[PATCH RFC 0/2] clk: add HiSilicon CLK framework
The first supported chip is Hi3798MV200.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- Yang Xiwen (2): clk: ccf: Export clk_register_mux_table() in linux/clk-provider.h clk: add clock framework for HiSilicon SoCs
drivers/clk/Kconfig | 7 ++ drivers/clk/Makefile | 1 + drivers/clk/hisilicon/Kconfig | 14 +++ drivers/clk/hisilicon/Makefile | 8 ++ drivers/clk/hisilicon/clk-hi3798mv200.c | 213 ++++++++++++++++++++++++++++++++ drivers/clk/hisilicon/clk.c | 102 +++++++++++++++ drivers/clk/hisilicon/clk.h | 55 +++++++++ include/dt-bindings/clock/histb-clock.h | 4 + include/linux/clk-provider.h | 6 + 9 files changed, 410 insertions(+) --- base-commit: f7cca7ccc5117eaafcc2bde91ad1bed6fee7cfc3 change-id: 20240119-b4-hisi-clk-88075b46c359
This function is used by HiSilicon Clock Framework.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- include/linux/clk-provider.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index b8acacd49e..952439ad39 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -247,6 +247,12 @@ struct clk *clk_register_mux(struct device *dev, const char *name, void __iomem *reg, u8 shift, u8 width, u8 clk_mux_flags);
+struct clk *clk_register_mux_table(struct device *dev, const char *name, + const char * const *parent_names, u8 num_parents, + unsigned long flags, + void __iomem *reg, u8 shift, u32 mask, + u8 clk_mux_flags, u32 *table); + struct clk *clk_register_fixed_rate(struct device *dev, const char *name, ulong rate);
Hi3798 Series SoCs have a CRG (Clock Reset Generator) module which manages all clocks and resets of the SoC.
The first supported chip is Hi3798MV200. The unused clocks are not registered to save space and time. Only necessary clocks are implemented right now.
Signed-off-by: Yang Xiwen forbidden405@outlook.com --- drivers/clk/Kconfig | 7 ++ drivers/clk/Makefile | 1 + drivers/clk/hisilicon/Kconfig | 14 +++ drivers/clk/hisilicon/Makefile | 8 ++ drivers/clk/hisilicon/clk-hi3798mv200.c | 213 ++++++++++++++++++++++++++++++++ drivers/clk/hisilicon/clk.c | 102 +++++++++++++++ drivers/clk/hisilicon/clk.h | 55 +++++++++ include/dt-bindings/clock/histb-clock.h | 4 + 8 files changed, 404 insertions(+)
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 017dd260a5..4c5ac46b26 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -127,6 +127,12 @@ config CLK_ICS8N3QV01 Crystal Oscillator). The output frequency can be programmed via an I2C interface.
+config CLK_HISI + bool "Enable Hisilicon Clock Framework" + depends on CLK && CLK_CCF + help + Support for Hisilicon Clock Framework. + config CLK_INTEL bool "Enable clock driver for Intel x86" depends on CLK && X86 @@ -249,6 +255,7 @@ config CLK_ZYNQMP source "drivers/clk/analogbits/Kconfig" source "drivers/clk/at91/Kconfig" source "drivers/clk/exynos/Kconfig" +source "drivers/clk/hisilicon/Kconfig" source "drivers/clk/imx/Kconfig" source "drivers/clk/meson/Kconfig" source "drivers/clk/microchip/Kconfig" diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 638ad04bae..90e7e1b5f4 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -32,6 +32,7 @@ obj-$(CONFIG_CLK_BCM6345) += clk_bcm6345.o obj-$(CONFIG_CLK_BOSTON) += clk_boston.o obj-$(CONFIG_CLK_CDCE9XX) += clk-cdce9xx.o