[PATCH v5 0/6] doc: board: toradex reST documentation
This patch-series adds/converts existing README files for Toradex modules to reStructureFormat.
To verify please run: $ make htmldocs
v5: - Fixed markup for headers [Bin Meng] - Applied R-b tag for colibri_imx7.rst [Bin Beng]
v4: - Removed blank lines from EOF in some readme files [Heinrich Schuchardt] - Adjust MAINTAINERS, add entries for newly created docs
v3: - Fixed Colibri iMX7 image adjustments section [Max Krummenacher] - Changed hierarchy of documents and moved to doc/board/toradex [Bin Meng] - Fixed some typos ('%s/U-boot/U-Boot/g') [Bin Meng]
v2: - Converted to reStructuredText format [Bin Meng]
Igor Opaniuk (6): doc: board: toradex: add colibri_imx7.rst doc: board: verdin-imx8mm: convert readme to reST doc: board: apalis-imx8: convert readme to reST doc: board: colibri-imx8x: convert readme to reST toradex: MAINTAINERS: entries for new reST docs doc: board: add rockchip subfolder
board/toradex/apalis-imx8/MAINTAINERS | 1 + board/toradex/apalis-imx8/README | 66 ------------ board/toradex/colibri-imx8x/MAINTAINERS | 1 + board/toradex/colibri-imx8x/README | 66 ------------ board/toradex/colibri_imx7/MAINTAINERS | 1 + board/toradex/verdin-imx8mm/MAINTAINERS | 1 + board/toradex/verdin-imx8mm/README | 88 ---------------- doc/board/index.rst | 2 + doc/board/toradex/apalix-imx8.rst | 82 +++++++++++++++ doc/board/toradex/colibri-imx8x.rst | 82 +++++++++++++++ doc/board/toradex/colibri_imx7.rst | 127 ++++++++++++++++++++++++ doc/board/toradex/index.rst | 12 +++ doc/board/toradex/verdin-imx8mm.rst | 112 +++++++++++++++++++++ 13 files changed, 421 insertions(+), 220 deletions(-) delete mode 100644 board/toradex/apalis-imx8/README delete mode 100644 board/toradex/colibri-imx8x/README delete mode 100644 board/toradex/verdin-imx8mm/README create mode 100644 doc/board/toradex/apalix-imx8.rst create mode 100644 doc/board/toradex/colibri-imx8x.rst create mode 100644 doc/board/toradex/colibri_imx7.rst create mode 100644 doc/board/toradex/index.rst create mode 100644 doc/board/toradex/verdin-imx8mm.rst
- add initial index for toradex boards reST documentation - add initial colibri_imx7.rst doc file which provides all needed information for obtaining a workable image ready for flashing for both eMMC/NAND versions of Colibri iMX7.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
doc/board/index.rst | 1 + doc/board/toradex/colibri_imx7.rst | 127 +++++++++++++++++++++++++++++ doc/board/toradex/index.rst | 9 ++ 3 files changed, 137 insertions(+) create mode 100644 doc/board/toradex/colibri_imx7.rst create mode 100644 doc/board/toradex/index.rst
diff --git a/doc/board/index.rst b/doc/board/index.rst index 00e72f57cd..f2f5907b8c 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -15,4 +15,5 @@ Board-specific doc intel/index renesas/index sifive/index + toradex/index xilinx/index diff --git a/doc/board/toradex/colibri_imx7.rst b/doc/board/toradex/colibri_imx7.rst new file mode 100644 index 0000000000..0c7ae082d0 --- /dev/null +++ b/doc/board/toradex/colibri_imx7.rst @@ -0,0 +1,127 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Colibri iMX7 +============ + +Quick Start +----------- + +- Build U-Boot +- NAND IMX image adjustments before flashing +- Flashing manually U-Boot to eMMC +- Flashing manually U-Boot to NAND +- Using ``update_uboot`` script + +Build U-Boot +------------ + +.. code-block:: bash + + $ export CROSS_COMPILE=arm-linux-gnueabi- + $ export ARCH=arm + $ make colibri_imx7_emmc_defconfig # For NAND: colibri_imx7_defconfig + $ make + +After build succeeds, you will obtain final ``u-boot-dtb.imx`` IMX specific +image, ready for flashing (but check next