[U-Boot-Users] [PATCH 7/9] NAND update
Here is more of the changes made in include/
Note that the patch-series is broken unless it is seen as one single patch. It is broken up to multiple emails to fit the size limit.
We have set up a git repository were you can pull the complete patch: http://git.tandberg.com/tandberg/u-boot.git
Best regards William
------------------------------------------------- William Juul, Senior Development Engineer Data Respons Norge AS Sandviksveien 26 P.O. Box 489 NO-1323 Høvik, Norway
www.datarespons.no -------------------------------------------------
diff --git a/include/linux/mtd/nand.h b/include/linux/mtd/nand.h index 49ff80f..0c18dbe 100644 --- a/include/linux/mtd/nand.h +++ b/include/linux/mtd/nand.h @@ -2,114 +2,123 @@ * linux/include/linux/mtd/nand.h * * Copyright (c) 2000 David Woodhouse dwmw2@mvhi.com - * Steven J. Hill sjhill@realitydiluted.com + * Steven J. Hill sjhill@realitydiluted.com * Thomas Gleixner tglx@linutronix.de * - * $Id: nand.h,v 1.68 2004/11/12 10:40:37 gleixner Exp $ + * $Id: nand.h,v 1.74 2005/09/15 13:58:50 vwool Exp $ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. * - * Info: - * Contains standard defines and IDs for NAND flash devices + * Info: + * Contains standard defines and IDs for NAND flash devices * - * Changelog: - * 01-31-2000 DMW Created - * 09-18-2000 SJH Moved structure out of the Disk-On-Chip drivers - * so it can be used by other NAND flash device - * drivers. I also changed the copyright since none - * of the original contents of this file are specific - * to DoC devices. David can whack me with a baseball - * bat later if I did something naughty. - * 10-11-2000 SJH Added private NAND flash structure for driver - * 10-24-2000 SJH Added prototype for 'nand_scan' function - * 10-29-2001 TG changed nand_chip structure to support - * hardwarespecific function for accessing control lines - * 02-21-2002 TG added support for different read/write adress and - * ready/busy line access function - * 02-26-2002 TG added chip_delay to nand_chip structure to optimize - * command delay times for different chips - * 04-28-2002 TG OOB config defines moved from nand.c to avoid duplicate - * defines in jffs2/wbuf.c - * 08-07-2002 TG forced bad block location to byte 5 of OOB, even if - * CONFIG_MTD_NAND_ECC_JFFS2 is not set - * 08-10-2002 TG extensions to nand_chip structure to support HW-ECC - * - * 08-29-2002 tglx nand_chip structure: data_poi for selecting - * internal / fs-driver buffer - * support for 6byte/512byte hardware ECC - * read_ecc, write_ecc extended for different oob-layout - * oob layout selections: NAND_NONE_OOB, NAND_JFFS2_OOB, - * NAND_YAFFS_OOB - * 11-25-2002 tglx Added Manufacturer code FUJITSU, NATIONAL - * Split manufacturer and device ID structures - * - * 02-08-2004 tglx added option field to nand structure for chip anomalities - * 05-25-2004 tglx added bad block table support, ST-MICRO manufacturer id - * update of nand_chip structure description + * Changelog: + * See git changelog. */ #ifndef __LINUX_MTD_NAND_H #define __LINUX_MTD_NAND_H
-#include <linux/mtd/compat.h> +/* XXX U-BOOT XXX */ +#if 0 +#include <linux/wait.h> +#include <linux/spinlock.h> #include <linux/mtd/mtd.h> +#endif + +#include "config.h" + +#include "linux/mtd/compat.h" +#include "linux/mtd/mtd.h" +
struct mtd_info; /* Scan and identify a NAND device */ extern int nand_scan (struct mtd_info *mtd, int max_chips); +/* Separate phases of nand_scan(), allowing board driver to intervene + * and override command or ECC setup according to flash type */ +extern int nand_scan_ident(struct mtd_info *mtd, int max_chips); +extern int nand_scan_tail(struct mtd_info *mtd); + /* Free resources held by the NAND device */ extern void nand_release (struct mtd_info *mtd);
