[U-Boot-Users] [GIT PULL] avr32 update
Hi Wolfgang,
Please pull the 'master' branch of
git://git.denx.de/u-boot-avr32.git master
to receive the below updates.
The SPI stuff and a few other patches I've posted are not included here since they aren't really avr32-related. I'm hoping you'll still apply them before the merge window closes.
David Brownell (2): avr32: stk1002 and ngw100 convergence avr32: Disable the AP7000 internal watchdog on startup
Haavard Skinnemoen (15): avr32: Use correct condition around macb clock accessors avr32: Get rid of the .flashprog section avr32: Add support for the ATSTK1006 board avr32: Clean up the HMATRIX code avr32: Remove unused file cpu/at32ap/pm.c avr32: Use new-style Makefile for the at32ap platform avr32: Rename pm_init() as clk_init() and make SoC-specific avr32: Put memset in its own section avr32: Use the same entry point for reset and exception handling avr32: Do stricter stack checking in the exception handler avr32: Rework SDRAM initialization code avr32: Fix two warnings in atmel_mci.c avr32: Fix wrong error flags in atmel_mci driver avr32: Compile atmel_mci.o conditionally avr32: Fix theoretical race in udelay()
MAINTAINERS | 1 + MAKEALL | 1 + Makefile | 3 + board/atmel/atngw100/atngw100.c | 27 ++- board/atmel/atngw100/u-boot.lds | 9 +- board/atmel/atstk1000/atstk1000.c | 54 +++++- board/atmel/atstk1000/flash.c | 6 +- board/atmel/atstk1000/u-boot.lds | 9 +- cpu/at32ap/Makefile | 20 ++- cpu/at32ap/at32ap700x/Makefile | 2 +- cpu/at32ap/at32ap700x/clk.c | 68 +++++++ cpu/at32ap/{ => at32ap700x}/sm.h | 0 cpu/at32ap/atmel_mci.c | 12 +- cpu/at32ap/cpu.c | 50 +----- cpu/at32ap/entry.S | 64 ------- cpu/at32ap/exception.c | 3 +- cpu/at32ap/hsdramc.c | 102 ++++------- cpu/at32ap/interrupts.c | 16 +- cpu/at32ap/pm.c | 42 ----- cpu/at32ap/start.S | 129 ++++++++++++- include/asm-avr32/arch-at32ap700x/clk.h | 4 +- include/asm-avr32/arch-at32ap700x/hmatrix.h | 61 ++++++ include/asm-avr32/arch-at32ap700x/hmatrix2.h | 232 ------------------------ include/asm-avr32/arch-at32ap700x/memory-map.h | 20 ++ include/asm-avr32/hmatrix-common.h | 131 +++++++++++++ include/asm-avr32/sdram.h | 27 +++- include/asm-avr32/sections.h | 7 - include/configs/atngw100.h | 26 +-- include/configs/atstk1002.h | 19 +- include/configs/atstk1003.h | 15 +- include/configs/atstk1004.h | 16 +- include/configs/atstk1006.h | 203 +++++++++++++++++++++ lib_avr32/memset.S | 2 +- 33 files changed, 817 insertions(+), 564 deletions(-) create mode 100644 cpu/at32ap/at32ap700x/clk.c rename cpu/at32ap/{ => at32ap700x}/sm.h (100%) delete mode 100644 cpu/at32ap/entry.S delete mode 100644 cpu/at32ap/pm.c create mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix.h delete mode 100644 include/asm-avr32/arch-at32ap700x/hmatrix2.h create mode 100644 include/asm-avr32/hmatrix-common.h create mode 100644 include/configs/atstk1006.h
In message 20080529194141.50ff3adf@hskinnemo-gx745.norway.atmel.com you wrote:
Done. Thanks.
Haavard Skinnemoen
