[U-Boot] [PATCH 1/7] armv7: Mark the default lowlevel_init function as weak
Rather than have a long and if check in the Makefile, mark the default lowlevel_init function as weak (as we do on armv8) so that SoCs can override it if needed, and it will still be discarded if unused. Provide a weak s_init as well to allow for this to link and be discarded.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/cpu/armv7/Makefile | 2 -- arch/arm/cpu/armv7/lowlevel_init.S | 10 +++++++++- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 5fac252c0e00..45dd3caec6b3 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -12,11 +12,9 @@ obj-y += cache_v7.o cache_v7_asm.o obj-y += cpu.o cp15.o obj-y += syslib.o
-ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_MX7)$(CONFIG_TI81XX)$(CONFIG_AT91FAMILY)$(CONFIG_ARCH_SUNXI)$(CONFIG_ARCH_SOCFPGA)$(CONFIG_ARCH_MX7ULP)$(CONFIG_ARCH_LS1021A),) ifneq ($(CONFIG_SKIP_LOWLEVEL_INIT),y) obj-y += lowlevel_init.o endif -endif
obj-$(CONFIG_ARM_SMCCC) += smccc-call.o obj-$(CONFIG_ARMV7_NONSEC) += nonsec_virt.o virt-v7.o virt-dt.o diff --git a/arch/arm/cpu/armv7/lowlevel_init.S b/arch/arm/cpu/armv7/lowlevel_init.S index 658934d664a4..64f105864f87 100644 --- a/arch/arm/cpu/armv7/lowlevel_init.S +++ b/arch/arm/cpu/armv7/lowlevel_init.S @@ -15,7 +15,14 @@ #include <config.h> #include <linux/linkage.h>
-ENTRY(lowlevel_init) +.pushsection .text.s_init, "ax" +WEAK(s_init) + bx lr +ENDPROC(s_init) +.popsection + +.pushsection .text.lowlevel_init, "ax" +WEAK(lowlevel_init) /* * Setup a temporary stack. Global data is not available yet. */ @@ -61,3 +68,4 @@ ENTRY(lowlevel_init) bl s_init pop {ip, pc} ENDPROC(lowlevel_init) +.popsection
The ti816x/am389x SoC is the first generation in what U-Boot calls the "am33xx" family. In the first generation of this family the DDR initialization sequence is quite different from all of the subsequent generations. Whereas with ti814x (second generation) we can easily work the minor differenced between that and am33xx (third generation), our attempts to do this for ti816x weren't sufficient. Rather than add a large amount of #ifdef logic to make this different sequence work we add a new file, ti816x_emif4.c to handle the various required undocumented register writes and sequence and leverage what we can from arch/arm/mach-omap2/am33xx/ddr.c still. As DDR2 has similar problems today but I am unable to test it, we drop the DDR2 defines from the code rather than imply that it works by leaving it. We also remove a bunch of other untested code about changing the speed the DDR runs at.
Signed-off-by: Tom Rini trini@konsulko.com --- Note that today the board will boot perhaps 3 out of 5 times in a row. This allows us to perform power on reset reliably. And yes, there are lots of undocumented register writes, but no, it is unlikely that they will ever be documented. --- arch/arm/include/asm/arch-am33xx/clocks_am33xx.h | 1 + arch/arm/include/asm/arch-am33xx/ddr_defs.h | 6 + arch/arm/mach-omap2/am33xx/Makefile | 3 + arch/arm/mach-omap2/am33xx/board.c | 21 +++ arch/arm/mach-omap2/am33xx/clock_ti816x.c | 68 ++------ arch/arm/mach-omap2/am33xx/ddr.c | 9 ++ arch/arm/mach-omap2/am33xx/emif4.c | 41 +---- arch/arm/mach-omap2/am33xx/ti816x_emif4.c | 165 +++++++++++++++++++ board/ti/ti816x/evm.c | 192 +++++------------------ include/configs/ti816x_evm.h | 15 -- scripts/config_whitelist.txt | 5 - 11 files changed, 260 insertions(+), 266 deletions(-) create mode 100644 arch/arm/mach-omap2/am33xx/ti816x_emif4.c
diff --git a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h index 653ec1b2394f..bc1dab5b72b2 100644 --- a/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h +++ b/arch/arm/include/asm/arch-am33xx/clocks_am33xx.h @@ -29,6 +29,7 @@ #define NUM_OPPS 6
extern void enable_dmm_clocks(void); +extern void enable_emif_clocks(void); extern const struct dpll_params dpll_core_opp100; extern struct dpll_params dpll_mpu_opp100;
diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index 43e122e26191..a97ebb557bcd 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -354,9 +354,15 @@ struct ddr_ctrl { unsigned int ddrckectrl; };
+#ifdef CONFIG_TI816X +void config_ddr(const struct ddr_data *data, const struct cmd_control *ctrl, + const struct emif_regs *regs, + const struct dmm_lisa_map_regs *lisa_regs, int nrs); +#else void config_ddr(unsigned int pll, const struct ctrl_ioregs *ioregs, const struct ddr_data *data, const struct cmd_control *ctrl, const struct emif_regs *regs, int nr); +#endif void emif_get_ext_phy_ctrl_const_regs(const u32 **regs, u32 *size);
#endif /* _DDR_DEFS_H */ diff --git a/arch/arm/mach-omap2/am33xx/Makefile b/arch/arm/mach-omap2/am33xx/Makefile index 05cc8a11c5cb..1e4c04e7a65b 100644 --- a/arch/arm/mach-omap2/am33xx/Makefile +++ b/arch/arm/mach-omap2/am33xx/Makefile @@ -15,7 +15,10 @@ endif obj-$(CONFIG_TI816X) += clock_ti816x.o obj-y += sys_info.o obj-y += ddr.o +ifeq ($(CONFIG_TI816X)$(CONFIG_SKIP_LOWLEVEL_INIT),) obj-y += emif4.o +endif +obj-$(CONFIG_TI816X) += ti816x_emif4.o obj-y += board.o obj-y += mux.o
diff --git a/arch/arm/mach-omap2/am33xx/board.c b/arch/arm/mach-omap2/am33xx/board.c index a8b5d13238a2..faf7d07a0330 100644 --- a/arch/arm/mach-omap2/am33xx/board.c +++ b/arch/arm/mach-omap2/am33xx/board.c @@ -39,6 +39,27 @@
DECLARE_GLOBAL_DATA_PTR;
+int dram_init(void) +{ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + sdram_init(); +#endif + + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size( + (void *)CONFIG_SYS_SDRAM_BASE, + CONFIG_MAX_RAM_BANK_SIZE); + return 0; +} + +int dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; + gd->bd->bi_dram[0].size = gd->ram_size; + + return 0; +} + #if !CONFIG_IS_ENABLED(OF_CONTROL) static const struct ns16550_platdata am33xx_serial[] = { { .base = CONFIG_SYS_NS16550_COM1, .reg_shift = 2, diff --git a/arch/arm/mach-omap2/am33xx/clock_ti816x.c b/arch/arm/mach-omap2/am33xx/clock_ti816x.c index 079ddd7eb9fc..967623d467b0 100644 --- a/arch/arm/mach-omap2/am33xx/clock_ti816x.c +++ b/arch/arm/mach-omap2/am33xx/clock_ti816x.c @@ -54,55 +54,6 @@ #define MAIN_MDIV7 0x4
/* DDR PLL */ -#if defined(CONFIG_TI816X_DDR_PLL_400) /* 400 MHz */ -#define DDR_N 59 -#define DDR_P 0x1 -#define DDR_MDIV1 0x4 -#define DDR_INTFREQ2 0x8 -#define DDR_FRACFREQ2 0xD99999 -#define DDR_MDIV2 0x1E -#define DDR_INTFREQ3 0x8 -#define DDR_FRACFREQ3 0x0 -#define DDR_MDIV3 0x4 -#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ4 0x0 -#define DDR_MDIV4 0x4 -#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ5 0x0 -#define DDR_MDIV5 0x4 -#elif defined(CONFIG_TI816X_DDR_PLL_531) /* 531 MHz */ -#define DDR_N 59 -#define DDR_P 0x1 -#define DDR_MDIV1 0x3 -#define DDR_INTFREQ2 0x8 -#define DDR_FRACFREQ2 0xD99999 -#define DDR_MDIV2 0x1E -#define DDR_INTFREQ3 0x8 -#define DDR_FRACFREQ3 0x0 -#define DDR_MDIV3 0x4 -#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ4 0x0 -#define DDR_MDIV4 0x4 -#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ5 0x0 -#define DDR_MDIV5 0x4 -#elif defined(CONFIG_TI816X_DDR_PLL_675) /* 675 MHz */ -#define DDR_N 50 -#define DDR_P 0x1 -#define DDR_MDIV1 0x2 -#define DDR_INTFREQ2 0x9 -#define DDR_FRACFREQ2 0x0 -#define DDR_MDIV2 0x19 -#define DDR_INTFREQ3 0x13 -#define DDR_FRACFREQ3 0x800000 -#define DDR_MDIV3 0x2 -#define DDR_INTFREQ4 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ4 0x0 -#define DDR_MDIV4 0x4 -#define DDR_INTFREQ5 0xE /* Expansion DDR clk */ -#define DDR_FRACFREQ5 0x0 -#define DDR_MDIV5 0x4 -#elif defined(CONFIG_TI816X_DDR_PLL_796) /* 796 MHz */ #define DDR_N 59 #define DDR_P 0x1 #define DDR_MDIV1 0x2 @@ -118,12 +69,10 @@ #define DDR_INTFREQ5 0xE /* Expansion DDR clk */ #define DDR_FRACFREQ5 0x0 #define DDR_MDIV5 0x4 -#endif