-/* Read raw data from the device without ECC */ -extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_t len, size_t ooblen); +/* Internal helper for board drivers which need to override command function */ +extern void nand_wait_ready(struct mtd_info *mtd);
+/* The maximum number of NAND chips in an array */ +#ifndef NAND_MAX_CHIPS +#define NAND_MAX_CHIPS 8 +#endif
/* This constant declares the max. oobsize / page, which * is supported now. If you add a chip with bigger oobsize/page * adjust this accordingly. */ -#define NAND_MAX_OOBSIZE 64 +#define NAND_MAX_OOBSIZE 128 +#define NAND_MAX_PAGESIZE 4096
/* * Constants for hardware specific CLE/ALE/NCE function -*/ + * + * These are bits which can be or'ed to set/clear multiple + * bits in one go. + */ /* Select the chip by setting nCE to low */ -#define NAND_CTL_SETNCE 1 -/* Deselect the chip by setting nCE to high */ -#define NAND_CTL_CLRNCE 2 +#define NAND_NCE 0x01 /* Select the command latch by setting CLE to high */ -#define NAND_CTL_SETCLE 3 -/* Deselect the command latch by setting CLE to low */ -#define NAND_CTL_CLRCLE 4 +#define NAND_CLE 0x02 /* Select the address latch by setting ALE to high */ -#define NAND_CTL_SETALE 5 -/* Deselect the address latch by setting ALE to low */ -#define NAND_CTL_CLRALE 6 -/* Set write protection by setting WP to high. Not used! */ -#define NAND_CTL_SETWP 7 -/* Clear write protection by setting WP to low. Not used! */ -#define NAND_CTL_CLRWP 8 +#define NAND_ALE 0x04 + +#define NAND_CTRL_CLE (NAND_NCE | NAND_CLE) +#define NAND_CTRL_ALE (NAND_NCE | NAND_ALE) +#define NAND_CTRL_CHANGE 0x80
/* * Standard NAND flash commands */ #define NAND_CMD_READ0 0 #define NAND_CMD_READ1 1 +#define NAND_CMD_RNDOUT 5 #define NAND_CMD_PAGEPROG 0x10 #define NAND_CMD_READOOB 0x50 #define NAND_CMD_ERASE1 0x60 #define NAND_CMD_STATUS 0x70 #define NAND_CMD_STATUS_MULTI 0x71 #define NAND_CMD_SEQIN 0x80 +#define NAND_CMD_RNDIN 0x85 #define NAND_CMD_READID 0x90 #define NAND_CMD_ERASE2 0xd0 #define NAND_CMD_RESET 0xff
/* Extended commands for large page devices */ #define NAND_CMD_READSTART 0x30 +#define NAND_CMD_RNDOUTSTART 0xE0 #define NAND_CMD_CACHEDPROG 0x15
+/* Extended commands for AG-AND device */ +/* + * Note: the command for NAND_CMD_DEPLETE1 is really 0x00 but + * there is no way to distinguish that from NAND_CMD_READ0 + * until the remaining sequence of commands has been completed + * so add a high order bit and mask it off in the command. + */ +#define NAND_CMD_DEPLETE1 0x100 +#define NAND_CMD_DEPLETE2 0x38 +#define NAND_CMD_STATUS_MULTI 0x71 +#define NAND_CMD_STATUS_ERROR 0x72 +/* multi-bank error status (banks 0-3) */ +#define NAND_CMD_STATUS_ERROR0 0x73 +#define NAND_CMD_STATUS_ERROR1 0x74 +#define NAND_CMD_STATUS_ERROR2 0x75 +#define NAND_CMD_STATUS_ERROR3 0x76 +#define NAND_CMD_STATUS_RESET 0x7f +#define NAND_CMD_STATUS_CLEAR 0xff + +#define NAND_CMD_NONE -1 + /* Status bits */ #define NAND_STATUS_FAIL 0x01 #define NAND_STATUS_FAIL_N1 0x02 @@ -120,25 +129,16 @@ extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_ /* * Constants for ECC_MODES */ - -/* No ECC. Usage is not recommended ! */ -#define NAND_ECC_NONE 0 -/* Software ECC 3 byte ECC per 256 Byte data */ -#define NAND_ECC_SOFT 1 -/* Hardware ECC 3 byte ECC per 256 Byte data */ -#define NAND_ECC_HW3_256 2 -/* Hardware ECC 3 byte ECC per 512 Byte data */ -#define NAND_ECC_HW3_512 3 -/* Hardware ECC 3 byte ECC per 512 Byte data */ -#define NAND_ECC_HW6_512 4 -/* Hardware ECC 8 byte ECC per 512 Byte data */ -#define NAND_ECC_HW8_512 6 -/* Hardware ECC 12 byte ECC per 2048 Byte data */ -#define NAND_ECC_HW12_2048 7 +typedef enum { + NAND_ECC_NONE, + NAND_ECC_SOFT, + NAND_ECC_HW, + NAND_ECC_HW_SYNDROME, +} nand_ecc_modes_t;
