Re: [U-Boot-Users] drivers MMCplus for at91sam9x
I posted the following patch under a different subject line: Re: [U-Boot-Users] [PATCH] Add eSDHC driver
--- u-boot_at91sam9260_mmc.patch (AT91 MCI driver) ---
Pierre Savary wrote:
Thanks for that... but it's my own patch ;)
Pierre
Pierre, I hope you like this patch better. :)
The following MMC v4 patch is for u-boot-1.1.5_atmel_1.2. To the AT91SAM9261 MCI device driver it adds support for MMC v4.x chips (MoviNAND in particular).
The u-boot_at91sam9260_mmc.patch, previously send to this thread 23 April 2008 must be applied to u-boot-1.1.5_atmel_1.2, prior to applying the patch below.
The patch includes lines "/* Ignore */". These are simply place holders for code that was not relevant to the MCI driver or MMC code.
The patch is actually of four individual source files. Please let me know of any serious problems applying the patch. It should apply cleanly, but I didn't verify this.
The MCI MMC v4 features contained in this patch work perfectly on our AT91SAM9261 board, except that I never got MMC 4 bit bus working (that code is omitted from this patch). Anyone know why the AT91SAM9261-EK doesn't appear to support 4 bit MMC?
This patch may not work on AT91SAM9261-EK, since we modified the AT91SAM9261-EK board definitions rather than creating a new configuration and files for our board.
Sincerely,
Ken Fuchs
u-boot-at91sam9261-mmc-v4.patch ===============================
svn diff -r21 cpu/arm926ejs/at91sam926x/atmel_mci.c Index: cpu/arm926ejs/at91sam926x/atmel_mci.c =================================================================== --- cpu/arm926ejs/at91sam926x/atmel_mci.c (revision 21) +++ cpu/arm926ejs/at91sam926x/atmel_mci.c (working copy) @@ -1,4 +1,8 @@ /* + * (C) Copyright 2007-2008 + * Benchmark Electronics, Inc. + * Added MMC v4.x (MoviNAND) support + * * Copyright (C) 2004-2006 Atmel Corporation * * See file CREDITS for list of people who contributed to this @@ -34,21 +38,43 @@ #include <asm/arch/hardware.h> //klk
#include "atmel_mci.h" -#undef DEBUG + +/* Ignore */ +/* Ignore */ +/* Ignore */ + +#if 0 +#define DEBUG +#else /* 0 */ +#undef DEBUG /* kf - was #undef */ +#endif /* 0 */ + #ifdef DEBUG #define pr_debug(fmt, args...) printf(fmt, ##args) #else #define pr_debug(...) do { } while(0) #endif
+#undef CFG_MMC_CLK_OD +#define CFG_MMC_CLK_OD 375000 + #ifndef CFG_MMC_CLK_OD #define CFG_MMC_CLK_OD 375000 #endif
+#undef CFG_MMC_CLK_PP +#define CFG_MMC_CLK_PP 20000000 + #ifndef CFG_MMC_CLK_PP #define CFG_MMC_CLK_PP 20000000 #endif
+#undef CFG_MMC_OP_COND +#define CFG_MMC_OP_COND 0x80ff8000 +/* 0x80ff8080 works with 30+ sec. power off req */ +/* 0x00800000 works better, but write forever? */ +/* 0x00100000 works with 30+ sec. power off req */ + #ifndef CFG_MMC_OP_COND #define CFG_MMC_OP_COND 0x00100000 #endif @@ -74,8 +100,13 @@ bus_hz = AT91C_MASTER_CLOCK; clkdiv = (bus_hz / hz) / 2 - 1;
+#if 1 + printf("mmc: setting clock %lu Hz, block size %lu\n", + hz, blklen); +#else /* 1 */ pr_debug("mmc: setting clock %lu Hz, block size %lu\n", hz, blklen); +#endif /* 1 */
if (clkdiv & ~255UL) { clkdiv = 255; @@ -84,10 +115,17 @@ }
blklen &= 0xfffc; + +#if 1 /* AT91SAM9261 does not have RDPROOF and WRPROOF fields. */ mmci_writel(MR, (MMCI_BF(CLKDIV, clkdiv) + | MMCI_BF(BLKLEN, blklen))); +#else /* 1 */ + mmci_writel(MR, (MMCI_BF(CLKDIV, clkdiv) | MMCI_BF(BLKLEN, blklen) | MMCI_BIT(RDPROOF) | MMCI_BIT(WRPROOF))); +#endif /* 1 */ + }
#define RESP_NO_CRC 1 @@ -99,6 +137,7 @@ #define NCR MMCI_BF(MAXLAT, 1) #define TRCMD_START MMCI_BF(TRCMD, 1) #define TRDIR_READ MMCI_BF(TRDIR, 1) +#define TRDIR_WRITE MMCI_BF(TRDIR, 0) #define TRTYP_BLOCK MMCI_BF(TRTYP, 0) #define INIT_CMD MMCI_BF(SPCMD, 1) #define OPEN_DRAIN MMCI_BF(OPDCMD, 1) @@ -109,6 +148,20 @@ | MMCI_BIT(RINDE) \ | MMCI_BIT(RTOE))
