSET;
Best regards, Stefano Babic
Stefano Babic
