[U-Boot] PATCH mtd CFI flash: timeout calculation underflow if imprecise 1kHz timer: fix
From 341dbd88695d3514699aae612d640ed93feb8821 Mon Sep 17 00:00:00 2001 From: Renato Andreola renato.andreola@imagos.it Date: Thu, 6 Aug 2009 18:05:00 +0200 Subject: [PATCH] drivers/mtd/cfi_flash: precision and underflow problem in tout calculation
With old configuration it could happen tout=0 if CONFIG_SYS_HZ<1000 solved avoiding the preprocessor conditional and introducing a compile time branch between a high freq case and a slow freq case.
Signed-off-by: Alessandro Rubini rubini@gnudd.com Renato Andreola renato.andreola@imagos.it --- drivers/mtd/cfi_flash.c | 7 ++++--- 1 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/cfi_flash.c b/drivers/mtd/cfi_flash.c index 81ac5d3..499044f 100644 --- a/drivers/mtd/cfi_flash.c +++ b/drivers/mtd/cfi_flash.c @@ -659,9 +659,10 @@ static int flash_status_check (flash_info_t * info, flash_sect_t sector, { ulong start;
-#if CONFIG_SYS_HZ != 1000 - tout *= CONFIG_SYS_HZ/1000; -#endif + if (CONFIG_SYS_HZ > 10000) + tout *= CONFIG_SYS_HZ/1000; /* for a big HZ, avoid overflow */ + else + tout = (tout * CONFIG_SYS_HZ) / 1000 + 1;
/* Wait for command completion */ start = get_timer (0);
Renato Andreola
