Re: [PATCH v7 2/8] drivers: clk: add fu740 support
(resending to the list after subscribing)
On Thu, Apr 22, 2021 at 10:15 AM Green Wan green.wan@sifive.com wrote:
Add fu740 support. One abstract layer is added for supporting multiple chips such as fu540 and fu740.
Signed-off-by: Green Wan green.wan@sifive.com
drivers/clk/sifive/Kconfig | 8 +- drivers/clk/sifive/Makefile | 4 +- drivers/clk/sifive/fu540-prci.c | 769 +------------------------------ drivers/clk/sifive/fu540-prci.h | 22 + drivers/clk/sifive/fu740-prci.c | 158 +++++++ drivers/clk/sifive/fu740-prci.h | 22 + drivers/clk/sifive/sifive-prci.c | 733 +++++++++++++++++++++++++++++ drivers/clk/sifive/sifive-prci.h | 323 +++++++++++++ 8 files changed, 1286 insertions(+), 753 deletions(-) create mode 100644 drivers/clk/sifive/fu540-prci.h create mode 100644 drivers/clk/sifive/fu740-prci.c create mode 100644 drivers/clk/sifive/fu740-prci.h create mode 100644 drivers/clk/sifive/sifive-prci.c create mode 100644 drivers/clk/sifive/sifive-prci.h
diff --git a/drivers/clk/sifive/Kconfig b/drivers/clk/sifive/Kconfig index c4d0a1f9b1..20fc004b59 100644 --- a/drivers/clk/sifive/Kconfig +++ b/drivers/clk/sifive/Kconfig @@ -6,11 +6,11 @@ config CLK_SIFIVE help SoC drivers for SiFive Linux-capable SoCs.
-config CLK_SIFIVE_FU540_PRCI
bool "PRCI driver for SiFive FU540 SoCs"
+config CLK_SIFIVE_PRCI
bool "PRCI driver for SiFive SoCs" depends on CLK_SIFIVE
Since the above is done in this patch, I would expect to remove all references to the CLK_SIFIVE_FU540_PRCI config option at the same time. Specifically:
$ git grep CLK_SIFIVE_FU540_PRCI arch/riscv/cpu/fu540/Kconfig: imply CLK_SIFIVE_FU540_PRCI drivers/reset/Kconfig: depends on DM_RESET && CLK_SIFIVE_FU540_PRCI && TARGET_SIFIVE_UNLEASHED
If above references were fixed, it remove the need to manually add "CONFIG_CLK_SIFIVE_PRCI=y" to unleashed config in the "board: sifive: add HiFive Unmatched board support" patch.
Leaving left over references to the removed config options is confusing, and makes the patch not self contained.
select CLK_ANALOGBITS_WRPLL_CLN28HPC help Supports the Power Reset Clock interface (PRCI) IP block found in
FU540 SoCs. If this kernel is meant to run on a SiFive FU540 SoC,
enable this driver.
FU540/FU740 SoCs. If this kernel is meant to run on a SiFive FU540/
FU740 SoCs, enable this driver.
diff --git a/drivers/clk/sifive/Makefile b/drivers/clk/sifive/Makefile index b224279afb..51348b1ddc 100644 --- a/drivers/clk/sifive/Makefile +++ b/drivers/clk/sifive/Makefile @@ -1,3 +1,5 @@ # SPDX-License-Identifier: GPL-2.0+
-obj-$(CONFIG_CLK_SIFIVE_FU540_PRCI) += fu540-prci.o +obj-y += sifive-prci.o
+obj-$(CONFIG_CLK_SIFIVE_PRCI) += fu540-prci.o fu740-prci.o diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index b3882d0b77..ceb2c6fab0 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -5,6 +5,8 @@
- Copyright (C) 2018 SiFive, Inc.
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License version 2 as
@@ -15,632 +17,48 @@
- The FU540 PRCI implements clock and reset control for the SiFive
- FU540-C000 chip. This driver assumes that it has sole control
- over all PRCI resources.
- This driver is based on the PRCI driver written by Wesley Terpstra.
- Refer, commit 999529edf517ed75b56659d456d221b2ee56bb60 of:
- References:
- SiFive FU540-C000 manual v1p0, Chapter 7 "Clocking and Reset"
-#include <common.h> -#include <clk-uclass.h> -#include <clk.h> -#include <div64.h> -#include <dm.h> -#include <dm/device.h> -#include <dm/device_compat.h> -#include <dm/uclass.h> #include <dt-bindings/clock/sifive-fu540-prci.h> -#include <dt-bindings/reset/sifive-fu540-prci.h> -#include <errno.h> -#include <reset-uclass.h> -#include <asm/io.h> -#include <asm/arch/reset.h> -#include <linux/delay.h> -#include <linux/err.h> -#include <linux/math64.h> -#include <linux/clk/analogbits-wrpll-cln28hpc.h>
- EXPECTED_CLK_PARENT_COUNT: how many parent clocks this driver expects:
hfclk and rtcclk
-#define EXPECTED_CLK_PARENT_COUNT 2
- Register offsets and bitmasks
-/* COREPLLCFG0 */ -#define PRCI_COREPLLCFG0_OFFSET 0x4 -#define PRCI_COREPLLCFG0_DIVR_SHIFT 0 -#define PRCI_COREPLLCFG0_DIVR_MASK (0x3f << PRCI_COREPLLCFG0_DIVR_SHIFT) -#define PRCI_COREPLLCFG0_DIVF_SHIFT 6 -#define PRCI_COREPLLCFG0_DIVF_MASK (0x1ff << PRCI_COREPLLCFG0_DIVF_SHIFT) -#define PRCI_COREPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_COREPLLCFG0_DIVQ_MASK (0x7 << PRCI_COREPLLCFG0_DIVQ_SHIFT) -#define PRCI_COREPLLCFG0_RANGE_SHIFT 18 -#define PRCI_COREPLLCFG0_RANGE_MASK (0x7 << PRCI_COREPLLCFG0_RANGE_SHIFT) -#define PRCI_COREPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_COREPLLCFG0_BYPASS_MASK (0x1 << PRCI_COREPLLCFG0_BYPASS_SHIFT) -#define PRCI_COREPLLCFG0_FSE_SHIFT 25 -#define PRCI_COREPLLCFG0_FSE_MASK (0x1 << PRCI_COREPLLCFG0_FSE_SHIFT) -#define PRCI_COREPLLCFG0_LOCK_SHIFT 31 -#define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT)
-/* COREPLLCFG1 */ -#define PRCI_COREPLLCFG1_OFFSET 0x8 -#define PRCI_COREPLLCFG1_CKE_SHIFT 31 -#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT)
-/* DDRPLLCFG0 */ -#define PRCI_DDRPLLCFG0_OFFSET 0xc -#define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 -#define PRCI_DDRPLLCFG0_DIVR_MASK (0x3f << PRCI_DDRPLLCFG0_DIVR_SHIFT) -#define PRCI_DDRPLLCFG0_DIVF_SHIFT 6 -#define PRCI_DDRPLLCFG0_DIVF_MASK (0x1ff << PRCI_DDRPLLCFG0_DIVF_SHIFT) -#define PRCI_DDRPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_DDRPLLCFG0_DIVQ_MASK (0x7 << PRCI_DDRPLLCFG0_DIVQ_SHIFT) -#define PRCI_DDRPLLCFG0_RANGE_SHIFT 18 -#define PRCI_DDRPLLCFG0_RANGE_MASK (0x7 << PRCI_DDRPLLCFG0_RANGE_SHIFT) -#define PRCI_DDRPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_DDRPLLCFG0_BYPASS_MASK (0x1 << PRCI_DDRPLLCFG0_BYPASS_SHIFT) -#define PRCI_DDRPLLCFG0_FSE_SHIFT 25 -#define PRCI_DDRPLLCFG0_FSE_MASK (0x1 << PRCI_DDRPLLCFG0_FSE_SHIFT) -#define PRCI_DDRPLLCFG0_LOCK_SHIFT 31 -#define PRCI_DDRPLLCFG0_LOCK_MASK (0x1 << PRCI_DDRPLLCFG0_LOCK_SHIFT)
