[U-Boot] [PATCH v2] gpio: mscc-bitbang-spi: Add a simple gpio driver for bitbgang spi
The VCore III SoCs such as the Luton but also the Ocelot can remap an SPI flash directly in memory. However, for writing in the flash the communication has to be done by software.
Each of the signal used for the SPI are exposed in a single register. In order to be able to use the soft-spi driver, the management of this pin is done through this simple gpio driver.
Even if the main purpose of this driver is to be used by soft-spi, it can still be used as a normal gpio driver but with limitation: for example the first pin can't be used as output.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- Changelog: v1 -> v2: - use const and static when needed - fix style - use dev_remap_addr
drivers/gpio/Kconfig | 7 ++ drivers/gpio/Makefile | 1 + drivers/gpio/gpio-mscc-bitbang-spi.c | 122 +++++++++++++++++++++++++++ 3 files changed, 130 insertions(+) create mode 100644 drivers/gpio/gpio-mscc-bitbang-spi.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 5cd8b34400..947a59cce3 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -99,6 +99,13 @@ config LPC32XX_GPIO help Support for the LPC32XX GPIO driver.
+config MSCC_BITBANG_SPI_GPIO + bool "Microsemi bitbang spi GPIO driver" + depends on DM_GPIO && SOC_VCOREIII + help + Support controlling the GPIO used for SPI bitbang by software. Can + be used by the VCoreIII SoCs, but it was mainly useful for Luton. + config MSM_GPIO bool "Qualcomm GPIO driver" depends on DM_GPIO diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index f186120684..2085dd3cba 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -58,3 +58,4 @@ obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o obj-$(CONFIG_PM8916_GPIO) += pm8916_gpio.o +obj-$(CONFIG_MSCC_BITBANG_SPI_GPIO) += gpio-mscc-bitbang-spi.o diff --git a/drivers/gpio/gpio-mscc-bitbang-spi.c b/drivers/gpio/gpio-mscc-bitbang-spi.c new file mode 100644 index 0000000000..b675f9052c --- /dev/null +++ b/drivers/gpio/gpio-mscc-bitbang-spi.c @@ -0,0 +1,122 @@ +// SPDX-License-Identifier: (GPL-2.0 OR MIT) +/* + * Microsemi SoCs pinctrl driver + * + * Author: gregory.clement@bootlin.com + * License: Dual MIT/GPL + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <asm-generic/gpio.h> +#include <asm/io.h> +#include <dm.h> +#include <errno.h> + +enum { + SDI, + CS0, + CS1, + CS2, + CS3, + SDO, + SCK +}; + +static const int pinmap[] = { 0, 5, 6, 7, 8, 10, 12 }; + +#define SW_SPI_CSn_OE 0x1E /* bits 1 to 4 */ +#define SW_SPI_CS0_OE BIT(1) +#define SW_SPI_SDO_OE BIT(9) +#define SW_SPI_SCK_OE BIT(11) +#define SW_PIN_CTRL_MODE BIT(13) + +struct mscc_bb_spi_gpio { + void __iomem *regs; + u32 cache_val; +}; + +static int mscc_bb_spi_gpio_set(struct udevice *dev, unsigned oft, int val) +{ + struct mscc_bb_spi_gpio *gpio = dev_get_priv(dev); + + if (val) + gpio->cache_val |= BIT(pinmap[oft]); + else + gpio->cache_val &= ~BIT(pinmap[oft]); + + writel(gpio->cache_val, gpio->regs); + + return 0; +} + +static int mscc_bb_spi_gpio_direction_output(struct udevice *dev, unsigned oft, + int val) +{ + if (oft == 0) { + pr_err("SW_SPI_DSI can't be used as output\n"); + return -ENOTSUPP; + } + + mscc_bb_spi_gpio_set(dev, oft, val); + + return 0; +} + +static int mscc_bb_spi_gpio_direction_input(struct udevice *dev, unsigned oft) +{ + return 0; +} + +static int mscc_bb_spi_gpio_get(struct udevice *dev, unsigned int oft) +{ + struct mscc_bb_spi_gpio *gpio = dev_get_priv(dev); + u32 val = readl(gpio->regs); + + return !!