section for additional +adjustments). + +Final IMX program image includes (section ``6.6.7`` from `IMX7DRM +https://www.nxp.com/webapp/Download?colCode=IMX7DRM`_): + +* **Image vector table** (IVT) for BootROM +* **Boot data** -indicates the program image location, program image size + in bytes, and the plugin flag. +* **Device configuration data** +* **User image**: U-Boot image (``u-boot-dtb.bin``) + + +IMX image adjustments prior to flashing +-------------------------------------------- + +1. U-Boot for both Colibri iMX7 NAND and eMMC versions +is built with HABv4 support (`AN4581.pdf +https://www.nxp.com/docs/en/application-note/AN4581.pdf`_) +enabled by default, which requires to generate a proper +Command Sequence File (CSF) by srktool from NXP (not included in the +U-Boot tree, check additional details in introduction_habv4.txt) +and concatenate it to the final ``u-boot-dtb.imx``. + +2. In case if you don't want to generate a proper ``CSF`` (for any reason), +you still need to pad the IMX image so i has the same size as specified in +in **Boot Data** section of IMX image. +To obtain this value, run: + +.. code-block:: bash + + $ od -X -N 0x30 u-boot-dtb.imx + 0000000 402000d1 87800000 00000000 877ff42c + 0000020 877ff420 877ff400 878a5000 00000000 + ^^^^^^^^ + 0000040 877ff000 000a8060 00000000 40b401d2 + ^^^^^^^^ ^^^^^^^^ + +Where: + +* ``877ff400`` - IVT self address +* ``877ff000`` - Program image address +* ``000a8060`` - Program image size + +To calculate the padding: + +* IVT offset = ``0x877ff400`` - ``0x877ff000`` = ``0x400`` +* Program image size = ``0xa8060`` - ``0x400`` = ``0xa7c60`` + +and then pad the image: + +.. code-block:: bash + + $ objcopy -I binary -O binary --pad-to 0xa7c60 --gap-fill=0x00 \ + u-boot-dtb.imx u-boot-dtb.imx.zero-padded + +3. Also, according to requirement from ``6.6.7.1``, the final image +should have ``0x400`` offset for initial IVT table. + +For eMMC setup we handle this by flashing it to ``0x400``, howewer +for NAND setup we adjust the image prior to flashing, adding padding in the +beginning of the image. + +.. code-block:: bash + + $ dd if=u-boot-dtb.imx.zero-padded of=u-boot-dtb.imx.ready bs=1024 seek=1 + +Flash U-Boot IMX image to eMMC +------------------------------ + +Flash the ``u-boot-dtb.imx.zero-padded`` binary to the primary eMMC hardware +boot area partition: + +.. code-block:: bash + + + => load mmc 1:1 $loadaddr u-boot-dtb.imx.zero-padded + => setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 + => mmc dev 0 1 + => mmc write ${loadaddr} 0x2 ${blkcnt} + +Flash U-Boot IMX image to NAND +------------------------------ + +.. code-block:: bash + + => load mmc 1:1 $loadaddr u-boot-dtb.imx.ready + => nand erase.part u-boot1 + => nand write ${loadaddr} u-boot1 ${filesize} + => nand erase.part u-boot2 + => nand write ${loadaddr} u-boot2 ${filesize} + +Using update_uboot script +------------------------- + +You can also usb U-Boot env update_uboot script, +which wraps all eMMC/NAND specific command invocation: + +.. code-block:: bash + + => load mmc 1:1 $loadaddr u-boot-dtb.imx.ready + => run update_uboot diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst new file mode 100644 index 0000000000..aa418d6bad --- /dev/null +++ b/doc/board/toradex/index.rst @@ -0,0 +1,9 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Toradex +======= + +.. toctree:: + :maxdepth: 2 + + colibri_imx7
Reviewed-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com
- toradex/index xilinx/index
- $ export CROSS_COMPILE=arm-linux-gnueabi-
- $ export ARCH=arm
- $ make colibri_imx7_emmc_defconfig # For NAND: colibri_imx7_defconfig
- $ make
- in bytes, and the plugin flag.
