Porting U-Boot's UEFI Payload to coreboot
Hi everyone,
I am trying to work on a project to port the U-Boot UEFI code to coreboot as a payload. I haven't worked with UEFI before except running a basic EFI payload in a coreboot/u-boot environment. (Serial output: https://gist.github.com/drac98/6166d29f6c3a2baf2f4e791925ea98d3)
I would like to know how UEFI is implemented in U-Boot. Is UEFI integrated into u-boot or is it implemented like a payload?
Where is the UEFI source code? Is it the following files in the tree https://source.denx.de/u-boot/custodians/u-boot-efi lib/ |__ efi/ |__ efi_driver/ |__ efi_loader/
Please help me understand the structure.
Best regards, Husni.
On 3/8/22 13:59, Ahamed Husni wrote:
Hi everyone,
Hello Ahamed,
the UEFI API implementation is an integral part of U-Boot.
U-Boot can both be run on top of UEFI. This is the code you find in /lib/efi/. Furthermore UEFI can run as a firmware providing the UEFI API. This is what you find in /lib/efi_loader/ and /lib/efi_driver/.
You can build U-Boot as payload for coreboot which offers the UEFI API implementation. See configs/coreboot64_defconfig.
U-Boot runs ARM and RISC-V Linux successfully via UEFI.
What architecture are you looking at?
Simon (on CC) has been working on U-Boot on UEFI and Coreboot while I have concentrated on the UEFI API implementation in U-Boot.
Best regards
Heinrich
Hi everyone,
Hello Ahamed,
Yes you can use U-Boot as a coreboot payload - this is now running in CI so we make sure it works on each release. I plan to add more test cases to it but have been waiting to see if coreboot can add something similar to its CI.
+Stefan Reinauer as we have been talking about this
It seems better to go that way than trying to duplicate efforts. We have a program now to move UEFI to use driver model properly, for example.
Hello,
Sorry for the delay. Thank you for the replies.
Hi everyone,
coreboot
in a
integrated
Hello Ahamed,
Then I should look at the lib/efi_loader/ and lib/efi_driver/ I guess. Thank you!
I'll be mostly working with a x86_64 QEMU target. I am proposing this project for the GSoC this year. So the architecture could change after discussions.
@Simon can I CC you to the discussion in coreboot?
I used U-Boot (v2019.4) as a coreboot payload to run my hello world EFI payload and it worked.
I also tried different combinations of the applications, | Arch | U-Boot | EFI | Status | |--------|---------|--------|-------------| | 32bit | 32bit | 32bit | Success | | 64bit | 32bit | 32bit | Success | | 64bit | 64bit | 64bit | Fails and reboot | | 64bit | 64bit | 32bit | Fails and returns back to shell printing the error code | | 64bit | 32bit | 64bit | Fails and returns back to shell printing the error code |
The last two fail because the EFI does not support booting a 64-bit application from a 32-bit EFI (or vice versa) as mentioned in the u-boot docs. Is this something in the UEFI specification?
The third one fails because 64-bit EFI is not supported yet.
Is there a way to run 64-bit EFI with something like the 32-bit SPL binary used to boot 64-bit u-boot in coreboot(32-bit)? Ex: can we boot a 64bit Windows/Linux with 32-bit EFI? It seems linux can work with 32bit EFI from this https://github.com/maharmstone/quibble/issues/2 thread.
Best Regards, Husni Faiz.
Hi Ahamed,
On Sat, 12 Mar 2022 at 08:23, Ahamed Husni ahamedhusni73@gmail.com wrote:
Hello,
Hi everyone,
Hello Ahamed,
Yes that is OK.
Yes.
+Ilias Apalodimas might comment on that too.
It is supported now but there are some problems and it needs some work. You are welcome to look at it and I can help.
+Christian Melki was testing that
Is there a way to run 64-bit EFI with something like the 32-bit SPL binary used to boot 64-bit u-boot in coreboot(32-bit)? Ex: can we boot a 64bit Windows/Linux with 32-bit EFI? It seems linux can work with 32bit EFI from this thread.
It sounds like you found the coreboot64 build which uses SPL to switch to 64bit, then runs 64-bit U-Boot.
But if I understand correctly, your question is more for Linux and Windows I think, so I would check there.
Ahamed Husni
