[U-Boot] [PATCH 1/1] net: phy: delay only if reset handler is registered
With commit e3a77218a256edbe201112a39beeed8adcabae3f the MII bus is only reset if a reset handler is registered. If there is no reset handler there is no need to wait for a device to come out of the reset.
Signed-off-by: Jörg Krause joerg.krause@embedded.rocks --- drivers/net/phy/phy.c | 8 +++++--- 1 file changed, 5 insertions(+), 3 deletions(-)
diff --git a/drivers/net/phy/phy.c b/drivers/net/phy/phy.c index 865abab..65c731a 100644 --- a/drivers/net/phy/phy.c +++ b/drivers/net/phy/phy.c @@ -763,11 +763,13 @@ struct phy_device *phy_find_by_mask(struct mii_dev *bus, unsigned phy_mask, phy_interface_t interface) { /* Reset the bus */ - if (bus->reset) + if (bus->reset) { bus->reset(bus);
- /* Wait 15ms to make sure the PHY has come out of hard reset */ - udelay(15000); + /* Wait 15ms to make sure the PHY has come out of hard reset */ + udelay(15000); + } + return get_phy_device_by_mask(bus, phy_mask, interface); }
Hi Jörg,
On Wed, Jul 15, 2015 at 8:18 AM, Jörg Krause joerg.krause@embedded.rocks wrote:
Applied to u-boot-net, thanks! -Joe
Joe Hershberger
Jörg Krause
