[PATCH v1] mtd: rawnand: macronix: OTP access for MX30LFxG18AC
Support for OTP area access on MX30LFxG18AC chip series.
Signed-off-by: Arseniy Krasnov avkrasnov@salutedevices.com --- drivers/mtd/nand/raw/nand_macronix.c | 170 +++++++++++++++++++++++++++ 1 file changed, 170 insertions(+)
diff --git a/drivers/mtd/nand/raw/nand_macronix.c b/drivers/mtd/nand/raw/nand_macronix.c index dc972e5909..4c6ddd9233 100644 --- a/drivers/mtd/nand/raw/nand_macronix.c +++ b/drivers/mtd/nand/raw/nand_macronix.c @@ -16,13 +16,183 @@ * GNU General Public License for more details. */
+#include <dm/device_compat.h> #include <linux/mtd/rawnand.h>
+#define ONFI_FEATURE_ADDR_30LFXG18AC_OTP 0x90 +#define MACRONIX_30LFXG18AC_OTP_START_PAGE 2 +#define MACRONIX_30LFXG18AC_OTP_PAGES 30 +#define MACRONIX_30LFXG18AC_OTP_PAGE_SIZE 2112 +#define MACRONIX_30LFXG18AC_OTP_SIZE_BYTES \ + (MACRONIX_30LFXG18AC_OTP_PAGES * \ + MACRONIX_30LFXG18AC_OTP_PAGE_SIZE) + +#define MACRONIX_30LFXG18AC_OTP_EN BIT(0) + +static int macronix_30lfxg18ac_get_otp_info(struct mtd_info *mtd, size_t len, + size_t *retlen, + struct otp_info *buf) +{ + if (len < sizeof(*buf)) + return -EINVAL; + + /* Always report that OTP is unlocked. Reason is that this + * type of flash chip doesn't provide way to check that OTP + * is locked or not: subfeature parameter is implemented as + * volatile register. Technically OTP region could be locked + * and become readonly, but as there is no way to check it, + * don't allow to lock it ('_lock_user_prot_reg' callback + * always returns -EOPNOTSUPP) and thus we report that OTP + * is unlocked. + */ + buf->locked = 0; + buf->start = 0; + buf->length = MACRONIX_30LFXG18AC_OTP_SIZE_BYTES; + + *retlen = sizeof(*buf); + + return 0; +} + +static int macronix_30lfxg18ac_otp_enable(struct nand_chip *nand) +{ + u8 feature_buf[ONFI_SUBFEATURE_PARAM_LEN] = { 0 }; + struct mtd_info *mtd; + + mtd = nand_to_mtd(nand); + feature_buf[0] = MACRONIX_30LFXG18AC_OTP_EN; + + return nand->onfi_set_features(mtd, nand, ONFI_FEATURE_ADDR_30LFXG18AC_OTP, feature_buf); +} + +static int macronix_30lfxg18ac_otp_disable(struct nand_chip *nand) +{ + u8 feature_buf[ONFI_SUBFEATURE_PARAM_LEN] = { 0 }; + struct mtd_info *mtd; + + mtd = nand_to_mtd(nand); + return nand->onfi_set_features(mtd, nand, ONFI_FEATURE_ADDR_30LFXG18AC_OTP, feature_buf); +} + +static int __macronix_30lfxg18ac_rw_otp(struct mtd_info *mtd, + loff_t offs_in_flash, + size_t len, size_t *retlen, + u_char *buf, bool write) +{ + struct nand_chip *nand; + size_t bytes_handled; + off_t offs_in_page; + u64 page; + int ret; + + nand = mtd_to_nand(mtd); + nand->select_chip(mtd, 0); + + ret = macronix_30lfxg18ac_otp_enable(nand); + if (ret) + goto out_otp; + + page = offs_in_flash; + /* 'page' will be result of division. */ + offs_in_page = do_div(page, MACRONIX_30LFXG18AC_OTP_PAGE_SIZE); + bytes_handled = 0; + + while (bytes_handled < len && + page < MACRONIX_30LFXG18AC_OTP_PAGES) { + size_t bytes_to_handle; + u64 phys_page = page + MACRONIX_30LFXG18AC_OTP_START_PAGE; + + bytes_to_handle = min_t(size_t, len - bytes_handled, + MACRONIX_30LFXG18AC_OTP_PAGE_SIZE - + offs_in_page); + + if (write) + ret = nand_prog_page_op(nand, phys_page, offs_in_page, + &buf[bytes_handled], bytes_to_handle); + else + ret = nand_read_page_op(nand, phys_page, offs_in_page, + &buf[bytes_handled], bytes_to_handle); + if (ret) + goto out_otp; + + bytes_handled += bytes_to_handle; + offs_in_page = 0; + page++; + } + + *retlen = bytes_handled; + +out_otp: + if (ret) + dev_err(mtd->dev, "failed to perform OTP IO: %i\n", ret); + + ret = macronix_30lfxg18ac_otp_disable(nand); + if (ret) + dev_err(mtd->dev, "failed to leave OTP mode after %s\n", + write ? "write" : "read"); + + nand->select_chip(mtd, -1); + + return ret; +} + +static int macronix_30lfxg18ac_write_otp(struct mtd_info *mtd, loff_t to, + size_t len, size_t *rlen, + u_char *buf) +{ + return __macronix_30lfxg18ac_rw_otp(mtd, to, len, rlen, (u_char *)buf, + true); +} + +static int macronix_30lfxg18ac_read_otp(struct mtd_info *mtd, loff_t from, + size_t len, size_t *rlen, + u_char *buf) +{ + return __macronix_30lfxg18ac_rw_otp(mtd, from, len, rlen, buf, false); +} + +static int macronix_30lfxg18ac_lock_otp(struct mtd_info *mtd, loff_t from, + size_t len) +{ + /* See comment in 'macronix_30lfxg18ac_get_otp_info()'. */ + return -EOPNOTSUPP; +} + +static void macronix_nand_setup_otp(struct nand_chip *chip) +{ + static const char * const supported_otp_models[] = { + "MX30LF1G18AC", + "MX30LF2G18AC", + "MX30LF4G18AC", + }; + int i; + + if (!chip->onfi_version || + !(le16_to_cpu(chip->onfi_params.opt_cmd) + & ONFI_OPT_CMD_SET_GET_FEATURES)) + return; + + for (i = 0; i < ARRAY_SIZE(supported_otp_models); i++) { + if (!strcmp(chip->onfi_params.model, supported_otp_models[i])) { + struct mtd_info *mtd; + + mtd = nand_to_mtd(chip); + mtd->_get_user_prot_info = macronix_30lfxg18ac_get_otp_info; + mtd->_read_user_prot_reg = macronix_30lfxg18ac_read_otp; + mtd->_write_user_prot_reg = macronix_30lfxg18ac_write_otp; + mtd->_lock_user_prot_reg = macronix_30lfxg18ac_lock_otp; + return; + } + } +} + static int macronix_nand_init(struct nand_chip *chip) { if (nand_is_slc(chip)) chip->bbt_options |= NAND_BBT_SCAN2NDPAGE;
+ macronix_nand_setup_otp(chip); + return 0; }
cc: Miquel Raynal
- (MACRONIX_30LFXG18AC_OTP_PAGES * \
size_t *retlen,
- if (len < sizeof(*buf))
return -EINVAL;
- /* Always report that OTP is unlocked. Reason is that this
* is unlocked.
- buf->locked = 0;
- buf->start = 0;
- buf->length = MACRONIX_30LFXG18AC_OTP_SIZE_BYTES;
- *retlen = sizeof(*buf);
- u8 feature_buf[ONFI_SUBFEATURE_PARAM_LEN] = { 0 };
- struct mtd_info *mtd;
- mtd = nand_to_mtd(nand);
- feature_buf[0] = MACRONIX_30LFXG18AC_OTP_EN;
- return nand->onfi_set_features(mtd, nand, ONFI_FEATURE_ADDR_30LFXG18AC_OTP, feature_buf);
- struct nand_chip *nand;
- size_t bytes_handled;
- off_t offs_in_page;
- u64 page;
- int ret;
- nand = mtd_to_nand(mtd);
- nand->select_chip(mtd, 0);
- ret = macronix_30lfxg18ac_otp_enable(nand);
- if (ret)
goto out_otp;
- page = offs_in_flash;
- /* 'page' will be result of division. */
- offs_in_page = do_div(page, MACRONIX_30LFXG18AC_OTP_PAGE_SIZE);
- bytes_handled = 0;
- while (bytes_handled < len &&
offs_in_page);
if (write)
else
if (ret)
goto out_otp;
offs_in_page = 0;
page++;
- *retlen = bytes_handled;
+out_otp:
- if (ret)
- ret = macronix_30lfxg18ac_otp_disable(nand);
- if (ret)
- nand->select_chip(mtd, -1);
- return ret;
u_char *buf)
- return __macronix_30lfxg18ac_rw_otp(mtd, to, len, rlen, (u_char *)buf,
true);
u_char *buf)
- return __macronix_30lfxg18ac_rw_otp(mtd, from, len, rlen, buf, false);
size_t len)
- /* See comment in 'macronix_30lfxg18ac_get_otp_info()'. */
- return -EOPNOTSUPP;
- static const char * const supported_otp_models[] = {
"MX30LF1G18AC",
"MX30LF2G18AC",
"MX30LF4G18AC",
- int i;
- if (!chip->onfi_version ||
return;
- for (i = 0; i < ARRAY_SIZE(supported_otp_models); i++) {
return;
- macronix_nand_setup_otp(chip);
cc: Jaime Liao
On 04.12.2023 22:23, Arseniy Krasnov wrote:
cc: Miquel Raynal
size_t *retlen,
return -EINVAL;
* is unlocked.