obj-$(CONFIG_CLK_EXYNOS) += exynos/ +obj-$(CONFIG_CLK_HISI) += hisilicon/ obj-$(CONFIG_CLK_HSDK) += clk-hsdk-cgu.o obj-$(CONFIG_CLK_K210) += clk_k210.o obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o diff --git a/drivers/clk/hisilicon/Kconfig b/drivers/clk/hisilicon/Kconfig new file mode 100644 index 0000000000..caa51b7831 --- /dev/null +++ b/drivers/clk/hisilicon/Kconfig @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0-only + +if CLK_HISI +menu "HiSilicon CRG Driver" + +config COMMON_CLK_HI3798MV200 + tristate "Hi3798MV200 CRG Driver" + select RESET_HISILICON + depends on ARCH_HISTB + help + Build the CRG driver for Hi3798MV200. + +endmenu +endif diff --git a/drivers/clk/hisilicon/Makefile b/drivers/clk/hisilicon/Makefile new file mode 100644 index 0000000000..85a0ffb4a1 --- /dev/null +++ b/drivers/clk/hisilicon/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0 +# +# Hisilicon Clock specific Makefile +# + +obj-y += clk.o + +obj-$(CONFIG_COMMON_CLK_HI3798MV200) += clk-hi3798mv200.o diff --git a/drivers/clk/hisilicon/clk-hi3798mv200.c b/drivers/clk/hisilicon/clk-hi3798mv200.c new file mode 100644 index 0000000000..01bb20d940 --- /dev/null +++ b/drivers/clk/hisilicon/clk-hi3798mv200.c @@ -0,0 +1,213 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Hi3798MV200 Clock and Reset Generator Driver. + * Adapted from clk-hi3798cv200.c. + * + * Copyright (c) 2024 Yang Xiwen forbidden405@outlook.com + * Copyright (c) 2016 HiSilicon Technologies Co., Ltd. + */ + +#include <dt-bindings/clock/histb-clock.h> +#include <linux/clk-provider.h> +#include <dm/device.h> +#include <dm/lists.h> +#include <dm/read.h> + +#include "clk.h" + +/* hi3798MV200 core CRG */ +#define HI3798MV200_INNER_CLK_OFFSET 64 +#define HI3798MV200_FIXED_12M 65 +#define HI3798MV200_FIXED_24M 66 +#define HI3798MV200_FIXED_25M 67 +#define HI3798MV200_FIXED_27M 68 +#define HI3798MV200_FIXED_48M 69 +#define HI3798MV200_FIXED_50M 70 +#define HI3798MV200_FIXED_54M 71 +#define HI3798MV200_FIXED_60M 72 +#define HI3798MV200_FIXED_75M 73 +#define HI3798MV200_FIXED_100M 74 +#define HI3798MV200_FIXED_150M 75 +#define HI3798MV200_FIXED_166P5M 76 +#define HI3798MV200_FIXED_200M 77 +#define HI3798MV200_FIXED_250M 78 +#define HI3798MV200_FIXED_300M 79 +#define HI3798MV200_FIXED_400M 80 +#define HI3798MV200_MMC_MUX 81 +#define HI3798MV200_COMBPHY1_MUX 82 +#define HI3798MV200_SDIO0_MUX 83 +#define HI3798MV200_COMBPHY0_MUX 84 +#define HI3798MV200_SDIO1_MUX 85 +#define HI3798MV200_ETH_MUX 86 + +static const struct hisi_fixed_rate_clock hi3798mv200_fixed_rate_clks[] = { + { HISTB_OSC_CLK, "clk_osc", 24000000, }, + { HISTB_APB_CLK, "clk_apb", 100000000, }, + { HISTB_AHB_CLK, "clk_ahb", 200000000, }, + { HI3798MV200_FIXED_12M, "12m", 12000000, }, + { HI3798MV200_FIXED_24M, "24m", 24000000, }, + { HI3798MV200_FIXED_25M, "25m", 25000000, }, + { HI3798MV200_FIXED_27M, "27m", 27000000, }, + { HI3798MV200_FIXED_48M, "48m", 48000000, }, + { HI3798MV200_FIXED_50M, "50m", 50000000, }, + { HI3798MV200_FIXED_54M, "54m", 54000000, }, + { HI3798MV200_FIXED_60M, "60m", 60000000, }, + { HI3798MV200_FIXED_75M, "75m", 75000000, }, + { HI3798MV200_FIXED_100M, "100m", 100000000, }, + { HI3798MV200_FIXED_150M, "150m", 150000000, }, + { HI3798MV200_FIXED_166P5M, "166p5m", 