(val & BIT(pinmap[oft])); +} + +static const struct dm_gpio_ops mscc_bb_spi_gpio_ops = { + .direction_output = mscc_bb_spi_gpio_direction_output, + .direction_input = mscc_bb_spi_gpio_direction_input, + .set_value = mscc_bb_spi_gpio_set, + .get_value = mscc_bb_spi_gpio_get, +}; + +static int mscc_bb_spi_gpio_probe(struct udevice *dev) +{ + struct mscc_bb_spi_gpio *gpio = dev_get_priv(dev); + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + + gpio->regs = dev_remap_addr(dev); + if (!gpio->regs) + return -EINVAL; + + uc_priv->bank_name = dev->name; + uc_priv->gpio_count = ARRAY_SIZE(pinmap); + /* + * Enable software mode to control the SPI pin, enables the + * output mode for most of the pin and initialize the cache + * value in the same time + */ + + gpio->cache_val = SW_PIN_CTRL_MODE | SW_SPI_SCK_OE | SW_SPI_SDO_OE | + SW_SPI_CS0_OE; + writel(gpio->cache_val, gpio->regs); + + return 0; +} + +static const struct udevice_id mscc_bb_spi_gpio_ids[] = { + {.compatible = "mscc,spi-bitbang-gpio"}, + {} +}; + +U_BOOT_DRIVER(gpio_mscc_bb_spi) = { + .name = "gpio-mscc-spi-bitbang", + .id = UCLASS_GPIO, + .ops = &mscc_bb_spi_gpio_ops, + .probe = mscc_bb_spi_gpio_probe, + .of_match = of_match_ptr(mscc_bb_spi_gpio_ids), + .priv_auto_alloc_size = sizeof(struct mscc_bb_spi_gpio), +};
- fix style
I sent this version 2 months ago and addressed all the comments, how could we going further ?
Thanks,
Gregory
- bool "Microsemi bitbang spi GPIO driver"
- depends on DM_GPIO && SOC_VCOREIII
- help
- Microsemi SoCs pinctrl driver
- Author: gregory.clement@bootlin.com
- License: Dual MIT/GPL
- Copyright (c) 2018 Microsemi Corporation
+enum {
- SDI,
- CS0,
- CS1,
- CS2,
- CS3,
- SDO,
- SCK
- void __iomem *regs;
- u32 cache_val;
- struct mscc_bb_spi_gpio *gpio = dev_get_priv(dev);
- if (val)
- else
- writel(gpio->cache_val, gpio->regs);
int val)
- if (oft == 0) {
return -ENOTSUPP;
- mscc_bb_spi_gpio_set(dev, oft, val);
- u32 val = readl(gpio->regs);
- return !!(val & BIT(pinmap[oft]));
- .direction_output = mscc_bb_spi_gpio_direction_output,
- .direction_input = mscc_bb_spi_gpio_direction_input,
- .set_value = mscc_bb_spi_gpio_set,
- .get_value = mscc_bb_spi_gpio_get,
- struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
- gpio->regs = dev_remap_addr(dev);
- if (!gpio->regs)
return -EINVAL;
- uc_priv->bank_name = dev->name;
- uc_priv->gpio_count = ARRAY_SIZE(pinmap);
- gpio->cache_val = SW_PIN_CTRL_MODE | SW_SPI_SCK_OE | SW_SPI_SDO_OE |
SW_SPI_CS0_OE;
- {.compatible = "mscc,spi-bitbang-gpio"},
- .name = "gpio-mscc-spi-bitbang",
- .id = UCLASS_GPIO,
- .ops = &mscc_bb_spi_gpio_ops,
- .probe = mscc_bb_spi_gpio_probe,
- .of_match = of_match_ptr(mscc_bb_spi_gpio_ids),
- .priv_auto_alloc_size = sizeof(struct mscc_bb_spi_gpio),
2.19.1
Am 08.12.18 um 10:00 schrieb Gregory CLEMENT:
- fix style
Thanks,
Gregory
I'll apply it along with your Ocelot/Luton series. It only makes sense to merge a new driver if there is a user for it ;)
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
Gregory CLEMENT
