[PATCH v1] arm: Remove redundant loading of image copy start offse
Remove redundant loading of image copy start offset. Because the beginning is already computed
Reviewed-by: Pali Rohár pali@kernel.org Reviewed-by: Simon Glass sjg@chromium.org Signed-off-by: Liya Huang 1425075683@qq.com ---
Changes in v1: - Due to an error, the patch was resubmitted, leaving the code unchanged
arch/arm/lib/relocate.S | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/lib/relocate.S b/arch/arm/lib/relocate.S index 345e282e3e..bffadfecba 100644 --- a/arch/arm/lib/relocate.S +++ b/arch/arm/lib/relocate.S @@ -83,8 +83,6 @@ relocate_base: add r1, r3 /* r1 <- Run &__image_copy_start */ subs r4, r0, r1 /* r4 <- Run to copy offset */ beq relocate_done /* skip relocation */ - ldr r1, _image_copy_start_ofs - add r1, r3 /* r1 <- Run &__image_copy_start */ ldr r2, _image_copy_end_ofs add r2, r3 /* r2 <- Run &__image_copy_end */ copy_loop:
Changes in v1:
I don't understand what you're doing. Please stop posting patches that have "Reviewed-by" tags on them without pointing to other evidence that the person in question supplied that tag somewhere else in public. Thanks.
Hi Liya,
Changes in v1:
Just to explain that a bit more, when you send a patch it normally should just have your 'Signed-off-by:' line. Then, other people reply to your patch with 'Reviewed-by name <email>' tags and these get collected by patchwork.
If you then send a new version (say v2), you can collect the tags from v1 and add them to you patch. But until then you should not add your own 'Reviewed-by' tags since it suggests that others have already reviewed the patch, when they haven't :-)
1425075683@qq.com