/* * Constants for Hardware ECC -*/ + */ /* Reset Hardware ECC for read */ #define NAND_ECC_READ 0 /* Reset Hardware ECC for write */ @@ -146,6 +146,10 @@ extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_ /* Enable Hardware ECC before syndrom is read back from flash */ #define NAND_ECC_READSYN 2
+/* Bit mask for flags passed to do_nand_read_ecc */ +#define NAND_GET_DEVICE 0x80 + + /* Option constants for bizarre disfunctionality and real * features */ @@ -165,6 +169,17 @@ extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_ /* Chip has a array of 4 pages which can be read without * additional ready /busy waits */ #define NAND_4PAGE_ARRAY 0x00000040 +/* Chip requires that BBT is periodically rewritten to prevent + * bits from adjacent blocks from 'leaking' in altering data. + * This happens with the Renesas AG-AND chips, possibly others. */ +#define BBT_AUTO_REFRESH 0x00000080 +/* Chip does not require ready check on read. True + * for all large page devices, as they do not support + * autoincrement.*/ +#define NAND_NO_READRDY 0x00000100 +/* Chip does not allow subpage writes */ +#define NAND_NO_SUBPAGE_WRITE 0x00000200 +
/* Options valid for Samsung large page devices */ #define NAND_SAMSUNG_LP_OPTIONS \ @@ -183,18 +198,18 @@ extern int nand_read_raw (struct mtd_info *mtd, uint8_t *buf, loff_t from, size_ /* Use a flash based bad block table. This option is passed to the * default bad block table function. */ #define NAND_USE_FLASH_BBT 0x00010000 -/* The hw ecc generator provides a syndrome instead a ecc value on read - * This can only work if we have the ecc bytes directly behind the - * data bytes. Applies for DOC and AG-AND Renesas HW Reed Solomon generators */ -#define NAND_HWECC_SYNDROME 0x00020000 - - +/* This option skips the bbt scan during initialization. */ +#define NAND_SKIP_BBTSCAN 0x00020000 +/* This option is defined if the board driver allocates its own buffers + (e.g. because it needs them DMA-coherent */ +#define NAND_OWN_BUFFERS 0x00040000 /* Options set by nand scan */ -/* Nand scan has allocated oob_buf */ -#define NAND_OOBBUF_ALLOC 0x40000000 -/* Nand scan has allocated data_buf */ -#define NAND_DATABUF_ALLOC 0x80000000 +/* Nand scan has allocated controller struct */ +#define NAND_CONTROLLER_ALLOC 0x80000000
+/* Cell info constants */ +#define NAND_CI_CHIPNR_MSK 0x03 +#define NAND_CI_CELLTYPE_MSK 0x0C
/* * nand_state_t - chip states @@ -207,135 +222,217 @@ typedef enum { FL_ERASING, FL_SYNCING, FL_CACHEDPRG, + FL_PM_SUSPENDED, } nand_state_t;
/* Keep gcc happy */ struct nand_chip;
-#if 0 /** - * struct nand_hw_control - Control structure for hardware controller (e.g ECC generator) shared among independend devices - * @lock: protection lock + * struct nand_hw_control - Control structure for hardware controller (e.g ECC generator) shared among independent devices + * @lock: protection lock * @active: the mtd device which holds the controller currently + * @wq: wait queue to sleep on if a NAND operation is in progress + * used instead of the per chip wait queue when a hw controller is available */ struct nand_hw_control { +/* XXX U-BOOT XXX */ +#if 0 spinlock_t lock; + wait_queue_head_t wq; +#endif struct nand_chip *active; }; -#endif + +/** + * struct nand_ecc_ctrl - Control structure for ecc + * @mode: ecc mode + * @steps: number of ecc steps per page + * @size: data bytes per ecc step + * @bytes: ecc bytes per step + * @total: total number of ecc bytes