[PATCH] arm: mach-k3: Move K3 degenerate keys out of board folder
This file is common for all of K3, move it out of board/ directory and into mach-k3. And change the relative paths to absolute paths in the binman paths.
Signed-off-by: Nishanth Menon nm@ti.com --- Cc: Neha Malcom Francis n-francis@ti.com Cc: Simon Glass sjg@chromium.org Cc: Marcel Ziswiler marcel.ziswiler@toradex.com Cc: Vignesh Raghavendra vigneshr@ti.com Cc: Francesco Dolcini francesco@dolcini.it Cc: Andrew Davis afd@ti.com
Similar to the patch https://lore.kernel.org/all/20231101183329.65091-1-afd@ti.com/
arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi | 2 +- arch/arm/dts/k3-binman.dtsi | 2 +- {board/ti/keys => arch/arm/mach-k3}/ti-degenerate-key.pem | 0 3 files changed, 2 insertions(+), 2 deletions(-) rename {board/ti/keys => arch/arm/mach-k3}/ti-degenerate-key.pem (100%)
diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi index b489d8afbe36..a6d7c2df20e0 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -10,7 +10,7 @@ };
&dkey_pem { - filename = "../../ti/keys/ti-degenerate-key.pem"; + filename = "arch/arm/mach-k3/ti-degenerate-key.pem"; };
#ifdef CONFIG_TARGET_VERDIN_AM62_R5 diff --git a/arch/arm/dts/k3-binman.dtsi b/arch/arm/dts/k3-binman.dtsi index 0212d44ee3b2..af0f83100bd5 100644 --- a/arch/arm/dts/k3-binman.dtsi +++ b/arch/arm/dts/k3-binman.dtsi @@ -20,7 +20,7 @@ ti-degenerate-key { filename = "ti-degenerate-key.pem"; dkey_pem: blob-ext { - filename = "../keys/ti-degenerate-key.pem"; + filename = "arch/arm/mach-k3/ti-degenerate-key.pem"; }; }; }; diff --git a/board/ti/keys/ti-degenerate-key.pem b/arch/arm/mach-k3/ti-degenerate-key.pem similarity index 100% rename from board/ti/keys/ti-degenerate-key.pem rename to arch/arm/mach-k3/ti-degenerate-key.pem
&dkey_pem {
- filename = "arch/arm/mach-k3/ti-degenerate-key.pem"; };
You shouldn't need to modify dkey_pem here anymore if the path is now absolute, you can just drop this whole override node.
While here you might as well move the TI dummy key (custMpk.pem) over the same way.
Andrew
}; }; };filename = "arch/arm/mach-k3/ti-degenerate-key.pem";
On 18:31-20231103, Andrew Davis wrote: [...]
diff --git a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi index b489d8afbe36..a6d7c2df20e0 100644 --- a/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi +++ b/arch/arm/dts/k3-am625-verdin-wifi-dev-binman.dtsi @@ -10,7 +10,7 @@ }; &dkey_pem {
True.. done in V2.
Andrew Davis
Nishanth Menon
