[PULL] u-boot-riscv/master
Hi Tom,
The following changes since commit 428bec7cf956c3558bbdfda4d2ba23beb73a68ba:
Merge branch '2021-05-17-assorted-fixes' (2021-05-18 14:17:54 -0400)
git@source.denx.de:u-boot/custodians/u-boot-riscv.git
for you to fetch changes up to a4691f363ef75783bee626bb8337c3a34d8c0e96:
riscv: ae350: Increase malloc size for binman spl flow (2021-05-19 17:01:52 +0800)
Gitlab CI result shows no issue: https://source.denx.de/u-boot/custodians/u-boot-riscv/-/pipelines/7583
---------------------------------------------------------------- Bin Meng (13): common: kconfig: Correct a typo in SPL_LOAD_FIT binman: Correct '-a' description in the doc binman: Correct the comment for ATF entry type binman: test: Rename 172_fit_fdt.dts to 170_fit_fdt.dts binman: Add support for RISC-V OpenSBI fw_dynamic blob makefile: Pass OpenSBI blob to binman make rules riscv: sifive: unleashed: Switch to use binman to generate u-boot.itb lib: kconfig: Limit BINMAN_FDT for OF_SEPARATE or OF_EMBED binman: Support packaging U-Boot for scenarios like OF_BOARD or OF_PRIOR_STAGE riscv: dts: Sort build targets in alphabetical order riscv: qemu: Switch to use binman to generate u-boot.itb riscv: ae350: Switch to use binman to generate u-boot.itb riscv: Drop USE_SPL_FIT_GENERATOR
Rick Chen (1): riscv: ae350: Increase malloc size for binman spl flow
Makefile | 4 +- arch/riscv/cpu/generic/Kconfig | 1 + arch/riscv/dts/Makefile | 3 +- arch/riscv/dts/ae350_32.dts | 2 + arch/riscv/dts/ae350_64.dts | 2 + arch/riscv/dts/binman.dtsi | 78 ++++++++++++++++ arch/riscv/dts/hifive-unleashed-a00-u-boot.dtsi | 1 + arch/riscv/dts/qemu-virt.dts | 8 ++ arch/riscv/lib/mkimage_fit_opensbi.sh | 100 --------------------- board/AndesTech/ax25-ae350/Kconfig | 1 + board/sifive/unleashed/Kconfig | 1 + common/Kconfig.boot | 5 +- configs/ae350_rv32_spl_defconfig | 2 + configs/ae350_rv32_spl_xip_defconfig | 2 + configs/ae350_rv64_spl_defconfig | 2 + configs/ae350_rv64_spl_xip_defconfig | 2 + configs/qemu-riscv32_spl_defconfig | 1 + configs/qemu-riscv64_spl_defconfig | 1 + dts/Kconfig | 18 ++++ lib/Kconfig | 2 +- tools/binman/binman.rst | 28 +++++- tools/binman/entries.rst | 13 +++ tools/binman/etype/atf_bl31.py | 2 +- tools/binman/etype/opensbi.py | 23 +++++ tools/binman/ftest.py | 17 ++-- .../test/{172_fit_fdt.dts => 170_fit_fdt.dts} | 0 tools/binman/test/201_opensbi.dts | 14 +++ 27 files changed, 219 insertions(+), 114 deletions(-) create mode 100644 arch/riscv/dts/binman.dtsi create mode 100644 arch/riscv/dts/qemu-virt.dts delete mode 100755 arch/riscv/lib/mkimage_fit_opensbi.sh create mode 100644 tools/binman/etype/opensbi.py rename tools/binman/test/{172_fit_fdt.dts => 170_fit_fdt.dts} (100%) create mode 100644 tools/binman/test/201_opensbi.dts
Best regards, Leo
On Thu, May 20, 2021 at 10:19:54AM +0800, Leo Liang wrote:
Hi Tom,
Leo Liang
