[PATCH v2] tools/mxsimage: Remove fclose on empty FILE pointer
If `sb_load_cmdfile()` fails to open the configuration file it will jump to error handling where the code will try to `fclose()` the FILE pointer which is NULL causing `mkimage` to segfault.
This patch removes the label for error handling and instead returns immediately which skips the `fclose()` and prevents the segfault. The errno is also described in the error message to guide users.
Signed-off-by: Mattias Hansson hansson.mattias@gmail.com --- tools/mxsimage.c | 13 +++++-------- 1 file changed, 5 insertions(+), 8 deletions(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 002f4b525a..fee022aab4 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -1595,8 +1595,11 @@ static int sb_load_cmdfile(struct sb_image_ctx *ictx) size_t len;
fp = fopen(ictx->cfg_filename, "r"); - if (!fp) - goto err_file; + if (!fp) { + fprintf(stderr, "ERR: Failed to load file "%s": "%s"\n", + ictx->cfg_filename, strerror(errno)); + return -EINVAL; + }
while ((rlen = getline(&line, &len, fp)) > 0) { memset(&cmd, 0, sizeof(cmd)); @@ -1616,12 +1619,6 @@ static int sb_load_cmdfile(struct sb_image_ctx *ictx) fclose(fp);
return 0; - -err_file: - fclose(fp); - fprintf(stderr, "ERR: Failed to load file "%s"\n", - ictx->cfg_filename); - return -EINVAL; }
static int sb_build_tree_from_cfg(struct sb_image_ctx *ictx)
Dear Mattias Hansson,
Reviewed-by: Wolfgang Denk wd@denx.de
If `sb_load_cmdfile()` fails to open the configuration file it will jump to error handling where the code will try to `fclose()` the FILE pointer which is NULL causing `mkimage` to segfault. This patch removes the label for error handling and instead returns immediately which skips the `fclose()` and prevents the segfault. The errno is also described in the error message to guide users. Signed-off-by: Mattias Hansson hansson.mattias@gmail.com Reviewed-by: Wolfgang Denk wd@denx.de
Best regards, Stefano Babic
Mattias Hansson
sbabic@denx.de
