[U-Boot] [PULL] u-boot-socfpga/master
The following changes since commit 454cf76184c65426b68033a23da086e73663f2fc:
Prepare v2018.11-rc3 (2018-10-29 16:04:26 -0400)
git://git.denx.de/u-boot-socfpga.git master
for you to fetch changes up to f48db4ede07b52290477e188de714e327e4954de:
arm: socfpga: imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION (2018-10-31 01:41:10 +0100)
---------------------------------------------------------------- Simon Goldschmidt (2): arm: socfpga: fpga: fix type of local variable arm: socfpga: imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION
Stefan Roese (1): arm: socfpga: Fix bootcounter located at the end of internal SRAM
arch/arm/Kconfig | 2 +- drivers/fpga/socfpga_arria10.c | 2 +- drivers/fpga/socfpga_gen5.c | 2 +- include/configs/socfpga_common.h | 13 +++++++++++++ 4 files changed, 16 insertions(+), 3 deletions(-)
