[U-Boot] [PATCH 6/8] powerpc/p1021: add more P1021 defines.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/include/asm/immap_85xx.h | 6 ++++++ arch/powerpc/include/asm/immap_qe.h | 9 +++++++-- 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/arch/powerpc/include/asm/immap_85xx.h b/arch/powerpc/include/asm/immap_85xx.h index 30c64eb..9eb106c 100644 --- a/arch/powerpc/include/asm/immap_85xx.h +++ b/arch/powerpc/include/asm/immap_85xx.h @@ -1963,6 +1963,12 @@ typedef struct ccsr_gur { u8 res10b[76]; par_io_t qe_par_io[7]; u8 res10c[1600]; +#elif defined(CONFIG_P1021) + u8 res10b1[12]; + u32 iovselsr; + u8 res10b2[60]; + par_io_t qe_par_io[3]; + u8 res10c[1496]; #else u8 res10b[1868]; #endif diff --git a/arch/powerpc/include/asm/immap_qe.h b/arch/powerpc/include/asm/immap_qe.h index 531cfc8..74c9013 100644 --- a/arch/powerpc/include/asm/immap_qe.h +++ b/arch/powerpc/include/asm/immap_qe.h @@ -3,7 +3,7 @@ * The Internal Memory Map for devices with QE on them. This * is the superset of all QE devices (8360, etc.). * - * Copyright (c) 2006-2009 Freescale Semiconductor, Inc. + * Copyright (c) 2006-2010 Freescale Semiconductor, Inc. * Author: Shlomi Gridih gridish@freescale.com * * This program is free software; you can redistribute it and/or modify it @@ -588,6 +588,9 @@ typedef struct qe_immap { #elif defined(CONFIG_MPC8569) u8 muram[0x20000]; /* 0x1_0000 - 0x3_0000 Multi-user RAM */ u8 res17[0x10000]; /* 0x3_0000 - 0x4_0000 */ +#elif defined(CONFIG_P1021) + u8 muram[0x06000]; /* 0x1_0000 - 0x1_6000 Multi-user RAM */ + u8 res17[0x1a000]; /* 0x1_6000 - 0x3_0000 */ #else u8 muram[0xC000]; /* 0x110000 - 0x11C000 Multi-user RAM */ u8 res17[0x24000]; /* 0x11C000 - 0x140000 */ @@ -601,13 +604,15 @@ extern qe_map_t *qe_immr; #define QE_MURAM_SIZE 0x10000UL #elif defined(CONFIG_MPC8569) #define QE_MURAM_SIZE 0x20000UL +#elif defined(CONFIG_P1021) +#define QE_MURAM_SIZE 0x6000UL #elif defined(CONFIG_MPC8360) #define QE_MURAM_SIZE 0xc000UL #elif defined(CONFIG_MPC832x) #define QE_MURAM_SIZE 0x4000UL #endif
-#if defined(CONFIG_MPC8323) +#if defined(CONFIG_MPC8323) || defined(CONFIG_P1021) #define MAX_QE_RISC 1 #define QE_NUM_OF_SNUM 28 #elif defined(CONFIG_MPC8569)
