[U-Boot] [PATCH] board: ethernut5: Update to support DT and DM
Add the dts files to support deivce tree, update the configuration files to support the device tree and driver model. The peripheral clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com ---
arch/arm/dts/at91sam9xe.dtsi | 60 ++++++++++++++++++++++++ arch/arm/dts/ethernut5.dts | 94 ++++++++++++++++++++++++++++++++++++++ board/egnite/ethernut5/ethernut5.c | 54 ---------------------- configs/ethernut5_defconfig | 16 +++++++ include/configs/ethernut5.h | 36 ++++----------- 5 files changed, 178 insertions(+), 82 deletions(-) create mode 100644 arch/arm/dts/at91sam9xe.dtsi create mode 100644 arch/arm/dts/ethernut5.dts
diff --git a/arch/arm/dts/at91sam9xe.dtsi b/arch/arm/dts/at91sam9xe.dtsi new file mode 100644 index 0000000000..0278f63b2d --- /dev/null +++ b/arch/arm/dts/at91sam9xe.dtsi @@ -0,0 +1,60 @@ +/* + * at91sam9xe.dtsi - Device Tree Include file for AT91SAM9XE family SoC + * + * Copyright (C) 2015 Atmel, + * 2015 Alexandre Belloni alexandre.Belloni@free-electrons.com + * + * This file is dual-licensed: you can use it either under the terms + * of the GPL or the X11 license, at your option. Note that this dual + * licensing only applies to this file, and not this project as a + * whole. + * + * a) This file is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of the + * License, or (at your option) any later version. + * + * This file is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Or, alternatively, + * + * b) Permission is hereby granted, free of charge, to any person + * obtaining a copy of this software and associated documentation + * files (the "Software"), to deal in the Software without + * restriction, including without limitation the rights to use, + * copy, modify, merge, publish, distribute, sublicense, and/or + * sell copies of the Software, and to permit persons to whom the + * Software is furnished to do so, subject to the following + * conditions: + * + * The above copyright notice and this permission notice shall be + * included in all copies or substantial portions of the Software. + * + * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, + * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES + * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND + * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT + * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, + * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING + * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR + * OTHER DEALINGS IN THE SOFTWARE. + */ + +#include "at91sam9260.dtsi" + +/ { + model = "Atmel AT91SAM9XE family SoC"; + compatible = "atmel,at91sam9xe", "atmel,at91sam9260"; + + sram0: sram@002ff000 { + status = "disabled"; + }; + + sram1: sram@00300000 { + compatible = "mmio-sram"; + reg = <0x00300000 0x4000>; + }; +}; diff --git a/arch/arm/dts/ethernut5.dts b/arch/arm/dts/ethernut5.dts new file mode 100644 index 0000000000..e07715225f --- /dev/null +++ b/arch/arm/dts/ethernut5.dts @@ -0,0 +1,94 @@ +/* + * ethernut5.dts - Device Tree file for Ethernut 5 board + * + * Copyright (C) 2012 egnite GmbH info@egnite.de + * + * Licensed under GPLv2. + */ +/dts-v1/; +#include "at91sam9xe.dtsi" + +/ { + model = "Ethernut 5"; + compatible = "egnite,ethernut5", "atmel,at91sam9260", "atmel,at91sam9"; + + chosen { + bootargs = "console=ttyS0,115200 root=/dev/mtdblock0 rw rootfstype=jffs2"; + }; + + memory { + reg = <0x20000000 0x08000000>; + }; + + clocks { + slow_xtal { + clock-frequency = <32768>; + }; + + main_xtal { + clock-frequency = <18432000>; + }; + }; + + ahb { + apb { + dbgu: serial@fffff200 { + status = "okay"; + }; + + usart0: serial@fffb0000 { + status = "okay"; + }; + + usart1: serial@fffb4000 { + status = "okay"; + }; + + macb0: ethernet@fffc4000 { + phy-mode = "rmii"; + status = "okay"; + }; + + usb1: gadget@fffa4000 { + atmel,vbus-gpio = <&pioC 5 GPIO_ACTIVE_HIGH>; + status = "okay"; + }; + }; + + nand0: nand@40000000 { + nand-bus-width = <8>; + nand-ecc-mode = "soft"; + nand-on-flash-bbt; + status = "okay"; + + gpios = <0 + &pioC 14 GPIO_ACTIVE_HIGH + 0 + >; + + root@0 { + label = "root"; + reg = <0x0 0x08000000>; + }; + + data@20000 { + label = "data"; + reg = <0x08000000 0x38000000>; + }; + }; + + usb0: ohci@00500000 { + num-ports = <2>; + status = "okay"; + }; + }; + + i2c-gpio-0 { + status = "okay"; + + pcf8563@50 { + compatible = "nxp,pcf8563"; + reg = <0x51>; + }; + }; +}; diff --git a/board/egnite/ethernut5/ethernut5.c b/board/egnite/ethernut5/ethernut5.c index 2c8e978eb3..d64c3456b1 100644 --- a/board/egnite/ethernut5/ethernut5.c +++ b/board/egnite/ethernut5/ethernut5.c @@ -58,8 +58,6 @@ #include <netdev.h> #include <miiphy.h> #include <i2c.h> -#include <spi.h> -#include <dataflash.h> #include <mmc.h> #include <atmel_mci.h>
@@ -67,7 +65,6 @@ #include <asm/arch/at91sam9260_matrix.h> #include <asm/arch/at91sam9_smc.h> #include <asm/arch/at91_common.h> -#include <asm/arch/at91_spi.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> #include <asm/io.h> @@ -77,25 +74,6 @@
