[PATCH 1/1] test: test_fs error message
For non-root users mkfs.vfat is not in the search path at least on Debian. Hence when running 'make tests' a message indicates that file system tests have been skipped:
SKIPPED [13] test/py/tests/test_fs/conftest.py:340: Setup failed for filesystem: fat16
This message is not really helpful as the executed program is not indicated. Provide a more complete message like
SKIPPED [13] test/py/tests/test_fs/conftest.py:340: Setup failed for filesystem: fat16. Command 'mkfs.vfat -F 16 build-sandbox/persistent-data/3GB.fat16.img' returned non-zero exit status 127.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/py/tests/test_fs/conftest.py | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/test/py/tests/test_fs/conftest.py b/test/py/tests/test_fs/conftest.py index b03fe75f5c..0d9a30bb07 100644 --- a/test/py/tests/test_fs/conftest.py +++ b/test/py/tests/test_fs/conftest.py @@ -335,8 +335,9 @@ def fs_obj_basic(request, u_boot_config): md5val.append(out.split()[0])
umount_fs(mount_dir) - except CalledProcessError: - pytest.skip('Setup failed for filesystem: ' + fs_type) + except CalledProcessError as err: + pytest.skip('Setup failed for filesystem: ' + fs_type + \ + '. {}'.format(err)) return else: yield [fs_ubtype, fs_img, md5val] -- 2.26.1
'. {}'.format(err))
Wouldn't it be much simpler to avoid the format call:
... + fs_type + '. ' + err)
But either way the change seems conceptually fine.
Stephen Warren