- $ od -X -N 0x30 u-boot-dtb.imx
- 0000000 402000d1 87800000 00000000 877ff42c
- 0000020 877ff420 877ff400 878a5000 00000000
- 0000040 877ff000 000a8060 00000000 40b401d2
+Where:
- $ objcopy -I binary -O binary --pad-to 0xa7c60 --gap-fill=0x00 \
- $ dd if=u-boot-dtb.imx.zero-padded of=u-boot-dtb.imx.ready bs=1024 seek=1
- => load mmc 1:1 $loadaddr u-boot-dtb.imx.zero-padded
- => setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
- => mmc dev 0 1
- => mmc write ${loadaddr} 0x2 ${blkcnt}
- => load mmc 1:1 $loadaddr u-boot-dtb.imx.ready
- => nand erase.part u-boot1
- => nand write ${loadaddr} u-boot1 ${filesize}
- => nand erase.part u-boot2
- => nand write ${loadaddr} u-boot2 ${filesize}
- => run update_uboot
+Toradex +=======
+.. toctree::
- :maxdepth: 2
- colibri_imx7
-- 2.17.1
- $ export ARCH=arm
- $ make
nits: title underline length should match the title
Will fix the nits when applying.
Tested the doc build, no warnings Tested-by: Bin Meng bmeng.cn@gmail.com
Convert README to reStructuredText format.
board/toradex/verdin-imx8mm/README | 88 ---------------------- doc/board/toradex/index.rst | 1 + doc/board/toradex/verdin-imx8mm.rst | 112 ++++++++++++++++++++++++++++ 3 files changed, 113 insertions(+), 88 deletions(-) delete mode 100644 board/toradex/verdin-imx8mm/README create mode 100644 doc/board/toradex/verdin-imx8mm.rst
diff --git a/board/toradex/verdin-imx8mm/README b/board/toradex/verdin-imx8mm/README deleted file mode 100644 index 1dac969476..0000000000 --- a/board/toradex/verdin-imx8mm/README +++ /dev/null @@ -1,88 +0,0 @@ -U-Boot for the Toradex Verdin iMX8M Mini Module - -Quick Start -=========== - -- Build the ARM trusted firmware binary -- Get the DDR firmware -- Build U-Boot -- Flash to eMMC -- Boot - -Get and Build the ARM Trusted Firmware (Trusted Firmware A) -=========================================================== - -$ echo "Downloading and building TF-A..." -$ git clone -b imx_4.14.98_2.3.0 https://source.codeaurora.org/external/imx/imx-atf -$ cd imx-atf - -Please edit `plat/imx/imx8mm/include/platform_def.h` so it contains proper -values for UART configuration and BL31 base address (correct values listed -below): -#define BL31_BASE 0x910000 -#define IMX_BOOT_UART_BASE 0x30860000 -#define DEBUG_CONSOLE 1 - -Then build ATF (TF-A): -$ make PLAT=imx8mm bl31 - -Get the DDR Firmware -==================== - -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.4.1.bin -$ chmod +x firmware-imx-8.4.1.bin -$ ./firmware-imx-8.4.1.bin -$ cp firmware-imx-8.4.1/firmware/ddr/synopsys/lpddr4*.bin ./ - -Build U-Boot -============ - -$ export CROSS_COMPILE=aarch64-linux-gnu- -$ make verdin-imx8mm_defconfig -$ make flash.bin - -Flash to eMMC -============= - -> tftpboot ${loadaddr} flash.bin -> setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 -> mmc dev 0 1 && mmc write ${loadaddr} 0x2 ${blkcnt} - -As a convenience, instead of the last two commands one may also use the update -U-Boot wrapper: -> run update_uboot - -Boot -==== - -ATF, U-boot proper and u-boot.dtb images are packed into FIT image, -which is loaded and parsed by SPL. - -Boot sequence is: -SPL ---> ATF (TF-A) ---> U-boot proper - -Output: -U-Boot SPL 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100) -Normal Boot -Trying to boot from MMC1 -NOTICE: Configuring TZASC380 -NOTICE: RDC off -NOTICE: BL31: v2.0(release):rel_imx_4.14.98_2.3.0-0-g09c5cc994-dirty -NOTICE: BL31: Built : 01:11:41, Jan 25 2020 -NOTICE: sip svc init - - -U-Boot 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100) - -CPU: Freescale i.MX8MMQ rev1.0 at 0 MHz -Reset cause: POR -DRAM: 2 GiB -MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 -Loading Environment from MMC... OK -In: serial -Out: serial -Err: serial -Model: Toradex Verdin iMX8M Mini Quad 2GB Wi-Fi / BT IT V1.0A, Serial# 06535149 -Net: eth0: ethernet@30be0000 -Hit any key to stop autoboot: 0 -Verdin iMX8MM # diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index aa418d6bad..6cd2ade9f4 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -7,3 +7,4 @@ Toradex :maxdepth: 2
colibri_imx7 + verdin-imx8mm diff --git a/doc/board/toradex/verdin-imx8mm.rst b/doc/board/toradex/verdin-imx8mm.rst new file mode 100644 index 0000000000..4ed16fce34 --- /dev/null +++ b/doc/board/toradex/verdin-imx8mm.rst @@ -0,0 +1,112 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Verdin iMX8M Mini Module +======================== + +Quick Start +----------- + +- Build the ARM trusted firmware binary +- Get the DDR firmware +- Build U-Boot +- Flash to eMMC +- Boot + +Get and Build the ARM Trusted Firmware (Trusted Firmware A) +----------------------------------------------------------- + +.. code-block:: bash + + $ echo "Downloading and building TF-A..." + $ git clone -b imx_4.14.98_2.3.0 \ + https://source.codeaurora.org/external/imx/imx-atf + $ cd imx-atf + +Please edit ``plat/imx/imx8mm/include/platform_def.h`` so it contains proper +values for UART configuration and BL31 base address (correct values listed +below): + +.. code-block:: bash + + #define BL31_BASE 0x910000 + #define IMX_BOOT_UART_BASE 0x30860000 + #define DEBUG_CONSOLE 1 + +Then build ATF (TF-A): + +.. code-block:: bash + + $ make PLAT=imx8mm bl31 + +Get the DDR Firmware +-------------------- + +.. code-block:: bash + + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.4.1.bin + $ chmod +x firmware-imx-8.4.1.bin + $ ./firmware-imx-8.4.1.bin + $ cp firmware-imx-8.4.1/firmware/ddr/synopsys/lpddr4*.bin ./ + +Build U-Boot +------------ +.. code-block:: bash + + $ export CROSS_COMPILE=aarch64-linux-gnu- + $ make verdin-imx8mm_defconfig + $ make flash.bin + +Flash to eMMC +------------- + +.. code-block:: bash + + > tftpboot ${loadaddr} flash.bin + > setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 + > mmc dev 0 1 && mmc write ${loadaddr} 0x2 ${blkcnt} + +As a convenience, instead of the last two commands one may also use the update +U-Boot wrapper: + +.. code-block:: bash + + > run update_uboot + +Boot +---- + +ATF, U-boot proper and u-boot.dtb images are packed into FIT image, +which is loaded and parsed by SPL. + +Boot sequence is: + +* SPL ---> ATF (TF-A) ---> U-boot proper + +Output: + +.. code-block:: bash + + U-Boot SPL 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100) + Normal Boot + Trying to boot from MMC1 + NOTICE: Configuring TZASC380 + NOTICE: RDC off + NOTICE: BL31: v2.0(release):rel_imx_4.14.98_2.3.0-0-g09c5cc994-dirty + NOTICE: BL31: Built : 01:11:41, Jan 25 2020 + NOTICE: sip svc init + + + U-Boot 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100) + + CPU: Freescale i.MX8MMQ rev1.0 at 0 MHz + Reset cause: POR + DRAM: 2 GiB + MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 + Loading Environment from MMC... OK + In: serial + Out: serial + Err: serial + Model: Toradex Verdin iMX8M Mini Quad 2GB Wi-Fi / BT IT V1.0A, Serial: + Net: eth0: ethernet@30be0000 + Hit any key to stop autoboot: 0 + Verdin iMX8MM #
-Quick Start
-Build U-Boot
-Flash to eMMC
-Boot
colibri_imx7
- verdin-imx8mm
- $ echo "Downloading and building TF-A..."