-/* DDRPLLCFG1 */ -#define PRCI_DDRPLLCFG1_OFFSET 0x10 -#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 -#define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT)
-/* GEMGXLPLLCFG0 */ -#define PRCI_GEMGXLPLLCFG0_OFFSET 0x1c -#define PRCI_GEMGXLPLLCFG0_DIVR_SHIFT 0 -#define PRCI_GEMGXLPLLCFG0_DIVR_MASK \
(0x3f << PRCI_GEMGXLPLLCFG0_DIVR_SHIFT)
-#define PRCI_GEMGXLPLLCFG0_DIVF_SHIFT 6 -#define PRCI_GEMGXLPLLCFG0_DIVF_MASK \
(0x1ff << PRCI_GEMGXLPLLCFG0_DIVF_SHIFT)
-#define PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT 15 -#define PRCI_GEMGXLPLLCFG0_DIVQ_MASK (0x7 << PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT) -#define PRCI_GEMGXLPLLCFG0_RANGE_SHIFT 18 -#define PRCI_GEMGXLPLLCFG0_RANGE_MASK \
(0x7 << PRCI_GEMGXLPLLCFG0_RANGE_SHIFT)
-#define PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT 24 -#define PRCI_GEMGXLPLLCFG0_BYPASS_MASK \
(0x1 << PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT)
-#define PRCI_GEMGXLPLLCFG0_FSE_SHIFT 25 -#define PRCI_GEMGXLPLLCFG0_FSE_MASK \
(0x1 << PRCI_GEMGXLPLLCFG0_FSE_SHIFT)
-#define PRCI_GEMGXLPLLCFG0_LOCK_SHIFT 31 -#define PRCI_GEMGXLPLLCFG0_LOCK_MASK (0x1 << PRCI_GEMGXLPLLCFG0_LOCK_SHIFT)
-/* GEMGXLPLLCFG1 */ -#define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 -#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 -#define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT)
-/* CORECLKSEL */ -#define PRCI_CORECLKSEL_OFFSET 0x24 -#define PRCI_CORECLKSEL_CORECLKSEL_SHIFT 0 -#define PRCI_CORECLKSEL_CORECLKSEL_MASK \
(0x1 << PRCI_CORECLKSEL_CORECLKSEL_SHIFT)
-/* DEVICESRESETREG */ -#define PRCI_DEVICESRESETREG_OFFSET 0x28 -#define PRCI_DEVICERESETCNT 5
-#define PRCI_DEVICESRESETREG_DDR_CTRL_RST_N_MASK \
(0x1 << PRCI_RST_DDR_CTRL_N)
-#define PRCI_DEVICESRESETREG_DDR_AXI_RST_N_MASK \
(0x1 << PRCI_RST_DDR_AXI_N)
-#define PRCI_DEVICESRESETREG_DDR_AHB_RST_N_MASK \
(0x1 << PRCI_RST_DDR_AHB_N)
-#define PRCI_DEVICESRESETREG_DDR_PHY_RST_N_MASK \
(0x1 << PRCI_RST_DDR_PHY_N)
-#define PRCI_DEVICESRESETREG_GEMGXL_RST_N_MASK \
(0x1 << PRCI_RST_GEMGXL_N)
-/* CLKMUXSTATUSREG */ -#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c -#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 -#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \
(0x1 << PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT)
-/* PROCMONCFG */ -#define PRCI_PROCMONCFG_OFFSET 0xF0 -#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 -#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \
(0x1 << PRCI_PROCMONCFG_CORE_CLOCK_SHIFT)
- Private structures
- struct __prci_data - per-device-instance data
- @va: base virtual address of the PRCI IP block
- @parent: parent clk instance
- PRCI per-device instance data
-struct __prci_data {
void *va;
struct clk parent_hfclk;
struct clk parent_rtcclk;
- struct __prci_wrpll_data - WRPLL configuration and integration data
- @c: WRPLL current configuration record
- @enable_bypass: fn ptr to code to bypass the WRPLL (if applicable; else NULL)
- @disable_bypass: fn ptr to code to not bypass the WRPLL (or NULL)
- @cfg0_offs: WRPLL CFG0 register offset (in bytes) from the PRCI base address
- @cfg1_offs: WRPLL CFG1 register offset (in bytes) from the PRCI base address
- @release_reset: fn ptr to code to release clock reset
- @enable_bypass and @disable_bypass are used for WRPLL instances
- that contain a separate external glitchless clock mux downstream
- from the PLL. The WRPLL internal bypass mux is not glitchless.
-struct __prci_wrpll_data {
struct wrpll_cfg c;
void (*enable_bypass)(struct __prci_data *pd);
void (*disable_bypass)(struct __prci_data *pd);
u8 cfg0_offs;
u8 cfg1_offs;
void (*release_reset)(struct __prci_data *pd);
-struct __prci_clock;
-/* struct __prci_clock_ops - clock operations */ -struct __prci_clock_ops {
int (*set_rate)(struct __prci_clock *pc,
unsigned long rate,
unsigned long parent_rate);
unsigned long (*round_rate)(struct __prci_clock *pc,
unsigned long rate,
unsigned long *parent_rate);
unsigned long (*recalc_rate)(struct __prci_clock *pc,
int (*enable_clk)(struct __prci_clock *pc, bool enable);
- struct __prci_clock - describes a clock device managed by PRCI
- @name: user-readable clock name string - should match the manual
- @parent_name: parent name for this clock
- @ops: struct __prci_clock_ops for control
- @pwd: WRPLL-specific data, associated with this clock (if not NULL)
- @pd: PRCI-specific data associated with this clock (if not NULL)
- PRCI clock data. Used by the PRCI driver to register PRCI-provided
- clocks to the Linux clock infrastructure.
-struct __prci_clock {
const char *name;
const char *parent_name;
const struct __prci_clock_ops *ops;
struct __prci_wrpll_data *pwd;
struct __prci_data *pd;
- Private functions
- __prci_readl() - read from a PRCI register
- @pd: PRCI context
- @offs: register offset to read from (in bytes, from PRCI base address)
- Read the register located at offset @offs from the base virtual
- address of the PRCI register target described by @pd, and return
- the value to the caller.
- Context: Any context.
- Return: the contents of the register described by @pd and @offs.
-static u32 __prci_readl(struct __prci_data *pd, u32 offs) -{
return readl(pd->va + offs);
-static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) -{
writel(v, pd->va + offs);
-/* WRPLL-related private functions */
- __prci_wrpll_unpack() - unpack WRPLL configuration registers into parameters
- @c: ptr to a struct wrpll_cfg record to write config into
- @r: value read from the PRCI PLL configuration register
- Given a value @r read from an FU540 PRCI PLL configuration register,
- split it into fields and populate it into the WRPLL configuration record
- pointed to by @c.
- The COREPLLCFG0 macros are used below, but the other *PLLCFG0 macros
- have the same register layout.