#define CONTROL_STATUS (CTRL_BASE + 0x40) #define DDR_RCD (CTRL_BASE + 0x070C) #define CM_TIMER1_CLKSEL (PRCM_BASE + 0x390) -#define DMM_PAT_BASE_ADDR (DMM_BASE + 0x420) #define CM_ALWON_CUST_EFUSE_CLKCTRL (PRCM_BASE + 0x1628)
#define INTCPS_SYSCONFIG 0x48200010 @@ -187,6 +136,15 @@ const struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE;
void enable_dmm_clocks(void) { + writel(PRCM_MOD_EN, &cmdef->dmmclkctrl); + /* Wait for dmm to be fully functional, including OCP */ + while (((readl(&cmdef->dmmclkctrl) >> 17) & 0x3) != 0) + ; +} + +void enable_emif_clocks(void) +{ + writel(PRCM_MOD_EN, &cmdef->fwclkctrl); writel(PRCM_MOD_EN, &cmdef->l3fastclkstctrl); writel(PRCM_MOD_EN, &cmdef->emif0clkctrl); writel(PRCM_MOD_EN, &cmdef->emif1clkctrl); @@ -200,14 +158,6 @@ void enable_dmm_clocks(void) /* Wait for emif1 to be fully functional, including OCP */ while (((readl(&cmdef->emif1clkctrl) >> 17) & 0x3) != 0) ; - - writel(PRCM_MOD_EN, &cmdef->dmmclkctrl); - /* Wait for dmm to be fully functional, including OCP */ - while (((readl(&cmdef->dmmclkctrl) >> 17) & 0x3) != 0) - ; - - /* Enable Tiled Access */ - writel(0x80000000, DMM_PAT_BASE_ADDR); }
/* assume delay is aprox at least 1us */ diff --git a/arch/arm/mach-omap2/am33xx/ddr.c b/arch/arm/mach-omap2/am33xx/ddr.c index 690487e7c38b..7bf19ed9665f 100644 --- a/arch/arm/mach-omap2/am33xx/ddr.c +++ b/arch/arm/mach-omap2/am33xx/ddr.c @@ -163,6 +163,14 @@ void config_sdram_emif4d5(const struct emif_regs *regs, int nr) */ void config_sdram(const struct emif_regs *regs, int nr) { +#ifdef CONFIG_TI816X + writel(regs->sdram_config, &emif_reg[nr]->emif_sdram_config); + writel(regs->emif_ddr_phy_ctlr_1, &emif_reg[nr]->emif_ddr_phy_ctrl_1); + writel(regs->emif_ddr_phy_ctlr_1, &emif_reg[nr]->emif_ddr_phy_ctrl_1_shdw); + writel(0x0000613B, &emif_reg[nr]->emif_sdram_ref_ctrl); /* initially a large refresh period */ + writel(0x1000613B, &emif_reg[nr]->emif_sdram_ref_ctrl); /* trigger initialization */ + writel(regs->ref_ctrl, &emif_reg[nr]->emif_sdram_ref_ctrl); +#else if (regs->zq_config) { writel(regs->zq_config, &emif_reg[nr]->emif_zq_config); writel(regs->sdram_config, &cstat->secure_emif_sdram_config); @@ -184,6 +192,7 @@ void config_sdram(const struct emif_regs *regs, int nr) /* Write REG_COS_COUNT_1, REG_COS_COUNT_2, and REG_PR_OLD_COUNT. */ if (regs->ocp_config) writel(regs->ocp_config, &emif_reg[nr]->emif_l3_config); +#endif }
/** diff --git a/arch/arm/mach-omap2/am33xx/emif4.c b/arch/arm/mach-omap2/am33xx/emif4.c index 3a110f284570..68c770517871 100644 --- a/arch/arm/mach-omap2/am33xx/emif4.c +++ b/arch/arm/mach-omap2/am33xx/emif4.c @@ -17,40 +17,9 @@ #include <asm/io.h> #include <asm/emif.h>
-DECLARE_GLOBAL_DATA_PTR; - -int dram_init(void) -{ -#ifndef CONFIG_SKIP_LOWLEVEL_INIT - sdram_init(); -#endif - - /* dram_init must store complete ramsize in gd->ram_size */ - gd->ram_size = get_ram_size( - (void *)CONFIG_SYS_SDRAM_BASE, - CONFIG_MAX_RAM_BANK_SIZE); - return 0; -} - -int dram_init_banksize(void) -{ - gd->bd->bi_dram[0].start = CONFIG_SYS_SDRAM_BASE; - gd->bd->bi_dram[0].size = gd->ram_size; - - return 0; -} - - -#ifndef CONFIG_SKIP_LOWLEVEL_INIT -#ifdef CONFIG_TI81XX -static struct dmm_lisa_map_regs *hw_lisa_map_regs = - (struct dmm_lisa_map_regs *)DMM_BASE; -#endif -#ifndef CONFIG_TI816X static struct vtp_reg *vtpreg[2] = { (struct vtp_reg *)VTP0_CTRL_ADDR, (struct vtp_reg *)VTP1_CTRL_ADDR}; -#endif #ifdef CONFIG_AM33XX static struct ddr_ctrl *ddrctrl = (struct ddr_ctrl *)DDR_CTRL_ADDR; #endif @@ -60,9 +29,12 @@ static struct cm_device_inst *cm_device = (struct cm_device_inst *)CM_DEVICE_INST; #endif
-#ifdef CONFIG_TI81XX +#ifdef CONFIG_TI814X void config_dmm(const struct dmm_lisa_map_regs *regs) { + struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)DMM_BASE; + enable_dmm_clocks();
writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); @@ -77,7 +49,6 @@ void config_dmm(const struct dmm_lisa_map_regs *regs) } #endif
-#ifndef CONFIG_TI816X static void config_vtp(int nr) { writel(readl(&vtpreg[nr]->vtp0ctrlreg) | VTP_CTRL_ENABLE, @@ -92,7 +63,6 @@ static void config_vtp(int nr) VTP_CTRL_READY) ; } -#endif
void __weak ddr_pll_config(unsigned int ddrpll_m) { @@ -103,9 +73,7 @@ void config_ddr(unsigned int pll, const struct ctrl_ioregs *ioregs, const struct emif_regs *regs, int nr) { ddr_pll_config(pll); -#ifndef CONFIG_TI816X config_vtp(nr); -#endif config_cmd_ctrl(ctrl, nr);
config_ddr_data(data, nr); @@ -139,4 +107,3 @@ void config_ddr(unsigned int pll, const struct ctrl_ioregs *ioregs, else config_sdram(regs, nr); } -#endif diff --git a/arch/arm/mach-omap2/am33xx/ti816x_emif4.c b/arch/arm/mach-omap2/am33xx/ti816x_emif4.c new file mode 100644 index 000000000000..2e7ea90da961 --- /dev/null +++ b/arch/arm/mach-omap2/am33xx/ti816x_emif4.c @@ -0,0 +1,165 @@ +/* + * ti816x_emif4.c + * + * TI816x emif4 configuration file + * + * Copyright (C) 2017, Konsulko Group + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/cpu.h> +#include <asm/arch/ddr_defs.h> +#include <asm/arch/hardware.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> +#include <asm/io.h> +#include <asm/emif.h> + +/********************************************************************* + * Init DDR3 on TI816X EVM + *********************************************************************/ +static void ddr_init_settings(const struct cmd_control *ctrl, int emif) +{ + /* + * setup use_rank_delays to 1. This is only necessary when + * multiple ranks are in use. Though the EVM does not have + * multiple ranks, this is a good value to set. + */ + writel(1, DDRPHY_CONFIG_BASE + 0x134); // DATA0_REG_PHY_USE_RANK0_DELAYS + writel(1, DDRPHY_CONFIG_BASE + 0x1d8); // DATA1_REG_PHY_USE_RANK0_DELAYS + writel(1, DDRPHY_CONFIG_BASE + 0x27c); // DATA2_REG_PHY_USE_RANK0_DELAYS + writel(1, DDRPHY_CONFIG_BASE + 0x320); // DATA3_REG_PHY_USE_RANK0_DELAYS + + config_cmd_ctrl(ctrl, emif); + + /* for ddr3 this needs to be set to 1 */ + writel(0x1, DDRPHY_CONFIG_BASE + 0x0F8); /* init mode */ + writel(0x1, DDRPHY_CONFIG_BASE + 0x104); + writel(0x1, DDRPHY_CONFIG_BASE + 0x19C); + writel(0x1, DDRPHY_CONFIG_BASE + 0x1A8); + writel(0x1, DDRPHY_CONFIG_BASE + 0x240); + writel(0x1, DDRPHY_CONFIG_BASE + 0x24C); + writel(0x1, DDRPHY_CONFIG_BASE + 0x2E4); + writel(0x1, DDRPHY_CONFIG_BASE + 0x2F0); + + /* + * This represents the initial value for the leveling process. The + * value is a ratio - so 0x100 represents one cycle. The real delay + * is determined through the leveling process. + * + * During the leveling process, 0x20 is subtracted from the value, so + * we have added that to the value we want to set. We also set the + * values such that byte3 completes leveling after byte2 and byte1 + * after byte0. + */ + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x0F0); /* data0 writelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x0F4); /* */ + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x194); /* data1 writelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x198); /* */ + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x238); /* data2 writelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x23c); /* */ + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x2dc); /* data3 writelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x2e0); /* */ + + + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x0FC); /* data0 gatelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x100); + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x1A0); /* data1 gatelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x1A4); + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x244); /* data2 gatelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x248); + writel((0x20 << 10) | 0x20, DDRPHY_CONFIG_BASE + 0x2E8); /* data3 gatelvl init ratio */ + writel(0x0, DDRPHY_CONFIG_BASE + 0x2EC); + + writel(0x5, DDRPHY_CONFIG_BASE + 0x00C); /* cmd0 io config - output impedance of pad */ + writel(0x5, DDRPHY_CONFIG_BASE + 0x010); /* cmd0 io clk config - output impedance of pad */ + writel(0x5, DDRPHY_CONFIG_BASE + 0x040); /* cmd1 io config - output impedance of pad */ + writel(0x5, DDRPHY_CONFIG_BASE + 0x044); /* cmd1 io clk config - output impedance of pad */ + writel(0x5, DDRPHY_CONFIG_BASE + 0x074); /* cmd2 io config - output impedance of pad */ + writel(0x5, DDRPHY_CONFIG_BASE + 0x078); /* cmd2 io clk config - output impedance of pad */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x0A8); /* data0 io config - output impedance of pad */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x0AC); /* data0 io clk config - output impedance of pad */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x14C); /* data1 io config - output impedance of pa */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x150); /* data1 io clk config - output impedance of pad */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x1F0); /* data2 io config - output impedance of pa */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x1F4); /* data2 io clk config - output impedance of pad */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x294); /* data3 io config - output impedance of pa */ + writel(0x4, DDRPHY_CONFIG_BASE + 0x298); /* data3 io clk config - output impedance of pad */ +} + +static void ddr3_sw_levelling(const struct ddr_data *data, int emif) +{ + /* Set the correct value to DDR_VTP_CTRL_0 */ + writel(0x6, (DDRPHY_CONFIG_BASE + 0x358)); + + writel(data->datafwsratio0, (DDRPHY_CONFIG_BASE + 0x108)); + writel(data->datafwsratio0, (DDRPHY_CONFIG_BASE + 0x1AC)); + writel(data->datafwsratio0, (DDRPHY_CONFIG_BASE + 0x250)); + writel(data->datafwsratio0, (DDRPHY_CONFIG_BASE + 0x2F4)); + + writel(data->datawdsratio0, (DDRPHY_CONFIG_BASE + 0x0DC)); + writel(data->datawdsratio0, (DDRPHY_CONFIG_BASE + 0x180)); + writel(data->datawdsratio0, (DDRPHY_CONFIG_BASE + 0x224)); + writel(data->datawdsratio0, (DDRPHY_CONFIG_BASE + 0x2C8)); + + writel(data->datawrsratio0, (DDRPHY_CONFIG_BASE + 0x120)); + writel(data->datawrsratio0, (DDRPHY_CONFIG_BASE + 0x1C4)); + writel(data->datawrsratio0, (DDRPHY_CONFIG_BASE + 0x268)); + writel(data->datawrsratio0, (DDRPHY_CONFIG_BASE + 0x30C)); + + writel(data->datardsratio0, (DDRPHY_CONFIG_BASE + 0x0C8)); + writel(data->datardsratio0, (DDRPHY_CONFIG_BASE + 0x16C)); + writel(data->datardsratio0, (DDRPHY_CONFIG_BASE + 0x210)); + writel(data->datardsratio0, (DDRPHY_CONFIG_BASE + 0x2B4)); +} + +static struct dmm_lisa_map_regs *hw_lisa_map_regs = + (struct dmm_lisa_map_regs *)DMM_BASE; + +#define DMM_PAT_BASE_ADDR (DMM_BASE + 0x420) +void config_dmm(const struct dmm_lisa_map_regs *regs) +{ + writel(0, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(0, &hw_lisa_map_regs->dmm_lisa_map_0); + + writel(regs->dmm_lisa_map_3, &hw_lisa_map_regs->dmm_lisa_map_3); + writel(regs->dmm_lisa_map_2, &hw_lisa_map_regs->dmm_lisa_map_2); + writel(regs->dmm_lisa_map_1, &hw_lisa_map_regs->dmm_lisa_map_1); + writel(regs->dmm_lisa_map_0, &hw_lisa_map_regs->dmm_lisa_map_0); + + /* Enable Tiled Access */ + writel(0x80000000, DMM_PAT_BASE_ADDR); +} + +void config_ddr(const struct ddr_data *data, const struct cmd_control *ctrl, + const struct emif_regs *regs, + const struct dmm_lisa_map_regs *lisa_regs, int nrs) +{ + int i; + + enable_emif_clocks(); + + for (i = 0; i < nrs; i++) + ddr_init_settings(ctrl, i); + + enable_dmm_clocks(); + + /* Program the DMM to for non-interleaved configuration */ + config_dmm(lisa_regs); + + /* Program EMIF CFG Registers */ + for (i = 0; i < nrs; i++) { + set_sdram_timings(regs, i); + config_sdram(regs, i); + } + + udelay(1000); + for (i = 0; i < nrs; i++) + ddr3_sw_levelling(data, i); + + udelay(50000); /* Some delay needed */ +} diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index b6bf16236f40..ad98e09e2082 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -41,176 +41,68 @@ static struct module_pin_mux mmc_pin_mux[] = { { -1 }, };
-const struct dmm_lisa_map_regs evm_lisa_map_regs = { - .dmm_lisa_map_0 = 0x00000000, - .dmm_lisa_map_1 = 0x00000000, - .dmm_lisa_map_2 = 0x80640300, - .dmm_lisa_map_3 = 0xC0640320, -}; - -/* - * DDR2 related definitions - */ -#ifdef CONFIG_TI816X_EVM_DDR2 -static struct ddr_data ddr2_data = { - .datardsratio0 = ((0x40<<10) | (0x40<<0)), - .datawdsratio0 = ((0x4A<<10) | (0x4A<<0)), - .datawiratio0 = ((0x0<<10) | (0x0<<0)), - .datagiratio0 = ((0x0<<10) | (0x0<<0)), - .datafwsratio0 = ((0x13A<<10) | (0x13A<<0)), - .datawrsratio0 = ((0x8A<<10) | (0x8A<<0)), -}; - -static struct cmd_control ddr2_ctrl = { - .cmd0csratio = 0x80, - .cmd0iclkout = 0x00, - - .cmd1csratio = 0x80, - .cmd1iclkout = 0x00, - - .cmd2csratio = 0x80, - .cmd2iclkout = 0x00, - -}; - -static struct emif_regs ddr2_emif0_regs = { - .sdram_config = 0x43801A3A, - .ref_ctrl = 0x10000C30, - .sdram_tim1 = 0x0AAB15E2, - .sdram_tim2 = 0x423631D2, - .sdram_tim3 = 0x0080032F, - .emif_ddr_phy_ctlr_1 = 0x0, /* depend on cpu rev, set later */ -}; +void set_uart_mux_conf(void) {}
-static struct emif_regs ddr2_emif1_regs = { - .sdram_config = 0x43801A3A, - .ref_ctrl = 0x10000C30, - .sdram_tim1 = 0x0AAB15E2, - .sdram_tim2 = 0x423631D2, - .sdram_tim3 = 0x0080032F, - .emif_ddr_phy_ctlr_1 = 0x0, /* depend on cpu rev, set later */ -}; -#endif +void set_mux_conf_regs(void) +{ + configure_module_pin_mux(mmc_pin_mux); +}
/* - * DDR3 related definitions + * EMIF Paramters. Refer the EMIF register documentation and the + * memory datasheet for details. This is for 796 MHz. */ - -#if defined(CONFIG_TI816X_DDR_PLL_400) -#define RD_DQS 0x03B -#define WR_DQS 0x0A6 -#define RD_DQS_GATE 0x12A -#define EMIF_SDCFG 0x62A41032 -#define EMIF_SDREF 0x10000C30 -#define EMIF_TIM1 0x0CCCE524 -#define EMIF_TIM2 0x30308023 -#define EMIF_TIM3 0x009F82CF -#define EMIF_PHYCFG 0x0000010B -#elif defined(CONFIG_TI816X_DDR_PLL_531) -#define RD_DQS 0x039 -#define WR_DQS 0x0B4 -#define RD_DQS_GATE 0x13D -#define EMIF_SDCFG 0x62A51832 -#define EMIF_SDREF 0x1000102E -#define EMIF_TIM1 0x0EF136AC -#define EMIF_TIM2 0x30408063 -#define EMIF_TIM3 0x009F83AF -#define EMIF_PHYCFG 0x0000010C -#elif defined(CONFIG_TI816X_DDR_PLL_675) -#define RD_DQS 0x039 -#define WR_DQS 0x091 -#define RD_DQS_GATE 0x196 -#define EMIF_SDCFG 0x62A63032 -#define EMIF_SDREF 0x10001491 -#define EMIF_TIM1 0x13358875 -#define EMIF_TIM2 0x5051806C -#define EMIF_TIM3 0x009F84AF -#define EMIF_PHYCFG 0x0000010F -#elif defined(CONFIG_TI816X_DDR_PLL_796) -#define RD_DQS 0x035 -#define WR_DQS 0x093 -#define RD_DQS_GATE 0x1B3 -#define EMIF_SDCFG 0x62A73832 -#define EMIF_SDREF 0x10001841 -#define EMIF_TIM1 0x1779C9FE -#define EMIF_TIM2 0x50608074 -#define EMIF_TIM3 0x009F857F -#define EMIF_PHYCFG 0x00000110 -#endif - -static struct ddr_data ddr3_data = { - .datardsratio0 = ((RD_DQS<<10) | (RD_DQS<<0)), - .datawdsratio0 = ((WR_DQS<<10) | (WR_DQS<<0)), - .datawiratio0 = ((0x20<<10) | 0x20<<0), - .datagiratio0 = ((0x20<<10) | 0x20<<0), - .datafwsratio0 = ((RD_DQS_GATE<<10) | (RD_DQS_GATE<<0)), - .datawrsratio0 = (((WR_DQS+0x40)<<10) | ((WR_DQS+0x40)<<0)), +#define EMIF_TIM1 0x1779C9FE +#define EMIF_TIM2 0x50608074 +#define EMIF_TIM3 0x009F857F +#define EMIF_SDREF 0x10001841 +#define EMIF_SDCFG 0x62A73832 +#define EMIF_PHYCFG 0x00000110 +static const struct emif_regs ddr3_emif_regs = { + .sdram_config = EMIF_SDCFG, + .ref_ctrl = EMIF_SDREF, + .sdram_tim1 = EMIF_TIM1, + .sdram_tim2 = EMIF_TIM2, + .sdram_tim3 = EMIF_TIM3, + .emif_ddr_phy_ctlr_1 = EMIF_PHYCFG, };
