[U-Boot] [PATCH] ARM: zynq: Fix default ps7_init_gpl.c/h for ZYBO
There is incorrect setting for USB which didn't work with origin ps7_init_gpl.X files. Use default setting for Digilent Zybo projects with HDMI in PL.
Signed-off-by: Michal Simek monstr@monstr.eu Signed-off-by: Michal Simek michal.simek@xilinx.com ---
board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.c | 1581 +++++++++++++++++---- board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.h | 9 +- 2 files changed, 1344 insertions(+), 246 deletions(-)
diff --git a/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.c b/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.c index 2c0fecac43f3..83daf7bf15b8 100644 --- a/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.c +++ b/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.c @@ -310,11 +310,11 @@ unsigned long ps7_clock_init_data_3_0[] = { /* .. SRCSEL = 0x0 */ /* .. ==> 0XF8000154[5:4] = 0x00000000U */ /* .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. DIVISOR = 0x14 */ - /* .. ==> 0XF8000154[13:8] = 0x00000014U */ - /* .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ + /* .. DIVISOR = 0xa */ + /* .. ==> 0XF8000154[13:8] = 0x0000000AU */ + /* .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ /* .. */ - EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00001402U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A02U), /* .. .. START: TRACE CLOCK */ /* .. .. FINISH: TRACE CLOCK */ /* .. .. CLKACT = 0x1 */ @@ -339,39 +339,39 @@ unsigned long ps7_clock_init_data_3_0[] = { /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00100A00U), - /* .. .. SRCSEL = 0x3 */ - /* .. .. ==> 0XF8000180[5:4] = 0x00000003U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000030U */ - /* .. .. DIVISOR0 = 0x6 */ - /* .. .. ==> 0XF8000180[13:8] = 0x00000006U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000600U */ + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000180[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x7 */ + /* .. .. ==> 0XF8000180[13:8] = 0x00000007U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF8000180[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100630U), - /* .. .. SRCSEL = 0x2 */ - /* .. .. ==> 0XF8000190[5:4] = 0x00000002U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000020U */ - /* .. .. DIVISOR0 = 0x35 */ - /* .. .. ==> 0XF8000190[13:8] = 0x00000035U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00003500U */ - /* .. .. DIVISOR1 = 0x2 */ - /* .. .. ==> 0XF8000190[25:20] = 0x00000002U */ - /* .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00203520U), + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100700U), + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000190[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x5 */ + /* .. .. ==> 0XF8000190[13:8] = 0x00000005U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U */ + /* .. .. DIVISOR1 = 0x1 */ + /* .. .. ==> 0XF8000190[25:20] = 0x00000001U */ + /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ + /* .. .. */ + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00100500U), /* .. .. SRCSEL = 0x0 */ /* .. .. ==> 0XF80001A0[5:4] = 0x00000000U */ /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. .. DIVISOR0 = 0xa */ - /* .. .. ==> 0XF80001A0[13:8] = 0x0000000AU */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ + /* .. .. DIVISOR0 = 0x14 */ + /* .. .. ==> 0XF80001A0[13:8] = 0x00000014U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF80001A0[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00100A00U), + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00101400U), /* .. .. CLK_621_TRUE = 0x1 */ /* .. .. ==> 0XF80001C4[0:0] = 0x00000001U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -667,9 +667,9 @@ unsigned long ps7_ddr_init_data_3_0[] = { /* .. .. reg_ddrc_burst_rdwr = 0x4 */ /* .. .. ==> 0XF8006034[3:0] = 0x00000004U */ /* .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U */ - /* .. .. reg_ddrc_pre_cke_x1024 = 0x101 */ - /* .. .. ==> 0XF8006034[13:4] = 0x00000101U */ - /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001010U */ + /* .. .. reg_ddrc_pre_cke_x1024 = 0x167 */ + /* .. .. ==> 0XF8006034[13:4] = 0x00000167U */ + /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001670U */ /* .. .. reg_ddrc_post_cke_x1024 = 0x1 */ /* .. .. ==> 0XF8006034[25:16] = 0x00000001U */ /* .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U */ @@ -677,7 +677,7 @@ unsigned long ps7_ddr_init_data_3_0[] = { /* .. .. ==> 0XF8006034[28:28] = 0x00000000U */ /* .. .. ==> MASK : 0x10000000U VAL : 0x00000000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011014U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011674U), /* .. .. reg_ddrc_force_low_pri_n = 0x0 */ /* .. .. ==> 0XF8006038[0:0] = 0x00000000U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000000U */ @@ -2020,6 +2020,35 @@ unsigned long ps7_mio_init_data_3_0[] = { /* .. FINISH: DDRIOB SETTINGS */ /* .. START: MIO PROGRAMMING */ /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000700[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000700[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000700[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000700[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000700[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000700[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000700[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000700[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000700[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000704[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -2194,6 +2223,267 @@ unsigned long ps7_mio_init_data_3_0[] = { /* .. */ EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800071C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800071C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800071C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800071C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800071C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800071C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800071C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF800071C[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800071C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000720[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 