-static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) -{
u32 v;
v = r & PRCI_COREPLLCFG0_DIVR_MASK;
v >>= PRCI_COREPLLCFG0_DIVR_SHIFT;
c->divr = v;
v = r & PRCI_COREPLLCFG0_DIVF_MASK;
v >>= PRCI_COREPLLCFG0_DIVF_SHIFT;
c->divf = v;
v = r & PRCI_COREPLLCFG0_DIVQ_MASK;
v >>= PRCI_COREPLLCFG0_DIVQ_SHIFT;
c->divq = v;
v = r & PRCI_COREPLLCFG0_RANGE_MASK;
v >>= PRCI_COREPLLCFG0_RANGE_SHIFT;
c->range = v;
c->flags &= (WRPLL_FLAGS_INT_FEEDBACK_MASK |
WRPLL_FLAGS_EXT_FEEDBACK_MASK);
/* external feedback mode not supported */
c->flags |= WRPLL_FLAGS_INT_FEEDBACK_MASK;
- __prci_wrpll_pack() - pack PLL configuration parameters into a register value
- @c: pointer to a struct wrpll_cfg record containing the PLL's cfg
- Using a set of WRPLL configuration values pointed to by @c,
- assemble a PRCI PLL configuration register value, and return it to
- the caller.
- Context: Any context. Caller must ensure that the contents of the
record pointed to by @c do not change during the execution
of this function.
- Returns: a value suitable for writing into a PRCI PLL configuration
register
-static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) -{
u32 r = 0;
r |= c->divr << PRCI_COREPLLCFG0_DIVR_SHIFT;
r |= c->divf << PRCI_COREPLLCFG0_DIVF_SHIFT;
r |= c->divq << PRCI_COREPLLCFG0_DIVQ_SHIFT;
r |= c->range << PRCI_COREPLLCFG0_RANGE_SHIFT;
r |= PRCI_COREPLLCFG0_FSE_MASK;
return r;
- __prci_wrpll_read_cfg0() - read the WRPLL configuration from the PRCI
- @pd: PRCI context
- @pwd: PRCI WRPLL metadata
- Read the current configuration of the PLL identified by @pwd from
- the PRCI identified by @pd, and store it into the local configuration
- cache in @pwd.
- Context: Any context. Caller must prevent the records pointed to by
@pd and @pwd from changing during execution.
-static void __prci_wrpll_read_cfg0(struct __prci_data *pd,
struct __prci_wrpll_data *pwd)
__prci_wrpll_unpack(&pwd->c, __prci_readl(pd, pwd->cfg0_offs));
- __prci_wrpll_write_cfg0() - write WRPLL configuration into the PRCI
- @pd: PRCI context
- @c: WRPLL configuration record to write
- Write the WRPLL configuration described by @c into the WRPLL
- configuration register identified by @pwd in the PRCI instance
- described by @c. Make a cached copy of the WRPLL's current
- configuration so it can be used by other code.
-static void __prci_wrpll_write_cfg0(struct __prci_data *pd,
struct __prci_wrpll_data *pwd,
__prci_writel(__prci_wrpll_pack(c), pwd->cfg0_offs, pd);
memcpy(&pwd->c, c, sizeof(*c));
- __prci_wrpll_write_cfg1() - write Clock enable/disable configuration
- into the PRCI
- @pd: PRCI context
- @enable: Clock enable or disable value
-static void __prci_wrpll_write_cfg1(struct __prci_data *pd,
u32 enable)
__prci_writel(enable, pwd->cfg1_offs, pd);
-/* Core clock mux control */
- __prci_coreclksel_use_hfclk() - switch the CORECLK mux to output HFCLK
- @pd: struct __prci_data * for the PRCI containing the CORECLK mux reg
- Switch the CORECLK mux to the HFCLK input source; return once complete.
- Context: Any context. Caller must prevent concurrent changes to the
PRCI_CORECLKSEL_OFFSET register.
-static void __prci_coreclksel_use_hfclk(struct __prci_data *pd) -{
u32 r;
r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET);
r |= PRCI_CORECLKSEL_CORECLKSEL_MASK;
__prci_writel(r, PRCI_CORECLKSEL_OFFSET, pd);
r = __prci_readl(pd, PRCI_CORECLKSEL_OFFSET); /* barrier */
- __prci_coreclksel_use_corepll() - switch the CORECLK mux to output COREPLL
- Switch the CORECLK mux to the PLL output clock; return once complete.
-static void __prci_coreclksel_use_corepll(struct __prci_data *pd) -{
u32 r;
r &= ~PRCI_CORECLKSEL_CORECLKSEL_MASK;
-static unsigned long sifive_fu540_prci_wrpll_recalc_rate(
struct __prci_wrpll_data *pwd = pc->pwd;
return wrpll_calc_output_rate(&pwd->c, parent_rate);
-static unsigned long sifive_fu540_prci_wrpll_round_rate(
unsigned long rate,
struct wrpll_cfg c;
memcpy(&c, &pwd->c, sizeof(c));
wrpll_configure_for_rate(&c, rate, *parent_rate);
return wrpll_calc_output_rate(&c, *parent_rate);
-static int sifive_fu540_prci_wrpll_set_rate(struct __prci_clock *pc,
unsigned long rate,
struct __prci_data *pd = pc->pd;
int r;
r = wrpll_configure_for_rate(&pwd->c, rate, parent_rate);
if (r)
return r;
if (pwd->enable_bypass)
pwd->enable_bypass(pd);
__prci_wrpll_write_cfg0(pd, pwd, &pwd->c);
udelay(wrpll_calc_max_lock_us(&pwd->c));
if (pwd->disable_bypass)
pwd->disable_bypass(pd);
-static int sifive_fu540_prci_clock_enable(struct __prci_clock *pc, bool enable) -{
if (enable) {
__prci_wrpll_write_cfg1(pd, pwd, PRCI_COREPLLCFG1_CKE_MASK);
if (pwd->release_reset)
pwd->release_reset(pd);
} else {
u32 r;
r = __prci_readl(pd, pwd->cfg1_offs);
r &= ~PRCI_COREPLLCFG1_CKE_MASK;
__prci_wrpll_write_cfg1(pd, pwd, r);
-static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = {
.set_rate = sifive_fu540_prci_wrpll_set_rate,
.round_rate = sifive_fu540_prci_wrpll_round_rate,
.recalc_rate = sifive_fu540_prci_wrpll_recalc_rate,
.enable_clk = sifive_fu540_prci_clock_enable,
-/* TLCLKSEL clock integration */
-static unsigned long sifive_fu540_prci_tlclksel_recalc_rate(
u32 v;
u8 div;
v = __prci_readl(pd, PRCI_CLKMUXSTATUSREG_OFFSET);
v &= PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK;
div = v ? 1 : 2;
return div_u64(parent_rate, div);
-static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
.recalc_rate = sifive_fu540_prci_tlclksel_recalc_rate,
-static int __prci_consumer_reset(const char *rst_name, bool trigger) -{
struct udevice *dev;
struct reset_ctl rst_sig;
int ret;
ret = uclass_get_device_by_driver(UCLASS_RESET,
DM_DRIVER_GET(sifive_reset),
&dev);
if (ret) {
dev_err(dev, "Reset driver not found: %d\n", ret);
return ret;
ret = reset_get_by_name(dev, rst_name, &rst_sig);
if (ret) {
dev_err(dev, "failed to get %s reset\n", rst_name);
return ret;
if (reset_valid(&rst_sig)) {
if (trigger)
ret = reset_deassert(&rst_sig);
else
ret = reset_assert(&rst_sig);
if (ret) {
dev_err(dev, "failed to trigger reset id = %ld\n",
rst_sig.id);
return ret;
return ret;
- __prci_ddr_release_reset() - Release DDR reset
- @pd: struct __prci_data * for the PRCI containing the DDRCLK mux reg
-static void __prci_ddr_release_reset(struct __prci_data *pd) -{
/* Release DDR ctrl reset */
__prci_consumer_reset("ddr_ctrl", true);
/* HACK to get the '1 full controller clock cycle'. */
asm volatile ("fence");
/* Release DDR AXI reset */
__prci_consumer_reset("ddr_axi", true);
/* Release DDR AHB reset */
__prci_consumer_reset("ddr_ahb", true);
/* Release DDR PHY reset */
__prci_consumer_reset("ddr_phy", true);
* These take like 16 cycles to actually propagate. We can't go sending
* stuff before they come out of reset. So wait.
