[U-Boot] [PATCH v3] Kconfig: Move USE_ARCH_MEMCPY/MEMSET to Kconfig
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig.
Make it "default y" for the ARMv7 architecture and make it depend on !ARM64 && !SPL.
Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- Changes since v2: - Move it to arch/arm/Kconfig - Change default and depends logic
arch/arm/Kconfig | 18 ++++++++++++++++++ include/configs/armadillo-800eva.h | 2 -- include/configs/blanche.h | 3 --- include/configs/colibri_imx7.h | 2 -- include/configs/colibri_vf.h | 2 -- include/configs/exynos-common.h | 3 --- include/configs/pcm052.h | 1 - include/configs/tegra-common.h | 6 ------ include/configs/uniphier.h | 5 ----- include/configs/vf610twr.h | 1 - 10 files changed, 18 insertions(+), 25 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 714dd8b..b15f13f 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -126,6 +126,24 @@ config ENABLE_ARM_SOC_BOOT0_HOOK ARM_SOC_BOOT0_HOOK which contains the required assembler preprocessor code.
+config USE_ARCH_MEMCPY + bool "Use an assembly optimized implementation of memcpy" + default y if CPU_V7 + depends on !ARM64 && !SPL + help + Enable the generation of an optimized version of memcpy. + Such implementation may be faster under some conditions + but may increase the binary size. + +config USE_ARCH_MEMSET + bool "Use an assembly optimized implementation of memset" + default y if CPU_V7 + depends on !ARM64 && !SPL + help + Enable the generation of an optimized version of memset. + Such implementation may be faster under some conditions + but may increase the binary size. + config ARCH_OMAP2 bool select CPU_V7 diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 2d24253..3775a49 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -28,8 +28,6 @@
#define CONFIG_ARCH_CPU_INIT #define CONFIG_BOARD_EARLY_INIT_F -#define CONFIG_USE_ARCH_MEMSET -#define CONFIG_USE_ARCH_MEMCPY #define CONFIG_TMU_TIMER #define CONFIG_SYS_DCACHE_OFF
diff --git a/include/configs/blanche.h b/include/configs/blanche.h index f094bbe..0deb350 100755 --- a/include/configs/blanche.h +++ b/include/configs/blanche.h @@ -16,9 +16,6 @@
#include "rcar-gen2-common.h"
-#define CONFIG_USE_ARCH_MEMSET -#define CONFIG_USE_ARCH_MEMCPY - /* STACK */ #define CONFIG_SYS_INIT_SP_ADDR 0xE817FFFC #define STACK_AREA_SIZE 0xC000 diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 5ce0a34..bc3b53b 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -15,8 +15,6 @@ #include "mx7_common.h"
#define CONFIG_SYS_THUMB_BUILD -#define CONFIG_USE_ARCH_MEMCPY -#define CONFIG_USE_ARCH_MEMSET
/*#define CONFIG_DBG_MONITOR*/ #define PHYS_SDRAM_SIZE SZ_512M diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index d58145e..47dea62 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -16,8 +16,6 @@
#define CONFIG_VF610 #define CONFIG_SYS_THUMB_BUILD -#define CONFIG_USE_ARCH_MEMCPY -#define CONFIG_USE_ARCH_MEMSET #define CONFIG_SYS_FSL_CLK
#define CONFIG_ARCH_MISC_INIT diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 3b61a41..566f246 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -20,9 +20,6 @@ #define CONFIG_SKIP_LOWLEVEL_INIT #define CONFIG_BOARD_EARLY_INIT_F
-#define CONFIG_USE_ARCH_MEMCPY -#define CONFIG_USE_ARCH_MEMSET - /* Keep L2 Cache Disabled */
/* input clock of PLL: 24MHz input clock */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index eb1944a..e70c3f0 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -35,7 +35,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION
#ifdef CONFIG_CMD_NAND -#define CONFIG_USE_ARCH_MEMCPY #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_SYS_NAND_BASE NFC_BASE_ADDR
diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 63b711b..23a0e78 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -76,12 +76,6 @@ #define CONFIG_SYS_MEMTEST_START (NV_PA_SDRC_CS0 + 0x600000) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x100000)
-#ifndef CONFIG_ARM64 -#ifndef CONFIG_SPL_BUILD -#define CONFIG_USE_ARCH_MEMCPY -#endif -#endif - /*----------------------------------------------------------------------- * Physical Memory Map */ diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index f9c9f82..74f1373 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -63,11 +63,6 @@ /* serial console configuration */ #define CONFIG_BAUDRATE 115200
-#if !defined(CONFIG_SPL_BUILD) && !defined(CONFIG_ARM64) -#define CONFIG_USE_ARCH_MEMSET -#define CONFIG_USE_ARCH_MEMCPY -#endif - #define CONFIG_SYS_LONGHELP /* undef to save memory */
#define CONFIG_CMDLINE_EDITING /* add command line history */ diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index af5ba61..6aeb078 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -42,7 +42,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION
Thanks, Tom.
Are you also happy with this one? https://patchwork.ozlabs.org/patch/706199/
Fabio Estevam