165000000, }, + { HI3798MV200_FIXED_200M, "200m", 200000000, }, + { HI3798MV200_FIXED_250M, "250m", 250000000, }, +}; + +static const char *const mmc_mux_p[] = { + "100m", "50m", "25m", "200m", "150m" }; +static u32 mmc_mux_table[] = {0, 1, 2, 3, 6}; + +static const char *const comphy_mux_p[] = { + "25m", "100m"}; +static u32 comphy_mux_table[] = {0, 1}; + +static const char *const sdio_mux_p[] = { + "100m", "50m", "150m", "166p5m" }; +static u32 sdio_mux_table[] = {0, 1, 2, 3}; + +static const char *const eth_mux_p[] = { + "54m", "27m" }; +static u32 eth_mux_table[] = {0, 1}; + +static struct hisi_mux_clock hi3798mv200_mux_clks[] = { + { HI3798MV200_MMC_MUX, "mmc_mux", mmc_mux_p, ARRAY_SIZE(mmc_mux_p), + CLK_SET_RATE_PARENT, 0xa0, 8, 3, 0, mmc_mux_table, }, + { HI3798MV200_COMBPHY0_MUX, "combphy0_mux", + comphy_mux_p, ARRAY_SIZE(comphy_mux_p), + CLK_SET_RATE_PARENT, 0x188, 3, 1, 0, comphy_mux_table, }, + { HI3798MV200_SDIO0_MUX, "sdio0_mux", sdio_mux_p, + ARRAY_SIZE(sdio_mux_p), CLK_SET_RATE_PARENT, + 0x9c, 8, 2, 0, sdio_mux_table, }, + { HI3798MV200_SDIO1_MUX, "sdio1_mux", sdio_mux_p, + ARRAY_SIZE(sdio_mux_p), CLK_SET_RATE_PARENT, + 0x28c, 8, 2, 0, sdio_mux_table, }, + { HI3798MV200_ETH_MUX, "eth_mux", eth_mux_p, + ARRAY_SIZE(eth_mux_p), CLK_SET_RATE_PARENT, + 0xd0, 2, 1, 0, eth_mux_table, }, +}; + +static const struct hisi_gate_clock hi3798mv200_gate_clks[] = { + /* SDIO0 */ + { HISTB_SDIO0_BIU_CLK, "clk_sdio0_biu", "200m", + CLK_SET_RATE_PARENT, 0x9c, 0, 0, }, + { HISTB_SDIO0_CIU_CLK, "clk_sdio0_ciu", "sdio0_mux", + CLK_SET_RATE_PARENT, 0x9c, 1, 0, }, + /* EMMC */ + { HISTB_MMC_BIU_CLK, "clk_mmc_biu", "200m", + CLK_SET_RATE_PARENT, 0xa0, 0, 0, }, + { HISTB_MMC_CIU_CLK, "clk_mmc_ciu", "mmc_mux", + CLK_SET_RATE_PARENT, 0xa0, 1, 0, }, + /* Ethernet */ + { HI3798MV200_GMAC_CLK, "clk_gmac", "75m", + CLK_SET_RATE_PARENT, 0xcc, 2, 0, }, + { HI3798MV200_GMACIF_CLK, "clk_gmacif", NULL, + CLK_SET_RATE_PARENT, 0xcc, 0, 0, }, + { HI3798MV200_FEMAC_CLK, "clk_femac", "eth_mux", + CLK_SET_RATE_PARENT, 0xd0, 1, 0, }, + { HI3798MV200_FEMACIF_CLK, "clk_femacif", NULL, + CLK_SET_RATE_PARENT, 0xd0, 0, 0, }, + { HI3798MV200_FEPHY_CLK, "clk_fephy", NULL, + 0, 0x388, 0, 0, }, + /* COMBPHY */ + { HISTB_COMBPHY0_CLK, "clk_combphy0", "combphy0_mux", + CLK_SET_RATE_PARENT, 0x188, 0, 0, }, + /* USB2 */ + { HISTB_USB2_BUS_CLK, "clk_u2_bus", "clk_ahb", + CLK_SET_RATE_PARENT, 0xb8, 0, 0, }, + { HISTB_USB2_PHY_CLK, "clk_u2_phy", "60m", + CLK_SET_RATE_PARENT, 0xb8, 4, 0, }, + { HISTB_USB2_12M_CLK, "clk_u2_12m", "12m", + CLK_SET_RATE_PARENT, 0xb8, 2, 0 }, + { HISTB_USB2_48M_CLK, "clk_u2_48m", "48m", + CLK_SET_RATE_PARENT, 0xb8, 1, 0 }, + { HISTB_USB2_UTMI_CLK, "clk_u2_utmi", "60m", + CLK_SET_RATE_PARENT, 0xb8, 5, 0 }, + { HISTB_USB2_OTG_UTMI_CLK, "clk_u2_otg_utmi", "60m", + CLK_SET_RATE_PARENT, 0xb8, 3, 0 }, + { HISTB_USB2_PHY1_REF_CLK, "clk_u2_phy1_ref", "24m", + CLK_SET_RATE_PARENT, 0xbc, 0, 0 }, + { HISTB_USB2_PHY2_REF_CLK, "clk_u2_phy2_ref", "24m", + CLK_SET_RATE_PARENT, 0xbc, 2, 0 }, + /* USB3 */ + { HISTB_USB3_BUS_CLK, "clk_u3_bus", NULL, + CLK_SET_RATE_PARENT, 0xb0, 0, 0 }, + { HISTB_USB3_UTMI_CLK, "clk_u3_utmi", NULL, + CLK_SET_RATE_PARENT, 0xb0, 4, 0 }, + { HISTB_USB3_PIPE_CLK, "clk_u3_pipe", NULL, + CLK_SET_RATE_PARENT, 0xb0, 3, 0 }, + { HISTB_USB3_SUSPEND_CLK, "clk_u3_suspend", NULL, + CLK_SET_RATE_PARENT, 0xb0, 2, 0 }, + { HISTB_USB3_BUS_CLK1, "clk_u3_bus1", NULL, + CLK_SET_RATE_PARENT, 0xb0, 16, 0 }, + { HISTB_USB3_UTMI_CLK1, "clk_u3_utmi1", NULL, + CLK_SET_RATE_PARENT, 0xb0, 20, 0 }, + { HISTB_USB3_PIPE_CLK1, "clk_u3_pipe1", NULL, + CLK_SET_RATE_PARENT, 0xb0, 19, 0 }, + { HISTB_USB3_SUSPEND_CLK1, "clk_u3_suspend1", NULL, + CLK_SET_RATE_PARENT, 0xb0, 18, 0 }, + /* Watchdog */ + { HISTB_WDG0_CLK, "clk_wdg0", "24m", + CLK_SET_RATE_PARENT, 0x178, 0, 0 }, + /* SDIO1 */ + { HISTB_SDIO1_BIU_CLK, "clk_sdio1_biu", "200m", + CLK_SET_RATE_PARENT, 0x28c, 0, 0, }, + { HISTB_SDIO1_CIU_CLK, "clk_sdio1_ciu", "sdio1_mux", + CLK_SET_RATE_PARENT, 0x28c, 1, 0, }, +}; + +static int hi3798mv200_clk_init(struct udevice *pdev) +{ + struct hisi_clock_data *data = dev_get_priv(pdev); + + return hisi_clk_init(pdev, data); +} + +static int hi3798mv200_clk_register(struct udevice *pdev) +{ + struct hisi_clock_data *clk_data = dev_get_priv(pdev); + int ret; + + ret = hisi_clk_register_fixed_rate(NULL, hi3798mv200_fixed_rate_clks, + ARRAY_SIZE(hi3798mv200_fixed_rate_clks)); + if (ret) + return ret; + + ret = hisi_clk_register_mux(NULL, hi3798mv200_mux_clks, + ARRAY_SIZE(hi3798mv200_mux_clks), clk_data); + if (ret) + return ret; + + return hisi_clk_register_gate(NULL, hi3798mv200_gate_clks, + ARRAY_SIZE(hi3798mv200_gate_clks), clk_data); +} + +static int hi3798mv200_clk_bind(struct udevice *pdev) +{ + ofnode node = dev_ofnode(pdev); + + /* bind hisilicon_reset driver to our device tree node */ + return device_bind_driver_to_node(pdev, "hisilicon_reset", "hisilicon_reset", node, NULL); +}; + +static const struct udevice_id hi3798mv200_crg_compat[] = { + { .compatible = "hisilicon,hi3798mv200-crg", }, + { } +}; + +U_BOOT_DRIVER(hi3798mv200_crg) = { + .name = "hi3798mv200_crg", + .id = UCLASS_CLK, + .bind = hi3798mv200_clk_bind, + .of_to_plat = hi3798mv200_clk_init, + .priv_auto = sizeof(struct hisi_clock_data), + .probe = hi3798mv200_clk_register, + .of_match = hi3798mv200_crg_compat, + .ops = &ccf_clk_ops, +}; diff --git a/drivers/clk/hisilicon/clk.c b/drivers/clk/hisilicon/clk.c new file mode 100644 index 0000000000..6bd7f9ef60 --- /dev/null +++ b/drivers/clk/hisilicon/clk.c @@ -0,0 +1,102 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Hisilicon clock driver + * Adapted from linux kernel + */ + +#include <dm/read.h> +#include <linux/clk-provider.h> +#include "clk.h" + +static spinlock_t lock; + +int hisi_clk_init(struct udevice *dev, struct hisi_clock_data *data) +{ + data->base = dev_remap_addr(dev); + if (!data->base) + return -EINVAL; + + return 0; +} + +int hisi_clk_register_fixed_rate(struct device *dev, const struct hisi_fixed_rate_clock *clks, + int nums) +{ + struct clk *clk; + int i; + + for (i = 0; i < nums; i++) { + clk = clk_register_fixed_rate(dev, clks[i].name, + clks[i].fixed_rate); + if (IS_ERR(clk)) { + pr_err("%s: failed to register clock %s\n", + __func__, clks[i].name); + goto err; + } + clk_dm(clks[i].id, clk); + } + return 0; + +err: + return PTR_ERR(clk); +} + +int hisi_clk_register_mux(struct device *dev, + const struct hisi_mux_clock *clks, + int nums, + const struct hisi_clock_data *data) +{ + struct clk *clk; + void __iomem *base = data->base; + int