+#if 0 +#define DEBUG +#else /* 0 */ +#undef DEBUG /* kf - was #undef */ +#endif /* 0 */ + +#undef pr_debug + +#ifdef DEBUG +#define pr_debug(fmt, args...) printf(fmt, ##args) +#else +#define pr_debug(...) do { } while(0) +#endif + static int mmc_cmd(unsigned long cmd, unsigned long arg, void *resp, unsigned long flags) @@ -117,7 +170,9 @@ int i, response_words = 0; unsigned long error_flags; u32 status; - +#if 1 + pr_debug("mmc_cmd: entry\n"); +#endif /* 1 */ AT91F_MMC_Hardware_Init(); pr_debug("mmc: CMD%lu 0x%lx (flags 0x%lx)\n", @@ -161,12 +216,28 @@ return 0; }
+#if 0 +#define DEBUG +#else /* 0 */ +#undef DEBUG /* kf - was #undef */ +#endif /* 0 */ + +#undef pr_debug + +#ifdef DEBUG +#define pr_debug(fmt, args...) printf(fmt, ##args) +#else +#define pr_debug(...) do { } while(0) +#endif + static int mmc_acmd(unsigned long cmd, unsigned long arg, void *resp, unsigned long flags) { unsigned long aresp[4]; int ret;
+ pr_debug("mmc_acmd: entry\n"); + /* * Seems like the APP_CMD part of an ACMD has 64 cycles max * latency even though the ACMD part doesn't. This isn't @@ -184,7 +255,16 @@ return ret; }
-static unsigned long +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + +unsigned long mmc_bread(int dev, unsigned long start, lbaint_t blkcnt, unsigned long *buffer) { @@ -193,7 +273,14 @@ unsigned long card_status, data; unsigned long wordcount; u32 status; + unsigned long *bufaddr;
+ pr_debug("mmc_bread: entry\n"); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("mmc: bread ret = %d, card status = %08x\n", ret, card_status); + + bufaddr = buffer; + if (blkcnt == 0) return 0;
@@ -202,10 +289,16 @@
/* Put the device into Transfer state */ ret = mmc_cmd(MMC_CMD_SELECT_CARD, mmc_rca << 16, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("mmc: bread ret = %d, card status = %08x\n", + ret, card_status); if (ret) goto fail;
/* Set block length */ ret = mmc_cmd(MMC_CMD_SET_BLOCKLEN, mmc_blkdev.blksz, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("mmc: bread ret = %d, card status = %08x\n", + ret, card_status); if (ret) goto fail;
pr_debug("MCI_DTOR = %08lx\n", mmci_readl(DTOR)); @@ -228,7 +321,6 @@
if (status & MMCI_BIT(RXRDY)) { data = mmci_readl(RDR); - /* pr_debug("%x\n", data); */ *buffer++ = data; wordcount++; } @@ -240,12 +332,68 @@ status = mmci_readl(SR); } while (!(status & MMCI_BIT(BLKE)));
- putc('.'); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, + &card_status, R1 | NCR); + pr_debug("mmc: bread ret = %d, card status = %08x\n", + ret, card_status); + + if (i % 0x800 == 0x7ff) { + putc('.'); /* Display '.', after each MB xfer'ed */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + } + +#if 0 + buffer = bufaddr; + wordcount = 0; + do { + if (wordcount % 8 == 0) { + pr_debug("\n%06lx:", 4 * wordcount); + } + pr_debug(" %08lx", *buffer++); + wordcount++; + } while (4 * wordcount < mmc_blkdev.blksz); + pr_debug("\n"); +#endif /* 0 */ + }
out: /* Put the device back into Standby state */ mmc_cmd(MMC_CMD_SELECT_CARD, 0, resp, NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("mmc: bread ret = %d, card status = %08x\n", ret, card_status); + if (i >= 0x7ff) { + putc('\n'); + } return i;
fail: @@ -254,8 +402,329 @@ goto out; }
+unsigned long +mmc_bwrite(int dev, unsigned long start, lbaint_t blkcnt, + unsigned long *buffer) +{ + int ret, i = 0; + unsigned long resp[4]; + unsigned long card_status, data; + unsigned long wordcount; + u32 status; + unsigned long *bufaddr; + + pr_debug("mmc_bwrite: entry\n"); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("en mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + + bufaddr = buffer; + + if (blkcnt == 0) + return 0; + + pr_debug("mmc_bwrite: dev %d, start %lx, blkcnt %lx\n", + dev, start, blkcnt); + + /* Put the device into Transfer state */ + ret = mmc_cmd(MMC_CMD_SELECT_CARD, mmc_rca << 16, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("sc mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; + + /* Set block length */ + ret = mmc_cmd(MMC_CMD_SET_BLOCKLEN, mmc_blkdev.blksz, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("bl mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; + + pr_debug("MCI_DTOR = %08lx\n", mmci_readl(DTOR)); + + for (i = 0; i < blkcnt; i++, start++) { + ret = mmc_cmd(MMC_CMD_WRITE_BLOCK, + start * mmc_blkdev.blksz, resp, + (R1 | NCR | TRCMD_START | TRDIR_WRITE + | TRTYP_BLOCK)); + if (ret) goto fail; + + ret = -EIO; + wordcount = 0; + do { + do { + status = mmci_readl(SR); + if (status & (ERROR_FLAGS | MMCI_BIT(UNRE))) + goto fail; + } while (!(status & MMCI_BIT(TXRDY))); + + if (status & MMCI_BIT(TXRDY)) { + data = *buffer++; + mmci_writel(TDR, data); + wordcount++; + } + } while(wordcount < (mmc_blkdev.blksz / 4)); + + pr_debug("mmc: write %u words, waiting for BLKE\n", wordcount); + + do { + status = mmci_readl(SR); + } while (!(status & MMCI_BIT(BLKE))); + + do { + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, + &card_status, R1 | NCR); + if ((card_status & 0x00000100) != 0x00000100) { +#if 0 + printf("lp mmc: bwrite ret = %d, ", ret); + printf("card status = %08x\n", card_status); +#endif /* 0 */ + } else { + pr_debug("lp mmc: bwrite ret = %d, ", ret); + pr_debug("card status = %08x\n", card_status); + } + } while ((card_status & 0x00000100) != 0x00000100); + + if (i % 0x800 == 0x7ff) { + putc('.'); /* Display '.', after each MB xfer'ed */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + } + +#if 0 + ret = mmc_cmd(MMC_CMD_STOP_TRANSMISSION, + 0, resp, + R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, + &card_status, R1 | NCR); + pr_debug("st mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; +#endif /* 0 */ + + } + +out: +#if 0 + ret = mmc_cmd(MMC_CMD_STOP_TRANSMISSION, + 0, resp, + R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("st mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; +#endif /* 0 */ + + /* Put the device back into Standby state */ + mmc_cmd(MMC_CMD_SELECT_CARD, 0, resp, NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("dc mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + if (i >= 0x7ff) { + putc('\n'); + } + return i; + +fail: + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("fa mmc: bwrite ret = %d, card status = %08x\n", + ret, card_status); + goto out; +} + + /* Hangs - did not attempt to debug */ +/* MMC Multiple Block Write - mmc_mbwrite() */ +unsigned long +mmc_mbwrite(int dev, unsigned long start, lbaint_t blkcnt, + unsigned long *buffer) +{ + int ret, i = 0; + unsigned long resp[4]; + unsigned long card_status, data; + unsigned long wordcount; + u32 status; + unsigned long *bufaddr; + + pr_debug("mmc_bwrite: entry\n"); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("en mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + + bufaddr = buffer; + + if (blkcnt == 0) + return 0; + + if (blkcnt > 0xffff) { /* Exceeds length supported by MoviNAND. */ + return -1; + } + + pr_debug("mmc_mbwrite: dev %d, start %lx, blkcnt %lx\n", + dev, start, blkcnt); + + /* Put the device into Transfer state */ + ret = mmc_cmd(MMC_CMD_SELECT_CARD, mmc_rca << 16, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("sc mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; + + /* Set block length */ + ret = mmc_cmd(MMC_CMD_SET_BLOCKLEN, mmc_blkdev.blksz, resp, R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("bl mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; + + pr_debug("MCI_DTOR = %08lx\n", mmci_readl(DTOR)); + + ret = mmc_cmd(MMC_CMD_SET_BLOCK_COUNT, + blkcnt, resp, + R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("bc mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; + + ret = mmc_cmd(MMC_CMD_WRITE_MULTIPLE_BLOCK, + start * mmc_blkdev.blksz, resp, + (R1 | NCR | TRCMD_START | TRDIR_WRITE | TRTYP_BLOCK)); + if (ret) goto fail; + + for (i = 0; i < blkcnt; i++, start++) { + + ret = -EIO; + wordcount = 0; + do { + do { + status = mmci_readl(SR); + if (status & (ERROR_FLAGS | MMCI_BIT(UNRE))) + goto fail; + } while (!