[PATCH v6] Add support for SoM "VoCore2".
Small patch to add support for VoCore/VoCore2 board.
VoCore is open hardware and runs OpenWrt/LEDE. It has WIFI, USB, UART, 20+ GPIOs but is only one inch square. It will help you to make a smart house, study embedded system or even make the tiniest router in the world.
Details about this SoM can be found at "https://vocore.io/v2.html".
Signed-off-by: Mauro Condarelli mc5686@mclink.it ---
Changes in v6: - Added MAINTAINERS file. - Removed project-specific configs/vocore2_defconfig_ENV_IN_FAT. - Removed guard for SPL Serial definitions in include/configs/vocore2.h. - Removed Baudrate Table definition in include/configs/vocore2.h. - Moved board-specific DTS settingsto arch/mips/dts/vocore_vocore2.dts. - Added UART2 pin definitions to arch/mips/dts/vocore_vocore2.dts. - Removed unused mmc pin definition from arch/mips/dts/vocore_vocore2.dts. - Added select of SPL_UART2_SPIS_PINMUX in board choice. - Updated configs/vocore2_defconfig.
Changes in v5: - Removed unneeded (and wrong) UART2 initialization in board.c - Added network setup. - Removed project-specific code. - Move back environment to SPI NOR. - Changes to environment default settings. - Rebase on current u-boot-mips/testing.
Changes in v4: - Reverted some overzealous DTS cleaning. - Added support for bootcount.
Changes in v3: - based on top of Weijie Gao patchset: "[v3,xx/20]Refactor the architecture parts of mt7628"
Changes in v2: - Removed some dead code - Changed Author to my full name (no nick) - Removed unwanted fixup to .dts generation (not my call). - Fixed commit message - Fixed various variables/filenames to include Vendor name - Changed Vendor name (Vonger -> Vocore)
arch/mips/dts/Makefile | 1 + arch/mips/dts/vocore_vocore2.dts | 85 ++++++++++++++++++++++++++ arch/mips/mach-mtmips/Kconfig | 10 +++ board/vocore/vocore2/Kconfig | 12 ++++ board/vocore/vocore2/MAINTAINERS | 7 +++ board/vocore/vocore2/Makefile | 3 + board/vocore/vocore2/board.c | 6 ++ configs/vocore2_defconfig | 101 +++++++++++++++++++++++++++++++ include/configs/vocore2.h | 54 +++++++++++++++++ 9 files changed, 279 insertions(+) create mode 100644 arch/mips/dts/vocore_vocore2.dts create mode 100644 board/vocore/vocore2/Kconfig create mode 100644 board/vocore/vocore2/MAINTAINERS create mode 100644 board/vocore/vocore2/Makefile create mode 100644 board/vocore/vocore2/board.c create mode 100644 configs/vocore2_defconfig create mode 100644 include/configs/vocore2.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index cbd0c8bc8b..f711e9fb59 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -23,6 +23,7 @@ dtb-$(CONFIG_BOARD_NETGEAR_DGND3700V2) += netgear,dgnd3700v2.dtb dtb-$(CONFIG_BOARD_SAGEM_FAST1704) += sagem,f@st1704.dtb dtb-$(CONFIG_BOARD_SFR_NB4_SER) += sfr,nb4-ser.dtb dtb-$(CONFIG_BOARD_TPLINK_WDR4300) += tplink_wdr4300.dtb +dtb-$(CONFIG_BOARD_VOCORE2) += vocore_vocore2.dtb dtb-$(CONFIG_TARGET_JZ4780_CI20) += ci20.dtb dtb-$(CONFIG_SOC_LUTON) += luton_pcb090.dtb luton_pcb091.dtb dtb-$(CONFIG_SOC_OCELOT) += ocelot_pcb120.dtb ocelot_pcb123.dtb diff --git a/arch/mips/dts/vocore_vocore2.dts b/arch/mips/dts/vocore_vocore2.dts new file mode 100644 index 0000000000..3502e4b8b7 --- /dev/null +++ b/arch/mips/dts/vocore_vocore2.dts @@ -0,0 +1,85 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + */ + +/dts-v1/; + +#include "mt7628a.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + compatible = "vocore,vocore2", "ralink,mt7628a-soc"; + model = "VoCore2"; + + aliases { + serial0 = &uart2; + spi0 = &spi0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x08000000>; + }; + leds { + compatible = "gpio-leds"; + + power { + label = "vocore:power"; + gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + }; + + chosen { + bootargs = "console=ttyS2,115200"; + stdout-path = &uart2; + }; +}; + +&pinctrl { + state_default: pin_state { + p0led { + groups = "p0led_a"; + function = "led"; + }; + }; +}; + +&uart2 { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pwm_pins>; +}; + +&spi0 { + status = "okay"; + nor0: spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; + +ð { + status = "okay"; + + pinctrl-names = "default"; + pinctrl-0 = <&ephy_iot_mode>; + mediatek,poll-link-phy = <0>; +}; + +&mmc { + status = "okay"; + + bus-width = <4>; + max-frequency = <48000000>; + cap-sd-highspeed; + cap-mmc-highspeed; + + pinctrl-names = "default"; + pinctrl-0 = <&sd_iot_mode>; +}; diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index bcd635f438..6ca3b3aad3 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -83,6 +83,15 @@ config BOARD_MT7628_RFB SPI-NOR flash, 1 built-in switch with 5 ports, 1 UART, 1 USB host, 1 SDXC, 1 PCIe socket and JTAG pins.
