The following changes since commit 12c1e5782401abca1a8cff578d1911a9ca7d2e7d:
Merge branch 'master' of https://source.denx.de/u-boot/custodians/u-boot-marvell (2023-04-14 10:50:55 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master_sh/gen4/rswitch
for you to fetch changes up to 47811beaff1f2560cf681d58535644c6ab07a2ab:
ARM: renesas: Enable rswitch, serdes and PHY driver on R8A779F0 S4 Spider (2023-04-16 22:50:54 +0200)
---------------------------------------------------------------- Marek Vasut (2): phy: renesas: Add Renesas Ethernet SERDES driver for R-Car S4-8 ARM: renesas: Enable rswitch, serdes and PHY driver on R8A779F0 S4 Spider
Phong Hoang (1): net: rswitch: Add Renesas Ethernet Switch
configs/r8a779f0_spider_defconfig | 5 + drivers/net/Kconfig | 8 + drivers/net/Makefile | 1 + drivers/net/rswitch.c | 1139 +++++++++++++++++++++++++++ drivers/phy/Kconfig | 1 + drivers/phy/Makefile | 1 + drivers/phy/renesas/Kconfig | 9 + drivers/phy/renesas/Makefile | 1 + drivers/phy/renesas/r8a779f0-ether-serdes.c | 384 +++++++++ 9 files changed, 1549 insertions(+) create mode 100644 drivers/net/rswitch.c create mode 100644 drivers/phy/renesas/Kconfig create mode 100644 drivers/phy/renesas/Makefile create mode 100644 drivers/phy/renesas/r8a779f0-ether-serdes.c
