[U-Boot] [PATCH V3] mtd: nand: mxs check maximum ecc that platfrom supports
Check maximum ecc strength for each platfrom to avoid the calculated ecc exceed the limitation.
Signed-off-by: Peng Fan Peng.Fan@freescale.com Signed-off-by: Han Xu b45815@freescale.com Tested-By: Tim Harvey <tharvey at gateworks.com> Reviewed-by: Marek Vasut marex@denx.de Acked-by: Scott Wood scottwood@freescale.com Cc: Stefano Babic sbabic@denx.de ---
Original V2 mail thread: http://lists.denx.de/pipermail/u-boot/2015-August/225362.html
Because is_cpu_type was not merged to uboot upstream at that time, this patch can not be compiled successfully. Since now is_cpu_type is already in uboot upstream master branch, this patch can be applied and built without failure.
Changes v3: Add Scott's Acked by Add Tim's Tested by
Changes v2: Add Marek's reviewed by.
drivers/mtd/nand/mxs_nand.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 1d68901..f15cf36 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -149,6 +149,13 @@ static inline uint32_t mxs_nand_get_ecc_strength(uint32_t page_data_size, uint32_t page_oob_size) { int ecc_strength; + int max_ecc_strength_supported; + + /* Refer to Chapter 17 for i.MX6DQ, Chapter 18 for i.MX6SX */ + if (is_cpu_type(MXC_CPU_MX6SX)) + max_ecc_strength_supported = 62; + else + max_ecc_strength_supported = 40;
/* * Determine the ECC layout with the formula: @@ -162,7 +169,7 @@ static inline uint32_t mxs_nand_get_ecc_strength(uint32_t page_data_size, / (galois_field * mxs_nand_ecc_chunk_cnt(page_data_size));
- return round_down(ecc_strength, 2); + return min(round_down(ecc_strength, 2), max_ecc_strength_supported); }
static inline uint32_t mxs_nand_get_mark_offset(uint32_t page_data_size,
Best regards, Stefano Babic
Peng Fan
Stefano Babic