+config BOARD_VOCORE2 + bool "VoCore2" + depends on SOC_MT7628 + select SPL_SERIAL_SUPPORT + select SPL_UART2_SPIS_PINMUX + help + VoCore VoCore2 board has a MT7628 SoC with 128 MiB of RAM + and 16 MiB of flash (SPI). + endchoice
config SPL_UART2_SPIS_PINMUX @@ -96,5 +105,6 @@ config SPL_UART2_SPIS_PINMUX source "board/gardena/smart-gateway-mt7688/Kconfig" source "board/mediatek/mt7628/Kconfig" source "board/seeed/linkit-smart-7688/Kconfig" +source "board/vocore/vocore2/Kconfig"
endmenu diff --git a/board/vocore/vocore2/Kconfig b/board/vocore/vocore2/Kconfig new file mode 100644 index 0000000000..baeff31b69 --- /dev/null +++ b/board/vocore/vocore2/Kconfig @@ -0,0 +1,12 @@ +if BOARD_VOCORE2 + +config SYS_BOARD + default "vocore2" + +config SYS_VENDOR + default "vocore" + +config SYS_CONFIG_NAME + default "vocore2" + +endif diff --git a/board/vocore/vocore2/MAINTAINERS b/board/vocore/vocore2/MAINTAINERS new file mode 100644 index 0000000000..8472351fe2 --- /dev/null +++ b/board/vocore/vocore2/MAINTAINERS @@ -0,0 +1,7 @@ +VOCORE_VOCORE2 BOARD +M: Mauro Condarelli mc5686@mclink.it +S: Maintained +F: board/vocore/vocore2 +F: include/configs/vocore2.h +F: configs/vocore2_defconfig +F: arch/mips/dts/vocore_vocore2.dts diff --git a/board/vocore/vocore2/Makefile b/board/vocore/vocore2/Makefile new file mode 100644 index 0000000000..70cd7a8e56 --- /dev/null +++ b/board/vocore/vocore2/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0+ + +obj-y += board.o diff --git a/board/vocore/vocore2/board.c b/board/vocore/vocore2/board.c new file mode 100644 index 0000000000..27e42d1414 --- /dev/null +++ b/board/vocore/vocore2/board.c @@ -0,0 +1,6 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + * + * Nothing actually needed here + */ diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig new file mode 100644 index 0000000000..952d9d42de --- /dev/null +++ b/configs/vocore2_defconfig @@ -0,0 +1,101 @@ +CONFIG_MIPS=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SIZE=0x1000 +CONFIG_ENV_SECT_SIZE=0x1000 +CONFIG_ENV_OFFSET=0x04e000 +CONFIG_SYS_BOOTCOUNT_ADDR=0xb000006c +CONFIG_SPL_SYS_MALLOC_F_LEN=0x20000 +CONFIG_NR_DRAM_BANKS=1 +CONFIG_SPL=y +CONFIG_SYS_BOOTCOUNT_SINGLEWORD=y +CONFIG_ARCH_MTMIPS=y +CONFIG_BOARD_VOCORE2=y +CONFIG_RESTORE_EXCEPTION_VECTOR_BASE=y +CONFIG_MIPS_BOOT_FDT=y +CONFIG_ENV_VARS_UBOOT_CONFIG=y +CONFIG_SYS_BOOT_GET_CMDLINE=y +CONFIG_SYS_BOOT_GET_KBD=y +CONFIG_FIT=y +CONFIG_FIT_SIGNATURE=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_LOGLEVEL=8 +CONFIG_VERSION_VARIABLE=y +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_SYS_MALLOC_SIMPLE=y +CONFIG_SPL_NOR_SUPPORT=y +CONFIG_HUSH_PARSER=y +CONFIG_CMD_LICENSE=y +# CONFIG_BOOTM_NETBSD is not set +# CONFIG_BOOTM_PLAN9 is not set +# CONFIG_BOOTM_RTEMS is not set +# CONFIG_BOOTM_VXWORKS is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_CRC32 is not set +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_GPT_RENAME=y +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_MTD=y +CONFIG_CMD_PART=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_BOOTCOUNT=y +CONFIG_CMD_TIME=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_CMD_MTDPARTS=y +CONFIG_MTDIDS_DEFAULT="nor0=spi0.0" +CONFIG_MTDPARTS_DEFAULT="spi0.0:312k(u-boot),4k(env),4k(factory),2368k(kernel),-(filesystem)" +CONFIG_DEFAULT_DEVICE_TREE="vocore_vocore2" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_DM=y +# CONFIG_DM_DEVICE_REMOVE is