[PATCH] rockchip: puma: fix GPT table corruption when saving U-Boot environment
From: Quentin Schulz quentin.schulz@theobroma-systems.com
The GPT table is taking the first 34 sectors, which amounts to 0x4400 bytes. Saving the environment below this address in storage will corrupt the GPT table.
While technically the table ends at 0x4400, some tools (e.g. bmaptool) are rounding everything to the logical block size (0x1000), so it is safer to make it point to 0x5000 so that the environment could still persist when flashing a sparse image with bmaptool or similar tools.
Obviously, the default 0x4000 environment size does not work anymore, so let's set it to 0x3000 so it does fill the gap between the GPT table (rounded to 0x1000) and the start of the idbloader.img.
Fixes: 56f580d3eb8d ("rockchip: dts: rk3399-puma: put environment (in MMC/SD configurations) before SPL") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- To: Simon Glass sjg@chromium.org To: Philipp Tomsich philipp.tomsich@vrull.eu To: Kever Yang kever.yang@rock-chips.com To: Klaus Goger klaus.goger@theobroma-systems.com Cc: u-boot@lists.denx.de --- arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi | 2 +- configs/puma-rk3399_defconfig | 1 + 2 files changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi index f8335c74a7..d2349ae90e 100644 --- a/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi +++ b/arch/arm/dts/rk3399-puma-haikou-u-boot.dtsi @@ -15,7 +15,7 @@ / { config { u-boot,spl-payload-offset = <0x80000>; /* @ 512KB */ - u-boot,mmc-env-offset = <0x4000>; /* @ 16KB */ + u-boot,mmc-env-offset = <0x5000>; /* @ 20KB */ u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ u-boot,boot-led = "module_led"; sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>; diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 34186d1caa..91f31b37e8 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_ENV_SIZE=0x3000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" CONFIG_ROCKCHIP_RK3399=y
--- base-commit: 1e892ef0b59a4a04971ac23619b95917020b3e18 change-id: 20221025-upstream-puma-mmc-env-gpt-6f42cd038fdd
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
u-boot,efi-partition-entries-offset = <0x200000>; /* 2MB */ u-boot,boot-led = "module_led"; sysreset-gpio = <&gpio1 RK_PA6 GPIO_ACTIVE_HIGH>;u-boot,mmc-env-offset = <0x5000>; /* @ 20KB */
Kever Yang
Quentin Schulz