- buf->locked = 0;
- buf->start = 0;
- u64 page;
- int ret;
- if (ret)
goto out_otp;
offs_in_page);
if (write)
else
if (ret)
goto out_otp;
offs_in_page = 0;
page++;
+out_otp:
- if (ret)
- if (ret)
- return ret;
u_char *buf)
true);
u_char *buf)
size_t len)
"MX30LF1G18AC",
"MX30LF2G18AC",
"MX30LF4G18AC",
- int i;
return;
return;
Sorry, pls ping
Thanks, Arseniy
On 18.12.2023 14:54, Arseniy Krasnov wrote:
cc: Jaime Liao
cc: Miquel Raynal
size_t *retlen,
return -EINVAL;
* is unlocked.
- buf->locked = 0;
- buf->start = 0;
- u64 page;
- int ret;
- if (ret)
goto out_otp;
offs_in_page);
if (write)
else
if (ret)
goto out_otp;
offs_in_page = 0;
page++;
+out_otp:
- if (ret)
- if (ret)
- return ret;
u_char *buf)
true);
u_char *buf)
size_t len)
"MX30LF1G18AC",
"MX30LF2G18AC",
"MX30LF4G18AC",
- int i;
return;
return;
Hi Dario
Can apply this series and put in CI?
Michael
On Wed, Mar 13, 2024 at 7:43 AM Arseniy Krasnov avkrasnov@salutedevices.com wrote:
Sorry, please ping
Thanks, Arseniy
On 11.02.2024 02:16, Arseniy Krasnov wrote:
Sorry, pls ping
Thanks, Arseniy
On 08.01.2024 21:33, Arseniy Krasnov wrote:
Sorry, pls ping
Thanks, Arseniy
Hello,
Sorry, pls ping
Thanks, Arseniy
On 13.03.2024 09:46, Michael Nazzareno Trimarchi wrote:
Hi Dario
Michael
Sorry, please ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
Hi
Dario did you add those patches in CI and test them again?
Michael
On Wed, Apr 17, 2024 at 8:44 PM Arseniy Krasnov avkrasnov@salutedevices.com wrote:
Hello,
Sorry, pls ping
Thanks, Arseniy
Hi Dario
Michael
Sorry, please ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
Arseniy, Michael, All
On Wed, Apr 17, 2024 at 8:44 PM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi
Michael
Hello,
Sorry, pls ping
Thanks, Arseniy
Hi Dario
Sorry, but I mistakenly tagged it as 'superseded'. I just pushed it to my nand-next branch and I'm running the CI now.
Thanks and regards, Dario
Michael
Sorry, please ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
-- Michael Nazzareno Trimarchi Co-Founder & Chief Executive Officer M. +39 347 913 2170 michael@amarulasolutions.com __________________________________
Amarula Solutions BV Joop Geesinkweg 125, 1114 AB, Amsterdam, NL T. +31 (0)85 111 9172 info@amarulasolutions.com www.amarulasolutions.com
Hi Dario!
Sorry, is this patch ok?
Thanks
Hi
Michael
Hello,
Sorry, pls ping
Thanks, Arseniy
Hi Dario
Michael
Sorry, please ping
Thanks, Arseniy
Sorry, pls ping
Thanks, Arseniy
On 08.01.2024 21:33, Arseniy Krasnov wrote: > Sorry, pls ping > > Thanks, Arseniy
Hi Arseniy,
On Fri, May 24, 2024 at 11:25 AM Arseniy Krasnov avkrasnov@salutedevices.com wrote:
Hi Dario!
Sorry, I told you I was testing it but I forgot to tell you that testing was successfully completed for this patch.
Thanks
Hi
Michael
Hello,
Sorry, pls ping
Thanks, Arseniy
Hi Dario
Michael
Sorry, please ping
Thanks, Arseniy
On 11.02.2024 02:16, Arseniy Krasnov wrote: > Sorry, pls ping > > Thanks, Arseniy > > On 08.01.2024 21:33, Arseniy Krasnov wrote: >> Sorry, pls ping >> >> Thanks, Arseniy
On 24.05.2024 16:31, Dario Binacchi wrote:
Hi Arseniy,
Hi Dario!
Ah, no problem, it will be merged to next release ?
Thanks
Thanks
Hi
Michael
Hello,
Sorry, pls ping
Thanks, Arseniy
Hi Dario
Michael
On Wed, Mar 13, 2024 at 7:43 AM Arseniy Krasnov avkrasnov@salutedevices.com wrote: > > Sorry, please ping > > Thanks, Arseniy > > On 11.02.2024 02:16, Arseniy Krasnov wrote: >> Sorry, pls ping >> >> Thanks, Arseniy >> >> On 08.01.2024 21:33, Arseniy Krasnov wrote: >>> Sorry, pls ping >>> >>> Thanks, Arseniy
Arseniy Krasnov
Dario Binacchi
