[U-Boot] [PATCH] rockchip: clk: rk3188: update dpll settings to make EMAC work
The patch set dpll settings for 300MHz to values used by binary blob[1]. With new values dpll still generate 300MHz clock, but EMAC work. Probably with new values dpll generate more stable clock.
dpll on rk3188 provide clocks to DDR and EMAC. With current dpll settings EMAC doesn't work on radxa rock. EMAC sends packets to network, but it doesn't receive anything. ifconfig shows a lot of framing errors.
[1] https://github.com/linux-rockchip/u-boot-rockchip/blob/u-boot-rk3288/ tools/rk_tools/3188_LPDDR2_300MHz_DDR3_300MHz_20130830.bin
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com --- drivers/clk/rockchip/clk_rk3188.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/rockchip/clk_rk3188.c b/drivers/clk/rockchip/clk_rk3188.c index 6451c95..f674e60 100644 --- a/drivers/clk/rockchip/clk_rk3188.c +++ b/drivers/clk/rockchip/clk_rk3188.c @@ -123,7 +123,7 @@ static int rkclk_configure_ddr(struct rk3188_cru *cru, struct rk3188_grf *grf, unsigned int hz, bool has_bwadj) { static const struct pll_div dpll_cfg[] = { - {.nf = 25, .nr = 2, .no = 1}, + {.nf = 75, .nr = 1, .no = 6}, {.nf = 400, .nr = 9, .no = 2}, {.nf = 500, .nr = 9, .no = 2}, {.nf = 100, .nr = 3, .no = 1},
Kever,
please review.
Thanks, Philipp.
{.nf = 400, .nr = 9, .no = 2}, {.nf = 500, .nr = 9, .no = 2}, {.nf = 100, .nr = 3, .no = 1},{.nf = 75, .nr = 1, .no = 6},
-- 1.7.9.5
Hi Philipp,
Sorry for reply so late. On 02/26/2018 07:28 PM, Dr. Philipp Tomsich wrote:
Kever,
please review.
Thanks, Philipp.
Rockchip always prefer to use nr=1 even if we can only get a frequency close to target frequency, because this setting can get smaller jitter. Some of IP like jitter may very sensitive to this setting.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
-- 1.7.9.5
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Alexander Kochetkov al.kochet@gmail.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Alexander Kochetkov
Dr. Philipp Tomsich
Kever Yang
Philipp Tomsich