1 */ + /* .. ==> 0XF8000720[1:1] = 0x00000001U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000002U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000720[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000720[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000720[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 1 */ + /* .. ==> 0XF8000720[8:8] = 0x00000001U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000100U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000720[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF8000720[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000720[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000724[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000724[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000724[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000724[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000724[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000724[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000724[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000724[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000724[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000728[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000728[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000728[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000728[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000728[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000728[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000728[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000728[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000728[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800072C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800072C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800072C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800072C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800072C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800072C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800072C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800072C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800072C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000730[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000730[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000730[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000730[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000730[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000730[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000730[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000730[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000730[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000734[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000734[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000734[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000734[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000734[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000734[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000734[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000734[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000734[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000738[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000738[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000738[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000738[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000738[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000738[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000738[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000738[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000738[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800073C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800073C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800073C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800073C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800073C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800073C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800073C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800073C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800073C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000740[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -3063,6 +3353,35 @@ unsigned long ps7_mio_init_data_3_0[] = { /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ /* .. */ EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007B8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007B8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007B8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007B8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007B8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007B8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007B8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF80007B8[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007B8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00001200U), /* .. TRI_ENABLE = 1 */ /* .. ==> 0XF80007BC[0:0] = 0x00000001U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -3139,6 +3458,64 @@ unsigned long ps7_mio_init_data_3_0[] = { /* .. */ EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x000002E1U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007C8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007C8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007C8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007C8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007C8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007C8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007C8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007C8[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007C8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007CC[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007CC[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007CC[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007CC[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007CC[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007CC[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007CC[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007CC[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007CC[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF80007D0[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 