(status & MMCI_BIT(TXRDY))); + + if (status & MMCI_BIT(TXRDY)) { + data = *buffer++; + mmci_writel(TDR, data); + wordcount++; + } + } while(wordcount < (mmc_blkdev.blksz / 4)); + +#if 1 + pr_debug("mmc: write %u words, waiting for BLKE\n", wordcount); + + do { + status = mmci_readl(SR); + } while (!(status & MMCI_BIT(BLKE))); +#endif /* 0 */ + + do { + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, + &card_status, R1 | NCR); + if ((card_status & 0x00000100) != 0x00000100) { +#if 0 + printf("lp mmc: mbwrite ret = %d, ", ret); + printf("card status = %08x\n", card_status); +#endif /* 0 */ + } else { + pr_debug("lp mmc: mbwrite ret = %d, ", ret); + pr_debug("card status = %08x\n", card_status); + } + } while ((card_status & 0x00000100) != 0x00000100); + + if (i % 0x800 == 0x7ff) { + putc('.'); /* Display '.', after each MB xfer'ed */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + } + } + +out: +#if 0 + ret = mmc_cmd(MMC_CMD_STOP_TRANSMISSION, + 0, resp, + R1 | NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("st mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + if (ret) goto fail; +#endif /* 0 */ + + /* Put the device back into Standby state */ + mmc_cmd(MMC_CMD_SELECT_CARD, 0, resp, NCR); + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("dc mmc: mbwrite ret = %d, card status = %08x\n", + ret, card_status); + if (i >= 0x7ff) { + putc('\n'); + } + return i; + +fail: + mmc_cmd(MMC_CMD_SEND_STATUS, mmc_rca << 16, &card_status, R1 | NCR); + pr_debug("fa mmc: mbwrite failed, card status = %08x\n", card_status); + goto out; +} + static void mmc_parse_cid(struct mmc_cid *cid, unsigned long *resp) { + pr_debug("mmc_parse_cid: entry\n"); + cid->mid = resp[0] >> 24; cid->oid = (resp[0] >> 8) & 0xffff; cid->pnm[0] = resp[0]; @@ -272,6 +741,8 @@
static void sd_parse_cid(struct mmc_cid *cid, unsigned long *resp) { + pr_debug("sd_parse_cid: entry\n"); + cid->mid = resp[0] >> 24; cid->oid = (resp[0] >> 8) & 0xffff; cid->pnm[0] = resp[0]; @@ -288,6 +759,8 @@
static void mmc_dump_cid(const struct mmc_cid *cid) { + pr_debug("mmc_dump_cid: entry\n"); + printf("Manufacturer ID: %02lX\n", cid->mid); printf("OEM/Application ID: %04lX\n", cid->oid); printf("Product name: %s\n", cid->pnm); @@ -301,6 +774,9 @@ static void mmc_dump_csd(const struct mmc_csd *csd) { unsigned long *csd_raw = (unsigned long *)csd; + + pr_debug("mmc_dump_csd: entry\n"); + pr_debug("CSD data: %08lx %08lx %08lx %08lx\n", csd_raw[0], csd_raw[1], csd_raw[2], csd_raw[3]); pr_debug("CSD structure version: 1.%u\n", csd->csd_structure); @@ -337,6 +813,8 @@ { int ret;
+ pr_debug("mmc_idle_cards: entry\n"); + /* Reset and initialize all cards */ ret = mmc_cmd(MMC_CMD_GO_IDLE_STATE, 0, NULL, 0); @@ -352,6 +830,8 @@ unsigned long resp[4]; int i, ret = 0;
+ pr_debug("sd_init_card: entry\n"); + mmc_idle_cards(); for (i = 0; i < 1000; i++) { ret = mmc_acmd(MMC_ACMD_SD_SEND_OP_COND, CFG_MMC_OP_COND, @@ -387,10 +867,40 @@ { unsigned long resp[4]; int i, ret = 0; + u32 status;
+ pr_debug("mmc_init_card: entry\n"); + mmc_idle_cards();
