[PATCH v3] usb: cdns3: gadget.c: Set fast access bit
When the device port is in a low power state [U3/L2/Not Connected], accesses to usb device registers may take a long time. This could lead to potential core hang when the controller registers are accessed after the port is disabled by setting DEVDS field. Setting the fast register access bit ensures that the PHY clock is keeping up in active state.
Therefore, set fast access bit to ensure the accesses to device registers are quick even in low power states.
commit b5148d946f45 ("usb: cdns3: gadget: set fast access bit") in the upstream kernel is taken as reference.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com Signed-off-by: Ravi Gunasekaran r-gunasekaran@ti.com Reviewed-by: Roger Quadros rogerq@kernel.org Reviewed-by: Marek Vasut marex@denx.de --- Changes since v2: ---------------- * Updated the commit description with reference to upstream kernel commit * Picked up Marek's Reviewed-by tag from v2
Changes since v1: ----------------- * Rebased to tip of -next * Added Reviewed-by tag
v2: https://lore.kernel.org/all/20240423082420.32336-1-r-gunasekaran@ti.com/ v1: https://lore.kernel.org/u-boot/20230505121353.23486-1-r-gunasekaran@ti.com/
drivers/usb/cdns3/gadget.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c index 7aa0c6b2be..d11175dc5b 100644 --- a/drivers/usb/cdns3/gadget.c +++ b/drivers/usb/cdns3/gadget.c @@ -2325,6 +2325,9 @@ static void cdns3_gadget_config(struct cdns3_device *priv_dev) writel(USB_IEN_INIT, ®s->usb_ien); writel(USB_CONF_CLK2OFFDS | USB_CONF_L1DS, ®s->usb_conf);
+ /* Set the Fast access bit */ + writel(PUSB_PWR_FST_REG_ACCESS, &priv_dev->regs->usb_pwr); + cdns3_configure_dmult(priv_dev, NULL);
cdns3_gadget_pullup(&priv_dev->gadget, 1); @@ -2383,6 +2386,7 @@ static int cdns3_gadget_udc_stop(struct usb_gadget *gadget)
/* disable interrupt for device */ writel(0, &priv_dev->regs->usb_ien); + writel(0, &priv_dev->regs->usb_pwr); writel(USB_CONF_DEVDS, &priv_dev->regs->usb_conf);
return ret;
base-commit: bc39e06778168a34bb4e0a34fbee4edbde4414d8
Changes since v2:
- Updated the commit description with reference to upstream kernel commit
- Picked up Marek's Reviewed-by tag from v2
Changes since v1:
- Rebased to tip of -next
- Added Reviewed-by tag
return ret;
Since this is gadget stuff, +CC Mattijs , that should go through their tree.
Thanks!
Hi Ravi,
Thank you for the patch.
Changes since v2:
Changes since v1:
return ret;
Thanks!
Thank you Marek for CC'ing me, I missed this patch.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
Thanks, Applied to https://source.denx.de/u-boot/custodians/u-boot-dfu (u-boot-dfu)
[1/1] usb: cdns3: gadget.c: Set fast access bit https://source.denx.de/u-boot/custodians/u-boot-dfu/-/commit/3f831439c2dddcb...
-- Mattijs
Mattijs Korpershoek
Ravi Gunasekaran
