[U-Boot] [PATCH v2 0/3] libfdt: fix bugs
This series fixes bugs of libfdt.
These functions were added by Thierry for U-boot only. So, we do not send it back to the DTC ML.
Masahiro Yamada (3): libfdt: fix description of fdt_get_string() libfdt: fix error code of fdt_get_string_index() libfdt: fix error code of fdt_count_strings()
include/libfdt.h | 2 +- lib/libfdt/fdt_ro.c | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
Looks like this comment was copied from that of fdt_get_string_index().
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Fixes: 5094eb408a5d ("fdt: Add functions to retrieve strings") ---
Changes in v2: None
include/libfdt.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/libfdt.h b/include/libfdt.h index f3cbb63..421d64f 100644 --- a/include/libfdt.h +++ b/include/libfdt.h @@ -915,7 +915,7 @@ int fdt_get_string_index(const void *fdt, int node, const char *property, int index, const char **output);
/** - * fdt_get_string() - obtain the string at a given index in a string list + * fdt_get_string() - obtain the first string in a string list * @fdt: pointer to the device tree blob * @node: offset of the node * @property: name of the property containing the string list
On 14 July 2015 at 10:08, Masahiro Yamada yamada.masahiro@socionext.com wrote:
Changes in v2: None
Changes in v2: None
Applied to u-boot-fdt, thanks!
As mentioned in the comment block in include/libfdt.h, fdt_get_string_index() is supposed to return a negative value on error.
Changes in v2: - minor fix in git-log (drop "commit") - return code -> error code
lib/libfdt/fdt_ro.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 44fc0aa..38bfcbd 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -577,7 +577,7 @@ int fdt_get_string_index(const void *fdt, int node, const char *property, index--; }
- return FDT_ERR_NOTFOUND; + return -FDT_ERR_NOTFOUND; }
int fdt_get_string(const void *fdt, int node, const char *property,
Changes in v2:
Changes in v2:
Currently, this function returns a positive value on error, so we never know whether this function has succeeded or failed.
For example, if the given property is not found, fdt_getprop() returns -FDT_ERR_NOTFOUND, and then this function inverts it, i.e., returns FDT_ERR_NOTFOUND (=1).
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com Fixes: bc4147ab2d69 ("fdt: Add a function to count strings") ---
Changes in v2: None
diff --git a/lib/libfdt/fdt_ro.c b/lib/libfdt/fdt_ro.c index 38bfcbd..7b0777b 100644 --- a/lib/libfdt/fdt_ro.c +++ b/lib/libfdt/fdt_ro.c @@ -517,7 +517,7 @@ int fdt_count_strings(const void *fdt, int node, const char *property)
list = fdt_getprop(fdt, node, property, &length); if (!list) - return -length; + return length;
for (i = 0; i < length; i++) { int len = strlen(list);
Changes in v2: None
return -length;
return length; for (i = 0; i < length; i++) { int len = strlen(list);
-- 1.9.1
Changes in v2: None
return -length;
-- 1.9.1
If they're not part of upstream dtc, why are they in the libfdt directory? Have they been sent upstream but not merged?
-Scott
Hi Scott,
-Scott
To avoid roadblocks we take patches in libfdt before they are merged upstream. I then tidy things up when I see them applied. So sometimes we are a little ahead of libfdt for a while. It works out OK since we need to sync with upstream regularly anyway.
On Sat, 2015-07-18 at 08:36 -0600, Simon Glass wrote:
Hi Scott,
-Scott
That's fine, but from what Masahiro said, it sounded like there was no intent to ever push these to upstream dtc.
-Scott
+Thierry
Hi Scott,
Hi Scott,
-Scott
I think it as just forgotten. Thierry sent it a few days ago and it looks promising so far.
Masahiro Yamada
Scott Wood