per page + * @prepad: padding information for syndrome based ecc generators + * @postpad: padding information for syndrome based ecc generators + * @layout: ECC layout control struct pointer + * @hwctl: function to control hardware ecc generator. Must only + * be provided if an hardware ECC is available + * @calculate: function for ecc calculation or readback from ecc hardware + * @correct: function for ecc correction, matching to ecc generator (sw/hw) + * @read_page_raw: function to read a raw page without ECC + * @write_page_raw: function to write a raw page without ECC + * @read_page: function to read a page according to the ecc generator requirements + * @write_page: function to write a page according to the ecc generator requirements + * @read_oob: function to read chip OOB data + * @write_oob: function to write chip OOB data + */ +struct nand_ecc_ctrl { + nand_ecc_modes_t mode; + int steps; + int size; + int bytes; + int total; + int prepad; + int postpad; + struct nand_ecclayout *layout; + void (*hwctl)(struct mtd_info *mtd, int mode); + int (*calculate)(struct mtd_info *mtd, + const uint8_t *dat, + uint8_t *ecc_code); + int (*correct)(struct mtd_info *mtd, uint8_t *dat, + uint8_t *read_ecc, + uint8_t *calc_ecc); + int (*read_page_raw)(struct mtd_info *mtd, + struct nand_chip *chip, + uint8_t *buf); + void (*write_page_raw)(struct mtd_info *mtd, + struct nand_chip *chip, + const uint8_t *buf); + int (*read_page)(struct mtd_info *mtd, + struct nand_chip *chip, + uint8_t *buf); + void (*write_page)(struct mtd_info *mtd, + struct nand_chip *chip, + const uint8_t *buf); + int (*read_oob)(struct mtd_info *mtd, + struct nand_chip *chip, + int page, + int sndcmd); + int (*write_oob)(struct mtd_info *mtd, + struct nand_chip *chip, + int page); +}; + +/** + * struct nand_buffers - buffer structure for read/write + * @ecccalc: buffer for calculated ecc + * @ecccode: buffer for ecc read from flash + * @databuf: buffer for data - dynamically sized + * + * Do not change the order of buffers. databuf and oobrbuf must be in + * consecutive order. + */ +struct nand_buffers { + uint8_t ecccalc[NAND_MAX_OOBSIZE]; + uint8_t ecccode[NAND_MAX_OOBSIZE]; + uint8_t databuf[NAND_MAX_PAGESIZE + NAND_MAX_OOBSIZE]; +};
/** * struct nand_chip - NAND Private Flash Chip Data * @IO_ADDR_R: [BOARDSPECIFIC] address to read the 8 I/O lines of the flash device * @IO_ADDR_W: [BOARDSPECIFIC] address to write the 8 I/O lines of the flash device * @read_byte: [REPLACEABLE] read one byte from the chip - * @write_byte: [REPLACEABLE] write one byte to the chip * @read_word: [REPLACEABLE] read one word from the chip - * @write_word: [REPLACEABLE] write one word to the chip * @write_buf: [REPLACEABLE] write data from the buffer to the chip * @read_buf: [REPLACEABLE] read data from the chip into the buffer * @verify_buf: [REPLACEABLE] verify buffer contents against the chip data * @select_chip: [REPLACEABLE] select chip nr * @block_bad: [REPLACEABLE] check, if the block is bad * @block_markbad: [REPLACEABLE] mark the block bad - * @hwcontrol: [BOARDSPECIFIC] hardwarespecific function for accesing control-lines + * @cmd_ctrl: [BOARDSPECIFIC] hardwarespecific funtion for controlling + * ALE/CLE/nCE. Also used to write command and address * @dev_ready: [BOARDSPECIFIC] hardwarespecific function for accesing device ready/busy line * If set to NULL no access to ready/busy is available and the ready/busy information * is read from the chip status register * @cmdfunc: [REPLACEABLE] hardwarespecific function for writing commands to the chip * @waitfunc: [REPLACEABLE] hardwarespecific function for wait on ready - * @calculate_ecc: [REPLACEABLE] function for ecc calculation or readback from ecc hardware - * @correct_data: [REPLACEABLE] function for ecc correction, matching to ecc generator (sw/hw) - * @enable_hwecc: [BOARDSPECIFIC] function to enable (reset) hardware ecc generator. Must only - * be provided if a hardware ECC is available + * @ecc: [BOARDSPECIFIC] ecc control ctructure + * @buffers: buffer structure for read/write + * @hwcontrol: platform-specific hardware control structure + * @ops: oob operation operands * @erase_cmd: [INTERN] erase command write function, selectable due to AND support * @scan_bbt: [REPLACEABLE] function to scan bad block table - * @eccmode: [BOARDSPECIFIC] mode of ecc, see defines - * @eccsize: [INTERN] databytes used per ecc-calculation - * @eccbytes: [INTERN] number of ecc bytes per ecc-calculation step - * @eccsteps: [INTERN] number of ecc calculation steps per page * @chip_delay: [BOARDSPECIFIC] chip dependent delay for transfering data from array to read regs (tR) - * @chip_lock: [INTERN] spinlock used to protect access to this structure and the chip * @wq: [INTERN] wait queue to sleep on if a NAND operation is in progress * @state: [INTERN] the current state of the NAND device + * @oob_poi: poison value buffer * @page_shift: [INTERN] number of address bits in a page (column address bits) * @phys_erase_shift: [INTERN] number of address bits in a physical eraseblock * @bbt_erase_shift: [INTERN] number of address bits in a bbt entry * @chip_shift: [INTERN] number of address bits in one chip - * @data_buf: [INTERN] internal buffer for one page + oob - * @oob_buf: [INTERN] oob buffer for one eraseblock + * @datbuf: [INTERN] internal buffer for one page + oob + * @oobbuf: [INTERN] oob buffer for one eraseblock * @oobdirty: [INTERN] indicates that oob_buf must be reinitialized * @data_poi: [INTERN] pointer to a data buffer * @options: [BOARDSPECIFIC] various chip options. They can partly be set to inform nand_scan about * special functionality. See the defines for further explanation * @badblockpos: [INTERN] position of the bad block marker in the oob area + * @cellinfo: [INTERN] MLC/multichip data from chip ident * @numchips: [INTERN] number of physical chips * @chipsize: [INTERN] the size of one chip for multichip arrays * @pagemask: [INTERN] page number mask = number of (pages / chip) - 1 * @pagebuf: [INTERN] holds the pagenumber which is currently in data_buf - * @autooob: [REPLACEABLE] the default (auto)placement scheme + * @subpagesize: [INTERN] holds the subpagesize + * @ecclayout: [REPLACEABLE] the default ecc placement scheme * @bbt: [INTERN] bad block table pointer * @bbt_td: [REPLACEABLE] bad block table descriptor for flash lookup * @bbt_md: [REPLACEABLE] bad block table mirror descriptor * @badblock_pattern: [REPLACEABLE] bad block scan pattern used for initial bad block scan - * @controller: [OPTIONAL] a pointer to a hardware controller structure which is shared among multiple independend devices + * @controller: [REPLACEABLE] a pointer to a hardware controller structure + * which is shared among multiple independend devices * @priv: [OPTIONAL] pointer to private chip date + * @errstat: [OPTIONAL] hardware specific function to perform additional error status checks + * (determine if errors are correctable) + * @write_page: [REPLACEABLE] High-level page write function */
struct nand_chip { void __iomem *IO_ADDR_R; void __iomem *IO_ADDR_W;