not set +CONFIG_BOOTCOUNT_LIMIT=y +CONFIG_LED=y +CONFIG_LED_BLINK=y +CONFIG_LED_GPIO=y +CONFIG_MMC=y +CONFIG_DM_MMC=y +# CONFIG_MMC_HW_PARTITIONING is not set +CONFIG_MMC_MTK=y +CONFIG_MTD=y +CONFIG_SPI_FLASH_SFDP_SUPPORT=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_MT7628_ETH=y +CONFIG_PHY=y +CONFIG_MT76X8_USB_PHY=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set +CONFIG_SPECIFY_CONSOLE_INDEX=y +CONFIG_CONS_INDEX=3 +CONFIG_SPI=y +CONFIG_MT7621_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_STORAGE=y +CONFIG_WDT=y +CONFIG_WDT_MT7621=y +CONFIG_FS_EXT4=y +CONFIG_FAT_WRITE=y +CONFIG_LZMA=y +CONFIG_LZO=y diff --git a/include/configs/vocore2.h b/include/configs/vocore2.h new file mode 100644 index 0000000000..8100e4dca7 --- /dev/null +++ b/include/configs/vocore2.h @@ -0,0 +1,54 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it + */ + +#ifndef __VOCORE2_CONFIG_H__ +#define __VOCORE2_CONFIG_H__ + +/* CPU */ +#define CONFIG_SYS_MIPS_TIMER_FREQ 290000000 + +/* RAM */ +#define CONFIG_SYS_SDRAM_BASE 0x80000000 + +#define CONFIG_SYS_LOAD_ADDR CONFIG_SYS_SDRAM_BASE + 0x100000 + +#define CONFIG_SYS_INIT_SP_OFFSET 0x400000 + +/* SPL */ +#if defined(CONFIG_SPL) && !defined(CONFIG_SPL_BUILD) +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif + +#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE +#define CONFIG_SPL_BSS_START_ADDR 0x80010000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x10000 +#define CONFIG_SPL_MAX_SIZE 0x10000 + +/* Dummy value */ +#define CONFIG_SYS_UBOOT_BASE 0 + +/* Serial SPL */ +#define CONFIG_SYS_NS16550_MEM32 +#define CONFIG_SYS_NS16550_CLK 40000000 +#define CONFIG_SYS_NS16550_REG_SIZE -4 +#define CONFIG_SYS_NS16550_COM3 0xb0000e00 +#define CONFIG_CONS_INDEX 3 + +/* RAM */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x80400000 + +/* Memory usage */ +#define CONFIG_SYS_MAXARGS 64 +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) +#define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) +#define CONFIG_SYS_CBSIZE 512 + +/* U-Boot */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +/* Environment settings */ + +#endif //__VOCORE2_CONFIG_H__
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- Copyright (C) 2019 Mauro Condarelli mc5686@mclink.it
+/dts-v1/;
- compatible = "vocore,vocore2", "ralink,mt7628a-soc";
- model = "VoCore2";
- aliases {
serial0 = &uart2;
spi0 = &spi0;
- memory@0 {
Nitpicking: It looks nicer with an empty line here as well. But no need to send v7 because of this. Other than this:
Thanks, Stefan
- leds {
power {
- chosen {
+&pinctrl {
- state_default: pin_state {
p0led {
groups = "p0led_a";
function = "led";
+&uart2 {
- status = "okay";
- pinctrl-names = "default";
- pinctrl-0 = <&uart2_pwm_pins>;
+&spi0 {
- status = "okay";
- nor0: spi-flash@0 {
#size-cells = <1>;
reg = <0>;
+ð {
- status = "okay";
- pinctrl-0 = <&ephy_iot_mode>;
- mediatek,poll-link-phy = <0>;
+&mmc {
- status = "okay";
- bus-width = <4>;
- max-frequency = <48000000>;
- cap-sd-highspeed;
- cap-mmc-highspeed;
- pinctrl-0 = <&sd_iot_mode>;
bool "VoCore2"
help
endchoice
+config SYS_BOARD
- default "vocore2"
+config SYS_VENDOR
- default "vocore"
- default "vocore2"
- Nothing actually needed here
Viele Grüße, Stefan
Am 18.02.20 um 09:34 schrieb Mauro Condarelli:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
applied to u-boot-mips/next with refreshing the defconfig
Daniel Schwierzeck
Mauro Condarelli
Stefan Roese
