[PATCH v2 03/14] board: freescale: ls1043aqds: Update I2C mux config
Updates the board configuration to enable use of the PCA9547 I2C mux.
Signed-off-by: Stephen Carlson stcarlso@linux.microsoft.com --- board/freescale/ls1043aqds/ls1043aqds.c | 27 +------------------- configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1043aqds_tfa_defconfig | 1 + 10 files changed, 10 insertions(+), 26 deletions(-)
diff --git a/board/freescale/ls1043aqds/ls1043aqds.c b/board/freescale/ls1043aqds/ls1043aqds.c index 5b131d1d67..76bbb6087a 100644 --- a/board/freescale/ls1043aqds/ls1043aqds.c +++ b/board/freescale/ls1043aqds/ls1043aqds.c @@ -28,6 +28,7 @@ #include <fsl_esdhc.h> #include <fsl_ifc.h> #include <spl.h> +#include "../common/i2c_mux.h"
#include "../common/qixis.h" #include "ls1043aqds_qixis.h" @@ -279,32 +280,6 @@ unsigned long get_board_ddr_clk(void) return 66666666; }
-int select_i2c_ch_pca9547(u8 ch, int bus_num) -{ - int ret; - -#if CONFIG_IS_ENABLED(DM_I2C) - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(bus_num, I2C_MUX_PCA_ADDR_PRI, - 1, &dev); - if (ret) { - printf("%s: Cannot find udev for a bus %d\n", __func__, - bus_num); - return ret; - } - ret = dm_i2c_write(dev, 0, &ch, 1); -#else - ret = i2c_write(I2C_MUX_PCA_ADDR_PRI, 0, 1, &ch, 1); -#endif - if (ret) { - puts("PCA: failed to select proper channel\n"); - return ret; - } - - return 0; -} - int dram_init(void) { /* diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 42fd350075..2f1da44884 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -69,3 +69,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 1bafc2bb03..41b304cee8 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -71,3 +71,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 8fb23acd88..25c5d93fcb 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -85,3 +85,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index f87c9a7cbf..a324291824 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -70,3 +70,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 5de4e07457..3724d392bc 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -66,3 +66,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 6e3318b1ed..eedabdbc6b 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -86,3 +86,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index cd20980c98..3058442cdd 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -80,3 +80,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 4caabcadb8..ee92209d63 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -72,3 +72,4 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index fb28072638..c15f956b0a 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -79,3 +79,4 @@ CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y +CONFIG_FSL_USE_PCA9547_MUX=y
Stephen Carlson