0 */ @@ -3277,11 +3654,11 @@ unsigned long ps7_peripherals_init_data_3_0[] = { /* .. ==> MASK : 0x000000FFU VAL : 0x00000006U */ /* .. */ EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U), - /* .. CD = 0x3e */ - /* .. ==> 0XE0001018[15:0] = 0x0000003EU */ - /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000003EU */ + /* .. CD = 0x7c */ + /* .. ==> 0XE0001018[15:0] = 0x0000007CU */ + /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU */ /* .. */ - EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000003EU), + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU), /* .. STPBRK = 0x0 */ /* .. ==> 0XE0001000[8:8] = 0x00000000U */ /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ @@ -3329,29 +3706,6 @@ unsigned long ps7_peripherals_init_data_3_0[] = { /* .. */ EMIT_MASKWRITE(0XE0001004, 0x000003FFU, 0x00000020U), /* .. FINISH: UART REGISTERS */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ /* .. START: QSPI REGISTERS */ /* .. Holdb_dr = 1 */ /* .. ==> 0XE000D000[19:19] = 0x00000001U */ @@ -3390,24 +3744,50 @@ unsigned long ps7_peripherals_init_data_3_0[] = { /* .. .. .. .. START: DIR MODE BANK 0 */ /* .. .. .. .. FINISH: DIR MODE BANK 0 */ /* .. .. .. .. START: DIR MODE BANK 1 */ + /* .. .. .. .. DIRECTION_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A244[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: DIR MODE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. START: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. START: OUTPUT ENABLE BANK 1 */ + /* .. .. .. .. OP_ENABLE_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A248[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x0 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00000000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF0000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] */ @@ -3420,6 +3800,14 @@ unsigned long ps7_peripherals_init_data_3_0[] = { /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ @@ -3660,29 +4048,6 @@ unsigned long ps7_post_config_3_0[] = { /* .. */ EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), /* .. FINISH: ENABLING LEVEL SHIFTER */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ /* .. START: FPGA RESETS TO 0 */ /* .. reserved_3 = 0 */ /* .. ==> 0XF8000240[31:25] = 0x00000000U */ @@ -3759,6 +4124,8 @@ unsigned long ps7_post_config_3_0[] = { /* .. .. FINISH: AFI2 REGISTERS */ /* .. .. START: AFI3 REGISTERS */ /* .. .. FINISH: AFI3 REGISTERS */ + /* .. .. START: AFI2 SECURE REGISTER */ + /* .. .. FINISH: AFI2 SECURE REGISTER */ /* .. FINISH: AFI REGISTERS */ /* .. START: LOCK IT BACK */ /* .. LOCK_KEY = 0X767B */ @@ -4110,11 +4477,11 @@ unsigned long ps7_clock_init_data_2_0[] = { /* .. SRCSEL = 0x0 */ /* .. ==> 0XF8000154[5:4] = 0x00000000U */ /* .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. DIVISOR = 0x14 */ - /* .. ==> 0XF8000154[13:8] = 0x00000014U */ - /* .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ + /* .. DIVISOR = 0xa */ + /* .. ==> 0XF8000154[13:8] = 0x0000000AU */ + /* .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ /* .. */ - EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00001402U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A02U), /* .. .. START: TRACE CLOCK */ /* .. .. FINISH: TRACE CLOCK */ /* .. .. CLKACT = 0x1 */ @@ -4139,39 +4506,39 @@ unsigned long ps7_clock_init_data_2_0[] = { /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00100A00U), - /* .. .. SRCSEL = 0x3 */ - /* .. .. ==> 0XF8000180[5:4] = 0x00000003U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000030U */ - /* .. .. DIVISOR0 = 0x6 */ - /* .. .. ==> 0XF8000180[13:8] = 0x00000006U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000600U */ + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000180[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x7 */ + /* .. .. ==> 0XF8000180[13:8] = 0x00000007U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF8000180[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100630U), - /* .. .. SRCSEL = 0x2 */ - /* .. .. ==> 0XF8000190[5:4] = 0x00000002U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000020U */ - /* .. .. DIVISOR0 = 0x35 */ - /* .. .. ==> 0XF8000190[13:8] = 0x00000035U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00003500U */ - /* .. .. DIVISOR1 = 0x2 */ - /* .. .. ==> 0XF8000190[25:20] = 0x00000002U */ - /* .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00203520U), + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100700U), + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000190[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x5 */ + /* .. .. ==> 0XF8000190[13:8] = 0x00000005U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U */ + /* .. .. DIVISOR1 = 0x1 */ + /* .. .. ==> 0XF8000190[25:20] = 0x00000001U */ + /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ + /* .. .. */ + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00100500U), /* .. .. SRCSEL = 0x0 */ /* .. .. ==> 0XF80001A0[5:4] = 0x00000000U */ /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. .. DIVISOR0 = 0xa */ - /* .. .. ==> 0XF80001A0[13:8] = 0x0000000AU */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ + /* .. .. DIVISOR0 = 0x14 */ + /* .. .. ==> 0XF80001A0[13:8] = 0x00000014U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF80001A0[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00100A00U), + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00101400U), /* .. .. CLK_621_TRUE = 0x1 */ /* .. .. ==> 0XF80001C4[0:0] = 0x00000001U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -4491,9 +4858,9 @@ unsigned long ps7_ddr_init_data_2_0[] = { /* .. .. reg_ddrc_burst_rdwr = 0x4 */ /* .. .. ==> 0XF8006034[3:0] = 0x00000004U */ /* .