- $ git clone -b imx_4.14.98_2.3.0 \
- $ cd imx-atf
- #define BL31_BASE 0x910000
- #define IMX_BOOT_UART_BASE 0x30860000
- #define DEBUG_CONSOLE 1
- $ make PLAT=imx8mm bl31
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.4.1.bin
- $ chmod +x firmware-imx-8.4.1.bin
- $ ./firmware-imx-8.4.1.bin
- $ cp firmware-imx-8.4.1/firmware/ddr/synopsys/lpddr4*.bin ./
- $ export CROSS_COMPILE=aarch64-linux-gnu-
- $ make verdin-imx8mm_defconfig
- $ make flash.bin
tftpboot ${loadaddr} flash.bin setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 mmc dev 0 1 && mmc write ${loadaddr} 0x2 ${blkcnt}+As a convenience, instead of the last two commands one may also use the update +U-Boot wrapper:
run update_uboot+Boot +----
+Boot sequence is:
+Output:
- U-Boot SPL 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100)
- Normal Boot
- Trying to boot from MMC1
- NOTICE: Configuring TZASC380
- NOTICE: RDC off
- NOTICE: BL31: v2.0(release):rel_imx_4.14.98_2.3.0-0-g09c5cc994-dirty
- NOTICE: BL31: Built : 01:11:41, Jan 25 2020
- NOTICE: sip svc init
- U-Boot 2020.01-00187-gd411d164e5 (Jan 26 2020 - 04:47:26 +0100)
- CPU: Freescale i.MX8MMQ rev1.0 at 0 MHz
- Reset cause: POR
- DRAM: 2 GiB
- MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
- Loading Environment from MMC... OK
- In: serial
- Out: serial
- Err: serial
- Model: Toradex Verdin iMX8M Mini Quad 2GB Wi-Fi / BT IT V1.0A, Serial:
- Net: eth0: ethernet@30be0000
- Hit any key to stop autoboot: 0
- Verdin iMX8MM #
-- 2.17.1
-Quick Start
-Build U-Boot
-Flash to eMMC
-Boot
nits: U-Boot
nits: U-Boot
-Output:
board/toradex/apalis-imx8/README | 66 ------------------------- doc/board/toradex/apalix-imx8.rst | 82 +++++++++++++++++++++++++++++++ doc/board/toradex/index.rst | 1 + 3 files changed, 83 insertions(+), 66 deletions(-) delete mode 100644 board/toradex/apalis-imx8/README create mode 100644 doc/board/toradex/apalix-imx8.rst
diff --git a/board/toradex/apalis-imx8/README b/board/toradex/apalis-imx8/README deleted file mode 100644 index e6e3dcb367..0000000000 --- a/board/toradex/apalis-imx8/README +++ /dev/null @@ -1,66 +0,0 @@ -U-Boot for the Toradex Apalis iMX8QM V1.0B Module - -Quick Start -=========== - -- Build the ARM trusted firmware binary -- Get scfw_tcm.bin and ahab-container.img -- Build U-Boot -- Load U-Boot binary using uuu -- Flash U-Boot binary into the eMMC -- Boot - -Get and Build the ARM Trusted Firmware -====================================== - -$ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf -$ cd imx-atf/ -$ make PLAT=imx8qm bl31 - -Get scfw_tcm.bin and ahab-container.img -======================================= - -$ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1.... -$ mv mx8qm-apalis-scfw-tcm.bin?raw=true mx8qm-apalis-scfw-tcm.bin -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin -$ chmod +x firmware-imx-8.0.bin -$ ./firmware-imx-8.0.bin - -Copy the following binaries to the U-Boot folder: - -$ cp imx-atf/build/imx8qm/release/bl31.bin . -$ cp u-boot/u-boot.bin . - -Copy the following firmware to the U-Boot folder: - -$ cp firmware-imx-8.0/firmware/seco/ahab-container.img . - -Build U-Boot -============ - -$ make apalis-imx8qm_defconfig -$ make u-boot-dtb.imx - -Load the U-Boot Binary Using UUU -================================ - -Get the latest version of the universal update utility (uuu) aka mfgtools 3.0: - -https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... - -Put the module into USB recovery aka serial downloader mode, connect USB device -to your host and execute uuu: - -sudo ./uuu u-boot/u-boot-dtb.imx - -Flash the U-Boot Binary into the eMMC -===================================== - -Burn the u-boot-dtb.imx binary to the primary eMMC hardware boot area partition: - -load mmc 1:1 $loadaddr u-boot-dtb.imx -setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 -mmc dev 0 1 -mmc write ${loadaddr} 0x0 ${blkcnt} - -Boot diff --git a/doc/board/toradex/apalix-imx8.rst b/doc/board/toradex/apalix-imx8.rst new file mode 100644 index 0000000000..4b7ea65d31 --- /dev/null +++ b/doc/board/toradex/apalix-imx8.rst @@ -0,0 +1,82 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Apalis