[U-Boot] [PATCH v2] wdt: Update uclass to make clear that the timeout is in ms
From: Andy Shevchenko andriy.shevchenko@linux.intel.com
Convert name to show explicitly that we are using milliseconds. For a watchdog timer this is precise enough.
No functional change intended.
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com Signed-off-by: Simon Glass sjg@chromium.org ---
Changes in v2: - Use milliseconds since microseconds seems too fine a control - Update commit message to suit
drivers/watchdog/wdt-uclass.c | 4 ++-- include/wdt.h | 8 ++++---- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/watchdog/wdt-uclass.c b/drivers/watchdog/wdt-uclass.c index bb9ae80866..8a30f024fd 100644 --- a/drivers/watchdog/wdt-uclass.c +++ b/drivers/watchdog/wdt-uclass.c @@ -13,14 +13,14 @@
DECLARE_GLOBAL_DATA_PTR;
-int wdt_start(struct udevice *dev, u64 timeout, ulong flags) +int wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags) { const struct wdt_ops *ops = device_get_ops(dev);
if (!ops->start) return -ENOSYS;
- return ops->start(dev, timeout, flags); + return ops->start(dev, timeout_ms, flags); }
int wdt_stop(struct udevice *dev) diff --git a/include/wdt.h b/include/wdt.h index 0b5f05851a..9b90fbeeb3 100644 --- a/include/wdt.h +++ b/include/wdt.h @@ -21,12 +21,12 @@ * Start the timer * * @dev: WDT Device - * @timeout: Number of ticks before timer expires + * @timeout_ms: Number of ticks (milliseconds) before timer expires * @flags: Driver specific flags. This might be used to specify * which action needs to be executed when the timer expires * @return: 0 if OK, -ve on error */ -int wdt_start(struct udevice *dev, u64 timeout, ulong flags); +int wdt_start(struct udevice *dev, u64 timeout_ms, ulong flags);
/* * Stop the timer, thus disabling the Watchdog. Use wdt_start to start it again. @@ -67,12 +67,12 @@ struct wdt_ops { * Start the timer * * @dev: WDT Device - * @timeout: Number of ticks before the timer expires + * @timeout_ms: Number of ticks (milliseconds) before the timer expires * @flags: Driver specific flags. This might be used to specify * which action needs to be executed when the timer expires * @return: 0 if OK, -ve on error */ - int (*start)(struct udevice *dev, u64 timeout, ulong flags); + int (*start)(struct udevice *dev, u64 timeout_ms, ulong flags); /* * Stop the timer *
Changes in v2:
- return ops->start(dev, timeout_ms, flags);
- Start the timer
- @dev: WDT Device
- @timeout: Number of ticks before timer expires
- @timeout_ms: Number of ticks (milliseconds) before timer expires
Should this not just be ‘number of milliseconds’ (as this would otherwise equate ticks and milliseconds, which don’t necessarily need to be the same)?
- @flags: Driver specific flags. This might be used to specify
- which action needs to be executed when the timer expires
- @return: 0 if OK, -ve on error
- Stop the timer, thus disabling the Watchdog. Use wdt_start to start it again.
See above.
- int (*start)(struct udevice *dev, u64 timeout_ms, ulong flags); /*
- Stop the timer
-- 2.14.0.rc1.383.gd1ce394fe2-goog
+Tom
Hi Philipp,
On 4 August 2017 at 16:21, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
Changes in v2:
- Start the timer
- @dev: WDT Device
Iarily
I believe they are the same. We used to have a setting for it (CONFIG_SYS_HZ I think) but now everything is in milliseconds. See for example get_timer().
See above.
On 05 Aug 2017, at 00:30, Simon Glass sjg@chromium.org wrote:
+Tom
Hi Philipp,
Changes in v2:
- Start the timer
- @dev: WDT Device
I had thought of my remark more as a nitpick. Bit it seems there’s more to it, after all: at least lib/time.c still treats ’ticks’ and ‘milliseconds' as separate concepts:
uint64_t __weak notrace get_ticks(void) { unsigned long now = timer_read_counter();
/* increment tbu if tbl has rolled over */ if (now < gd->timebase_l) gd->timebase_h++; gd->timebase_l = now; return ((uint64_t)gd->timebase_h << 32) | gd->timebase_l; }
/* Returns time in milliseconds */ static uint64_t notrace tick_to_time(uint64_t tick) { ulong div = get_tbclk();
tick *= CONFIG_SYS_HZ; do_div(tick, div); return tick; }
See above.
/* * Stop the timer *int (*start)(struct udevice *dev, u64 timeout_ms, ulong flags);
On 4 August 2017 at 16:37, Dr. Philipp Tomsich philipp.tomsich@theobroma-systems.com wrote:
+Tom
Hi Philipp,
Changes in v2:
- Start the timer
- @dev: WDT Device
But see lib/Kconfig:
config SYS_HZ int default 1000 help The frequency of the timer returned by get_timer(). get_timer() must operate in milliseconds and this option must be set to 1000.
See above.
Changes in v2:
Changes in v2:
- Start the timer
- @dev: WDT Device
These are not the same and this is definitely a functional change. The length of a single tick depends on frequency of the clock that feeds WDT. It might not be the same as 1/SYS_HZ. For example ast_wdt driver uses 1MHz clock, so this parameter means microseconds for it.
Hi Maxim,
Changes in v2:
- Start the timer
- @dev: WDT Device
OK I see. Then the current code is doubly confusing, because ticks has a certain meaning in U-Boot and we cannot have the WDT using a different meaning.
This patch changes / clarifies the API to indicate that the time is in ms. Can we update existing drivers to honour that?
-- Maxim Sloyko
Signed-off-by: Andy Shevchenko andriy.shevchenko@linux.intel.com Signed-off-by: Simon Glass sjg@chromium.org Reviewed-by: Bin Meng bmeng.cn@gmail.com
participants (5)
Bin Meng
Dr. Philipp Tomsich
Maxim Sloyko
