[U-Boot] [PATCH] USB: ohci-at91: make OHCI work on at91sam9g10 SoC
The at91sam9g10 need to configure HCK0 to make OHCI work
Signed-off-by: Bo Shen voice.shen@atmel.com --- drivers/usb/host/ohci-at91.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index efd711d..aa5cf57 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -55,7 +55,7 @@ int usb_cpu_init(void)
/* Enable USB host clock. */ writel(1 << ATMEL_ID_UHP, &pmc->pcer); -#ifdef CONFIG_AT91SAM9261 +#if defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9G10) writel(ATMEL_PMC_UHP | AT91_PMC_HCK0, &pmc->scer); #else writel(ATMEL_PMC_UHP, &pmc->scer); @@ -70,7 +70,7 @@ int usb_cpu_stop(void)
/* Disable USB host clock. */ writel(1 << ATMEL_ID_UHP, &pmc->pcdr); -#ifdef CONFIG_AT91SAM9261 +#if defined(CONFIG_AT91SAM9261) || defined(CONFIG_AT91SAM9G10) writel(ATMEL_PMC_UHP | AT91_PMC_HCK0, &pmc->scdr); #else writel(ATMEL_PMC_UHP, &pmc->scdr);
Bo Shen