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U */ - /* .. .. reg_ddrc_pre_cke_x1024 = 0x101 */ - /* .. .. ==> 0XF8006034[13:4] = 0x00000101U */ - /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001010U */ + /* .. .. reg_ddrc_pre_cke_x1024 = 0x167 */ + /* .. .. ==> 0XF8006034[13:4] = 0x00000167U */ + /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001670U */ /* .. .. reg_ddrc_post_cke_x1024 = 0x1 */ /* .. .. ==> 0XF8006034[25:16] = 0x00000001U */ /* .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U */ @@ -4501,7 +4868,7 @@ unsigned long ps7_ddr_init_data_2_0[] = { /* .. .. ==> 0XF8006034[28:28] = 0x00000000U */ /* .. .. ==> MASK : 0x10000000U VAL : 0x00000000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011014U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011674U), /* .. .. reg_ddrc_force_low_pri_n = 0x0 */ /* .. .. ==> 0XF8006038[0:0] = 0x00000000U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000000U */ @@ -5981,6 +6348,35 @@ unsigned long ps7_mio_init_data_2_0[] = { /* .. FINISH: DDRIOB SETTINGS */ /* .. START: MIO PROGRAMMING */ /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000700[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000700[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000700[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000700[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000700[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000700[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000700[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000700[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000700[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000704[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -6155,6 +6551,267 @@ unsigned long ps7_mio_init_data_2_0[] = { /* .. */ EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800071C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800071C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800071C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800071C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800071C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800071C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800071C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF800071C[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800071C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000720[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 1 */ + /* .. ==> 0XF8000720[1:1] = 0x00000001U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000002U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000720[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000720[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000720[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 1 */ + /* .. ==> 0XF8000720[8:8] = 0x00000001U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000100U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000720[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF8000720[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000720[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000724[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000724[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000724[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000724[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000724[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000724[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000724[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000724[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000724[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000728[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000728[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000728[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000728[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000728[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000728[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000728[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000728[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000728[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800072C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800072C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800072C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800072C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800072C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800072C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800072C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800072C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800072C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000730[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000730[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000730[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000730[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000730[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000730[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000730[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000730[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000730[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000734[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000734[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000734[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000734[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000734[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000734[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000734[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000734[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000734[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000738[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000738[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000738[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000738[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000738[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000738[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000738[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000738[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000738[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800073C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800073C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800073C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800073C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800073C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800073C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800073C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800073C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800073C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000740[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -7024,6 +7681,35 @@ unsigned long ps7_mio_init_data_2_0[] = { /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ /* .. */ EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007B8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007B8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007B8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007B8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007B8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007B8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007B8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF80007B8[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007B8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00001200U), /* .. TRI_ENABLE = 1 */ /* .. ==> 0XF80007BC[0:0] = 0x00000001U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -7100,6 +7786,64 @@ unsigned long ps7_mio_init_data_2_0[] = { /* .. */ EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x000002E1U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007C8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007C8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007C8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007C8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007C8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007C8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007C8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007C8[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007C8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007CC[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007CC[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007CC[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007CC[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007CC[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007CC[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007CC[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007CC[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007CC[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF80007D0[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 0 */ @@ -7238,11 +7982,11 @@ unsigned long ps7_peripherals_init_data_2_0[] = { /* .. ==> MASK : 0x000000FFU VAL : 0x00000006U */ /* .. */ EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U), - /* .. CD = 0x3e */ - /* .. ==> 0XE0001018[15:0] = 0x0000003EU */ - /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000003EU */ + /* .. CD = 0x7c */ + /* .. ==> 0XE0001018[15:0] = 0x0000007CU */ + /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU */ /* .. */ - EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000003EU), + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU), /* .. STPBRK = 0x0 */ /* .. ==> 0XE0001000[8:8] = 0x00000000U */ /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ @@ -7296,29 +8040,6 @@ unsigned long ps7_peripherals_init_data_2_0[] = { /* .. */ EMIT_MASKWRITE(0XE0001004, 0x00000FFFU, 0x00000020U), /* .. FINISH: UART REGISTERS */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ /* .. START: QSPI REGISTERS */ /* .. Holdb_dr = 1 */ /* .. ==> 0XE000D000[19:19] = 0x00000001U */ @@ -7357,24 +8078,50 @@ unsigned long ps7_peripherals_init_data_2_0[] = { /* .. .. .. .. START: DIR MODE BANK 0 */ /* .. .. .. .. FINISH: DIR MODE BANK 0 */ /* .. .. .. .. START: DIR MODE BANK 1 */ + /* .. .. .. .. DIRECTION_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A244[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: DIR MODE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. START: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. START: OUTPUT ENABLE BANK 1 */ + /* .. .. .. .. OP_ENABLE_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A248[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x0 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00000000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF0000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] */ @@ -7387,6 +8134,14 @@ unsigned long ps7_peripherals_init_data_2_0[] = { /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ @@ -7619,31 +8374,8 @@ unsigned long ps7_post_config_2_0[] = { /* .. ==> 0XF8000900[3:2] = 0x00000003U */ /* .. ==> MASK : 0x0000000CU VAL : 0x0000000CU */ /* .. */ - EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), - /* .. FINISH: ENABLING LEVEL SHIFTER */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ + EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), + /* .. FINISH: ENABLING LEVEL SHIFTER */ /* .. START: FPGA RESETS TO 0 */ /* .. reserved_3 = 0 */ /* .. ==> 0XF8000240[31:25] = 0x00000000U */ @@ -8071,11 +8803,11 @@ unsigned long ps7_clock_init_data_1_0[] = { /* .. SRCSEL = 0x0 */ /* .. ==> 0XF8000154[5:4] = 0x00000000U */ /* .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. DIVISOR = 0x14 */ - /* .. ==> 0XF8000154[13:8] = 0x00000014U */ - /* .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ + /* .. DIVISOR = 0xa */ + /* .. ==> 0XF8000154[13:8] = 0x0000000AU */ + /* .