+ /* MoviNAND initialization */ for (i = 0; i < 1000; i++) { + mmci_writel(ARGR, 0xFFFFFFFF); + mmci_writel(CMDR, 0x0018113F); + do { + status = mmci_readl(SR); + } while (!(status & MMCI_BIT(CMDRDY))); + } + /* Getting the OCR value seems to prevent marginal chips from */ + /* working at all, whereas they would work fine after waiting */ + /* a full minute or more with the power off prior to booting. */ + /* Our marginal chips have date codes 0716 and 0728. */ +#if 0 + for (i = 0; i < 1000; i++) { + /* Request OCR value to determine chip's supported volt. */ + ret = mmc_cmd(MMC_CMD_SEND_OP_COND, 0, resp, + R3 | NID | OPEN_DRAIN); + if (ret || (resp[0] & 0x80000000)) + { + break; + } + ret = -ETIMEDOUT; + } + if (ret) { + return ret; + } +#endif /* 0 */ + for (i = 0; i < 1000; i++) { ret = mmc_cmd(MMC_CMD_SEND_OP_COND, CFG_MMC_OP_COND, resp, R3 | NID | OPEN_DRAIN); if (ret || (resp[0] & 0x80000000)) @@ -399,13 +909,35 @@ } ret = -ETIMEDOUT; } + pr_debug("Step 4: ret = 0x%lx\n", ret); + pr_debug("MMC_CMD_SEND_OP_COND = 0x%lx\n", MMC_CMD_SEND_OP_COND); + pr_debug("CFG_MMC_OP_COND = 0x%lx\n", CFG_MMC_OP_COND); + pr_debug("resp[0] = 0x%lx\n", resp[0]); + pr_debug("resp[1] = 0x%lx\n", resp[1]); + pr_debug("resp[2] = 0x%lx\n", resp[2]); + pr_debug("resp[3] = 0x%lx\n", resp[3]); + pr_debug("R3 = 0x%lx\n", R3); + pr_debug("NID = 0x%lx\n", NID); + pr_debug("OPEN_DRAIN = 0x%lx\n", OPEN_DRAIN); + pr_debug("4\n"); pr_debug("ret : %i\n",ret); + + pr_debug("MCI_MR = 0x%08lx\n", mmci_readl(MR)); + pr_debug("MCI_DTOR = 0x%08lx\n", mmci_readl(DTOR)); + pr_debug("MCI_SDCR = 0x%08lx\n", mmci_readl(SDCR)); + pr_debug("MCI_ARGR = 0x%08lx\n", mmci_readl(ARGR)); + /* RSPR */ + /* RDR */ + pr_debug("MCI_SR = 0x%08lx\n", mmci_readl(SR)); + pr_debug("MCI_IMR = 0x%08lx\n", mmci_readl(IMR)); + if (ret) return ret; pr_debug("5\n"); /* Get CID of all cards. FIXME: Support more than one card */ ret = mmc_cmd(MMC_CMD_ALL_SEND_CID, 0, resp, R2 | NID | OPEN_DRAIN); + pr_debug("ALL_SEND_CID ret: 0x%08lx\n", ret); if (ret) return ret; mmc_parse_cid(cid, resp); @@ -415,6 +947,7 @@ /* Set Relative Address of the card that responded */ ret = mmc_cmd(MMC_CMD_SET_RELATIVE_ADDR, mmc_rca << 16, resp, R1 | NCR | OPEN_DRAIN); + pr_debug("SET_RELATIVE_ADDR ret: 0x%08lx\n", ret); return ret; }
@@ -471,23 +1004,42 @@ dtocyc << shift, dtor); }
+#define DEFAULT_SECTOR_SIZE 512 + int mmc_init(int verbose) { struct mmc_cid cid; struct mmc_csd csd; unsigned int max_blksz; int ret,aux; + unsigned char buffer[DEFAULT_SECTOR_SIZE]; + pr_debug("mmc_init: entry\n"); + pr_debug("mmc_init: verbose = 0x%08lx\n", verbose); + AT91F_MMC_Hardware_Init(); pr_debug("0\n"); /* Initialize controller */ mmci_writel(CR, MMCI_BIT(SWRST)); mmci_writel(CR, MMCI_BIT(MCIEN)); + + pr_debug("MCI_MR = 0x%08lx\n", mmci_readl(MR)); + pr_debug("MCI_DTOR = 0x%08lx\n", mmci_readl(DTOR)); + pr_debug("MCI_SDCR = 0x%08lx\n", mmci_readl(SDCR)); + pr_debug("MCI_ARGR = 0x%08lx\n", mmci_readl(ARGR)); + /* RSPR */ + /* RDR */ + pr_debug("MCI_SR = 0x%08lx\n", mmci_readl(SR)); + pr_debug("MCI_IMR = 0x%08lx\n", mmci_readl(IMR)); + mmci_writel(DTOR, 0x5f); mmci_writel(IDR, ~0UL); mmci_writel(SDCR, 0x1); mci_set_mode(CFG_MMC_CLK_OD, MMC_DEFAULT_BLKLEN); +#if 0 + mmci_writel(MR, 0x02009B4A); +#endif /* 0 */ /* //mmci_writel(CR, MMCI_BIT(SWRST)); mmci_writel(CR, 0x00000001); mmci_writel(DTOR, 0x0000007F); @@ -502,6 +1054,7 @@
ret = sd_init_card(&cid, verbose); if (ret) { + pr_debug("Not SDCard, try MMC\n"); mmc_rca = MMC_DEFAULT_RCA; ret = mmc_init_card(&cid, verbose); } @@ -545,6 +1098,20 @@ mci_set_mode(CFG_MMC_CLK_PP, mmc_blkdev.blksz);
#if 0 + mmc_bread(mmc_blkdev.dev, 1024, 1, (ulong *)buffer); + buffer[0] = 0x00; buffer[1] = 0x11; + buffer[2] = 0x22; buffer[3] = 0x33; + buffer[4] = 0x44; buffer[5] = 0x55; + buffer[6] = 0x66; buffer[7] = 0x77; + buffer[504] = 0x88; buffer[505] = 0x99; + buffer[506] = 0xaa; buffer[507] = 0xbb; + buffer[508] = 0xcc; buffer[509] = 0xdd; + buffer[510] = 0xee; buffer[511] = 0xff; + mmc_bwrite(mmc_blkdev.dev, 1024, 1, (ulong *)buffer); + mmc_bread(mmc_blkdev.dev, 1024, 1, (ulong *)buffer); +#endif /* 0 */ + +#if 0 if (fat_register_device(&mmc_blkdev, 1)) pr_debug("Could not register MMC fat device\n"); #else @@ -556,16 +1123,22 @@
