[U-Boot] [RESEND PATCH] common/lcd_console: fix console/logo regression
The following commit changed the order of the column vs. row parameter to the lcd_init_console() function but missed actually changing it as well the second time it is called from lcd_clear() which resulted in a garbled text console which this patch fixes.
commit 604c7d4a5a3cf70949f6e6094bf0d52ee3b4804d common/lcd_console: introduce display/framebuffer rotation
Tested on Colibri T20 with my latest assortment of tegra fixes/enhancements patch set.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com --- common/lcd.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/common/lcd.c b/common/lcd.c index 5a52fe4..d29308a 100644 --- a/common/lcd.c +++ b/common/lcd.c @@ -234,8 +234,8 @@ void lcd_clear(void) lcd_logo(); #if defined(CONFIG_LCD_LOGO) && !defined(CONFIG_LCD_INFO_BELOW_LOGO) addr = (ulong)lcd_base + BMP_LOGO_HEIGHT * lcd_line_length; - lcd_init_console((void *)addr, panel_info.vl_row, - panel_info.vl_col, panel_info.vl_rot); + lcd_init_console((void *)addr, panel_info.vl_col, + panel_info.vl_row, panel_info.vl_rot); #endif lcd_sync(); }
Thanks, Simon.
Could any of you guys please pull that one in or how do we proceed?
On Thu, 13 Aug 2015 13:57:37 +0200 Marcel Ziswiler marcel@ziswiler.com wrote: ...
Sorry for delay, I'll merge the patch soon.
Thanks,
Anatolij
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com Acked-by: Simon Glass sjg@chromium.org
Anatolij Gustschin
Marcel Ziswiler