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ /* .. */ - EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00001402U), + EMIT_MASKWRITE(0XF8000154, 0x00003F33U, 0x00000A02U), /* .. .. START: TRACE CLOCK */ /* .. .. FINISH: TRACE CLOCK */ /* .. .. CLKACT = 0x1 */ @@ -8100,39 +8832,39 @@ unsigned long ps7_clock_init_data_1_0[] = { /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ EMIT_MASKWRITE(0XF8000170, 0x03F03F30U, 0x00100A00U), - /* .. .. SRCSEL = 0x3 */ - /* .. .. ==> 0XF8000180[5:4] = 0x00000003U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000030U */ - /* .. .. DIVISOR0 = 0x6 */ - /* .. .. ==> 0XF8000180[13:8] = 0x00000006U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000600U */ + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000180[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x7 */ + /* .. .. ==> 0XF8000180[13:8] = 0x00000007U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000700U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF8000180[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100630U), - /* .. .. SRCSEL = 0x2 */ - /* .. .. ==> 0XF8000190[5:4] = 0x00000002U */ - /* .. .. ==> MASK : 0x00000030U VAL : 0x00000020U */ - /* .. .. DIVISOR0 = 0x35 */ - /* .. .. ==> 0XF8000190[13:8] = 0x00000035U */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00003500U */ - /* .. .. DIVISOR1 = 0x2 */ - /* .. .. ==> 0XF8000190[25:20] = 0x00000002U */ - /* .. .. ==> MASK : 0x03F00000U VAL : 0x00200000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00203520U), + EMIT_MASKWRITE(0XF8000180, 0x03F03F30U, 0x00100700U), + /* .. .. SRCSEL = 0x0 */ + /* .. .. ==> 0XF8000190[5:4] = 0x00000000U */ + /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ + /* .. .. DIVISOR0 = 0x5 */ + /* .. .. ==> 0XF8000190[13:8] = 0x00000005U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000500U */ + /* .. .. DIVISOR1 = 0x1 */ + /* .. .. ==> 0XF8000190[25:20] = 0x00000001U */ + /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ + /* .. .. */ + EMIT_MASKWRITE(0XF8000190, 0x03F03F30U, 0x00100500U), /* .. .. SRCSEL = 0x0 */ /* .. .. ==> 0XF80001A0[5:4] = 0x00000000U */ /* .. .. ==> MASK : 0x00000030U VAL : 0x00000000U */ - /* .. .. DIVISOR0 = 0xa */ - /* .. .. ==> 0XF80001A0[13:8] = 0x0000000AU */ - /* .. .. ==> MASK : 0x00003F00U VAL : 0x00000A00U */ + /* .. .. DIVISOR0 = 0x14 */ + /* .. .. ==> 0XF80001A0[13:8] = 0x00000014U */ + /* .. .. ==> MASK : 0x00003F00U VAL : 0x00001400U */ /* .. .. DIVISOR1 = 0x1 */ /* .. .. ==> 0XF80001A0[25:20] = 0x00000001U */ /* .. .. ==> MASK : 0x03F00000U VAL : 0x00100000U */ /* .. .. */ - EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00100A00U), + EMIT_MASKWRITE(0XF80001A0, 0x03F03F30U, 0x00101400U), /* .. .. CLK_621_TRUE = 0x1 */ /* .. .. ==> 0XF80001C4[0:0] = 0x00000001U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -8452,9 +9184,9 @@ unsigned long ps7_ddr_init_data_1_0[] = { /* .. .. reg_ddrc_burst_rdwr = 0x4 */ /* .. .. ==> 0XF8006034[3:0] = 0x00000004U */ /* .. .. ==> MASK : 0x0000000FU VAL : 0x00000004U */ - /* .. .. reg_ddrc_pre_cke_x1024 = 0x101 */ - /* .. .. ==> 0XF8006034[13:4] = 0x00000101U */ - /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001010U */ + /* .. .. reg_ddrc_pre_cke_x1024 = 0x167 */ + /* .. .. ==> 0XF8006034[13:4] = 0x00000167U */ + /* .. .. ==> MASK : 0x00003FF0U VAL : 0x00001670U */ /* .. .. reg_ddrc_post_cke_x1024 = 0x1 */ /* .. .. ==> 0XF8006034[25:16] = 0x00000001U */ /* .. .. ==> MASK : 0x03FF0000U VAL : 0x00010000U */ @@ -8462,7 +9194,7 @@ unsigned long ps7_ddr_init_data_1_0[] = { /* .. .. ==> 0XF8006034[28:28] = 0x00000000U */ /* .. .. ==> MASK : 0x10000000U VAL : 0x00000000U */ /* .. .. */ - EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011014U), + EMIT_MASKWRITE(0XF8006034, 0x13FF3FFFU, 0x00011674U), /* .. .. reg_ddrc_force_low_pri_n = 0x0 */ /* .. .. ==> 0XF8006038[0:0] = 0x00000000U */ /* .. .. ==> MASK : 0x00000001U VAL : 0x00000000U */ @@ -9875,6 +10607,35 @@ unsigned long ps7_mio_init_data_1_0[] = { /* .. FINISH: DDRIOB SETTINGS */ /* .. START: MIO PROGRAMMING */ /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000700[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000700[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000700[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000700[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000700[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000700[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000700[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000700[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000700[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000700, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000704[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -10049,6 +10810,267 @@ unsigned long ps7_mio_init_data_1_0[] = { /* .. */ EMIT_MASKWRITE(0XF8000718, 0x00003FFFU, 0x00000702U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800071C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800071C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800071C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800071C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800071C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800071C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800071C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF800071C[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800071C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800071C, 0x00003FFFU, 0x00000600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000720[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 1 */ + /* .. ==> 0XF8000720[1:1] = 0x00000001U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000002U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000720[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000720[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000720[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 1 */ + /* .. ==> 0XF8000720[8:8] = 0x00000001U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000100U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000720[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF8000720[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000720[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000720, 0x00003FFFU, 