int mmc_read(ulong src, uchar *dst, int size) { + pr_debug("mmc_read: entry\n"); + return -ENOSYS; }
int mmc_write(uchar *src, ulong dst, int size) { + pr_debug("mmc_write: entry\n"); + return -ENOSYS; }
int mmc2info(ulong addr) { + pr_debug("mmc2info: entry\n"); + return 0; }
svn diff -r21 include/asm-arm/arch-at91sam926x/mmc.h Index: include/asm-arm/arch-at91sam926x/mmc.h =================================================================== --- include/asm-arm/arch-at91sam926x/mmc.h (revision 0) +++ include/asm-arm/arch-at91sam926x/mmc.h (revision 50) @@ -0,0 +1,103 @@ +/* + * (C) Copyright 2007 + * Benchmark Electronics, Inc. + * Added MMC v4.x (MoviNAND) support + * + * Copyright (C) 2004-2006 Atmel Corporation + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_AT91SAM926X_MMC_H +#define __ASM_AT91SAM926X_MMC_H + +struct mmc_cid { + unsigned long psn; + unsigned short oid; + unsigned char mid; + unsigned char prv; + unsigned char mdt; + char pnm[7]; +}; + +struct mmc_csd +{ + u8 csd_structure:2, + spec_vers:4, + rsvd1:2; + u8 taac; + u8 nsac; + u8 tran_speed; + u16 ccc:12, + read_bl_len:4; + u64 read_bl_partial:1, + write_blk_misalign:1, + read_blk_misalign:1, + dsr_imp:1, + rsvd2:2, + c_size:12, + vdd_r_curr_min:3, + vdd_r_curr_max:3, + vdd_w_curr_min:3, + vdd_w_curr_max:3, + c_size_mult:3, + sector_size:5, + erase_grp_size:5, + wp_grp_size:5, + wp_grp_enable:1, + default_ecc:2, + r2w_factor:3, + write_bl_len:4, + write_bl_partial:1, + rsvd3:5; + u8 file_format_grp:1, + copy:1, + perm_write_protect:1, + tmp_write_protect:1, + file_format:2, + ecc:2; + u8 crc:7; + u8 one:1; +}; + +/* MMC Command numbers */ +#define MMC_CMD_GO_IDLE_STATE 0 +#define MMC_CMD_SEND_OP_COND 1 +#define MMC_CMD_ALL_SEND_CID 2 +#define MMC_CMD_SET_RELATIVE_ADDR 3 +#define MMC_CMD_SD_SEND_RELATIVE_ADDR 3 +#define MMC_CMD_SET_DSR 4 +#define MMC_CMD_SELECT_CARD 7 +#define MMC_CMD_SEND_CSD 9 +#define MMC_CMD_SEND_CID 10 +#define MMC_CMD_STOP_TRANSMISSION 12 +#define MMC_CMD_SEND_STATUS 13 +#define MMC_CMD_SET_BLOCKLEN 16 +#define MMC_CMD_READ_SINGLE_BLOCK 17 +#define MMC_CMD_READ_MULTIPLE_BLOCK 18 +#define MMC_CMD_SET_BLOCK_COUNT 23 +#define MMC_CMD_WRITE_BLOCK 24 +#define MMC_CMD_WRITE_MULTIPLE_BLOCK 25 +#define MMC_CMD_APP_CMD 55 + +#define MMC_ACMD_SD_SEND_OP_COND 41 + +#define R1_ILLEGAL_COMMAND (1 << 22) +#define R1_APP_CMD (1 << 5) + +#endif /* __ASM_AT91SAM926X_MMC_H */
svn diff -r21 include/configs/at91sam9261ek.h Index: include/configs/at91sam9261ek.h =================================================================== --- include/configs/at91sam9261ek.h (revision 21) +++ include/configs/at91sam9261ek.h (working copy) @@ -1,4 +1,8 @@ /* + * (C) Copyright 2007-2008 + * Benchmark Electronics, Inc. + * Added MMC v4.x (MoviNAND) support + * * (C) Copyright 2005 * M. Amine SAYA ATMEL Rousset, France. * @@ -95,18 +99,24 @@ /* SPI */ #define CONFIG_SPI
+/* kf - define hush (from busy box) command line interface & options */ +#define CFG_HUSH_PARSER +#define CFG_PROMPT_HUSH_PS2 "> " +#define CFG_AUTO_COMPLETE +#define CONFIG_CMDLINE_EDITING + #define CONFIG_COMMANDS \ ((CONFIG_CMD_DFL | \ CFG_CMD_NET | \ CFG_CMD_ENV | \ CFG_CMD_USB | \ CFG_CMD_FLASH | \ - CFG_CMD_NAND | \ + CFG_CMD_MMC | \ + CFG_CMD_EXT2 | \ + CFG_CMD_FAT | \ CFG_CMD_AUTOSCRIPT | \ - CFG_CMD_FAT | \ CFG_CMD_NFS | \ CFG_CMD_SPI | \ - CFG_CMD_U | \ CFG_CMD_IMI | \ CFG_CMD_PING ) & \ ~(CFG_CMD_BDI | \ @@ -296,8 +306,12 @@ #define CFG_FLASH_ERASE_TOUT (2*CFG_HZ) /* Timeout for Flash Erase */ #define CFG_FLASH_WRITE_TOUT (2*CFG_HZ) /* Timeout for Flash Write */
+#undef CFG_ENV_IS_IN_FLASH #define CFG_ENV_IS_IN_DATAFLASH 1 -#undef CFG_ENV_IS_IN_FLASH +#if 0 +#undef CFG_ENV_IS_IN_NAND +#endif /* 0 - kf */ +#undef CFG_ENV_IS_NOWHERE
