[PATCH] scmi: correctly configure MMU for SCMI buffer
Align the MMU area for SCMI shared buffer on section size; use the ALIGN macro in mmu_set_region_dcache_behaviour call.
Since commit d877f8fd0f09 ("arm: provide a function for boards init code to modify MMU virtual-physical map") the parameter of mmu_set_region_dcache_behaviour need to be MMU_SECTION_SIZE aligned.
Fixes: 240720e9052f ("firmware: scmi: mailbox/smt agent device") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
drivers/firmware/scmi/smt.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/firmware/scmi/smt.c b/drivers/firmware/scmi/smt.c index d25478796a..3c41013bca 100644 --- a/drivers/firmware/scmi/smt.c +++ b/drivers/firmware/scmi/smt.c @@ -54,8 +54,10 @@ int scmi_dt_get_smt_buffer(struct udevice *dev, struct scmi_smt *smt)
#ifdef CONFIG_ARM if (dcache_status()) - mmu_set_region_dcache_behaviour((uintptr_t)smt->buf, - smt->size, DCACHE_OFF); + mmu_set_region_dcache_behaviour(ALIGN_DOWN((uintptr_t)smt->buf, MMU_SECTION_SIZE), + ALIGN(smt->size, MMU_SECTION_SIZE), + DCACHE_OFF); + #endif
Hello Patrick,
On Tue, 16 Mar 2021 at 09:29, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
DCACHE_OFF);
#endif
-- 2.17.1
Reviewed-by: Etienne Carriere etienne.carriere@linaro.org
This indeed fixes the scmi smt driver. Thanks Patrick.
Regards, Etienne
Fixes: 240720e9052f ("firmware: scmi: mailbox/smt agent device") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com Reviewed-by: Etienne Carriere etienne.carriere@linaro.org
Etienne Carriere
Patrick Delaunay