for (int i = 0; i < 256; i++)
asm volatile ("nop");
- __prci_ethernet_release_reset() - Release ethernet reset
- @pd: struct __prci_data * for the PRCI containing the Ethernet CLK mux reg
-static void __prci_ethernet_release_reset(struct __prci_data *pd) -{
/* Release GEMGXL reset */
__prci_consumer_reset("gemgxl_reset", true);
/* Procmon => core clock */
__prci_writel(PRCI_PROCMONCFG_CORE_CLOCK_MASK, PRCI_PROCMONCFG_OFFSET,
pd);
- PRCI integration data for each WRPLL instance
+#include "sifive-prci.h"
+/* PRCI integration data for each WRPLL instance */ static struct __prci_wrpll_data __prci_corepll_data = { .cfg0_offs = PRCI_COREPLLCFG0_OFFSET, .cfg1_offs = PRCI_COREPLLCFG1_OFFSET,
.enable_bypass = __prci_coreclksel_use_hfclk,
.disable_bypass = __prci_coreclksel_use_corepll,
.enable_bypass = sifive_prci_coreclksel_use_hfclk,
.disable_bypass = sifive_prci_coreclksel_use_corepll,
static struct __prci_wrpll_data __prci_ddrpll_data = { .cfg0_offs = PRCI_DDRPLLCFG0_OFFSET, .cfg1_offs = PRCI_DDRPLLCFG1_OFFSET,
.release_reset = __prci_ddr_release_reset,
.release_reset = sifive_prci_ddr_release_reset,
static struct __prci_wrpll_data __prci_gemgxlpll_data = { .cfg0_offs = PRCI_GEMGXLPLLCFG0_OFFSET, .cfg1_offs = PRCI_GEMGXLPLLCFG1_OFFSET,
.release_reset = __prci_ethernet_release_reset,
.release_reset = sifive_prci_ethernet_release_reset,
- List of clock controls provided by the PRCI
+/* Linux clock framework integration */ +static const struct __prci_clock_ops sifive_fu540_prci_wrpll_clk_ops = {
.set_rate = sifive_prci_wrpll_set_rate,
.round_rate = sifive_prci_wrpll_round_rate,
.recalc_rate = sifive_prci_wrpll_recalc_rate,
.enable_clk = sifive_prci_clock_enable,
-static struct __prci_clock __prci_init_clocks[] = { +static const struct __prci_clock_ops sifive_fu540_prci_tlclksel_clk_ops = {
.recalc_rate = sifive_prci_tlclksel_recalc_rate,
+/* List of clock controls provided by the PRCI */ +struct __prci_clock __prci_init_clocks_fu540[] = { [PRCI_CLK_COREPLL] = { .name = "corepll", .parent_name = "hfclk", @@ -665,148 +83,3 @@ static struct __prci_clock __prci_init_clocks[] = { .ops = &sifive_fu540_prci_tlclksel_clk_ops, }, };
-static ulong sifive_fu540_prci_parent_rate(struct __prci_clock *pc) -{
ulong parent_rate;
struct __prci_clock *p;
if (strcmp(pc->parent_name, "corepll") == 0) {
p = &__prci_init_clocks[PRCI_CLK_COREPLL];
if (!p->pd || !p->ops->recalc_rate)
return -ENXIO;
return p->ops->recalc_rate(p, sifive_fu540_prci_parent_rate(p));
if (strcmp(pc->parent_name, "rtcclk") == 0)
parent_rate = clk_get_rate(&pc->pd->parent_rtcclk);
else
parent_rate = clk_get_rate(&pc->pd->parent_hfclk);
return parent_rate;
-static ulong sifive_fu540_prci_get_rate(struct clk *clk) -{
struct __prci_clock *pc;
if (ARRAY_SIZE(__prci_init_clocks) <= clk->id)
return -ENXIO;
pc = &__prci_init_clocks[clk->id];
if (!pc->pd || !pc->ops->recalc_rate)
return -ENXIO;
return pc->ops->recalc_rate(pc, sifive_fu540_prci_parent_rate(pc));
-static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) -{
int err;
return -ENXIO;
if (!pc->pd || !pc->ops->set_rate)
return -ENXIO;
err = pc->ops->set_rate(pc, rate, sifive_fu540_prci_parent_rate(pc));
if (err)
return err;
return rate;
-static int sifive_fu540_prci_enable(struct clk *clk) -{
int ret = 0;
return -ENXIO;
if (!pc->pd)
return -ENXIO;
if (pc->ops->enable_clk)
ret = pc->ops->enable_clk(pc, 1);
return ret;
-static int sifive_fu540_prci_disable(struct clk *clk) -{
int ret = 0;
return -ENXIO;
if (!pc->pd)
return -ENXIO;
ret = pc->ops->enable_clk(pc, 0);
return ret;
-static int sifive_fu540_prci_probe(struct udevice *dev) -{
int i, err;
struct __prci_data *pd = dev_get_priv(dev);
pd->va = (void *)dev_read_addr(dev);
if (IS_ERR(pd->va))
return PTR_ERR(pd->va);
err = clk_get_by_index(dev, 0, &pd->parent_hfclk);
if (err)
return err;
err = clk_get_by_index(dev, 1, &pd->parent_rtcclk);
if (err)
return err;
for (i = 0; i < ARRAY_SIZE(__prci_init_clocks); ++i) {
pc = &__prci_init_clocks[i];
pc->pd = pd;
if (pc->pwd)
__prci_wrpll_read_cfg0(pd, pc->pwd);
-static struct clk_ops sifive_fu540_prci_ops = {
.set_rate = sifive_fu540_prci_set_rate,
.get_rate = sifive_fu540_prci_get_rate,
.enable = sifive_fu540_prci_enable,
.disable = sifive_fu540_prci_disable,
-static int sifive_fu540_clk_bind(struct udevice *dev) -{
return sifive_reset_bind(dev, PRCI_DEVICERESETCNT);
-static const struct udevice_id sifive_fu540_prci_ids[] = {
{ .compatible = "sifive,fu540-c000-prci" },
-U_BOOT_DRIVER(sifive_fu540_prci) = {
.name = "sifive-fu540-prci",
.id = UCLASS_CLK,
.of_match = sifive_fu540_prci_ids,
.probe = sifive_fu540_prci_probe,
.ops = &sifive_fu540_prci_ops,
.priv_auto = sizeof(struct __prci_data),
.bind = sifive_fu540_clk_bind,
-}; diff --git a/drivers/clk/sifive/fu540-prci.h b/drivers/clk/sifive/fu540-prci.h new file mode 100644 index 0000000000..113301107d --- /dev/null +++ b/drivers/clk/sifive/fu540-prci.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Copyright (C) 2020-2021 SiFive, Inc.
- Zong Li
- Pragnesh Patel
+#ifndef __SIFIVE_CLK_FU540_PRCI_H +#define __SIFIVE_CLK_FU540_PRCI_H
+#define NUM_CLOCK_FU540 4
+extern struct __prci_clock __prci_init_clocks_fu540[NUM_CLOCK_FU540];
+static const struct prci_clk_desc prci_clk_fu540 = {
.clks = __prci_init_clocks_fu540,
.num_clks = ARRAY_SIZE(__prci_init_clocks_fu540),
+#endif /* __SIFIVE_CLK_FU540_PRCI_H */ diff --git a/drivers/clk/sifive/fu740-prci.c b/drivers/clk/sifive/fu740-prci.c new file mode 100644 index 0000000000..9a642c1c99 --- /dev/null +++ b/drivers/clk/sifive/fu740-prci.c @@ -0,0 +1,158 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Copyright (C) 2018-2021 SiFive, Inc.
