[U-Boot] [PATCH] tools/genboardscfg.py: change shebang into /usr/bin/env python2
This tool only works on python 2 (python 2.6 or lator).
Change the shebang to make sure the script is run by python 2 and clearly say the supported version in the comment block.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
tools/genboardscfg.py | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/tools/genboardscfg.py b/tools/genboardscfg.py index 13dbc63..e6870f5 100755 --- a/tools/genboardscfg.py +++ b/tools/genboardscfg.py @@ -1,4 +1,4 @@ -#!/usr/bin/env python +#!/usr/bin/env python2 # # Author: Masahiro Yamada yamada.m@jp.panasonic.com # @@ -11,6 +11,8 @@ Converter from Kconfig and MAINTAINERS to boards.cfg Run 'tools/genboardscfg.py' to create boards.cfg file.
Run 'tools/genboardscfg.py -h' for available options. + +This script only works on python 2.6 or later, but not python 3.x. """
import errno
Masahiro Yamada