iMX8QM V1.0B Module +========================== + +Quick Start +----------- + +- Build the ARM trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Build U-Boot +- Load U-Boot binary using uuu +- Flash U-Boot binary into the eMMC +- Boot + +Get and Build the ARM Trusted Firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf + $ cd imx-atf/ + $ make PLAT=imx8qm bl31 + +Get scfw_tcm.bin and ahab-container.img +--------------------------------------- + +.. code-block:: bash + + $ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1.... + bsp/imx-sc-firmware/files/mx8qm-apalis-scfw-tcm.bin?raw=true + $ mv mx8qm-apalis-scfw-tcm.bin?raw=true mx8qm-apalis-scfw-tcm.bin + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin + $ chmod +x firmware-imx-8.0.bin + $ ./firmware-imx-8.0.bin + +Copy the following binaries to the U-Boot folder: + +.. code-block:: bash + + $ cp imx-atf/build/imx8qm/release/bl31.bin . + $ cp u-boot/u-boot.bin . + +Copy the following firmware to the U-Boot folder: + +.. code-block:: bash + + $ cp firmware-imx-8.0/firmware/seco/ahab-container.img . + +Build U-Boot +------------ +.. code-block:: bash + + $ make apalis-imx8qm_defconfig + $ make u-boot-dtb.imx + +Load the U-Boot Binary Using UUU +-------------------------------- + +Get the latest version of the universal update utility (uuu) aka ``mfgtools 3.0``: + +https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... + +Put the module into USB recovery aka serial downloader mode, connect USB device +to your host and execute uuu: + +.. code-block:: bash + + sudo ./uuu u-boot/u-boot-dtb.imx + +Flash the U-Boot Binary into the eMMC +------------------------------------- + +Burn the ``u-boot-dtb.imx`` binary to the primary eMMC hardware boot area +partition and boot: + +.. code-block:: bash + + load mmc 1:1 $loadaddr u-boot-dtb.imx + setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 + mmc dev 0 1 + mmc write ${loadaddr} 0x0 ${blkcnt} diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index 6cd2ade9f4..da65ad2408 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -6,5 +6,6 @@ Toradex .. toctree:: :maxdepth: 2
+ apalix-imx8 colibri_imx7 verdin-imx8mm
-Quick Start
-Build U-Boot
- $ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf
- $ cd imx-atf/
- $ make PLAT=imx8qm bl31
- $ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1....
- $ mv mx8qm-apalis-scfw-tcm.bin?raw=true mx8qm-apalis-scfw-tcm.bin
- $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin
- $ chmod +x firmware-imx-8.0.bin
- $ ./firmware-imx-8.0.bin
- $ cp imx-atf/build/imx8qm/release/bl31.bin .
- $ cp u-boot/u-boot.bin .
- $ cp firmware-imx-8.0/firmware/seco/ahab-container.img .
- $ make apalis-imx8qm_defconfig
- $ make u-boot-dtb.imx
- sudo ./uuu u-boot/u-boot-dtb.imx
- load mmc 1:1 $loadaddr u-boot-dtb.imx
- setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
- mmc dev 0 1
- mmc write ${loadaddr} 0x0 ${blkcnt}
- apalix-imx8 colibri_imx7 verdin-imx8mm
-- 2.17.1
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
board/toradex/colibri-imx8x/README | 66 ----------------------- doc/board/toradex/colibri-imx8x.rst | 82 +++++++++++++++++++++++++++++ doc/board/toradex/index.rst | 1 + 3 files changed, 83 insertions(+), 66 deletions(-) delete mode 100644 board/toradex/colibri-imx8x/README create mode 100644 doc/board/toradex/colibri-imx8x.rst
diff --git a/board/toradex/colibri-imx8x/README b/board/toradex/colibri-imx8x/README deleted file mode 100644 index 708bb3e51c..0000000000 --- a/board/toradex/colibri-imx8x/README +++ /dev/null @@ -1,66 +0,0 @@ -U-Boot for the Toradex Colibri iMX8QXP V1.0B Module - -Quick Start -=========== - -- Build the ARM trusted firmware binary -- Get scfw_tcm.bin and ahab-container.img -- Build U-Boot -- Load U-Boot binary using uuu -- Flash U-Boot binary into the eMMC -- Boot - -Get and Build the ARM Trusted Firmware -====================================== - -$ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf -$ cd imx-atf/ -$ make PLAT=imx8qxp bl31 - -Get scfw_tcm.bin and ahab-container.img -======================================= - -$ wget https://github.com/toradex/meta-fsl-bsp-release/blob/toradex-sumo-4.14.78-1.... -$ mv mx8qx-colibri-scfw-tcm.bin?raw=true mx8qx-colibri-scfw-tcm.bin -$ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin -$ chmod +x firmware-imx-8.0.bin -$ ./firmware-imx-8.0.bin - -Copy the following binaries to the U-Boot folder: - -$ cp imx-atf/build/imx8qxp/release/bl31.bin . -$ cp u-boot/u-boot.bin . - -Copy the following firmware to the U-Boot folder: - -$ cp firmware-imx-8.0/firmware/seco/ahab-container.img . - -Build U-Boot -============ - -$ make colibri-imx8qxp_defconfig -$ make u-boot-dtb.imx - -Load the U-Boot Binary Using UUU -================================ - -Get the latest version of the universal update utility (uuu) aka mfgtools 3.0: - -https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... - -Put the module into USB recovery aka serial downloader mode, connect USB device -to your host and execute uuu: - -sudo ./uuu u-boot/u-boot-dtb.imx - -Flash the U-Boot Binary into the eMMC -===================================== - -Burn the u-boot-dtb.imx binary to the primary eMMC hardware boot area partition: - -load mmc 1:1 $loadaddr u-boot-dtb.imx -setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 -mmc dev 0 1 -mmc write ${loadaddr} 0x0 ${blkcnt} - -Boot diff --git a/doc/board/toradex/colibri-imx8x.rst b/doc/board/toradex/colibri-imx8x.rst new file mode 100644 index 0000000000..244e5a4c04 --- /dev/null +++ b/doc/board/toradex/colibri-imx8x.rst @@ -0,0 +1,82 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +Colibri iMX8QXP V1.0B Module +============================ + +Quick Start +----------- + +- Build the ARM trusted firmware binary +- Get scfw_tcm.bin and ahab-container.img +- Build U-Boot +- Load U-Boot binary using uuu +- Flash U-Boot binary into the eMMC +- Boot + +Get and Build the ARM Trusted Firmware +-------------------------------------- + +.. code-block:: bash + + $ git clone -b imx_4.14.78_1.0.0_ga https://source.codeaurora.org/external/imx/imx-atf + $ cd imx-atf/ + $ make PLAT=imx8qxp bl31 + +Get scfw_tcm.bin and ahab-container.img +--------------------------------------- +.. code-block:: bash + + $ wget https://github.com/toradex/meta-fsl-bsp-release/blob/ + toradex-sumo-4.14.78-1.0.0_ga-bringup/imx/meta-bsp/recipes- + bsp/imx-sc-firmware/files/mx8qx-colibri-scfw-tcm.bin?raw=true + $ mv mx8qx-colibri-scfw-tcm.bin?raw=true mx8qx-colibri-scfw-tcm.bin + $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/firmware-imx-8.0.bin + $ chmod +x firmware-imx-8.0.bin + $ ./firmware-imx-8.0.bin + +Copy the following binaries to the U-Boot folder: + +.. code-block:: bash + + $ cp imx-atf/build/imx8qxp/release/bl31.bin . + $ cp u-boot/u-boot.bin . + +Copy the following firmware to the U-Boot folder: + +.. code-block:: bash + + $ cp firmware-imx-8.0/firmware/seco/ahab-container.img . + +Build U-Boot +------------ + +.. code-block:: bash + + $ make colibri-imx8qxp_defconfig + $ make u-boot-dtb.imx + +Load the U-Boot Binary Using UUU +-------------------------------- + +Get the latest version of the universal update utility (uuu) aka ``mfgtools 3.0``: + +https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... + +Put the module into USB recovery aka serial downloader mode, connect USB device +to your host and execute ``uuu``: + +.. code-block:: bash + + sudo ./uuu u-boot/u-boot-dtb.imx + +Flash the U-Boot Binary into the eMMC +------------------------------------- + +Burn the ``u-boot-dtb.imx`` binary to the primary eMMC hardware boot area partition: + +.. code-block:: bash + + load mmc 1:1 $loadaddr u-boot-dtb.imx + setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 + mmc dev 0 1 + mmc write ${loadaddr} 0x0 ${blkcnt} diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index da65ad2408..16b5a0770d 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -8,4 +8,5 @@ Toradex
apalix-imx8 colibri_imx7 + colibri-imx8x verdin-imx8mm
-Quick Start
-Build U-Boot
- $ cd imx-atf/
- $ make PLAT=imx8qxp bl31
- $ mv mx8qx-colibri-scfw-tcm.bin?raw=true mx8qx-colibri-scfw-tcm.bin
- $ cp imx-atf/build/imx8qxp/release/bl31.bin .