- u_char (*read_byte)(struct mtd_info *mtd); - void (*write_byte)(struct mtd_info *mtd, u_char byte); + uint8_t (*read_byte)(struct mtd_info *mtd); u16 (*read_word)(struct mtd_info *mtd); - void (*write_word)(struct mtd_info *mtd, u16 word); - - void (*write_buf)(struct mtd_info *mtd, const u_char *buf, int len); - void (*read_buf)(struct mtd_info *mtd, u_char *buf, int len); - int (*verify_buf)(struct mtd_info *mtd, const u_char *buf, int len); + void (*write_buf)(struct mtd_info *mtd, const uint8_t *buf, int len); + void (*read_buf)(struct mtd_info *mtd, uint8_t *buf, int len); + int (*verify_buf)(struct mtd_info *mtd, const uint8_t *buf, int len); void (*select_chip)(struct mtd_info *mtd, int chip); int (*block_bad)(struct mtd_info *mtd, loff_t ofs, int getchip); int (*block_markbad)(struct mtd_info *mtd, loff_t ofs); - void (*hwcontrol)(struct mtd_info *mtd, int cmd); + void (*cmd_ctrl)(struct mtd_info *mtd, int dat, + unsigned int ctrl); int (*dev_ready)(struct mtd_info *mtd); void (*cmdfunc)(struct mtd_info *mtd, unsigned command, int column, int page_addr); - int (*waitfunc)(struct mtd_info *mtd, struct nand_chip *this, int state); - int (*calculate_ecc)(struct mtd_info *mtd, const u_char *dat, u_char *ecc_code); - int (*correct_data)(struct mtd_info *mtd, u_char *dat, u_char *read_ecc, u_char *calc_ecc); - void (*enable_hwecc)(struct mtd_info *mtd, int mode); + int (*waitfunc)(struct mtd_info *mtd, struct nand_chip *this); void (*erase_cmd)(struct mtd_info *mtd, int page); int (*scan_bbt)(struct mtd_info *mtd); - int eccmode; - int eccsize; - int eccbytes; - int eccsteps; + int (*errstat)(struct mtd_info *mtd, struct nand_chip *this, int state, int status, int page); + int (*write_page)(struct mtd_info *mtd, struct nand_chip *chip, + const uint8_t *buf, int page, int cached, int raw); + int chip_delay; -#if 0 - spinlock_t chip_lock; - wait_queue_head_t wq; - nand_state_t state; -#endif + unsigned int options; + int page_shift; int phys_erase_shift; int bbt_erase_shift; int chip_shift; - u_char *data_buf; - u_char *oob_buf; - int oobdirty; - u_char *data_poi; - unsigned int options; - int badblockpos; int numchips; unsigned long chipsize; int pagemask; int pagebuf; - struct nand_oobinfo *autooob; + int subpagesize; + uint8_t cellinfo; + int badblockpos; + + nand_state_t state; + + uint8_t *oob_poi; + struct nand_hw_control *controller; + struct nand_ecclayout *ecclayout; + + struct nand_ecc_ctrl ecc; + struct nand_buffers *buffers; + + struct nand_hw_control hwcontrol; + + struct mtd_oob_ops ops; + uint8_t *bbt; struct nand_bbt_descr *bbt_td; struct nand_bbt_descr *bbt_md; + struct nand_bbt_descr *badblock_pattern; - struct nand_hw_control *controller; + void *priv; };
@@ -348,11 +445,11 @@ struct nand_chip { #define NAND_MFR_NATIONAL 0x8f #define NAND_MFR_RENESAS 0x07 #define NAND_MFR_STMICRO 0x20 +#define NAND_MFR_HYNIX 0xad #define NAND_MFR_MICRON 0x2c
/** * struct nand_flash_dev - NAND Flash Device ID Structure - * * @name: Identify the device type * @id: device ID code * @pagesize: Pagesize in bytes. Either 256 or 512 or 0 @@ -399,7 +496,7 @@ extern struct nand_manufacturers nand_manuf_ids[]; * blocks is reserved at the end of the device where the tables are * written. * @reserved_block_code: if non-0, this pattern denotes a reserved (rather than - * bad) block in the stored bbt + * bad) block in the stored bbt * @pattern: pattern to identify bad block table or factory marked good / * bad blocks, can be NULL, if len = 0 * @@ -413,11 +510,11 @@ struct nand_bbt_descr { int pages[NAND_MAX_CHIPS]; int offs; int veroffs; - uint8_t version[NAND_MAX_CHIPS]; + uint8_t version[NAND_MAX_CHIPS]; int len; int maxblocks; int reserved_block_code; - uint8_t *pattern; + uint8_t *pattern; };
