[U-Boot] [PATCH V2] Update TEXT_BASE to CONFIG_SYS_TEXT_BASE
This was missed out in a couple of files under nand_spl
Signed-off-by: Sughosh Ganu urwithsughosh@gmail.com --- V2: Fix whitespace issues.
nand_spl/nand_boot.c | 3 ++- nand_spl/nand_boot_fsl_nfc.c | 3 ++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/nand_spl/nand_boot.c b/nand_spl/nand_boot.c index 4d6db14..ccd0af2 100644 --- a/nand_spl/nand_boot.c +++ b/nand_spl/nand_boot.c @@ -224,7 +224,8 @@ static int nand_load(struct mtd_info *mtd, unsigned int offs, #if defined(CONFIG_ARM) && !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) void board_init_f (ulong bootflag) { - relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, TEXT_BASE); + relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, + CONFIG_SYS_TEXT_BASE); } #endif
diff --git a/nand_spl/nand_boot_fsl_nfc.c b/nand_spl/nand_boot_fsl_nfc.c index 959f162..21ed3fc 100644 --- a/nand_spl/nand_boot_fsl_nfc.c +++ b/nand_spl/nand_boot_fsl_nfc.c @@ -266,7 +266,8 @@ static int nand_load(unsigned int from, unsigned int size, unsigned char *buf) #if defined(CONFIG_ARM) && !defined(CONFIG_SYS_ARM_WITHOUT_RELOC) void board_init_f (ulong bootflag) { - relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, TEXT_BASE); + relocate_code (CONFIG_SYS_TEXT_BASE - TOTAL_MALLOC_LEN, NULL, + CONFIG_SYS_TEXT_BASE); } #endif
Dear Sughosh Ganu,
In message 1287538444-2162-1-git-send-email-urwithsughosh@gmail.com you wrote:
Applying: Update TEXT_BASE to CONFIG_SYS_TEXT_BASE Using index info to reconstruct a base tree... Falling back to patching base and 3-way merge... No changes -- Patch already applied.
Sughosh Ganu