0x00000702U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000724[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000724[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000724[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000724[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000724[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000724[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000724[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000724[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000724[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000724, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000728[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000728[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000728[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000728[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000728[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000728[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000728[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000728[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000728[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000728, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800072C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800072C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800072C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800072C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800072C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800072C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800072C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800072C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800072C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800072C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000730[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000730[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000730[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000730[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000730[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000730[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000730[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000730[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000730[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000730, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000734[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000734[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000734[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000734[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000734[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000734[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000734[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000734[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000734[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000734, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF8000738[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF8000738[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF8000738[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF8000738[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF8000738[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF8000738[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF8000738[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF8000738[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF8000738[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF8000738, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF800073C[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF800073C[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF800073C[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF800073C[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF800073C[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF800073C[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 3 */ + /* .. ==> 0XF800073C[11:9] = 0x00000003U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000600U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF800073C[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF800073C[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF800073C, 0x00003FFFU, 0x00001600U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF8000740[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 1 */ @@ -10918,6 +11940,35 @@ unsigned long ps7_mio_init_data_1_0[] = { /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ /* .. */ EMIT_MASKWRITE(0XF80007B4, 0x00003FFFU, 0x00000380U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007B8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007B8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007B8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007B8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007B8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007B8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007B8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 1 */ + /* .. ==> 0XF80007B8[12:12] = 0x00000001U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00001000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007B8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007B8, 0x00003FFFU, 0x00001200U), /* .. TRI_ENABLE = 1 */ /* .. ==> 0XF80007BC[0:0] = 0x00000001U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000001U */ @@ -10994,6 +12045,64 @@ unsigned long ps7_mio_init_data_1_0[] = { /* .. */ EMIT_MASKWRITE(0XF80007C4, 0x00003FFFU, 0x000002E1U), /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007C8[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007C8[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007C8[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007C8[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007C8[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007C8[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007C8[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007C8[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007C8[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007C8, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ + /* .. ==> 0XF80007CC[0:0] = 0x00000000U */ + /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ + /* .. L0_SEL = 0 */ + /* .. ==> 0XF80007CC[1:1] = 0x00000000U */ + /* .. ==> MASK : 0x00000002U VAL : 0x00000000U */ + /* .. L1_SEL = 0 */ + /* .. ==> 0XF80007CC[2:2] = 0x00000000U */ + /* .. ==> MASK : 0x00000004U VAL : 0x00000000U */ + /* .. L2_SEL = 0 */ + /* .. ==> 0XF80007CC[4:3] = 0x00000000U */ + /* .. ==> MASK : 0x00000018U VAL : 0x00000000U */ + /* .. L3_SEL = 0 */ + /* .. ==> 0XF80007CC[7:5] = 0x00000000U */ + /* .. ==> MASK : 0x000000E0U VAL : 0x00000000U */ + /* .. Speed = 0 */ + /* .. ==> 0XF80007CC[8:8] = 0x00000000U */ + /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ + /* .. IO_Type = 1 */ + /* .. ==> 0XF80007CC[11:9] = 0x00000001U */ + /* .. ==> MASK : 0x00000E00U VAL : 0x00000200U */ + /* .. PULLUP = 0 */ + /* .. ==> 0XF80007CC[12:12] = 0x00000000U */ + /* .. ==> MASK : 0x00001000U VAL : 0x00000000U */ + /* .. DisableRcvr = 0 */ + /* .. ==> 0XF80007CC[13:13] = 0x00000000U */ + /* .. ==> MASK : 0x00002000U VAL : 0x00000000U */ + /* .. */ + EMIT_MASKWRITE(0XF80007CC, 0x00003FFFU, 0x00000200U), + /* .. TRI_ENABLE = 0 */ /* .. ==> 0XF80007D0[0:0] = 0x00000000U */ /* .. ==> MASK : 0x00000001U VAL : 0x00000000U */ /* .. L0_SEL = 0 */ @@ -11132,11 +12241,11 @@ unsigned long ps7_peripherals_init_data_1_0[] = { /* .. ==> MASK : 0x000000FFU VAL : 0x00000006U */ /* .. */ EMIT_MASKWRITE(0XE0001034, 0x000000FFU, 0x00000006U), - /* .. CD = 0x3e */ - /* .. ==> 0XE0001018[15:0] = 0x0000003EU */ - /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000003EU */ + /* .. CD = 0x7c */ + /* .. ==> 0XE0001018[15:0] = 0x0000007CU */ + /* .. ==> MASK : 0x0000FFFFU VAL : 0x0000007CU */ /* .. */ - EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000003EU), + EMIT_MASKWRITE(0XE0001018, 0x0000FFFFU, 0x0000007CU), /* .. STPBRK = 0x0 */ /* .. ==> 0XE0001000[8:8] = 0x00000000U */ /* .. ==> MASK : 0x00000100U VAL : 0x00000000U */ @@ -11190,29 +12299,6 @@ unsigned long ps7_peripherals_init_data_1_0[] = { /* .. */ EMIT_MASKWRITE(0XE0001004, 0x00000FFFU, 0x00000020U), /* .. FINISH: UART REGISTERS */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ /* .. START: QSPI REGISTERS */ /* .. Holdb_dr = 1 */ /* .. ==> 0XE000D000[19:19] = 0x00000001U */ @@ -11251,24 +12337,50 @@ unsigned long ps7_peripherals_init_data_1_0[] = { /* .. .. .. .. START: DIR MODE BANK 0 */ /* .. .. .. .. FINISH: DIR MODE BANK 0 */ /* .. .. .. .. START: DIR MODE BANK 1 */ + /* .. .. .. .. DIRECTION_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A244[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A244, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: DIR MODE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW HIGH BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. START: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 0 */ /* .. .. .. .. START: OUTPUT ENABLE BANK 1 */ + /* .. .. .. .. OP_ENABLE_1 = 0x4000 */ + /* .. .. .. .. ==> 0XE000A248[21:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x003FFFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A248, 0x003FFFFFU, 0x00004000U), /* .. .. .. .. FINISH: OUTPUT ENABLE BANK 1 */ /* .. .. .. .. START: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. FINISH: MASK_DATA_0_LSW LOW BANK [15:0] */ /* .. .. .. .. START: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW LOW BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW LOW BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x0 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00000000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00000000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF0000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW LOW BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW LOW BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW LOW BANK [53:48] */ @@ -11281,6 +12393,14 @@ unsigned long ps7_peripherals_init_data_1_0[] = { /* .. .. .. .. START: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. FINISH: MASK_DATA_0_MSW HIGH BANK [31:16] */ /* .. .. .. .. START: MASK_DATA_1_LSW HIGH BANK [47:32] */ + /* .. .. .. .. MASK_1_LSW = 0xbfff */ + /* .. .. .. .. ==> 0XE000A008[31:16] = 0x0000BFFFU */ + /* .. .. .. .. ==> MASK : 0xFFFF0000U VAL : 0xBFFF0000U */ + /* .. .. .. .. DATA_1_LSW = 0x4000 */ + /* .. .. .. .. ==> 0XE000A008[15:0] = 0x00004000U */ + /* .. .. .. .. ==> MASK : 0x0000FFFFU VAL : 0x00004000U */ + /* .. .. .. .. */ + EMIT_MASKWRITE(0XE000A008, 0xFFFFFFFFU, 0xBFFF4000U), /* .. .. .. .. FINISH: MASK_DATA_1_LSW HIGH BANK [47:32] */ /* .. .. .. .. START: MASK_DATA_1_MSW HIGH BANK [53:48] */ /* .. .. .. .. FINISH: MASK_DATA_1_MSW HIGH BANK [53:48] */ @@ -11515,29 +12635,6 @@ unsigned long ps7_post_config_1_0[] = { /* .. */ EMIT_MASKWRITE(0XF8000900, 0x0000000FU, 0x0000000FU), /* .. FINISH: ENABLING LEVEL SHIFTER */ - /* .. START: TPIU WIDTH IN CASE OF EMIO */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0XC5ACCE55 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0xC5ACCE55U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0xC5ACCE55U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0xC5ACCE55U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. .. START: TRACE CURRENT PORT SIZE */ - /* .. .. a = 2 */ - /* .. .. ==> 0XF8803004[31:0] = 0x00000002U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000002U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803004, 0xFFFFFFFFU, 0x00000002U), - /* .. .. FINISH: TRACE CURRENT PORT SIZE */ - /* .. .. START: TRACE LOCK ACCESS REGISTER */ - /* .. .. a = 0X0 */ - /* .. .. ==> 0XF8803FB0[31:0] = 0x00000000U */ - /* .. .. ==> MASK : 0xFFFFFFFFU VAL : 0x00000000U */ - /* .. .. */ - EMIT_MASKWRITE(0XF8803FB0, 0xFFFFFFFFU, 0x00000000U), - /* .. .. FINISH: TRACE LOCK ACCESS REGISTER */ - /* .. FINISH: TPIU WIDTH IN CASE OF EMIO */ /* .. START: FPGA RESETS TO 0 */ /* .. reserved_3 = 0 */ /* .. ==> 0XF8000240[31:25] = 0x00000000U */ diff --git a/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.h b/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.h index 62b8a5846b62..22d9fd9250e8 100644 --- a/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.h +++ b/board/xilinx/zynq/zybo_hw_platform/ps7_init_gpl.h @@ -62,7 +62,7 @@ extern unsigned long *ps7_peripherals_init_data; #define USB0_FREQ 60000000 #define USB1_FREQ 60000000 #define SDIO_FREQ 50000000 -#define UART_FREQ 50000000 +#define UART_FREQ 100000000 #define SPI_FREQ 10000000 #define I2C_FREQ 108333336 #define WDT_FREQ 108333336 @@ -71,9 +71,10 @@ extern unsigned long *ps7_peripherals_init_data; #define PCAP_FREQ 200000000 #define TPIU_FREQ 200000000 #define FPGA0_FREQ 100000000 -#define FPGA1_FREQ 175000000 -#define FPGA2_FREQ 12264151 -#define FPGA3_FREQ 100000000 +#define FPGA1_FREQ 142857132 +#define FPGA2_FREQ 200000000 +#define FPGA3_FREQ 50000000 +
/* For delay calculation using global registers*/ #define SCU_GLOBAL_TIMER_COUNT_L32 0xF8F00200
Michal Simek
