[U-Boot] Porting u-boot for MPC8280 based Board by taking MPC8260ads reference, Its hanging at some point
Dear sir,
I'm porting u-boot for mpc8280 based CPU board by taking mpc8260ads reference, its hanging at some some point. i enabled debug mode.
U-Boot 1.3.1 (Aug 8 2012 - 09:19:16)
MPC8260 Reset Status: Check Stop, External Soft, External Hard
MPC8260 Clock Configuration - Bus-to-Core Mult 2.5x, VCO Div 4, 60x Bus Freq 20-60 , Core Freq 50-120 - dfbrg 1, corecnf 0x11, busdf 3, cpmdf 1, plldf 0, pllmf 3, pcidf 3 - vco_out 400000000, scc_clk 100000000, brg_clk 25000000 - cpu_clk 250000000, cpm_clk 200000000, bus_clk 100000000
CPU: MPC8260 (HiP7 Rev 14, Mask 1.0 1K49M) at 250 MHz Board: MPC8280 Based Remote IO CARD.Testing By Thiru N............... I2C: ready DRAM: 512 MB Top of RAM usable for U-Boot at: 20000000 Reserving 187k for U-Boot at: 1ffd1000 Reserving 192k for malloc() at: 1ffa1000 Reserving 76 Bytes for Board Info at: 1ffa0fb4 Reserving 72 Bytes for Global Data at: 1ffa0f6c Stack Pointer at: 1ffa0f48 New Stack Pointer is: 1ffa0f48
please can you suggest me to fix this issue.
for your reference
Clock frequency 100MHz Boot flash 512KB userflash 512MB SDRAM 512MB
Thanks & Regards Thiru N
Dear Thirumalesha N,
In message CAO1Rv-YKnF7sixuKqpHLCX9d_YwDhqHNPgQwVNZ1C+KXecH+gw@mail.gmail.com you wrote:
I explained this before. Please stop asking questions about 5 year old code - we don't concenrn ourself ith this any more (at least not unless you pay for a commercial contract to do that).
Please use current code, start your work, and if you get stuck, then ask specific questions. Requests as "can you suggest me to fix this issue" without actually asking a specific question will not bring you the help you appear to expect. Please read http://catb.org/esr/faqs/smart-questions.html to understand why this is so.
On Thu, Aug 09, 2012 at 11:44:18AM +0530, Thirumalesha N wrote:
I'm porting u-boot for mpc8280 based CPU board by taking mpc8260ads reference, its hanging at some some point. i enabled debug mode. U-Boot 1.3.1 (Aug 8 2012 - 09:19:16)
<snip>
I'm no expert, but I had a similar problem with my at91sam9g20 board. The problem was that the first level bootloader (at91bootstrap in my case) was wrong configured so it doesn't read the whole U-Boot binary from flash before starting it ...
Maybe you can check this. And of course ... use a resend U-Boot!
Cheers, Markus
Markus Hubig
Thirumalesha N
