[U-Boot-Users] Resend:MPC8272 PCI bridge problem?
hi,all Sorry to resend this message here. But I really have a problem using MPC8272 PCI bridge. Currently I am debugging our own board with a MPC8272 and PCI IDE chip (VIA VT6410). However I can not visit the memory of PCI space. In u-boot, When I type "md F40001F0", there is always a program check. My configuration is as follows:
* 0x00000000-0x07FFFFFF 128MB SDRAM * 0x80000000-0x9FFFFFFF 512MB outbound prefetchable PCI memory window * 0xA0000000-0xBFFFFFFF 512MB outbound non-prefetchable PCI memory window * 0xF0000000-0xF001FFFF 128KB MPC8272 internal memory * 0xF4000000-0xF7FFFFFF 64MB outbound PCI I/O window * 0xFE000000-0xFFFFFFFF 32MB flash /* PCIBR0 */ #define CFG_PCI_MSTR0_LOCAL 0x80000000 /* Local base */ #define CFG_PCIMSK0_MASK PCIMSK_1GB /* Size of window */ /* PCIBR1 */ #define CFG_PCI_MSTR1_LOCAL 0xF4000000 /* Local base */ #define CFG_PCIMSK1_MASK PCIMSK_64MB /* Size of window */ #define CFG_PCI_MSTR_IO_LOCAL 0xF4000000 /* Local base */ #define CFG_PCI_MSTR_IO_BUS 0xF4000000 /* PCI base */ #define CFG_CPU_PCI_IO_START PCI_MSTR_IO_LOCAL #define CFG_PCI_MSTR_IO_SIZE 0x04000000 /* 64MB */ #define CFG_POCMR2_MASK_ATTRIB (POCMR_MASK_64MB | POCMR_ENABLE | POCMR_PCI_IO)
So, I am wondering why the configured PCI space can not be accessed since I have configured the outbound window and PCIBR? In MPC8241, I can access PCI space by "md FE0001F0". Any kind help will be greatly appreciated.
Best regard Jack liu
Please don't resend messages just because you don't get help as fast as you would like. This is a maling list, and we help in our free time. If you need help really fast you can buy commercial support from several vendors.
Jack Liu