/* Options for the bad block table descriptors */ @@ -429,7 +526,7 @@ struct nand_bbt_descr { #define NAND_BBT_4BIT 0x00000004 #define NAND_BBT_8BIT 0x00000008 /* The bad block table is in the last good block of the device */ -#define NAND_BBT_LASTBLOCK 0x00000010 +#define NAND_BBT_LASTBLOCK 0x00000010 /* The bbt is at the given page, else we must scan for the bbt */ #define NAND_BBT_ABSPAGE 0x00000020 /* The bbt is at the given page, else we must scan for the bbt */ @@ -452,13 +549,16 @@ struct nand_bbt_descr { #define NAND_BBT_SCAN2NDPAGE 0x00004000
/* The maximum number of blocks to scan for a bbt */ -#define NAND_BBT_SCAN_MAXBLOCKS 4 +#define NAND_BBT_SCAN_MAXBLOCKS 4
-extern int nand_scan_bbt (struct mtd_info *mtd, struct nand_bbt_descr *bd); -extern int nand_update_bbt (struct mtd_info *mtd, loff_t offs); -extern int nand_default_bbt (struct mtd_info *mtd); -extern int nand_isbad_bbt (struct mtd_info *mtd, loff_t offs, int allowbbt); -extern int nand_erase_nand (struct mtd_info *mtd, struct erase_info *instr, int allowbbt); +extern int nand_scan_bbt(struct mtd_info *mtd, struct nand_bbt_descr *bd); +extern int nand_update_bbt(struct mtd_info *mtd, loff_t offs); +extern int nand_default_bbt(struct mtd_info *mtd); +extern int nand_isbad_bbt(struct mtd_info *mtd, loff_t offs, int allowbbt); +extern int nand_erase_nand(struct mtd_info *mtd, struct erase_info *instr, + int allowbbt); +extern int nand_do_read(struct mtd_info *mtd, loff_t from, size_t len, + size_t * retlen, uint8_t * buf);
/* * Constants for oob configuration @@ -466,4 +566,67 @@ extern int nand_erase_nand (struct mtd_info *mtd, struct erase_info *instr, int #define NAND_SMALL_BADBLOCK_POS 5 #define NAND_LARGE_BADBLOCK_POS 0
+/** + * struct platform_nand_chip - chip level device structure + * @nr_chips: max. number of chips to scan for + * @chip_offset: chip number offset + * @nr_partitions: number of partitions pointed to by partitions (or zero) + * @partitions: mtd partition list + * @chip_delay: R/B delay value in us + * @options: Option flags, e.g. 16bit buswidth + * @ecclayout: ecc layout info structure + * @part_probe_types: NULL-terminated array of probe types + * @priv: hardware controller specific settings + */ +struct platform_nand_chip { + int nr_chips; + int chip_offset; + int nr_partitions; + struct mtd_partition *partitions; + struct nand_ecclayout *ecclayout; + int chip_delay; + unsigned int options; + const char **part_probe_types; + void *priv; +}; + +/** + * struct platform_nand_ctrl - controller level device structure + * @hwcontrol: platform specific hardware control structure + * @dev_ready: platform specific function to read ready/busy pin + * @select_chip: platform specific chip select function + * @cmd_ctrl: platform specific function for controlling + * ALE/CLE/nCE. Also used to write command and address + * @priv: private data to transport driver specific settings + * + * All fields are optional and depend on the hardware driver requirements + */ +struct platform_nand_ctrl { + void (*hwcontrol)(struct mtd_info *mtd, int cmd); + int (*dev_ready)(struct mtd_info *mtd); + void (*select_chip)(struct mtd_info *mtd, int chip); + void (*cmd_ctrl)(struct mtd_info *mtd, int dat, + unsigned int ctrl); + void *priv; +}; + +/** + * struct platform_nand_data - container structure for platform-specific data + * @chip: chip level chip structure + * @ctrl: controller level device structure + */ +struct platform_nand_data { + struct platform_nand_chip chip; + struct platform_nand_ctrl ctrl; +}; + +/* Some helpers to access the data structures */ +static inline +struct platform_nand_chip *get_platform_nandchip(struct mtd_info *mtd) +{ + struct nand_chip *chip = mtd->priv; + + return chip->priv; +} + #endif /* __LINUX_MTD_NAND_H */
William Juul
