Fwd: New Defects reported by Coverity Scan for efi_capsule.c
Dear Sughosh, Takahiro, Jose,
could you please, look into the issues below.
-------- Forwarded Message -------- Subject: New Defects reported by Coverity Scan for Das U-Boot Date: Mon, 19 Apr 2021 01:18:38 +0000 (UTC) From: scan-admin@coverity.com To: xypron.glpk@gmx.de
Please find the latest report on new defect(s) introduced to Das U-Boot found with Coverity Scan.
13 new defect(s) introduced to Das U-Boot found with Coverity Scan. 5 defect(s), reported by Coverity Scan earlier, were marked fixed in the recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan Showing 13 of 13 defect(s)
** CID 331153: Code maintainability issues (UNUSED_VALUE) /lib/efi_loader/efi_capsule.c: 661 in find_boot_device()
________________________________________________________________________________________________________ *** CID 331153: Code maintainability issues (UNUSED_VALUE) /lib/efi_loader/efi_capsule.c: 661 in find_boot_device() 655 size = 0; 656 ret = efi_get_variable_int(L"BootOrder", &efi_global_variable_guid, 657 NULL, &size, NULL, NULL); 658 if (ret == EFI_BUFFER_TOO_SMALL) { 659 boot_order = malloc(size); 660 if (!boot_order) {
CID 331153: Code maintainability issues (UNUSED_VALUE) Assigning value "9223372036854775817UL" to "ret" here, but that stored value is overwritten before it can be used.
661 ret = EFI_OUT_OF_RESOURCES;
@Sughosh, Takahiro The logic after out: should consider ret. Maybe just move the label further down.
662 goto out; 663 } 664 665 ret = efi_get_variable_int(L"BootOrder", 666 &efi_global_variable_guid,
** CID 331147: Code maintainability issues (UNUSED_VALUE) /lib/efi_loader/efi_capsule.c: 456 in efi_update_capsule()
________________________________________________________________________________________________________ *** CID 331147: Code maintainability issues (UNUSED_VALUE) /lib/efi_loader/efi_capsule.c: 456 in efi_update_capsule() 450 efi_status_t ret; 451 452 EFI_ENTRY("%p, %zu, %llu\n", capsule_header_array, capsule_count, 453 scatter_gather_list); 454 455 if (!capsule_count) {
CID 331147: Code maintainability issues (UNUSED_VALUE) Assigning value "9223372036854775810UL" to "ret" here, but that stored value is overwritten before it can be used.
456 ret = EFI_INVALID_PARAMETER;
@Jose Calling efi_esrt_populate() in this case might not be the right thing to do.
457 goto out; 458 } 459 460 ret = EFI_SUCCESS; 461 for (i = 0, capsule = *capsule_header_array; i < capsule_count;
Best regards
Heinrich