- $ make colibri-imx8qxp_defconfig
- mmc dev 0 1
- colibri-imx8x verdin-imx8mm
-- 2.17.1
-- Best regards Oleksandr Suvorov
Toradex AG Altsagenstrasse 5 | 6048 Horw/Luzern | Switzerland | T: +41 41 500 4800 (main line)
Add entries for the newly created documentation files in reST format.
board/toradex/apalis-imx8/MAINTAINERS | 1 + board/toradex/colibri-imx8x/MAINTAINERS | 1 + board/toradex/colibri_imx7/MAINTAINERS | 1 + board/toradex/verdin-imx8mm/MAINTAINERS | 1 + 4 files changed, 4 insertions(+)
diff --git a/board/toradex/apalis-imx8/MAINTAINERS b/board/toradex/apalis-imx8/MAINTAINERS index c9ac58b47b..feacf7eded 100644 --- a/board/toradex/apalis-imx8/MAINTAINERS +++ b/board/toradex/apalis-imx8/MAINTAINERS @@ -6,4 +6,5 @@ F: arch/arm/dts/fsl-imx8-apalis.dts F: arch/arm/dts/fsl-imx8-apalis-u-boot.dtsi F: board/toradex/apalis-imx8/ F: configs/apalis-imx8qm_defconfig +F: doc/board/toradex/apalix-imx8.rst F: include/configs/apalis-imx8.h diff --git a/board/toradex/colibri-imx8x/MAINTAINERS b/board/toradex/colibri-imx8x/MAINTAINERS index e91b9975c2..f6853586c8 100644 --- a/board/toradex/colibri-imx8x/MAINTAINERS +++ b/board/toradex/colibri-imx8x/MAINTAINERS @@ -6,4 +6,5 @@ F: arch/arm/dts/fsl-imx8x-colibri.dts F: arch/arm/dts/fsl-imx8x-colibri-u-boot.dtsi F: board/toradex/colibri-imx8x/ F: configs/colibri-imx8qxp_defconfig +F: doc/board/toradex/colibri-imx8x.rst F: include/configs/colibri-imx8x.h diff --git a/board/toradex/colibri_imx7/MAINTAINERS b/board/toradex/colibri_imx7/MAINTAINERS index 178dece797..82246be160 100644 --- a/board/toradex/colibri_imx7/MAINTAINERS +++ b/board/toradex/colibri_imx7/MAINTAINERS @@ -4,6 +4,7 @@ W: http://developer.toradex.com/software/linux/linux-software W: https://www.toradex.com/community S: Maintained F: board/toradex/colibri_imx7/ +F: doc/board/toradex/colibri_imx7.rst F: include/configs/colibri_imx7.h F: configs/colibri_imx7_defconfig F: configs/colibri_imx7_emmc_defconfig diff --git a/board/toradex/verdin-imx8mm/MAINTAINERS b/board/toradex/verdin-imx8mm/MAINTAINERS index 3b4fae5c66..2495696e9d 100644 --- a/board/toradex/verdin-imx8mm/MAINTAINERS +++ b/board/toradex/verdin-imx8mm/MAINTAINERS @@ -6,4 +6,5 @@ F: arch/arm/dts/imx8mm-verdin.dts F: arch/arm/dts/imx8mm-verdin-u-boot.dtsi F: board/toradex/verdin-imx8mm/ F: configs/verdin-imx8mm_defconfig +F: doc/board/toradex/verdin-imx8mm.rst F: include/configs/verdin-imx8mm.h
This fixes a warning when invoking make htmldocs: checking consistency... doc/board/rockchip/index.rst: WARNING: document isn't included in any toctree
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de ---
doc/board/index.rst | 1 + 1 file changed, 1 insertion(+)
diff --git a/doc/board/index.rst b/doc/board/index.rst index f2f5907b8c..f061e8ecfc 100644 --- a/doc/board/index.rst +++ b/doc/board/index.rst @@ -14,6 +14,7 @@ Board-specific doc google/index intel/index renesas/index + rockchip/index sifive/index toradex/index xilinx/index
- rockchip/index sifive/index toradex/index xilinx/index
-- 2.17.1
This patch does not apply as there is one already in the mainline. Heinrich did the same below, but not sure how he gave a RB tag to this one as well :)
Will drop this patch.
commit 7d92204bc0eb0a775810f887838a93a218a22f96 Author: Heinrich Schuchardt xypron.glpk@gmx.de Date: Fri Feb 7 21:25:09 2020 +0100
doc: board: add Rockchip to doc/board/index.rst
Fix a build error
Regards, Bin
v5:
This was assigned to me on patchwork, so
series applied to u-boot-x86, thanks!
Bin Meng
Igor Opaniuk
Oleksandr Suvorov