#ifdef CFG_ENV_IS_IN_DATAFLASH #define CFG_ENV_OFFSET 0x4000 @@ -305,6 +319,10 @@ #define CFG_ENV_SIZE 0x4000 /* 0x8000 */ #endif
+#ifdef CFG_ENV_IS_NOWHERE +#define CFG_ENV_SIZE 0x4000 +#endif + #ifdef CFG_ENV_IS_IN_FLASH #ifdef CONFIG_BOOTBINFUNC #define CFG_ENV_ADDR (PHYS_FLASH_1 + 0x60000) /* after u-boot.bin */ @@ -316,6 +334,9 @@ #endif
/* Add LCD stuff */ +/* Ignore */ +/* Ignore */ + #if 0 /* No LCD */ #define CONFIG_LCD /* #undef CONFIG_LCD_LOGO */ @@ -333,8 +354,21 @@ #define CONFIG_DOS_PARTITION 1 #define LITTLEENDIAN 1
-#define CFG_LOAD_ADDR 0x23f00000 /* default load address */ +/* Add FAT filesystem configuration, other than CFG_CMD_FAT */ +#define CONFIG_SUPPORT_VFAT
+/* MMC */ +#define CONFIG_MMC 1 +#define MMCI_BASE 0xFFFA8000 /* (void *)AT91C_BASE_MCI */ +/* MMC - kf - slow down speed for debug from 20000000 Hz down to ... */ +/* However, tweaking this value here causes all code to be compiled, */ +/* so we shall change the value only where needed - in atmel_mci.c. */ +#define CFG_MMC_CLK_PP 20000000 + +#define CFG_LOAD_ADDR 0x23f00000 /* default load address */ + +#define CFG_BOOTM_LEN 0x02100000 /* 33MB uncompressed max. */ + #ifdef CONFIG_BOOTBINFUNC #define CFG_BOOT_SIZE 0x00 /* 0 KBytes */ #define CFG_U_BOOT_BASE PHYS_FLASH_1
svn diff -r21 board/at91sam9261ek/at91sam9261ek.c Index: board/at91sam9261ek/at91sam9261ek.c =================================================================== --- board/at91sam9261ek/at91sam9261ek.c (revision 21) +++ board/at91sam9261ek/at91sam9261ek.c (working copy) @@ -1,4 +1,8 @@ /* + * (C) Copyright 2007-2008 + * Benchmark Electronics, Inc. + * Added specific AT91SAM9261 board support + * * (C) Copyright 2005 * M. Amine SAYA ATMEL Rousset, France. * Added AT91SAM9261EK support. @@ -28,12 +32,19 @@
#include <common.h> #include <asm/arch/hardware.h> +#include <asm/arch-at91sam926x/at91sam9261.h>
#include <net.h>
extern void AT91F_Spi1Init (void); extern void gpio_init(void);
+/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + /* ------------------------------------------------------------------------ - */ /* * Miscelaneous platform dependent initialisations @@ -107,7 +118,8 @@ *AT91C_PMC_PCER |= 1 << AT91C_ID_US0; /* enable clock */ #endif
-#ifdef CONFIG_USART1 +#if 1 + /* #ifdef CONFIG_USART1 */ *AT91C_PIOB_PDR = AT91C_PC12_TXD1 | AT91C_PC13_RXD1; *AT91C_PMC_PCER |= 1 << AT91C_ID_US1; /* enable clock */ #endif @@ -118,6 +130,41 @@ #endif }
+#ifdef CONFIG_MMC +#if (CONFIG_COMMANDS & CFG_CMD_MMC) +int AT91F_MMC_Hardware_Init(void) +{ +#if 0 + printf("AT91F_MMC_Hardware_Init: entry\n"); +#endif /* 0 */ + + AT91F_PIO_CfgPeriph(AT91C_BASE_PIOA, + 0, /* <- Peripheral A */ + (AT91C_PA0_MCDA0 | /* MMC NAND MCDA0 */ + AT91C_PA1_MCCDA | /* MMC NAND MCCDA */ + AT91C_PA2_MCCK | /* MMC NAND MCCK */ + AT91C_PA4_MCDA1 | /* MMC NAND MCDA1 */ + AT91C_PA5_MCDA2 | /* MMC NAND MCDA2 */ + AT91C_PA6_MCDA3 | /* MMC NAND MCDA3 */ + 0)); /* <- Peripheral B */ + +#if 1 + /* Pull up disable register */ + AT91C_BASE_PIOA->PIO_PPUDR |= + AT91C_PA0_MCDA0 | /* MMC NAND MCDA0 */ + AT91C_PA1_MCCDA | /* MMC NAND MCCDA */ + AT91C_PA2_MCCK | /* MMC NAND MCCK */ + AT91C_PA4_MCDA1 | /* MMC NAND MCDA1 */ + AT91C_PA5_MCDA2 | /* MMC NAND MCDA2 */ + AT91C_PA6_MCDA3; /* MMC NAND MCDA3 */ +#endif /* 0 */ + + AT91C_BASE_PMC->PMC_PCER = (1 << AT91C_ID_MCI); +} +#endif /* CONFIG_COMMANDS & CFG_CMD_MMC */ +#endif /* CONFIG_MMC */ + + int dram_init (void) { DECLARE_GLOBAL_DATA_PTR; @@ -148,5 +195,35 @@
gpio_init();
+/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ +/* Ignore */ + return 0; }
hi folks,
I've come across a case on one of our PXA250 boards where the flash was getting corrupted when using the 1.3.2 version of cfi_flash.c, while the 1.2.0 version worked just fine.