static const struct cmd_control ddr3_ctrl = { .cmd0csratio = 0x100, .cmd0iclkout = 0x001, - .cmd1csratio = 0x100, .cmd1iclkout = 0x001, - .cmd2csratio = 0x100, .cmd2iclkout = 0x001, };
-static const struct emif_regs ddr3_emif0_regs = { - .sdram_config = EMIF_SDCFG, - .ref_ctrl = EMIF_SDREF, - .sdram_tim1 = EMIF_TIM1, - .sdram_tim2 = EMIF_TIM2, - .sdram_tim3 = EMIF_TIM3, - .emif_ddr_phy_ctlr_1 = EMIF_PHYCFG, +/* These values are obtained from the CCS app */ +#define RD_DQS_GATE (0x1B3) +#define RD_DQS (0x35) +#define WR_DQS (0x93) +static struct ddr_data ddr3_data = { + .datardsratio0 = ((RD_DQS<<10) | (RD_DQS<<0)), + .datawdsratio0 = ((WR_DQS<<10) | (WR_DQS<<0)), + .datawiratio0 = ((0x20<<10) | 0x20<<0), + .datagiratio0 = ((0x20<<10) | 0x20<<0), + .datafwsratio0 = ((RD_DQS_GATE<<10) | (RD_DQS_GATE<<0)), + .datawrsratio0 = (((WR_DQS+0x40)<<10) | ((WR_DQS+0x40)<<0)), };
-static const struct emif_regs ddr3_emif1_regs = { - .sdram_config = EMIF_SDCFG, - .ref_ctrl = EMIF_SDREF, - .sdram_tim1 = EMIF_TIM1, - .sdram_tim2 = EMIF_TIM2, - .sdram_tim3 = EMIF_TIM3, - .emif_ddr_phy_ctlr_1 = EMIF_PHYCFG, +static const struct dmm_lisa_map_regs evm_lisa_map_regs = { + .dmm_lisa_map_0 = 0x00000000, + .dmm_lisa_map_1 = 0x00000000, + .dmm_lisa_map_2 = 0x80640300, + .dmm_lisa_map_3 = 0xC0640320, };
-void set_uart_mux_conf(void) {} - -void set_mux_conf_regs(void) -{ - configure_module_pin_mux(mmc_pin_mux); -} - void sdram_init(void) { - config_dmm(&evm_lisa_map_regs); - -#ifdef CONFIG_TI816X_EVM_DDR2 - if (CONFIG_TI816X_USE_EMIF0) { - ddr2_emif0_regs.emif_ddr_phy_ctlr_1 = - (get_cpu_rev() == 0x1 ? 0x0000010B : 0x0000030B); - config_ddr(0, NULL, &ddr2_data, &ddr2_ctrl, &ddr2_emif0_regs, - 0); - } - - if (CONFIG_TI816X_USE_EMIF1) { - ddr2_emif1_regs.emif_ddr_phy_ctlr_1 = - (get_cpu_rev() == 0x1 ? 0x0000010B : 0x0000030B); - config_ddr(1, NULL, &ddr2_data, &ddr2_ctrl, &ddr2_emif1_regs, - 1); - } -#endif - -#ifdef CONFIG_TI816X_EVM_DDR3 - if (CONFIG_TI816X_USE_EMIF0) - config_ddr(0, NULL, &ddr3_data, &ddr3_ctrl, &ddr3_emif0_regs, - 0); - - if (CONFIG_TI816X_USE_EMIF1) - config_ddr(1, NULL, &ddr3_data, &ddr3_ctrl, &ddr3_emif1_regs, - 1); -#endif + /* + * Pass in our DDR3 config information and that we have 2 EMIFs to + * configure. + */ + config_ddr(&ddr3_data, &ddr3_ctrl, &ddr3_emif_regs, + &evm_lisa_map_regs, 2); } #endif /* CONFIG_SPL_BUILD */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 51b09d4b5616..335f71f292f5 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -52,21 +52,6 @@
#define CONFIG_FS_FAT
-/* - * Only one of the following two options (DDR3/DDR2) should be enabled - * CONFIG_TI816X_EVM_DDR2 - * CONFIG_TI816X_EVM_DDR3 - */ -#define CONFIG_TI816X_EVM_DDR3 - -/* - * Supported values: 400, 531, 675 or 796 MHz - */ -#define CONFIG_TI816X_DDR_PLL_796 - -#define CONFIG_TI816X_USE_EMIF0 1 -#define CONFIG_TI816X_USE_EMIF1 1 - #define CONFIG_NR_DRAM_BANKS 2 /* we have 2 banks of DRAM */ #define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ #define PHYS_DRAM_1_SIZE 0x40000000 /* 1 GB */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index fa9c3fc8cbd0..8d56daebedd0 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -6113,11 +6113,6 @@ CONFIG_THUMB2_KERNEL CONFIG_THUNDERX CONFIG_TI814X CONFIG_TI816X -CONFIG_TI816X_DDR_PLL_796 -CONFIG_TI816X_EVM_DDR2 -CONFIG_TI816X_EVM_DDR3 -CONFIG_TI816X_USE_EMIF0 -CONFIG_TI816X_USE_EMIF1 CONFIG_TI81XX CONFIG_TIMESTAMP CONFIG_TIZEN
On this platform, we can trace a general failure to boot to enabling / disabling this option. When this is enabled, we go off into the weeds during SPL and are unable to talk with the SD card and mmc_initialize() fails.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/ti816x_evm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 8021defb87af..abfc7d5b120f 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -27,3 +27,4 @@ CONFIG_CMD_FAT=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y +# CONFIG_USE_PRIVATE_LIBGCC is not set
The TI8168-EVM comes with NAND on board. Enable it and move environment over there.
Signed-off-by: Tom Rini trini@konsulko.com --- board/ti/ti816x/evm.c | 4 ++- configs/ti816x_evm_defconfig | 2 ++ include/configs/ti816x_evm.h | 60 +++++++++++++++++++++++++++++++++++++++++--- 3 files changed, 62 insertions(+), 4 deletions(-)
diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index ad98e09e2082..8f07e2c9aa00 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -25,11 +25,13 @@ DECLARE_GLOBAL_DATA_PTR; int board_init(void) { gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; +#if defined(CONFIG_NAND) + gpmc_init(); +#endif return 0; }
#ifdef CONFIG_SPL_BUILD - static struct module_pin_mux mmc_pin_mux[] = { { OFFSET(pincntl157), PULLDOWN_EN | PULLUDDIS | MODE(0x0) }, { OFFSET(pincntl158), PULLDOWN_EN | PULLUDEN | MODE(0x0) }, diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index abfc7d5b120f..4f9019220b1b 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -7,7 +7,9 @@ CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_SPL_FAT_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 335f71f292f5..35ee775adc42 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -70,8 +70,6 @@ #define CONFIG_SYS_TIMERBASE 0x4802E000 #define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */
-#undef CONFIG_NAND_OMAP_GPMC - /* * NS16550 Configuration */ @@ -88,10 +86,66 @@ #define CONFIG_SERIAL3 #define CONFIG_CONS_INDEX 1
-#define CONFIG_ENV_IS_NOWHERE +/* + * GPMC NAND block. We support 1 device and the physical address to + * access CS0 at is 0x8000000. + */ +#define CONFIG_SYS_NAND_BASE 0x8000000 +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +/* NAND: SPL related configs */ +#define CONFIG_SPL_NAND_BASE +#define CONFIG_SPL_NAND_DRIVERS +#define CONFIG_SPL_NAND_ECC +#define CONFIG_SPL_NAND_AM33XX_BCH +#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE + +/* NAND: device related configs */ +#define CONFIG_SYS_NAND_5_ADDR_CYCLE +#define CONFIG_SYS_NAND_BUSWIDTH_16BIT +#define CONFIG_SYS_NAND_PAGE_COUNT (CONFIG_SYS_NAND_BLOCK_SIZE / \ + CONFIG_SYS_NAND_PAGE_SIZE) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 +#define CONFIG_SYS_NAND_OOBSIZE 64 +#define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) +/* NAND: driver related configs */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_NAND_OMAP_GPMC_PREFETCH +#define CONFIG_NAND_OMAP_ELM +#define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS +#define CONFIG_SYS_NAND_ECCPOS { 2, 3, 4, 5, 6, 7, 8, 9, \ + 10, 11, 12, 13, 14, 15, 16, 17, \ + 18, 19, 20, 21, 22, 23, 24, 25, \ + 26, 27, 28, 29, 30, 31, 32, 33, \ + 34, 35, 36, 37, 38, 39, 40, 41, \ + 42, 43, 44, 45, 46, 47, 48, 49, \ + 50, 51, 52, 53, 54, 55, 56, 57, } + +#define CONFIG_SYS_NAND_ECCSIZE 512 +#define CONFIG_SYS_NAND_ECCBYTES 14 +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_NAND_OMAP_ECCSCHEME OMAP_ECC_BCH8_CODE_HW +#define MTDIDS_DEFAULT "nand0=nand.0" +#define MTDPARTS_DEFAULT "mtdparts=nand.0:" \ + "128k(NAND.SPL)," \ + "128k(NAND.SPL.backup1)," \ + "128k(NAND.SPL.backup2)," \ + "128k(NAND.SPL.backup3)," \ + "256k(NAND.u-boot-spl-os)," \ + "1m(NAND.u-boot)," \ + "128k(NAND.u-boot-env)," \ + "128k(NAND.u-boot-env.backup1)," \ + "8m(NAND.kernel)," \ + "-(NAND.file-system)" +#define CONFIG_SYS_NAND_U_BOOT_OFFS 0x000c0000 +#define CONFIG_ENV_IS_IN_NAND +#define CONFIG_ENV_OFFSET 0x001c0000 +#define CONFIG_ENV_OFFSET_REDUND 0x001e0000 +#define CONFIG_SYS_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE
/* SPL */ /* Defines for SPL */ +#define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x40400000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \
This brings in the required dts/dtsi files for the TI8168-EVM from the Linux Kernel v4.11 release.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/dm8168-evm.dts | 175 ++++++++++++++ arch/arm/dts/dm816x-clocks.dtsi | 250 +++++++++++++++++++ arch/arm/dts/dm816x.dtsi | 518 ++++++++++++++++++++++++++++++++++++++++ 4 files changed, 944 insertions(+) create mode 100644 arch/arm/dts/dm8168-evm.dts create mode 100644 arch/arm/dts/dm816x-clocks.dtsi create mode 100644 arch/arm/dts/dm816x.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index a985c5d216d6..73b10921443a 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -146,6 +146,7 @@ dtb-$(CONFIG_AM33XX) += am335x-boneblack.dtb am335x-bone.dtb \ dtb-$(CONFIG_AM43XX) += am437x-gp-evm.dtb am437x-sk-evm.dtb \ am43x-epos-evm.dtb \ am437x-idk-evm.dtb +dtb-$(CONFIG_TI816X) += dm8168-evm.dtb dtb-$(CONFIG_THUNDERX) += thunderx-88xx.dtb
dtb-$(CONFIG_ARCH_SOCFPGA) += \ diff --git a/arch/arm/dts/dm8168-evm.dts b/arch/arm/dts/dm8168-evm.dts new file mode 100644 index 000000000000..0bf55fa72dea --- /dev/null +++ b/arch/arm/dts/dm8168-evm.dts @@ -0,0 +1,175 @@ +/* + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ +/dts-v1/; + +#include "dm816x.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> + +/ { + model = "DM8168 EVM"; + compatible = "ti,dm8168-evm", "ti,dm8168"; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x40000000 /* 1 GB */ + 0xc0000000 0x40000000>; /* 1 GB */ + }; + + /* FDC6331L controlled by SD_POW pin */ + vmmcsd_fixed: fixedregulator0 { + compatible = "regulator-fixed"; + regulator-name = "vmmcsd_fixed"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&dm816x_pinmux { + mcspi1_pins: pinmux_mcspi1_pins { + pinctrl-single,pins = < + DM816X_IOPAD(0x0a94, MUX_MODE0) /* SPI_SCLK */ + DM816X_IOPAD(0x0a98, MUX_MODE0) /* SPI_SCS0 */ + DM816X_IOPAD(0x0aa8, MUX_MODE0) /* SPI_D0 */ + DM816X_IOPAD(0x0aac, MUX_MODE0) /* SPI_D1 */ + >; + }; + + mmc_pins: pinmux_mmc_pins { + pinctrl-single,pins = < + DM816X_IOPAD(0x0a70, MUX_MODE0) /* SD_POW */ + DM816X_IOPAD(0x0a74, MUX_MODE0) /* SD_CLK */ + DM816X_IOPAD(0x0a78, MUX_MODE0) /* SD_CMD */ + DM816X_IOPAD(0x0a7C, MUX_MODE0) /* SD_DAT0 */ + DM816X_IOPAD(0x0a80, MUX_MODE0) /* SD_DAT1 */ + DM816X_IOPAD(0x0a84, MUX_MODE0) /* SD_DAT2 */ + DM816X_IOPAD(0x0a88, MUX_MODE0) /* SD_DAT2 */ + DM816X_IOPAD(0x0a8c, MUX_MODE2) /* GP1[7] */ + DM816X_IOPAD(0x0a90, MUX_MODE2) /* GP1[8] */ + >; + }; + + usb0_pins: pinmux_usb0_pins { + pinctrl-single,pins = < + DM816X_IOPAD(0x0d04, MUX_MODE0) /* USB0_DRVVBUS */ + >; + }; + + usb1_pins: pinmux_usb1_pins { + pinctrl-single,pins = < + DM816X_IOPAD(0x0d08, MUX_MODE0) /* USB1_DRVVBUS */ + >; + }; +}; + +&i2c1 { + extgpio0: pcf8575@20 { + compatible = "nxp,pcf8575"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&i2c2 { + extgpio1: pcf8575@20 { + compatible = "nxp,pcf8575"; + reg = <0x20>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&gpmc { + ranges = <0 0 0x04000000 0x01000000>; /* CS0: 16MB for NAND */ + + nand@0,0 { + compatible = "ti,omap2-nand"; + linux,mtd-name= "micron,mt29f2g16aadwp"; + reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ + interrupt-parent = <&gpmc>; + interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ + <1 IRQ_TYPE_NONE>; /* termcount */ + #address-cells = <1>; + #size-cells = <1>; + ti,nand-ecc-opt = "bch8"; + nand-bus-width = <16>; + gpmc,device-width = <2>; + gpmc,sync-clk-ps = <0>; + gpmc,cs-on-ns = <0>; + gpmc,cs-rd-off-ns = <44>; + gpmc,cs-wr-off-ns = <44>; + gpmc,adv-on-ns = <6>; + gpmc,adv-rd-off-ns = <34>; + gpmc,adv-wr-off-ns = <44>; + gpmc,we-on-ns = <0>; + gpmc,we-off-ns = <40>; + gpmc,oe-on-ns = <0>; + gpmc,oe-off-ns = <54>; + gpmc,access-ns = <64>; + gpmc,rd-cycle-ns = <82>; + gpmc,wr-cycle-ns = <82>; + gpmc,bus-turnaround-ns = <0>; + gpmc,cycle2cycle-delay-ns = <0>; + gpmc,clk-activation-ns = <0>; + gpmc,wr-access-ns = <40>; + gpmc,wr-data-mux-bus-ns = <0>; + partition@0 { + label = "X-Loader"; + reg = <0 0x80000>; + }; + partition@0x80000 { + label = "U-Boot"; + reg = <0x80000 0x1c0000>; + }; + partition@0x1c0000 { + label = "Environment"; + reg = <0x240000 0x40000>; + }; + partition@0x280000 { + label = "Kernel"; + reg = <0x280000 0x500000>; + }; + partition@0x780000 { + label = "Filesystem"; + reg = <0x780000 0xf880000>; + }; + }; +}; + +&mcspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcspi1_pins>; + + m25p80@0 { + compatible = "w25x32"; + spi-max-frequency = <48000000>; + reg = <0>; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc_pins>; + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <4>; + cd-gpios = <&gpio2 7 GPIO_ACTIVE_LOW>; + wp-gpios = <&gpio2 8 GPIO_ACTIVE_LOW>; +}; + +/* At least dm8168-evm rev c won't support multipoint, later may */ +&usb0 { + pinctrl-names = "default"; + pinctrl-0 = <&usb0_pins>; + mentor,multipoint = <0>; +}; + +&usb1 { + pinctrl-names = "default"; + pinctrl-0 = <&usb1_pins>; + mentor,multipoint = <0>; +}; diff --git a/arch/arm/dts/dm816x-clocks.dtsi b/arch/arm/dts/dm816x-clocks.dtsi new file mode 100644 index 000000000000..51865eb84a80 --- /dev/null +++ b/arch/arm/dts/dm816x-clocks.dtsi @@ -0,0 +1,250 @@ +/* + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +&scrm { + main_fapll: main_fapll { + #clock-cells = <1>; + compatible = "ti,dm816-fapll-clock"; + reg = <0x400 0x40>; + clocks = <&sys_clkin_ck &sys_clkin_ck>; + clock-indices = <1>, <2>, <3>, <4>, <5>, + <6>, <7>; + clock-output-names = "main_pll_clk1", + "main_pll_clk2", + "main_pll_clk3", + "main_pll_clk4", + "main_pll_clk5", + "main_pll_clk6", + "main_pll_clk7"; + }; + + ddr_fapll: ddr_fapll { + #clock-cells = <1>; + compatible = "ti,dm816-fapll-clock"; + reg = <0x440 0x30>; + clocks = <&sys_clkin_ck &sys_clkin_ck>; + clock-indices = <1>, <2>, <3>, <4>; + clock-output-names = "ddr_pll_clk1", + "ddr_pll_clk2", + "ddr_pll_clk3", + "ddr_pll_clk4"; + }; + + video_fapll: video_fapll { + #clock-cells = <1>; + compatible = "ti,dm816-fapll-clock"; + reg = <0x470 0x30>; + clocks = <&sys_clkin_ck &sys_clkin_ck>; + clock-indices = <1>, <2>, <3>; + clock-output-names = "video_pll_clk1", + "video_pll_clk2", + "video_pll_clk3"; + }; + + audio_fapll: audio_fapll { + #clock-cells = <1>; + compatible = "ti,dm816-fapll-clock"; + reg = <0x4a0 0x30>; + clocks = <&main_fapll 7>, < &sys_clkin_ck>; + clock-indices = <1>, <2>, <3>, <4>, <5>; + clock-output-names = "audio_pll_clk1", + "audio_pll_clk2", + "audio_pll_clk3", + "audio_pll_clk4", + "audio_pll_clk5"; + }; +}; + +&scrm_clocks { + secure_32k_ck: secure_32k_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + sys_32k_ck: sys_32k_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + tclkin_ck: tclkin_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + sys_clkin_ck: sys_clkin_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <27000000>; + }; +}; + +/* 0x48180000 */ +&prcm_clocks { + clkout_pre_ck: clkout_pre_ck@100 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&main_fapll 5 &ddr_fapll 1 &video_fapll 1 + &audio_fapll 1>; + reg = <0x100>; + }; + + clkout_div_ck: clkout_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&clkout_pre_ck>; + ti,bit-shift = <3>; + ti,max-div = <8>; + reg = <0x100>; + }; + + clkout_ck: clkout_ck@100 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&clkout_div_ck>; + ti,bit-shift = <7>; + reg = <0x100>; + }; + + /* CM_DPLL clocks p1795 */ + sysclk1_ck: sysclk1_ck@300 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 1>; + ti,max-div = <7>; + reg = <0x0300>; + }; + + sysclk2_ck: sysclk2_ck@304 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 2>; + ti,max-div = <7>; + reg = <0x0304>; + }; + + sysclk3_ck: sysclk3_ck@308 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 3>; + ti,max-div = <7>; + reg = <0x0308>; + }; + + sysclk4_ck: sysclk4_ck@30c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 4>; + ti,max-div = <1>; + reg = <0x030c>; + }; + + sysclk5_ck: sysclk5_ck@310 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&sysclk4_ck>; + ti,max-div = <1>; + reg = <0x0310>; + }; + + sysclk6_ck: sysclk6_ck@314 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 4>; + ti,dividers = <2>, <4>; + reg = <0x0314>; + }; + + sysclk10_ck: sysclk10_ck@324 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&ddr_fapll 2>; + ti,max-div = <7>; + reg = <0x0324>; + }; + + sysclk24_ck: sysclk24_ck@3b4 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&main_fapll 5>; + ti,max-div = <7>; + reg = <0x03b4>; + }; + + mpu_ck: mpu_ck@15dc { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sysclk2_ck>; + ti,bit-shift = <1>; + reg = <0x15dc>; + }; + + audio_pll_a_ck: audio_pll_a_ck@35c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&audio_fapll 1>; + ti,max-div = <7>; + reg = <0x035c>; + }; + + sysclk18_ck: sysclk18_ck@378 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_32k_ck>, <&audio_pll_a_ck>; + reg = <0x0378>; + }; + + timer1_fck: timer1_fck@390 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x0390>; + }; + + timer2_fck: timer2_fck@394 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x0394>; + }; + + timer3_fck: timer3_fck@398 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x0398>; + }; + + timer4_fck: timer4_fck@39c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x039c>; + }; + + timer5_fck: timer5_fck@3a0 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x03a0>; + }; + + timer6_fck: timer6_fck@3a4 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x03a4>; + }; + + timer7_fck: timer7_fck@3a8 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&tclkin_ck>, <&sysclk18_ck>, <&sys_clkin_ck>; + reg = <0x03a8>; + }; +}; diff --git a/arch/arm/dts/dm816x.dtsi b/arch/arm/dts/dm816x.dtsi new file mode 100644 index 000000000000..276211e1ee53 --- /dev/null +++ b/arch/arm/dts/dm816x.dtsi @@ -0,0 +1,518 @@ +/* + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/pinctrl/omap.h> + +/ { + compatible = "ti,dm816"; + interrupt-parent = <&intc>; + #address-cells = <1>; + #size-cells = <1>; + chosen { }; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + ethernet0 = ð0; + ethernet1 = ð1; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + cpu@0 { + compatible = "arm,cortex-a8"; + device_type = "cpu"; + reg = <0>; + }; + }; + + pmu { + compatible = "arm,cortex-a8-pmu"; + interrupts = <3>; + }; + + /* + * The soc node represents the soc top level view. It is used for IPs + * that are not memory mapped in the MPU view or for the MPU itself. + */ + soc { + compatible = "ti,omap-infra"; + mpu { + compatible = "ti,omap3-mpu"; + ti,hwmods = "mpu"; + }; + }; + + /* + * XXX: Use a flat representation of the dm816x interconnect. + * The real dm816x interconnect network is quite complex. Since + * it will not bring real advantage to represent that in DT + * for the moment, just use a fake OCP bus entry to represent + * the whole bus hierarchy. + */ + ocp { + compatible = "simple-bus"; + reg = <0x44000000 0x10000>; + interrupts = <9 10>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + prcm: prcm@48180000 { + compatible = "ti,dm816-prcm"; + reg = <0x48180000 0x4000>; + + prcm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + prcm_clockdomains: clockdomains { + }; + }; + + scrm: scrm@48140000 { + compatible = "ti,dm816-scrm", "simple-bus"; + reg = <0x48140000 0x21000>; + #address-cells = <1>; + #size-cells = <1>; + #pinctrl-cells = <1>; + ranges = <0 0x48140000 0x21000>; + + dm816x_pinmux: pinmux@800 { + compatible = "pinctrl-single"; + reg = <0x800 0x50a>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0xf>; + }; + + /* Device Configuration Registers */ + scm_conf: syscon@600 { + compatible = "syscon", "simple-bus"; + reg = <0x600 0x110>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x600 0x110>; + + usb_phy0: usb-phy@20 { + compatible = "ti,dm8168-usb-phy"; + reg = <0x20 0x8>; + reg-names = "phy"; + clocks = <&main_fapll 6>; + clock-names = "refclk"; + #phy-cells = <0>; + syscon = <&scm_conf>; + }; + + usb_phy1: usb-phy@28 { + compatible = "ti,dm8168-usb-phy"; + reg = <0x28 0x8>; + reg-names = "phy"; + clocks = <&main_fapll 6>; + clock-names = "refclk"; + #phy-cells = <0>; + syscon = <&scm_conf>; + }; + }; + + scrm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + scrm_clockdomains: clockdomains { + }; + }; + + edma: edma@49000000 { + compatible = "ti,edma3"; + ti,hwmods = "tpcc", "tptc0", "tptc1", "tptc2", "tptc3"; + reg = <0x49000000 0x10000>, + <0x44e10f90 0x40>; + interrupts = <12 13 14>; + #dma-cells = <1>; + }; + + elm: elm@48080000 { + compatible = "ti,816-elm"; + ti,hwmods = "elm"; + reg = <0x48080000 0x2000>; + interrupts = <4>; + }; + + gpio1: gpio@48032000 { + compatible = "ti,omap4-gpio"; + ti,hwmods = "gpio1"; + ti,gpio-always-on; + reg = <0x48032000 0x1000>; + interrupts = <96>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio@4804c000 { + compatible = "ti,omap4-gpio"; + ti,hwmods = "gpio2"; + ti,gpio-always-on; + reg = <0x4804c000 0x1000>; + interrupts = <98>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpmc: gpmc@50000000 { + compatible = "ti,am3352-gpmc"; + ti,hwmods = "gpmc"; + reg = <0x50000000 0x2000>; + #address-cells = <2>; + #size-cells = <1>; + interrupts = <100>; + dmas = <&edma 52>; + dma-names = "rxtx"; + gpmc,num-cs = <6>; + gpmc,num-waitpins = <2>; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + i2c1: i2c@48028000 { + compatible = "ti,omap4-i2c"; + ti,hwmods = "i2c1"; + reg = <0x48028000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <70>; + dmas = <&edma 58 &edma 59>; + dma-names = "tx", "rx"; + }; + + i2c2: i2c@4802a000 { + compatible = "ti,omap4-i2c"; + ti,hwmods = "i2c2"; + reg = <0x4802a000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <71>; + dmas = <&edma 60 &edma 61>; + dma-names = "tx", "rx"; + }; + + intc: interrupt-controller@48200000 { + compatible = "ti,dm816-intc"; + interrupt-controller; + #interrupt-cells = <1>; + reg = <0x48200000 0x1000>; + }; + + rtc: rtc@480c0000 { + compatible = "ti,am3352-rtc", "ti,da830-rtc"; + reg = <0x480c0000 0x1000>; + interrupts = <75 76>; + ti,hwmods = "rtc"; + }; + + mailbox: mailbox@480c8000 { + compatible = "ti,omap4-mailbox"; + reg = <0x480c8000 0x2000>; + interrupts = <77>; + ti,hwmods = "mailbox"; + #mbox-cells = <1>; + ti,mbox-num-users = <4>; + ti,mbox-num-fifos = <12>; + mbox_dsp: mbox_dsp { + ti,mbox-tx = <3 0 0>; + ti,mbox-rx = <0 0 0>; + }; + }; + + spinbox: spinbox@480ca000 { + compatible = "ti,omap4-hwspinlock"; + reg = <0x480ca000 0x2000>; + ti,hwmods = "spinbox"; + #hwlock-cells = <1>; + }; + + mdio: mdio@4a100800 { + compatible = "ti,davinci_mdio"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0x4a100800 0x100>; + ti,hwmods = "davinci_mdio"; + bus_freq = <1000000>; + phy0: ethernet-phy@0 { + reg = <1>; + }; + phy1: ethernet-phy@1 { + reg = <2>; + }; + }; + + eth0: ethernet@4a100000 { + compatible = "ti,dm816-emac"; + ti,hwmods = "emac0"; + reg = <0x4a100000 0x800 + 0x4a100900 0x3700>; + clocks = <&sysclk24_ck>; + syscon = <&scm_conf>; + ti,davinci-ctrl-reg-offset = <0>; + ti,davinci-ctrl-mod-reg-offset = <0x900>; + ti,davinci-ctrl-ram-offset = <0x2000>; + ti,davinci-ctrl-ram-size = <0x2000>; + interrupts = <40 41 42 43>; + phy-handle = <&phy0>; + }; + + eth1: ethernet@4a120000 { + compatible = "ti,dm816-emac"; + ti,hwmods = "emac1"; + reg = <0x4a120000 0x4000>; + clocks = <&sysclk24_ck>; + syscon = <&scm_conf>; + ti,davinci-ctrl-reg-offset = <0>; + ti,davinci-ctrl-mod-reg-offset = <0x900>; + ti,davinci-ctrl-ram-offset = <0x2000>; + ti,davinci-ctrl-ram-size = <0x2000>; + interrupts = <44 45 46 47>; + phy-handle = <&phy1>; + }; + + mcspi1: spi@48030000 { + compatible = "ti,omap4-mcspi"; + reg = <0x48030000 0x1000>; + #address-cells = <1>; + #size-cells = <0>; + interrupts = <65>; + ti,spi-num-cs = <4>; + ti,hwmods = "mcspi1"; + dmas = <&edma 16 &edma 17 + &edma 18 &edma 19 + &edma 20 &edma 21 + &edma 22 &edma 23>; + dma-names = "tx0", "rx0", "tx1", "rx1", + "tx2", "rx2", "tx3", "rx3"; + }; + + mmc1: mmc@48060000 { + compatible = "ti,omap4-hsmmc"; + reg = <0x48060000 0x11000>; + ti,hwmods = "mmc1"; + interrupts = <64>; + dmas = <&edma 24 &edma 25>; + dma-names = "tx", "rx"; + }; + + timer1: timer@4802e000 { + compatible = "ti,dm816-timer"; + reg = <0x4802e000 0x2000>; + interrupts = <67>; + ti,hwmods = "timer1"; + ti,timer-alwon; + }; + + timer2: timer@48040000 { + compatible = "ti,dm816-timer"; + reg = <0x48040000 0x2000>; + interrupts = <68>; + ti,hwmods = "timer2"; + }; + + timer3: timer@48042000 { + compatible = "ti,dm816-timer"; + reg = <0x48042000 0x2000>; + interrupts = <69>; + ti,hwmods = "timer3"; + }; + + timer4: timer@48044000 { + compatible = "ti,dm816-timer"; + reg = <0x48044000 0x2000>; + interrupts = <92>; + ti,hwmods = "timer4"; + ti,timer-pwm; + }; + + timer5: timer@48046000 { + compatible = "ti,dm816-timer"; + reg = <0x48046000 0x2000>; + interrupts = <93>; + ti,hwmods = "timer5"; + ti,timer-pwm; + }; + + timer6: timer@48048000 { + compatible = "ti,dm816-timer"; + reg = <0x48048000 0x2000>; + interrupts = <94>; + ti,hwmods = "timer6"; + ti,timer-pwm; + }; + + timer7: timer@4804a000 { + compatible = "ti,dm816-timer"; + reg = <0x4804a000 0x2000>; + interrupts = <95>; + ti,hwmods = "timer7"; + ti,timer-pwm; + }; + + uart1: uart@48020000 { + compatible = "ti,am3352-uart", "ti,omap3-uart"; + ti,hwmods = "uart1"; + reg = <0x48020000 0x2000>; + clock-frequency = <48000000>; + interrupts = <72>; + dmas = <&edma 26 &edma 27>; + dma-names = "tx", "rx"; + }; + + uart2: uart@48022000 { + compatible = "ti,am3352-uart", "ti,omap3-uart"; + ti,hwmods = "uart2"; + reg = <0x48022000 0x2000>; + clock-frequency = <48000000>; + interrupts = <73>; + dmas = <&edma 28 &edma 29>; + dma-names = "tx", "rx"; + }; + + uart3: uart@48024000 { + compatible = "ti,am3352-uart", "ti,omap3-uart"; + ti,hwmods = "uart3"; + reg = <0x48024000 0x2000>; + clock-frequency = <48000000>; + interrupts = <74>; + dmas = <&edma 30 &edma 31>; + dma-names = "tx", "rx"; + }; + + /* NOTE: USB needs a transceiver driver for phys to work */ + usb: usb_otg_hs@47401000 { + compatible = "ti,am33xx-usb"; + reg = <0x47401000 0x400000>; + ranges; + #address-cells = <1>; + #size-cells = <1>; + ti,hwmods = "usb_otg_hs"; + + usb0: usb@47401000 { + compatible = "ti,musb-dm816"; + reg = <0x47401400 0x400 + 0x47401000 0x200>; + reg-names = "mc", "control"; + interrupts = <18>; + interrupt-names = "mc"; + dr_mode = "host"; + interface-type = <0>; + phys = <&usb_phy0>; + phy-names = "usb2-phy"; + mentor,multipoint = <1>; + mentor,num-eps = <16>; + mentor,ram-bits = <12>; + mentor,power = <500>; + + dmas = <&cppi41dma 0 0 &cppi41dma 1 0 + &cppi41dma 2 0 &cppi41dma 3 0 + &cppi41dma 4 0 &cppi41dma 5 0 + &cppi41dma 6 0 &cppi41dma 7 0 + &cppi41dma 8 0 &cppi41dma 9 0 + &cppi41dma 10 0 &cppi41dma 11 0 + &cppi41dma 12 0 &cppi41dma 13 0 + &cppi41dma 14 0 &cppi41dma 0 1 + &cppi41dma 1 1 &cppi41dma 2 1 + &cppi41dma 3 1 &cppi41dma 4 1 + &cppi41dma 5 1 &cppi41dma 6 1 + &cppi41dma 7 1 &cppi41dma 8 1 + &cppi41dma 9 1 &cppi41dma 10 1 + &cppi41dma 11 1 &cppi41dma 12 1 + &cppi41dma 13 1 &cppi41dma 14 1>; + dma-names = + "rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7", + "rx8", "rx9", "rx10", "rx11", "rx12", "rx13", + "rx14", "rx15", + "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7", + "tx8", "tx9", "tx10", "tx11", "tx12", "tx13", + "tx14", "tx15"; + }; + + usb1: usb@47401800 { + compatible = "ti,musb-dm816"; + reg = <0x47401c00 0x400 + 0x47401800 0x200>; + reg-names = "mc", "control"; + interrupts = <19>; + interrupt-names = "mc"; + dr_mode = "host"; + interface-type = <0>; + phys = <&usb_phy1>; + phy-names = "usb2-phy"; + mentor,multipoint = <1>; + mentor,num-eps = <16>; + mentor,ram-bits = <12>; + mentor,power = <500>; + + dmas = <&cppi41dma 15 0 &cppi41dma 16 0 + &cppi41dma 17 0 &cppi41dma 18 0 + &cppi41dma 19 0 &cppi41dma 20 0 + &cppi41dma 21 0 &cppi41dma 22 0 + &cppi41dma 23 0 &cppi41dma 24 0 + &cppi41dma 25 0 &cppi41dma 26 0 + &cppi41dma 27 0 &cppi41dma 28 0 + &cppi41dma 29 0 &cppi41dma 15 1 + &cppi41dma 16 1 &cppi41dma 17 1 + &cppi41dma 18 1 &cppi41dma 19 1 + &cppi41dma 20 1 &cppi41dma 21 1 + &cppi41dma 22 1 &cppi41dma 23 1 + &cppi41dma 24 1 &cppi41dma 25 1 + &cppi41dma 26 1 &cppi41dma 27 1 + &cppi41dma 28 1 &cppi41dma 29 1>; + dma-names = + "rx1", "rx2", "rx3", "rx4", "rx5", "rx6", "rx7", + "rx8", "rx9", "rx10", "rx11", "rx12", "rx13", + "rx14", "rx15", + "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", "tx7", + "tx8", "tx9", "tx10", "tx11", "tx12", "tx13", + "tx14", "tx15"; + }; + + cppi41dma: dma-controller@47402000 { + compatible = "ti,am3359-cppi41"; + reg = <0x47400000 0x1000 + 0x47402000 0x1000 + 0x47403000 0x1000 + 0x47404000 0x4000>; + reg-names = "glue", "controller", "scheduler", "queuemgr"; + interrupts = <17>; + interrupt-names = "glue"; + #dma-cells = <2>; + #dma-channels = <30>; + #dma-requests = <256>; + }; + }; + + wd_timer2: wd_timer@480c2000 { + compatible = "ti,omap3-wdt"; + ti,hwmods = "wd_timer"; + reg = <0x480c2000 0x1000>; + interrupts = <0>; + }; + }; +}; + +#include "dm816x-clocks.dtsi"
- Switch to using <configs/ti_armv7_omap.h> and family. This lets us drop lots of custom defines. - Ensure that our default environment uses DEFAULT_LINUX_BOOT_ENV so that Linux will boot correctly. - Enable CONFIG_DISTRO_DEFAULTS - Switch to using CONFIG_OF_CONTROL - Various other cleanups to match other SoCs in the family line.
