[PATCH v3] timer: Add a migration message
Some boards still use the old timer mechanism. Set a deadline for them to update to driver model. Point to some examples as well.
This needs a bit of a strange rule to avoid an error on some boards.
Changes in v3: - Push out the deadline
Makefile | 4 ++++ doc/develop/driver-model/migration.rst | 12 ++++++++++++ 2 files changed, 16 insertions(+)
diff --git a/Makefile b/Makefile index ab32efb4d11..7b24250103e 100644 --- a/Makefile +++ b/Makefile @@ -1124,6 +1124,10 @@ endif $(call deprecated,CONFIG_DM_ETH,Ethernet drivers,v2020.07,$(CONFIG_NET)) $(call deprecated,CONFIG_DM_I2C,I2C drivers,v2022.04,$(CONFIG_SYS_I2C_LEGACY)) $(call deprecated,CONFIG_DM_KEYBOARD,Keyboard drivers,v2022.10,$(CONFIG_KEYBOARD)) + @# CONFIG_SYS_TIMER_RATE has brackets in it for some boards which + @# confuses this rule. Use if() to send just a single character which + @# is enable to tell 'deprecated' that one of these symbols exists + $(call deprecated,CONFIG_TIMER,Timer drivers,v2023.01,$(if $(strip $(CONFIG_SYS_TIMER_RATE)$(CONFIG_SYS_TIMER_COUNTER)),x)) @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG @# options are whitelisted, so new ones should not be added. diff --git a/doc/develop/driver-model/migration.rst b/doc/develop/driver-model/migration.rst index 3dbeea6537c..ed342bd4930 100644 --- a/doc/develop/driver-model/migration.rst +++ b/doc/develop/driver-model/migration.rst @@ -106,3 +106,15 @@ Deadline: 2022.10 This is a legacy option which has been replaced by driver model. Maintainers should submit patches switching over to using CONFIG_DM_KEYBOARD and other base driver model options in time for inclusion in the 2022.10 release. + +CONFIG_SYS_TIMER_RATE and CONFIG_SYS_TIMER_COUNTER +-------------------------------------------------- +Deadline: 2023.01 + +These are legacy options which have been replaced by driver model. +Maintainers should submit patches switching over to using CONFIG_TIMER and +other base driver model options in time for inclusion in the 2022.10 release. + +There is only one method to implement, unless you want to support bootstage, +in which case you need an early timer alsol. For example drivers, see +sandbox_timer.c and rockchip_timer.c
Changes in v3:
- @# CONFIG_SYS_TIMER_RATE has brackets in it for some boards which
- @# confuses this rule. Use if() to send just a single character which
- @# is enable to tell 'deprecated' that one of these symbols exists
- $(call deprecated,CONFIG_TIMER,Timer drivers,v2023.01,$(if $(strip $(CONFIG_SYS_TIMER_RATE)$(CONFIG_SYS_TIMER_COUNTER)),x)) @# Check that this build does not use CONFIG options that we do not @# know about unless they are in Kconfig. All the existing CONFIG @# options are whitelisted, so new ones should not be added.
nit: also
Sean Anderson