Here's what happens:
1. Reprogram uboot. 2. Compare uboot in flash against uboot in DRAM. 3. Either run "reset" or press the reset button. 4. Compare the flash and DRAM, as well as a new copy of uboot re-read from CF for good measure.
At this point the low byte in the word at offset 0x554 has switched from a 0x30 to a 0x10. This is the only change in the flash. The new value is always the same.
I narrowed down the source of the problem to the loss of the volatile qualifier on the addr pointer in flash_write_cmd(). Adding the qualifier gets rid of the corruption. In the older 1.2.0 sources, addr was declared as "volatile cfiptr_t addr;".
Has anyone else seen this? It seems like the safe thing to do is to restore the qualifier in general.
Below is a diff, of the change for the 1.3.2. sources:
diff -u -r1.1.1.2.2.2 cfi_flash.c --- cfi_flash.c 23 Apr 2008 17:02:47 -0000 1.1.1.2.2.2 +++ cfi_flash.c 29 Apr 2008 18:55:47 -0000 @@ -464,7 +464,7 @@ uint offset, uchar cmd) {
- void *addr; + void *volatile addr; cfiword_t cword;
addr = flash_map (info, sect, offset);
Adrian -- Linux Software Engineer | EuroTech, Inc. | www.eurotech-inc.com
The volatile should not be needed - the CFI driver should use correct accessor macros instead. See Documentation/volatile-considered-harmful.txt in your Linux kernel source tree...
Sure, reducing the reliance on volatile is a good idea, but I'm at a loss for anything better to do.
I'm seeing a real problem that is only fixed by qualifying the container of the pointer as volatile, i.e. "void *volatile". "volatile void *" has no effect as expected given that the read/write accessors are used now.
The old data type was essentially "volatile void *volatile addr" and the new type is simply "void *addr". I seem to need at least "void *volatile addr" for things to work.
Note, I'm only seeing this problem on our PXA250 boards.
Adrian
Hi Adrian,
Please bottom post.
It may be useful to disassemble cfi_flash.o file (objdump -S) and see what the two different configurations of flash_write_cmd() get turned into in assembly.
Best regards, gvb
- void *addr;
- void *volatile addr;
That looks bogus. It makes the pointer itself volatile, not whatever it points to. All accesses through addr is performed by appropriate I/O accessors, so no volatile should be needed, and certainly not one that affects the pointer itself.
I suspect the change adds a few extra memory accesses (probably to the stack) so that any memory ordering problems just happen to go away.
flash_write_cmd() calls sync() after writing the command to the flash, so any memory ordering issues should have been taken care of. However, sync() does nothing on ARM. Maybe it should do something?
Haavard
Yeah, I agree it's bogus for the pointer to be volatile. There shouldn't be anything unusual about that.
The assembler does show several additional memory accesses, so I think your theory is right. I'm at a loss for what to to on the sync().
- void *addr;
Haavard
I'm at a loss too, I'm afraid...I don't really know PXA.
Linux seems to put an mb() after every write to the flash, so perhaps include/asm-arm/system.h on Linux can provide some hints?
In any case, sync() should probably expand to at least a compiler barrier on all architectures...though I'm not sure if it will make a difference in this particular case.
Haavard
Hi Ken, Thanks a lot for your patch. I will test it next week. Have you ever tested your U-Boot with 4GB or 8GB moviNAND? Thanks in advance
Pierre
-----Message d'origine----- De : u-boot-users-bounces@lists.sourceforge.net [mailto:u-boot-users-bounces@lists.sourceforge.net] De la part de Ken.Fuchs@bench.com Envoyé : mardi 29 avril 2008 21:46 À : pierre.savary@kerlink.fr Cc : u-boot-users@lists.sourceforge.net; afleming@freescale.com; abo@kerlink.fr; drzeus-mmc@drzeus.cx Objet : Re: [U-Boot-Users] drivers MMCplus for at91sam9x
Pierre
Sincerely,
Ken Fuchs
#include <net.h>
gpio_init();
------------------------------------------------------------------------- This SF.net email is sponsored by the 2008 JavaOne(SM) Conference Don't miss this year's exciting event. There's still time to save $100. Use priority code J8TL2D2. http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javao ne _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
participants (6)
Adrian Filipi
Haavard Skinnemoen
Jerry Van Baren
Ken.Fuchs@bench.com
Pierre Savary