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
- published by the Free Software Foundation.
+#include <dt-bindings/clock/sifive-fu740-prci.h> +#include "sifive-prci.h" +#include <asm/io.h>
+int sifive_prci_fu740_pciauxclk_enable(struct __prci_clock *pc, bool enable) +{
u32 v;
if (pwd->cfg1_offs != PRCI_PCIEAUXCFG1_OFFSET)
return -EINVAL;
v = readl(pd->va + pwd->cfg1_offs);
v = enable ? (v | PRCI_PCIEAUXCFG1_MASK) : (v & ~PRCI_PCIEAUXCFG1_MASK);
writel(v, pd->va + pwd->cfg1_offs);
+/* PRCI integration data for each WRPLL instance */ +static struct __prci_wrpll_data __prci_corepll_data = {
.disable_bypass = sifive_prci_coreclksel_use_final_corepll,
+static struct __prci_wrpll_data __prci_ddrpll_data = {
+static struct __prci_wrpll_data __prci_gemgxlpll_data = {
+static struct __prci_wrpll_data __prci_dvfscorepll_data = {
.cfg0_offs = PRCI_DVFSCOREPLLCFG0_OFFSET,
.cfg1_offs = PRCI_DVFSCOREPLLCFG1_OFFSET,
.enable_bypass = sifive_prci_corepllsel_use_corepll,
.disable_bypass = sifive_prci_corepllsel_use_dvfscorepll,
+static struct __prci_wrpll_data __prci_hfpclkpll_data = {
.cfg0_offs = PRCI_HFPCLKPLLCFG0_OFFSET,
.cfg1_offs = PRCI_HFPCLKPLLCFG1_OFFSET,
.enable_bypass = sifive_prci_hfpclkpllsel_use_hfclk,
.disable_bypass = sifive_prci_hfpclkpllsel_use_hfpclkpll,
+static struct __prci_wrpll_data __prci_cltxpll_data = {
.cfg0_offs = PRCI_CLTXPLLCFG0_OFFSET,
.cfg1_offs = PRCI_CLTXPLLCFG1_OFFSET,
.release_reset = sifive_prci_cltx_release_reset,
+static struct __prci_wrpll_data __prci_pcieaux_data = {
.cfg1_offs = PRCI_PCIEAUXCFG1_OFFSET,
+static const struct __prci_clock_ops sifive_fu740_prci_wrpll_clk_ops = {
+static const struct __prci_clock_ops sifive_fu740_prci_tlclksel_clk_ops = {
+static const struct __prci_clock_ops sifive_fu740_prci_hfpclkplldiv_clk_ops = {
.recalc_rate = sifive_prci_hfpclkplldiv_recalc_rate,
+static const struct __prci_clock_ops sifive_fu740_prci_pcieaux_clk_ops = {
.enable_clk = sifive_prci_fu740_pciauxclk_enable,
+/* List of clock controls provided by the PRCI */ +struct __prci_clock __prci_init_clocks_fu740[] = {
.name = "corepll",
.ops = &sifive_fu740_prci_wrpll_clk_ops,
.pwd = &__prci_corepll_data,
[PRCI_CLK_DDRPLL] = {
.name = "ddrpll",
.pwd = &__prci_ddrpll_data,
[PRCI_CLK_GEMGXLPLL] = {
.name = "gemgxlpll",
.pwd = &__prci_gemgxlpll_data,
[PRCI_CLK_DVFSCOREPLL] = {
.name = "dvfscorepll",
.pwd = &__prci_dvfscorepll_data,
[PRCI_CLK_HFPCLKPLL] = {
.name = "hfpclkpll",
.pwd = &__prci_hfpclkpll_data,
[PRCI_CLK_CLTXPLL] = {
.name = "cltxpll",
.pwd = &__prci_cltxpll_data,
[PRCI_CLK_TLCLK] = {
.name = "tlclk",
.parent_name = "corepll",
.ops = &sifive_fu740_prci_tlclksel_clk_ops,
[PRCI_CLK_PCLK] = {
.name = "pclk",
.parent_name = "hfpclkpll",
.ops = &sifive_fu740_prci_hfpclkplldiv_clk_ops,
[PRCI_CLK_PCIEAUX] {
.name = "pciaux",
.parent_name = "",
.ops = &sifive_fu740_prci_pcieaux_clk_ops,
.pwd = &__prci_pcieaux_data,
+}; diff --git a/drivers/clk/sifive/fu740-prci.h b/drivers/clk/sifive/fu740-prci.h new file mode 100644 index 0000000000..b74f078906 --- /dev/null +++ b/drivers/clk/sifive/fu740-prci.h @@ -0,0 +1,22 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Zong Li
- Pragnesh Patel
+#ifndef __SIFIVE_CLK_FU740_PRCI_H +#define __SIFIVE_CLK_FU740_PRCI_H
+#define NUM_CLOCK_FU740 9
+extern struct __prci_clock __prci_init_clocks_fu740[NUM_CLOCK_FU740];
+static const struct prci_clk_desc prci_clk_fu740 = {
.clks = __prci_init_clocks_fu740,
.num_clks = ARRAY_SIZE(__prci_init_clocks_fu740),
+#endif /* __SIFIVE_CLK_FU740_PRCI_H */ diff --git a/drivers/clk/sifive/sifive-prci.c b/drivers/clk/sifive/sifive-prci.c new file mode 100644 index 0000000000..cd1acb9442 --- /dev/null +++ b/drivers/clk/sifive/sifive-prci.c @@ -0,0 +1,733 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
- The PRCI implements clock and reset control for the SiFive chip.
- This driver assumes that it has sole control over all PRCI resources.
- This driver is based on the PRCI driver written by Wesley Terpstra:
+#include <common.h> +#include <clk-uclass.h> +#include <clk.h> +#include <dm.h> +#include <dm/device_compat.h> +#include <reset.h> +#include <asm/io.h> +#include <asm/arch/reset.h> +#include <linux/delay.h> +#include <linux/math64.h> +#include <dt-bindings/clock/sifive-fu740-prci.h>
+#include "fu540-prci.h" +#include "fu740-prci.h"
- Private functions
- @pd: PRCI context
+static u32 __prci_readl(struct __prci_data *pd, u32 offs) +{
+static void __prci_writel(u32 v, u32 offs, struct __prci_data *pd) +{
+/* WRPLL-related private functions */
- pointed to by @c.
+static void __prci_wrpll_unpack(struct wrpll_cfg *c, u32 r) +{
u32 v;
c->divr = v;
c->divf = v;
c->divq = v;
c->range = v;
- the caller.
of this function.
register
+static u32 __prci_wrpll_pack(const struct wrpll_cfg *c) +{
u32 r = 0;
return r;
- @pd: PRCI context
- cache in @pwd.
+static void __prci_wrpll_read_cfg0(struct __prci_data *pd,
- @pd: PRCI context
+static void __prci_wrpll_write_cfg0(struct __prci_data *pd,
- into the PRCI
- @pd: PRCI context
+static void __prci_wrpll_write_cfg1(struct __prci_data *pd,
u32 enable)
+unsigned long sifive_prci_wrpll_recalc_rate(struct __prci_clock *pc,
+unsigned long sifive_prci_wrpll_round_rate(struct __prci_clock *pc,
unsigned long rate,
struct wrpll_cfg c;
+int sifive_prci_wrpll_set_rate(struct __prci_clock *pc,
unsigned long rate,
int r;
if (r)
return r;
+int sifive_prci_clock_enable(struct __prci_clock *pc, bool enable) +{
if (enable) {
} else {
u32 r;
+/* TLCLKSEL clock integration */
+unsigned long sifive_prci_tlclksel_recalc_rate(struct __prci_clock *pc,
u32 v;
u8 div;
div = v ? 1 : 2;
+/* HFPCLK clock integration */
+unsigned long sifive_prci_hfpclkplldiv_recalc_rate(struct __prci_clock *pc,
u32 div = __prci_readl(pd, PRCI_HFPCLKPLLDIV_OFFSET);
return div_u64(parent_rate, div + 2);
- sifive_prci_coreclksel_use_final_corepll() - switch the CORECLK mux to output
- FINAL_COREPLL
- Switch the CORECLK mux to the final COREPLL output clock; return once
- complete.
