[U-Boot-Users] SDRAM initialization sequence!
Hi,I have a little problem with the uboot startup,the BDI2000 can program u-boot.bin into FLASH .My board is like the board MPC8260ADS.CPU is ppc8250. Board information can print through serial interface after the first initialization of board now. But when it run to the function relocate_code(in the /cpu/mpc8260/start.s),it don't run continually. Through LED on the board ,I find that it stops at the code below:
in_ram:
My SDRAM is samsang k4s643232f-tc60, total 16MBytes,two chips.Each is organzied as 4*512K*32bits. The link address is the SDRAM data sheet! http://www.samsung.com/Products/Semiconductor/DRAM/SDRAM/SDRAMcomponent/64Mb...
Please check whether my SDRAM initialization sequence is correct!
Thanks in advance!
/* init sdram dimm */ printf("Now init 60x sdram dimm ...\n"); ramaddr = (uchar *)CFG_SDRAM_BASE; memctl->memc_mptpr = 0x1900; memctl->memc_psrt = 0x10; immap->im_memctl.memc_or2 = 0xFF003080; immap->im_memctl.memc_br2 = 0x00000041; memctl->memc_psdmr = 0x2869a452; *ramaddr = c;
memctl->memc_psdmr = 0x0869a452;
for (i = 0; i < 8; i++) *ramaddr = c;
memctl->memc_psdmr = 0x1869a452;
*ramaddr = c;
memctl->memc_psdmr = 0x4069a452; *ramaddr = c;
__________________________________________________ 赶快注册雅虎超大容量免费邮箱? http://cn.mail.yahoo.com
Your SDRAM initialization is broken.
No need to check. It is not correct. You already know that: the code is crashing when relocating to / running from RAM. No further proof is needed.
junping feng
