[U-Boot] [PATCH v3] armv8: ls1028a: Add environment variables to facilitate the boot
Add some environment variables to facilitate the auto boot.
Signed-off-by: Yuantian Tang andy.tang@nxp.com --- v3: - rebase to the latest code include/configs/ls1028a_common.h | 28 +++++++++++++++++++++++++--- 1 file changed, 25 insertions(+), 3 deletions(-)
diff --git a/include/configs/ls1028a_common.h b/include/configs/ls1028a_common.h index 0db86396e9..022981bfa3 100644 --- a/include/configs/ls1028a_common.h +++ b/include/configs/ls1028a_common.h @@ -67,6 +67,7 @@
#define BOOT_TARGET_DEVICES(func) \ func(MMC, mmc, 0) \ + func(MMC, mmc, 1) \ func(USB, usb, 0) #include <config_distro_bootcmd.h>
@@ -127,25 +128,46 @@ "${scripthdraddr} ${prefix}${boot_script_hdr} " \ "&& esbc_validate ${scripthdraddr};" \ "source ${scriptaddr}\0" \ - "sd_bootcmd=echo Trying load from SD ..;" \ + "xspi_bootcmd=echo Trying load from FlexSPI flash ...;" \ + "sf probe 0:0 && sf read $load_addr " \ + "$kernel_start $kernel_size ; env exists secureboot &&" \ + "sf read $kernelheader_addr_r $kernelheader_start " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; "\ + " bootm $load_addr#$board\0" \ + "xspi_hdploadcmd=echo Trying load HDP firmware from FlexSPI...;" \ + "sf probe 0:0 && sf read $load_addr 0x940000 0x30000 " \ + "&& hdp load $load_addr 0x2000\0" \ + "sd_bootcmd=echo Trying load from SD ...;" \ "mmcinfo; mmc read $load_addr " \ "$kernel_addr_sd $kernel_size_sd && " \ "env exists secureboot && mmc read $kernelheader_addr_r " \ "$kernelhdr_addr_sd $kernelhdr_size_sd " \ " && esbc_validate ${kernelheader_addr_r};" \ "bootm $load_addr#$board\0" \ + "sd_hdploadcmd=echo Trying load HDP firmware from SD..;" \ + "mmcinfo;mmc read $load_addr 0x4a00 0x200 " \ + "&& hdp load $load_addr 0x2000\0" \ "emmc_bootcmd=echo Trying load from EMMC ..;" \ "mmcinfo; mmc dev 1; mmc read $load_addr " \ "$kernel_addr_sd $kernel_size_sd && " \ "env exists secureboot && mmc read $kernelheader_addr_r " \ "$kernelhdr_addr_sd $kernelhdr_size_sd " \ " && esbc_validate ${kernelheader_addr_r};" \ - "bootm $load_addr#$board\0" + "bootm $load_addr#$board\0" \ + "emmc_hdploadcmd=echo Trying load HDP firmware from EMMC..;" \ + "mmc dev 1;mmcinfo;mmc read $load_addr 0x4a00 0x200 " \ + "&& hdp load $load_addr 0x2000\0"
#undef CONFIG_BOOTCOMMAND
+#define XSPI_NOR_BOOTCOMMAND \ + "run xspi_hdploadcmd; run distro_bootcmd; run xspi_bootcmd; " \ + "env exists secureboot && esbc_halt;;" #define SD_BOOTCOMMAND \ - "run distro_bootcmd;run sd_bootcmd; " \ + "run sd_hdploadcmd; run distro_bootcmd;run sd_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#define SD2_BOOTCOMMAND \ + "run emmc_hdploadcmd; run distro_bootcmd;run emmc_bootcmd; " \ "env exists secureboot && esbc_halt;"
/* Monitor Command Prompt */
-----Original Message----- From: Yuantian Tang andy.tang@nxp.com Sent: Monday, November 4, 2019 12:41 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: u-boot@lists.denx.de; Andy Tang andy.tang@nxp.com Subject: [PATCH v3] armv8: ls1028a: Add environment variables to facilitate the boot
<snip> applied to fsl-qoriq master, awaiting upstream.
Thanks priyankajain
Priyanka Jain
Yuantian Tang
