[U-Boot] [PULL] u-boot-sh/master
The following changes since commit c3c863880479edeb5b08226e622d13c91326e4a7:
add FIT data-position & data-offset property support (2018-05-26 18:19:19 -0400)
git://git.denx.de/u-boot-sh.git master
for you to fetch changes up to 0bb5d24852d8051b70b2becc74f3a2c4fb925dbb:
ARM: dts: rmobile: Sync R8A77990 Ebisu DTS with Linux (2018-06-01 09:47:22 +0200)
---------------------------------------------------------------- Marek Vasut (20): ARM: rmobile: Enable MTD partitioning on Gen2 with SF ARM: rmobile: Represent SF partitioning with mtdparts on Alt ARM: rmobile: Represent SF partitioning with mtdparts on Gose ARM: rmobile: Represent SF partitioning with mtdparts on Koelsch ARM: rmobile: Represent SF partitioning with mtdparts on Lager ARM: rmobile: Represent SF partitioning with mtdparts on Porter ARM: rmobile: Represent SF partitioning with mtdparts on Silk ARM: rmobile: Represent SF partitioning with mtdparts on Stout clk: renesas: Fix swapped arguments in debug message clk: renesas: Pass clock rate around as 64bit number internally clk: renesas: Add PLL1 and PLL3 dividers clk: renesas: Add PE clock handling clk: renesas: Add R8A77990 E3 clock tables pinctrl: renesas: Initial R8A77990 PFC support gpio: rmobile: Add R8A77990 E3 compatible mmc: renesas-sdhi: Add R8A77990 E3 compatible net: ravb: Add R8A77990 E3 compatible ARM: renesas: Add R8A77990 E3 SoC ID ARM: renesas: Add R8A77990 E3 Ebisu board ARM: dts: rmobile: Sync R8A77990 Ebisu DTS with Linux
Takeshi Kihara (2): pinctrl: renesas: Add PORT_GP_11 helper macro ARM: dts: rmobile: Add Renesas Ebisu board support
Yoshihiro Shimoda (1): ARM: dts: rmobile: Add Renesas R8A77990 SoC support
arch/arm/dts/Makefile | 1 + arch/arm/dts/r8a77990-ebisu-u-boot.dts | 10 + arch/arm/dts/r8a77990-ebisu.dts | 65 ++++++ arch/arm/dts/r8a77990-u-boot.dtsi | 9 + arch/arm/dts/r8a77990.dtsi | 281 +++++++++++++++++++++++ arch/arm/mach-rmobile/Kconfig.64 | 9 + arch/arm/mach-rmobile/cpu_info.c | 1 + arch/arm/mach-rmobile/include/mach/rmobile.h | 1 + board/renesas/ebisu/Kconfig | 15 ++ board/renesas/ebisu/MAINTAINERS | 6 + board/renesas/ebisu/Makefile | 9 + board/renesas/ebisu/ebisu.c | 87 +++++++ configs/alt_defconfig | 5 + configs/gose_defconfig | 5 + configs/koelsch_defconfig | 5 + configs/lager_defconfig | 5 + configs/porter_defconfig | 5 + configs/r8a77990_ebisu_defconfig | 64 ++++++ configs/silk_defconfig | 5 + configs/stout_defconfig | 5 + drivers/clk/renesas/Kconfig | 7 + drivers/clk/renesas/Makefile | 1 + drivers/clk/renesas/clk-rcar-gen3.c | 102 ++++++--- drivers/clk/renesas/r8a77990-cpg-mssr.c | 303 +++++++++++++++++++++++++ drivers/clk/renesas/rcar-gen3-cpg.h | 6 +- drivers/gpio/gpio-rcar.c | 1 + drivers/mmc/renesas-sdhi.c | 1 + drivers/net/ravb.c | 1 + drivers/pinctrl/renesas/Kconfig | 11 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pfc-r8a77990.c | 1732 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/pinctrl/renesas/pfc.c | 11 + drivers/pinctrl/renesas/sh_pfc.h | 9 +- include/configs/ebisu.h | 34 +++ include/configs/rcar-gen2-common.h | 8 + include/dt-bindings/clock/r8a77990-cpg-mssr.h | 63 ++++++ 36 files changed, 2850 insertions(+), 34 deletions(-) create mode 100644 arch/arm/dts/r8a77990-ebisu-u-boot.dts create mode 100644 arch/arm/dts/r8a77990-ebisu.dts create mode 100644 arch/arm/dts/r8a77990-u-boot.dtsi create mode 100644 arch/arm/dts/r8a77990.dtsi create mode 100644 board/renesas/ebisu/Kconfig create mode 100644 board/renesas/ebisu/MAINTAINERS create mode 100644 board/renesas/ebisu/Makefile create mode 100644 board/renesas/ebisu/ebisu.c create mode 100644 configs/r8a77990_ebisu_defconfig create mode 100644 drivers/clk/renesas/r8a77990-cpg-mssr.c create mode 100644 drivers/pinctrl/renesas/pfc-r8a77990.c create mode 100644 include/configs/ebisu.h create mode 100644 include/dt-bindings/clock/r8a77990-cpg-mssr.h
