Re: [U-Boot] [PATCH v2 02/11] S3C24XX: Add core support for Samsung's S3C24XX SoCs
Dear José Miguel Gonçalves,
Hi Marek,
It's getting better :)
Hopefully :-)
+typedef ulong(*getfreq) (void);
Is this used?
In the array declaration bellow...
Why, these are only values, no ?
+static const getfreq freq_f[] = {
const array const members, no?
Do you mean I should declare it like this:
static const getfreq const freq[] = { ...
Yes
I don't see the point because an array has no other storage besides it's elements. Moreover GCC generates the same object code in both ways.
Type checking, if you ever decided to write into the array, it'll prevent you from doing so.
- get_FCLK,
- get_HCLK,
- get_PCLK,
- get_UCLK,
+static const char freq_c[] = { 'F', 'H', 'P', 'U' };
Same here.
+int print_cpuinfo(void) +{
- int i;
- char buf[32];
- ulong cpuid;
- struct s3c24xx_gpio *const gpio = s3c24xx_get_base_gpio();
- cpuid = readl(&gpio->gstatus[1]);
- printf("CPU: %8s (id %08lX) @ %s MHz\n", s3c24xx_get_cpu_name(),
cpuid, strmhz(buf, get_ARMCLK()));
- for (i = 0; i < ARRAY_SIZE(freq_f); i++)
printf("%cCLK: %8s MHz\n", freq_c[i],
strmhz(buf, freq_f[i] ()));
+ulong get_HCLK(void) +{
- struct s3c2412_sysctl *const sysctl = s3c2412_get_base_sysctl();
- u32 clkdivn;
- u16 hclk_div, arm_div;
- clkdivn = readl(&sysctl->clkdivn);
- hclk_div = (clkdivn & 0x3) + 1;
- arm_div = ((clkdivn >> 3) & 0x1) + 1;
Magic.
Missed that... I will fix it.
There's more, globally please.
diff --git a/include/common.h b/include/common.h index 55025c0..36f0636 100644 --- a/include/common.h +++ b/include/common.h @@ -628,6 +628,7 @@ ulong get_OPB_freq (void);
ulong get_PCI_freq (void); #endif #if defined(CONFIG_S3C24X0) || \
defined(CONFIG_S3C24XX) || \
defined(CONFIG_LH7A40X) || \ defined(CONFIG_S3C6400) || \ defined(CONFIG_EP93XX)
What's this change? Split into different patch please.
This is related. I need this to export the functions get_FCLK(), get_HCLK(), get_PCLK() and get_UCLK() used in arch/arm/cpu/arm926ejs/s3c24xx/cpu_info.c
OK
Best regards, José Gonçalves
Hi Marek,
Hopefully :-)
Is this used?
They're function pointers. If they were values the compiler should complain, because "getfreq" is used as the type of the array.
Yes
Why? When can you ever change what an array (not a pointer) points to?
The first const takes care of that.
-Scott
Dear Scott Wood,
Hi Marek,
Hopefully :-)
Is this used?
Yes
Uh oh ... now I see the stuff with the functions. Crazy
Doesn't one prevent you from manupulating the elements and the other manipulating the array ?
-Scott
Best regards, Marek Vasut
On Fri, Sep 14, 2012 at 09:07:12PM +0200, Marek Vasut wrote:
Dear Scott Wood,
Hi Marek,
Hopefully :-)
Is this used?
Yes
No. These are all identical:
const int foo[]; int const foo[]; const int const foo[]; const const const int const const const foo[];
If it were a pointer, then there would be a difference between these:
const int *foo; (pointed-to data is const) int *const foo; (pointer itself is const) const int *const foo; (both are const)
...but still there's no distinction between these:
const int *foo; const int const *foo;
-Scott
Scott Wood