DECLARE_GLOBAL_DATA_PTR;
-AT91S_DATAFLASH_INFO dataflash_info[CONFIG_SYS_MAX_DATAFLASH_BANKS]; - -struct dataflash_addr cs[CONFIG_SYS_MAX_DATAFLASH_BANKS] = { - {CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0, 0} -}; - -/* - * In fact we have 7 partitions, but u-boot supports 5 only. This is - * no big deal, because the first partition is reserved for applications - * and the last one is used by Nut/OS. Both need not to be visible here. - */ -dataflash_protect_t area_list[NB_DATAFLASH_AREA] = { - { 0x00021000, 0x00041FFF, FLAG_PROTECT_SET, 0, "setup" }, - { 0x00042000, 0x000C5FFF, FLAG_PROTECT_SET, 0, "uboot" }, - { 0x000C6000, 0x00359FFF, FLAG_PROTECT_SET, 0, "kernel" }, - { 0x0035A000, 0x003DDFFF, FLAG_PROTECT_SET, 0, "nutos" }, - { 0x003DE000, 0x003FEFFF, FLAG_PROTECT_CLEAR, 0, "env" } -}; - /* * This is called last during early initialization. Most of the basic * hardware interfaces are up and running. @@ -158,14 +136,10 @@ int board_init(void) /* Set adress of boot parameters. */ gd->bd->bi_boot_params = CONFIG_SYS_SDRAM_BASE + 0x100; /* Initialize UARTs and power management. */ - at91_seriald_hw_init(); ethernut5_power_init(); #ifdef CONFIG_CMD_NAND ethernut5_nand_hw_init(); #endif -#ifdef CONFIG_HAS_DATAFLASH - at91_spi0_hw_init(1 << 0); -#endif return 0; }
@@ -221,31 +195,3 @@ int board_mmc_getcd(struct mmc *mmc) return !at91_get_pio_value(CONFIG_SYS_MMC_CD_PIN); } #endif - -#ifdef CONFIG_ATMEL_SPI -/* - - * Note, that u-boot uses different code for SPI bus access. While - * memory routines use automatic chip select control, the serial - * flash support requires 'manual' GPIO control. Thus, we switch - * modes. - */ -void spi_cs_activate(struct spi_slave *slave) -{ - /* Enable NPCS0 in GPIO mode. This disables peripheral control. */ - at91_set_pio_output(AT91_PIO_PORTA, 3, 0); -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - /* Disable NPCS0 in GPIO mode. */ - at91_set_pio_output(AT91_PIO_PORTA, 3, 1); - /* Switch back to peripheral chip select control. */ - at91_set_a_periph(AT91_PIO_PORTA, 3, 1); -} - -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && cs == 0; -} -#endif diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 197052dba6..2d7da49019 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_ETHERNUT5=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="ethernut5" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set @@ -30,8 +32,22 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_CMD_JFFS2=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y CONFIG_MTD_NOR_FLASH=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y CONFIG_USB_STORAGE=y diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index e7f7a7cbe6..4dd8e97cfd 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -53,35 +53,13 @@ # define CONFIG_SYS_FLASH_PROTECTION /* First stage loader in sector 0 */ # define CONFIG_EFLASH_PROTSECTORS 1
-/* 512kB DataFlash at NPCS0 */ -#define CONFIG_SYS_MAX_DATAFLASH_BANKS 1 -#define CONFIG_HAS_DATAFLASH -#define CONFIG_ATMEL_DATAFLASH_SPI -#define CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 0xC0000000 -#define DATAFLASH_TCSS (0x1a << 16) -#define DATAFLASH_TCHS (0x1 << 24)
+/* bootstrap + u-boot + env + linux in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_OFFSET 0x3DE000 -#define CONFIG_ENV_SECT_SIZE (132 << 10) -#define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE -#define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 \ - + CONFIG_ENV_OFFSET) -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 \ - + 0x042000) - -/* SPI */ -#define CONFIG_ATMEL_SPI -#define AT91_SPI_CLK 15000000 - -/* Serial port */ -#define CONFIG_ATMEL_USART -#define CONFIG_USART3 /* USART 3 is DBGU */ -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS - -/* Misc. hardware drivers */ -#define CONFIG_AT91_GPIO +#define CONFIG_ENV_OFFSET 0x3DE000 +#define CONFIG_ENV_SIZE (132 << 10) +#define CONFIG_ENV_SECT_SIZE CONFIG_ENV_SIZE +#define CONFIG_ENV_SPI_MAX_HZ 15000000
/* Command line configuration */ #define CONFIG_CMD_MTDPARTS @@ -193,7 +171,9 @@ #define CONFIG_CMDLINE_TAG #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_INITRD_TAG -#define CONFIG_BOOTCOMMAND "cp.b 0xC00C6000 ${loadaddr} 0x294000; bootm" +#define CONFIG_BOOTCOMMAND "sf probe 0:0; " \ + "sf read 0x22000000 0xc6000 0x294000; " \ + "bootm 0x22000000" #if defined(CONFIG_CMD_NAND) #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \
Signed-off-by: Wenyou Yang wenyou.yang@microchip.com Reviewed-by: Simon Glass sjg@chromium.org
Applied to u-boot/master. However: Warning (reg_format): "reg" property in /i2c-gpio-0/pcf8563@50 has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1) Warning (avoid_default_addr_size): Relying on default #address-cells value for /i2c-gpio-0/pcf8563@50 Warning (avoid_default_addr_size): Relying on default #size-cells value for /i2c-gpio-0/pcf8563@50
Please fix and push to the kernel as well as U-Boot, thanks!
Yes, I will send the patch.
Best Regards, Wenyou Yang
Wenyou Yang
Yang, Wenyou