+void sifive_prci_coreclksel_use_final_corepll(struct __prci_data *pd) +{
u32 r;
- sifive_prci_corepllsel_use_dvfscorepll() - switch the COREPLL mux to
- output DVFS_COREPLL
- @pd: struct __prci_data * for the PRCI containing the COREPLL mux reg
- Switch the COREPLL mux to the DVFSCOREPLL output clock; return once complete.
PRCI_COREPLLSEL_OFFSET register.
+void sifive_prci_corepllsel_use_dvfscorepll(struct __prci_data *pd) +{
u32 r;
r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET);
r |= PRCI_COREPLLSEL_COREPLLSEL_MASK;
__prci_writel(r, PRCI_COREPLLSEL_OFFSET, pd);
r = __prci_readl(pd, PRCI_COREPLLSEL_OFFSET); /* barrier */
- sifive_prci_corepllsel_use_corepll() - switch the COREPLL mux to
- output COREPLL
- Switch the COREPLL mux to the COREPLL output clock; return once complete.
+void sifive_prci_corepllsel_use_corepll(struct __prci_data *pd) +{
u32 r;
r &= ~PRCI_COREPLLSEL_COREPLLSEL_MASK;
- sifive_prci_hfpclkpllsel_use_hfclk() - switch the HFPCLKPLL mux to
- output HFCLK
- @pd: struct __prci_data * for the PRCI containing the HFPCLKPLL mux reg
- Switch the HFPCLKPLL mux to the HFCLK input source; return once complete.
PRCI_HFPCLKPLLSEL_OFFSET register.
+void sifive_prci_hfpclkpllsel_use_hfclk(struct __prci_data *pd) +{
u32 r;
r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET);
r |= PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK;
__prci_writel(r, PRCI_HFPCLKPLLSEL_OFFSET, pd);
r = __prci_readl(pd, PRCI_HFPCLKPLLSEL_OFFSET); /* barrier */
- sifive_prci_hfpclkpllsel_use_hfpclkpll() - switch the HFPCLKPLL mux to
- output HFPCLKPLL
- Switch the HFPCLKPLL mux to the HFPCLKPLL output clock; return once complete.
+void sifive_prci_hfpclkpllsel_use_hfpclkpll(struct __prci_data *pd) +{
u32 r;
r &= ~PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK;
+static int __prci_consumer_reset(const char *rst_name, bool trigger) +{
int ret;
&dev);
if (ret) {
return ret;
if (ret) {
return ret;
if (trigger)
else
if (ret) {
rst_sig.id);
return ret;
return ret;
- sifive_prci_ddr_release_reset() - Release DDR reset
+void sifive_prci_ddr_release_reset(struct __prci_data *pd) +{
- sifive_prci_ethernet_release_reset() - Release ethernet reset
+void sifive_prci_ethernet_release_reset(struct __prci_data *pd) +{
pd);
/* Release Chiplink reset */
__prci_consumer_reset("cltx_reset", true);
- sifive_prci_cltx_release_reset() - Release cltx reset
+void sifive_prci_cltx_release_reset(struct __prci_data *pd) +{
/* Release CLTX reset */
+/* Core clock mux control */
- sifive_prci_coreclksel_use_hfclk() - switch the CORECLK mux to output HFCLK
+void sifive_prci_coreclksel_use_hfclk(struct __prci_data *pd) +{
u32 r;
- sifive_prci_coreclksel_use_corepll() - switch the CORECLK mux to output COREPLL
+void sifive_prci_coreclksel_use_corepll(struct __prci_data *pd) +{
u32 r;
+static ulong sifive_prci_parent_rate(struct __prci_clock *pc, struct prci_clk_desc *data) +{
ulong parent_rate;
ulong i;
if (strcmp(pc->parent_name, "corepll") == 0 ||
strcmp(pc->parent_name, "hfpclkpll") == 0) {
for (i = 0; i < data->num_clks; i++) {
if (strcmp(pc->parent_name, data->clks[i].name) == 0)
break;
if (i >= data->num_clks)
return -ENXIO;
p = &data->clks[i];
return -ENXIO;
return p->ops->recalc_rate(p, sifive_prci_parent_rate(p, data));
else
return parent_rate;
+static ulong sifive_prci_get_rate(struct clk *clk) +{
struct prci_clk_desc *data =
(struct prci_clk_desc *)dev_get_driver_data(clk->dev);
if (data->num_clks <= clk->id)
return -ENXIO;
pc = &data->clks[clk->id];
return -ENXIO;
return pc->ops->recalc_rate(pc, sifive_prci_parent_rate(pc, data));
+static ulong sifive_prci_set_rate(struct clk *clk, ulong rate) +{
int err;
return -ENXIO;
return -ENXIO;
err = pc->ops->set_rate(pc, rate, sifive_prci_parent_rate(pc, data));
if (err)
return err;
return rate;
+static int sifive_prci_enable(struct clk *clk) +{
int ret = 0;
return -ENXIO;
if (!pc->pd)
return -ENXIO;
return ret;
+static int sifive_prci_disable(struct clk *clk) +{
int ret = 0;
return -ENXIO;
if (!pc->pd)
return -ENXIO;
return ret;
+static int sifive_prci_probe(struct udevice *dev) +{
int i, err;
(struct prci_clk_desc *)dev_get_driver_data(dev);
if (IS_ERR(pd->va))
if (err)
return err;
if (err)
return err;
for (i = 0; i < data->num_clks; ++i) {
pc = &data->clks[i];
pc->pd = pd;
if (pc->pwd)
if (IS_ENABLED(CONFIG_SPL_BUILD)) {
if (device_is_compatible(dev, "sifive,fu740-c000-prci")) {
u32 prci_pll_reg;
unsigned long parent_rate;
prci_pll_reg = readl(pd->va + PRCI_PRCIPLL_OFFSET);
if (prci_pll_reg & PRCI_PRCIPLL_HFPCLKPLL) {
* Only initialize the HFPCLK PLL. In this
* case the design uses hfpclk to drive
* Chiplink
pc = &data->clks[PRCI_CLK_HFPCLKPLL];
parent_rate = sifive_prci_parent_rate(pc, data);
sifive_prci_wrpll_set_rate(pc, 260000000,
parent_rate);
} else if (prci_pll_reg & PRCI_PRCIPLL_CLTXPLL) {