Signed-off-by: Tom Rini trini@konsulko.com --- board/ti/ti816x/evm.c | 2 +- configs/ti816x_evm_defconfig | 19 +++++++++----- include/configs/ti816x_evm.h | 60 +++++++++++--------------------------------- 3 files changed, 28 insertions(+), 53 deletions(-)
diff --git a/board/ti/ti816x/evm.c b/board/ti/ti816x/evm.c index 8f07e2c9aa00..577e60f875f4 100644 --- a/board/ti/ti816x/evm.c +++ b/board/ti/ti816x/evm.c @@ -24,7 +24,7 @@ DECLARE_GLOBAL_DATA_PTR;
int board_init(void) { - gd->bd->bi_boot_params = PHYS_DRAM_1 + 0x100; + gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; #if defined(CONFIG_NAND) gpmc_init(); #endif diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 4f9019220b1b..729b709df900 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -8,25 +8,32 @@ CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_LIBDISK_SUPPORT=y CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL_FAT_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="dm8168-evm" +CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_BOOTDELAY=3 CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_SPL=y +CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x300 -CONFIG_SPL_YMODEM_SUPPORT=y -CONFIG_HUSH_PARSER=y -CONFIG_SYS_PROMPT="u-boot/ti816x# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y +CONFIG_CMD_I2C=y +# CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y +CONFIG_CMD_EXT4_WRITE=y +# CONFIG_ISO_PARTITION is not set +# CONFIG_EFI_PARTITION is not set +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y CONFIG_MMC_OMAP_HS=y CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y # CONFIG_USE_PRIVATE_LIBGCC is not set diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 35ee775adc42..27c6479ccc29 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -13,21 +13,16 @@ #define CONFIG_TI81XX #define CONFIG_TI816X
-#define CONFIG_ARCH_CPU_INIT - +#include <configs/ti_armv7_omap.h> #include <asm/arch/omap.h>
#define CONFIG_ENV_SIZE 0x2000 -#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (32 * 1024)) -#define CONFIG_SYS_LONGHELP /* undef save memory */ #define CONFIG_MACH_TYPE MACH_TYPE_TI8168EVM
-#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ -#define CONFIG_SETUP_MEMORY_TAGS -#define CONFIG_INITRD_TAG /* required for ramdisk support */ - #define CONFIG_EXTRA_ENV_SETTINGS \ - "loadaddr=0x81000000\0" \ + DEFAULT_LINUX_BOOT_ENV \ + "mtdids=" MTDIDS_DEFAULT "\0" \ + "mtdparts=" MTDPARTS_DEFAULT "\0" \
#define CONFIG_BOOTCOMMAND \ "mmc rescan;" \ @@ -40,28 +35,10 @@ #define V_OSCK 24000000 /* Clock output from T2 */ #define V_SCLK (V_OSCK >> 1)
-#define CONFIG_SYS_MAXARGS 32 -#define CONFIG_SYS_CBSIZE 512 /* console I/O buffer size */ -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ - + sizeof(CONFIG_SYS_PROMPT) + 16) /* print buffer size */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* boot arg buffer size */ - -#define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ - #define CONFIG_CMD_ASKENV
-#define CONFIG_FS_FAT - -#define CONFIG_NR_DRAM_BANKS 2 /* we have 2 banks of DRAM */ -#define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ -#define PHYS_DRAM_1_SIZE 0x40000000 /* 1 GB */ -#define PHYS_DRAM_2 0xC0000000 /* DRAM Bank #2 */ -#define PHYS_DRAM_2_SIZE 0x40000000 /* 1 GB */ - #define CONFIG_MAX_RAM_BANK_SIZE (2048 << 20) /* 2048MB */ -#define CONFIG_SYS_SDRAM_BASE PHYS_DRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR (NON_SECURE_SRAM_END - \ - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_SDRAM_BASE 0x80000000
/** * Platform/Board specific defs @@ -94,11 +71,7 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1
/* NAND: SPL related configs */ -#define CONFIG_SPL_NAND_BASE -#define CONFIG_SPL_NAND_DRIVERS -#define CONFIG_SPL_NAND_ECC #define CONFIG_SPL_NAND_AM33XX_BCH -#define CONFIG_SYS_NAND_U_BOOT_START CONFIG_SYS_TEXT_BASE
/* NAND: device related configs */ #define CONFIG_SYS_NAND_5_ADDR_CYCLE @@ -109,7 +82,6 @@ #define CONFIG_SYS_NAND_OOBSIZE 64 #define CONFIG_SYS_NAND_BLOCK_SIZE (128*1024) /* NAND: driver related configs */ -#define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_GPMC_PREFETCH #define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BAD_BLOCK_POS NAND_LARGE_BADBLOCK_POS @@ -146,26 +118,13 @@ /* SPL */ /* Defines for SPL */ #define CONFIG_SPL_NAND_AM33XX_BCH /* ELM support */ -#define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x40400000 #define CONFIG_SPL_MAX_SIZE (SRAM_SCRATCH_SPACE_ADDR - \ CONFIG_SPL_TEXT_BASE)
-#define CONFIG_SPL_BSS_START_ADDR 0x80000000 -#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ - -#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 -#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" - -#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x20000 -#define CONFIG_SYS_SPI_U_BOOT_SIZE 0x40000 #define CONFIG_SPL_LDSCRIPT "arch/arm/mach-omap2/u-boot-spl.lds"
-#define CONFIG_SPL_BOARD_INIT - #define CONFIG_SYS_TEXT_BASE 0x80800000 -#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000
/* Since SPL did pll and ddr initialization for us, * we don't need to do it twice. @@ -174,4 +133,13 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #endif
+/* + * Disable MMC DM for SPL build and can be re-enabled after adding + * DM support in SPL + */ +#ifdef CONFIG_SPL_BUILD +#undef CONFIG_DM_MMC +#undef CONFIG_TIMER +#undef CONFIG_DM_USB +#endif #endif
The symbol CONFIG_TI81XX is used for the parts that are common to the TI816x and TI814x SoCs and are not part of CONFIG_ARCH_OMAP2PLUS nor CONFIG_AM33XX. It however has so few uses that we can just modify the code to check for both and drop the symbol. The symbols CONFIG_TI816X and CONFIG_TI814X are for the repective SoCs.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-am33xx/clock.h | 2 +- arch/arm/include/asm/arch-am33xx/omap.h | 2 +- arch/arm/mach-omap2/Kconfig | 20 ++++++++++++++------ arch/arm/mach-omap2/am33xx/Kconfig | 20 ++++++++++++++++++++ configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + include/configs/ti814x_evm.h | 3 --- include/configs/ti816x_evm.h | 3 --- scripts/config_whitelist.txt | 3 --- 9 files changed, 38 insertions(+), 17 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/clock.h b/arch/arm/include/asm/arch-am33xx/clock.h index 19ccf5c8dbb1..5399bb81f0bb 100644 --- a/arch/arm/include/asm/arch-am33xx/clock.h +++ b/arch/arm/include/asm/arch-am33xx/clock.h @@ -14,7 +14,7 @@ #include <asm/arch/clocks_am33xx.h> #include <asm/arch/hardware.h>
-#ifdef CONFIG_TI81XX +#if defined(CONFIG_TI816X) || defined(CONFIG_TI814X) #include <asm/arch/clock_ti81xx.h> #endif
diff --git a/arch/arm/include/asm/arch-am33xx/omap.h b/arch/arm/include/asm/arch-am33xx/omap.h index 3293caaca4ab..0dafb9e3270a 100644 --- a/arch/arm/include/asm/arch-am33xx/omap.h +++ b/arch/arm/include/asm/arch-am33xx/omap.h @@ -21,7 +21,7 @@ #define NON_SECURE_SRAM_START 0x402F0400 #define NON_SECURE_SRAM_END 0x40310000 #define NON_SECURE_SRAM_IMG_END 0x4030B800 -#elif defined(CONFIG_TI81XX) +#elif defined(CONFIG_TI816X) || defined(CONFIG_TI814X) #define NON_SECURE_SRAM_START 0x40300000 #define NON_SECURE_SRAM_END 0x40320000 #define NON_SECURE_SRAM_IMG_END 0x4031B800 diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index 408b62c663af..d161b5194640 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -54,12 +54,6 @@ config TARGET_RUT select DM_SERIAL select DM_GPIO
-config TARGET_TI814X_EVM - bool "Support ti814x_evm" - -config TARGET_TI816X_EVM - bool "Support ti816x_evm" - config OMAP34XX bool "OMAP34XX SoC" select ARM_ERRATA_430973 @@ -116,6 +110,20 @@ config OMAP54XX imply SPL_POWER_SUPPORT imply SPL_SERIAL_SUPPORT
+config TI814X + bool "TI814X SoC" + help + Support for AM335x SOC from Texas Instruments. + The AM335x high performance SOC features a Cortex-A8 + ARM core and more. + +config TI816X + bool "TI816X SoC" + help + Support for AM335x SOC from Texas Instruments. + The AM335x high performance SOC features a Cortex-A8 + ARM core and more. + config AM43XX bool "AM43XX SoC" imply SPL_DM diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 5c4168fefc08..36ec13414098 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -1,3 +1,23 @@ +if TI816X + +config TARGET_TI816X_EVM + bool "Support ti816x_evm" + help + This option specifies support for the TI8168 EVM development platform + with PG2.0 silicon and DDR3 DRAM. + +endif + +if TI814X + +config TARGET_TI814X_EVM + bool "Support ti814x_evm" + help + This option specifies support for the TI8148 + EVM development platform. + +endif + if AM33XX
config AM33XX_CHILISOM diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index a72c7642f601..1b127b860926 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TI814X=y CONFIG_TARGET_TI814X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 729b709df900..1c6608218b00 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO_SUPPORT=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_TI816X=y CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 60322b1938af..068771b6dbd9 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -16,9 +16,6 @@ #ifndef __CONFIG_TI814X_EVM_H #define __CONFIG_TI814X_EVM_H
-#define CONFIG_TI81XX -#define CONFIG_TI814X - #include <asm/arch/omap.h>
#define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index 27c6479ccc29..defcad451880 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -10,9 +10,6 @@ #ifndef __CONFIG_TI816X_EVM_H #define __CONFIG_TI816X_EVM_H
-#define CONFIG_TI81XX -#define CONFIG_TI816X - #include <configs/ti_armv7_omap.h> #include <asm/arch/omap.h>
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 8d56daebedd0..04874a54807e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -6111,9 +6111,6 @@ CONFIG_TFTP_TSIZE CONFIG_THOR_RESET_OFF CONFIG_THUMB2_KERNEL CONFIG_THUNDERX -CONFIG_TI814X -CONFIG_TI816X -CONFIG_TI81XX CONFIG_TIMESTAMP CONFIG_TIZEN CONFIG_TI_KEYSTONE_SERDES
On Tue, May 16, 2017 at 02:46:34PM -0400, Tom Rini wrote:
Rather than have a long and if check in the Makefile, mark the default lowlevel_init function as weak (as we do on armv8) so that SoCs can override it if needed, and it will still be discarded if unused. Provide a weak s_init as well to allow for this to link and be discarded.
