[U-Boot] Pull request for ARM zynq
Hi Albert, CC: Joe and Tom
a month ago I have sent 4 Xilinx ARM zynq patches to mailing list (v2) (reminder yesterday) and I haven't got any reaction from anybody. The first patches were commented by Joe and problems fixed in the next version. There is one network driver which should require ACK from Joe and others from ARM maintainer. I would like to get these patches to mainline.
Albert and Tom: Can you please look at these patches and tell me what you thing? The best will be if you can pull them to your trees.
Here are links to patchwork http://patchwork.ozlabs.org/patch/177907/ http://patchwork.ozlabs.org/patch/177908/ http://patchwork.ozlabs.org/patch/177909/ http://patchwork.ozlabs.org/patch/177910/
Thanks, Michal
The following changes since commit a6f0c4faa4c65a7b7048b12c9d180d7e1aad1721: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-avr32
git://www.denx.de/git/u-boot-microblaze.git master-zynq
Michal Simek (4): serial: Add Zynq serial driver net: Add driver for Zynq Gem IP arm: Support new Xilinx Zynq platform xilinx: Add new Zynq board
arch/arm/cpu/armv7/zynq/Makefile | 52 ++++ arch/arm/cpu/armv7/zynq/lowlevel_init.S | 27 ++ arch/arm/cpu/armv7/zynq/timer.c | 151 ++++++++++ board/xilinx/zynq/Makefile | 54 ++++ board/xilinx/zynq/board.c | 64 +++++ boards.cfg | 1 + drivers/net/Makefile | 1 + drivers/net/zynq_gem.c | 453 +++++++++++++++++++++++++++++++ drivers/serial/Makefile | 1 + drivers/serial/serial_zynq.c | 200 ++++++++++++++ include/configs/zynq.h | 110 ++++++++ include/netdev.h | 2 +- 12 files changed, 1115 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/Makefile create mode 100644 arch/arm/cpu/armv7/zynq/lowlevel_init.S create mode 100644 arch/arm/cpu/armv7/zynq/timer.c create mode 100644 board/xilinx/zynq/Makefile create mode 100644 board/xilinx/zynq/board.c create mode 100644 drivers/net/zynq_gem.c create mode 100644 drivers/serial/serial_zynq.c create mode 100644 include/configs/zynq.h
Hi Albert,
please pull these three patches to your arm custodian tree. All of them are related to xilinx zynq. Also after my discussion with Wolfgang Denk I have enabled DCC for zynq because we are using it in one configuration and this driver is not compiled by any platform.
Thanks, Michal
The following changes since commit d62ef5619c9249772247d6af3b8e65207ae0c871: Jagannadha Sutradharudu Teki (1): sf: stmicro: Add support for N25Q256A
git://www.denx.de/git/u-boot-microblaze.git mainline/arm
Michal Simek (3): xilinx: zynq: Enable DCC and create new zynq_dcc board arm: zynq: Add SLCR support with system reset arm: zynq: Add lowlevel initialization to C
arch/arm/cpu/armv7/zynq/Makefile | 1 + arch/arm/cpu/armv7/zynq/cpu.c | 28 +++++++++- arch/arm/cpu/armv7/zynq/slcr.c | 63 ++++++++++++++++++++ arch/arm/include/asm/arch-zynq/hardware.h | 85 ++++++++++++++++++++++++++++ arch/arm/include/asm/arch-zynq/sys_proto.h | 30 ++++++++++ boards.cfg | 1 + include/configs/zynq.h | 5 ++ 7 files changed, 212 insertions(+), 1 deletions(-) create mode 100644 arch/arm/cpu/armv7/zynq/slcr.c create mode 100644 arch/arm/include/asm/arch-zynq/hardware.h create mode 100644 arch/arm/include/asm/arch-zynq/sys_proto.h
Hi Albert and Tom,
can you please look at my pull request?
Thanks, Michal
2012/9/13 Michal Simek monstr@monstr.eu:
Thanks, Michal
-- Michal Simek, Ing. (M.Eng) w: www.monstr.eu p: +42-0-721842854 Maintainer of Linux kernel 2.6 Microblaze Linux - http://www.monstr.eu/fdt/ Microblaze U-BOOT custodian
Michal Simek