/* CLTX pll init */
pc = &data->clks[PRCI_CLK_CLTXPLL];
parent_rate);
+static struct clk_ops sifive_prci_ops = {
.set_rate = sifive_prci_set_rate,
.get_rate = sifive_prci_get_rate,
.enable = sifive_prci_enable,
.disable = sifive_prci_disable,
+static int sifive_clk_bind(struct udevice *dev) +{
+static const struct udevice_id sifive_prci_ids[] = {
{ .compatible = "sifive,fu540-c000-prci", .data = (ulong)&prci_clk_fu540 },
{ .compatible = "sifive,fu740-c000-prci", .data = (ulong)&prci_clk_fu740 },
+U_BOOT_DRIVER(sifive_prci) = {
.name = "sifive-prci",
.id = UCLASS_CLK,
.of_match = sifive_prci_ids,
.probe = sifive_prci_probe,
.ops = &sifive_prci_ops,
.bind = sifive_clk_bind,
+}; diff --git a/drivers/clk/sifive/sifive-prci.h b/drivers/clk/sifive/sifive-prci.h new file mode 100644 index 0000000000..5ce33d6184 --- /dev/null +++ b/drivers/clk/sifive/sifive-prci.h @@ -0,0 +1,323 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/*
- Wesley Terpstra
- Paul Walmsley
- Zong Li
- Pragnesh Patel
+#ifndef __SIFIVE_CLK_SIFIVE_PRCI_H +#define __SIFIVE_CLK_SIFIVE_PRCI_H
+#include <clk.h> +#include <linux/clk/analogbits-wrpll-cln28hpc.h>
hfclk and rtcclk
+#define EXPECTED_CLK_PARENT_COUNT 2
+/* COREPLLCFG0 */ +#define PRCI_COREPLLCFG0_OFFSET 0x4 +#define PRCI_COREPLLCFG0_DIVR_SHIFT 0 +#define PRCI_COREPLLCFG0_DIVR_MASK (0x3f << PRCI_COREPLLCFG0_DIVR_SHIFT) +#define PRCI_COREPLLCFG0_DIVF_SHIFT 6 +#define PRCI_COREPLLCFG0_DIVF_MASK (0x1ff << PRCI_COREPLLCFG0_DIVF_SHIFT) +#define PRCI_COREPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_COREPLLCFG0_DIVQ_MASK (0x7 << PRCI_COREPLLCFG0_DIVQ_SHIFT) +#define PRCI_COREPLLCFG0_RANGE_SHIFT 18 +#define PRCI_COREPLLCFG0_RANGE_MASK (0x7 << PRCI_COREPLLCFG0_RANGE_SHIFT) +#define PRCI_COREPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_COREPLLCFG0_BYPASS_MASK (0x1 << PRCI_COREPLLCFG0_BYPASS_SHIFT) +#define PRCI_COREPLLCFG0_FSE_SHIFT 25 +#define PRCI_COREPLLCFG0_FSE_MASK (0x1 << PRCI_COREPLLCFG0_FSE_SHIFT) +#define PRCI_COREPLLCFG0_LOCK_SHIFT 31 +#define PRCI_COREPLLCFG0_LOCK_MASK (0x1 << PRCI_COREPLLCFG0_LOCK_SHIFT)
+/* COREPLLCFG1 */ +#define PRCI_COREPLLCFG1_OFFSET 0x8 +#define PRCI_COREPLLCFG1_CKE_SHIFT 31 +#define PRCI_COREPLLCFG1_CKE_MASK (0x1 << PRCI_COREPLLCFG1_CKE_SHIFT)
+/* DDRPLLCFG0 */ +#define PRCI_DDRPLLCFG0_OFFSET 0xc +#define PRCI_DDRPLLCFG0_DIVR_SHIFT 0 +#define PRCI_DDRPLLCFG0_DIVR_MASK (0x3f << PRCI_DDRPLLCFG0_DIVR_SHIFT) +#define PRCI_DDRPLLCFG0_DIVF_SHIFT 6 +#define PRCI_DDRPLLCFG0_DIVF_MASK (0x1ff << PRCI_DDRPLLCFG0_DIVF_SHIFT) +#define PRCI_DDRPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_DDRPLLCFG0_DIVQ_MASK (0x7 << PRCI_DDRPLLCFG0_DIVQ_SHIFT) +#define PRCI_DDRPLLCFG0_RANGE_SHIFT 18 +#define PRCI_DDRPLLCFG0_RANGE_MASK (0x7 << PRCI_DDRPLLCFG0_RANGE_SHIFT) +#define PRCI_DDRPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_DDRPLLCFG0_BYPASS_MASK (0x1 << PRCI_DDRPLLCFG0_BYPASS_SHIFT) +#define PRCI_DDRPLLCFG0_FSE_SHIFT 25 +#define PRCI_DDRPLLCFG0_FSE_MASK (0x1 << PRCI_DDRPLLCFG0_FSE_SHIFT) +#define PRCI_DDRPLLCFG0_LOCK_SHIFT 31 +#define PRCI_DDRPLLCFG0_LOCK_MASK (0x1 << PRCI_DDRPLLCFG0_LOCK_SHIFT)
+/* DDRPLLCFG1 */ +#define PRCI_DDRPLLCFG1_OFFSET 0x10 +#define PRCI_DDRPLLCFG1_CKE_SHIFT 31 +#define PRCI_DDRPLLCFG1_CKE_MASK (0x1 << PRCI_DDRPLLCFG1_CKE_SHIFT)
+/* PCIEAUXCFG1 */ +#define PRCI_PCIEAUXCFG1_OFFSET 0x14 +#define PRCI_PCIEAUXCFG1_SHIFT 0 +#define PRCI_PCIEAUXCFG1_MASK (0x1 << PRCI_PCIEAUXCFG1_SHIFT)
+/* GEMGXLPLLCFG0 */ +#define PRCI_GEMGXLPLLCFG0_OFFSET 0x1c +#define PRCI_GEMGXLPLLCFG0_DIVR_SHIFT 0 +#define PRCI_GEMGXLPLLCFG0_DIVR_MASK \
+#define PRCI_GEMGXLPLLCFG0_DIVF_SHIFT 6 +#define PRCI_GEMGXLPLLCFG0_DIVF_MASK \
+#define PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_GEMGXLPLLCFG0_DIVQ_MASK (0x7 << PRCI_GEMGXLPLLCFG0_DIVQ_SHIFT) +#define PRCI_GEMGXLPLLCFG0_RANGE_SHIFT 18 +#define PRCI_GEMGXLPLLCFG0_RANGE_MASK \
+#define PRCI_GEMGXLPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_GEMGXLPLLCFG0_BYPASS_MASK \
+#define PRCI_GEMGXLPLLCFG0_FSE_SHIFT 25 +#define PRCI_GEMGXLPLLCFG0_FSE_MASK \
+#define PRCI_GEMGXLPLLCFG0_LOCK_SHIFT 31 +#define PRCI_GEMGXLPLLCFG0_LOCK_MASK (0x1 << PRCI_GEMGXLPLLCFG0_LOCK_SHIFT)
+/* GEMGXLPLLCFG1 */ +#define PRCI_GEMGXLPLLCFG1_OFFSET 0x20 +#define PRCI_GEMGXLPLLCFG1_CKE_SHIFT 31 +#define PRCI_GEMGXLPLLCFG1_CKE_MASK (0x1 << PRCI_GEMGXLPLLCFG1_CKE_SHIFT)
+/* CORECLKSEL */ +#define PRCI_CORECLKSEL_OFFSET 0x24 +#define PRCI_CORECLKSEL_CORECLKSEL_SHIFT 0 +#define PRCI_CORECLKSEL_CORECLKSEL_MASK \
+/* DEVICESRESETREG */ +#define PRCI_DEVICESRESETREG_OFFSET 0x28 +#define PRCI_DEVICERESETCNT 6
+/* CLKMUXSTATUSREG */ +#define PRCI_CLKMUXSTATUSREG_OFFSET 0x2c +#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_SHIFT 1 +#define PRCI_CLKMUXSTATUSREG_TLCLKSEL_STATUS_MASK \