i; + + for (i = 0; i < nums; i++) { + u32 mask = BIT(clks[i].width) - 1; + + clk = clk_register_mux_table(dev, clks[i].name, + clks[i].parent_names, + clks[i].num_parents, clks[i].flags, + base + clks[i].offset, clks[i].shift, + mask, clks[i].mux_flags, clks[i].table); + if (IS_ERR(clk)) { + pr_err("%s: failed to register clock %s\n", + __func__, clks[i].name); + goto err; + } + + clk_dm(clks[i].id, clk); + } + return 0; + +err: + return PTR_ERR(clk); +} + +int hisi_clk_register_gate(struct device *dev, const struct hisi_gate_clock *clks, + int nums, const struct hisi_clock_data *data) +{ + struct clk *clk; + void __iomem *base = data->base; + int i; + + for (i = 0; i < nums; i++) { + clk = clk_register_gate(dev, clks[i].name, + clks[i].parent_name, + clks[i].flags, + base + clks[i].offset, + clks[i].bit_idx, + clks[i].gate_flags, + &lock); + if (IS_ERR(clk)) { + pr_err("%s: failed to register clock %s\n", + __func__, clks[i].name); + goto err; + } + + clk_dm(clks[i].id, clk); + } + return 0; + +err: + return PTR_ERR(clk); +} diff --git a/drivers/clk/hisilicon/clk.h b/drivers/clk/hisilicon/clk.h new file mode 100644 index 0000000000..67c889025d --- /dev/null +++ b/drivers/clk/hisilicon/clk.h @@ -0,0 +1,55 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Adapted from linux kernel, some functionalities are removed to keep it simple. + */ + +#ifndef __HISI_CLK_H +#define __HISI_CLK_H + +#include <linux/types.h> + +struct udevice; +struct device; + +struct hisi_clock_data { + void __iomem *base; +}; + +struct hisi_fixed_rate_clock { + unsigned int id; + char *name; + unsigned long fixed_rate; +}; + +struct hisi_mux_clock { + unsigned int id; + const char *name; + const char *const *parent_names; + u8 num_parents; + unsigned long flags; + unsigned long offset; + u8 shift; + u8 width; + u8 mux_flags; + u32 *table; +}; + +struct hisi_gate_clock { + unsigned int id; + const char *name; + const char *parent_name; + unsigned long flags; + unsigned long offset; + u8 bit_idx; + u8 gate_flags; +}; + +int hisi_clk_init(struct udevice *dev, struct hisi_clock_data *data); +int hisi_clk_register_fixed_rate(struct device *dev, const struct hisi_fixed_rate_clock *fixed, + int nums); +int hisi_clk_register_mux(struct device *dev, const struct hisi_mux_clock *mux, + int nums, const struct hisi_clock_data *data); +int hisi_clk_register_gate(struct device *dev, const struct hisi_gate_clock *gate, + int nums, const struct hisi_clock_data *data); + +#endif /* __HISI_CLK_H */ diff --git a/include/dt-bindings/clock/histb-clock.h b/include/dt-bindings/clock/histb-clock.h index 8a05790d1a..929e2a4488 100644 --- a/include/dt-bindings/clock/histb-clock.h +++ b/include/dt-bindings/clock/histb-clock.h @@ -74,6 +74,9 @@ #define HISTB_SDIO1_CIU_CLK 52 #define HISTB_SDIO1_DRV_CLK 53 #define HISTB_SDIO1_SAMPLE_CLK 54 +#define HISTB_ETH0_PHY_CLK 55 +#define HISTB_ETH1_PHY_CLK 56 +#define HISTB_WDG0_CLK 57
/* Hi3798MV200 specific clocks */
@@ -82,6 +85,7 @@ #define HI3798MV200_GMACIF_CLK HISTB_ETH0_MACIF_CLK #define HI3798MV200_FEMAC_CLK HISTB_ETH1_MAC_CLK #define HI3798MV200_FEMACIF_CLK HISTB_ETH1_MACIF_CLK +#define HI3798MV200_FEPHY_CLK HISTB_ETH1_PHY_CLK
/* clocks provided by mcu CRG */ #define HISTB_MCE_CLK 1
Yang Xiwen via B4 Relay