+/* CLTXPLLCFG0 */ +#define PRCI_CLTXPLLCFG0_OFFSET 0x30 +#define PRCI_CLTXPLLCFG0_DIVR_SHIFT 0 +#define PRCI_CLTXPLLCFG0_DIVR_MASK (0x3f << PRCI_CLTXPLLCFG0_DIVR_SHIFT) +#define PRCI_CLTXPLLCFG0_DIVF_SHIFT 6 +#define PRCI_CLTXPLLCFG0_DIVF_MASK (0x1ff << PRCI_CLTXPLLCFG0_DIVF_SHIFT) +#define PRCI_CLTXPLLCFG0_DIVQ_SHIFT 15 +#define PRCI_CLTXPLLCFG0_DIVQ_MASK (0x7 << PRCI_CLTXPLLCFG0_DIVQ_SHIFT) +#define PRCI_CLTXPLLCFG0_RANGE_SHIFT 18 +#define PRCI_CLTXPLLCFG0_RANGE_MASK (0x7 << PRCI_CLTXPLLCFG0_RANGE_SHIFT) +#define PRCI_CLTXPLLCFG0_BYPASS_SHIFT 24 +#define PRCI_CLTXPLLCFG0_BYPASS_MASK (0x1 << PRCI_CLTXPLLCFG0_BYPASS_SHIFT) +#define PRCI_CLTXPLLCFG0_FSE_SHIFT 25 +#define PRCI_CLTXPLLCFG0_FSE_MASK (0x1 << PRCI_CLTXPLLCFG0_FSE_SHIFT) +#define PRCI_CLTXPLLCFG0_LOCK_SHIFT 31 +#define PRCI_CLTXPLLCFG0_LOCK_MASK (0x1 << PRCI_CLTXPLLCFG0_LOCK_SHIFT)
+/* CLTXPLLCFG1 */ +#define PRCI_CLTXPLLCFG1_OFFSET 0x34 +#define PRCI_CLTXPLLCFG1_CKE_SHIFT 24 +#define PRCI_CLTXPLLCFG1_CKE_MASK (0x1 << PRCI_CLTXPLLCFG1_CKE_SHIFT)
+/* DVFSCOREPLLCFG0 */ +#define PRCI_DVFSCOREPLLCFG0_OFFSET 0x38
+/* DVFSCOREPLLCFG1 */ +#define PRCI_DVFSCOREPLLCFG1_OFFSET 0x3c +#define PRCI_DVFSCOREPLLCFG1_CKE_SHIFT 24 +#define PRCI_DVFSCOREPLLCFG1_CKE_MASK (0x1 << PRCI_DVFSCOREPLLCFG1_CKE_SHIFT)
+/* COREPLLSEL */ +#define PRCI_COREPLLSEL_OFFSET 0x40 +#define PRCI_COREPLLSEL_COREPLLSEL_SHIFT 0 +#define PRCI_COREPLLSEL_COREPLLSEL_MASK \
(0x1 << PRCI_COREPLLSEL_COREPLLSEL_SHIFT)
+/* HFPCLKPLLCFG0 */ +#define PRCI_HFPCLKPLLCFG0_OFFSET 0x50 +#define PRCI_HFPCLKPLL_CFG0_DIVR_SHIFT 0 +#define PRCI_HFPCLKPLL_CFG0_DIVR_MASK \
(0x3f << PRCI_HFPCLKPLLCFG0_DIVR_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_DIVF_SHIFT 6 +#define PRCI_HFPCLKPLL_CFG0_DIVF_MASK \
(0x1ff << PRCI_HFPCLKPLLCFG0_DIVF_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_DIVQ_SHIFT 15 +#define PRCI_HFPCLKPLL_CFG0_DIVQ_MASK \
(0x7 << PRCI_HFPCLKPLLCFG0_DIVQ_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_RANGE_SHIFT 18 +#define PRCI_HFPCLKPLL_CFG0_RANGE_MASK \
(0x7 << PRCI_HFPCLKPLLCFG0_RANGE_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_BYPASS_SHIFT 24 +#define PRCI_HFPCLKPLL_CFG0_BYPASS_MASK \
(0x1 << PRCI_HFPCLKPLLCFG0_BYPASS_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_FSE_SHIFT 25 +#define PRCI_HFPCLKPLL_CFG0_FSE_MASK \
(0x1 << PRCI_HFPCLKPLLCFG0_FSE_SHIFT)
+#define PRCI_HFPCLKPLL_CFG0_LOCK_SHIFT 31 +#define PRCI_HFPCLKPLL_CFG0_LOCK_MASK \
(0x1 << PRCI_HFPCLKPLLCFG0_LOCK_SHIFT)
+/* HFPCLKPLLCFG1 */ +#define PRCI_HFPCLKPLLCFG1_OFFSET 0x54 +#define PRCI_HFPCLKPLLCFG1_CKE_SHIFT 24 +#define PRCI_HFPCLKPLLCFG1_CKE_MASK \
(0x1 << PRCI_HFPCLKPLLCFG1_CKE_SHIFT)
+/* HFPCLKPLLSEL */ +#define PRCI_HFPCLKPLLSEL_OFFSET 0x58 +#define PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_SHIFT 0 +#define PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_MASK \
(0x1 << PRCI_HFPCLKPLLSEL_HFPCLKPLLSEL_SHIFT)
+/* HFPCLKPLLDIV */ +#define PRCI_HFPCLKPLLDIV_OFFSET 0x5c
+/* PRCIPLL */ +#define PRCI_PRCIPLL_OFFSET 0xe0
+#define PRCI_PRCIPLL_CLTXPLL (0x1 << 0) +#define PRCI_PRCIPLL_GEMGXLPLL (0x1 << 1) +#define PRCI_PRCIPLL_DDRPLL (0x1 << 2) +#define PRCI_PRCIPLL_HFPCLKPLL (0x1 << 3) +#define PRCI_PRCIPLL_DVFSCOREPLL (0x1 << 4) +#define PRCI_PRCIPLL_COREPLL (0x1 << 5)
+/* PROCMONCFG */ +#define PRCI_PROCMONCFG_OFFSET 0xF0 +#define PRCI_PROCMONCFG_CORE_CLOCK_SHIFT 24 +#define PRCI_PROCMONCFG_CORE_CLOCK_MASK \
+struct __prci_data {
void *va;
+struct __prci_wrpll_data {
struct wrpll_cfg c;
u8 cfg0_offs;
u8 cfg1_offs;
+struct __prci_clock {
const char *name;
+/* struct __prci_clock_ops - clock operations */ +struct __prci_clock_ops {
unsigned long rate,
unsigned long rate,
- struct prci_clk_desc - describes the information of clocks of each SoCs
- @clks: point to a array of __prci_clock
- @num_clks: the number of element of clks
+struct prci_clk_desc {
struct __prci_clock *clks;
size_t num_clks;
+void sifive_prci_ethernet_release_reset(struct __prci_data *pd); +void sifive_prci_ddr_release_reset(struct __prci_data *pd); +void sifive_prci_cltx_release_reset(struct __prci_data *pd);
+/* Core clock mux control */ +void sifive_prci_coreclksel_use_hfclk(struct __prci_data *pd); +void sifive_prci_coreclksel_use_corepll(struct __prci_data *pd); +void sifive_prci_coreclksel_use_final_corepll(struct __prci_data *pd); +void sifive_prci_corepllsel_use_dvfscorepll(struct __prci_data *pd); +void sifive_prci_corepllsel_use_corepll(struct __prci_data *pd); +void sifive_prci_hfpclkpllsel_use_hfclk(struct __prci_data *pd); +void sifive_prci_hfpclkpllsel_use_hfpclkpll(struct __prci_data *pd);
unsigned long rate,
+/* Linux clock framework integration */ +int sifive_prci_wrpll_set_rate(struct __prci_clock *pc,
unsigned long rate,
+int sifive_prci_clock_enable(struct __prci_clock *pc, bool enable);
+#endif /* __SIFIVE_CLK_SIFIVE_PRCI_H */
2.31.0
-- Regards,
Dimitri.
Dimitri John Ledkov
