Pull request for UEFI sub-system for efi-2020-10-rc1 (2)
The following changes since commit 61608f395e7dcb2be6060407a72a1149b046430a:
Merge branch '2020-07-08-misc-features-and-fixes' (2020-07-08 20:20:24 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git efi-2020-10-rc1-2
for you to fetch changes up to f4cef8e7585c268f05a8c39e368ca115c25e40d5:
efi_selftest: adjust runtime test for variables (2020-07-09 12:08:41 +0200)
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-10-rc1 (2)
Up to now UEFI variables where stored in U-Boot environment variables. Saving UEFI variables was not possible without saving the U-Boot environment variables. With this patch series file ubootefi.var in the EFI system partition is used for saving UEFI variables. Furthermore the UEFI variables are exposed for reading at runtime.
Code corrections for UEFI secure boot are provided.
A buffer overrun in the RSA library is fixed.
---------------------------------------------------------------- AKASHI Takahiro (13): efi_loader: image_loader: add a check against certificate type of authenticode efi_loader: image_loader: retrieve authenticode only if it exists efi_loader: signature: fix a size check against revocation list efi_loader: signature: make efi_hash_regions more generic efi_loader: image_loader: verification for all signatures should pass efi_loader: image_loader: add digest-based verification for signed image test/py: efi_secboot: apply autopep8 test/py: efi_secboot: more fixes against pylint test/py: efi_secboot: split "signed image" test case-1 into two cases test/py: efi_secboot: add a test against certificate revocation test/py: efi_secboot: add a test for multiple signatures test/py: efi_secboot: add a test for verifying with digest of signed image lib: rsa: export rsa_verify_with_pkey()
Heinrich Schuchardt (22): lib/crypto: use qualified path for x509_parser.h efi_loader: wrong printf format in efi_image_parse efi_loader: fix efi_get_child_controllers() efi_loader: NULL dereference in efi_convert_pointer fs/fat: reduce data size for FAT_WRITE efi_loader: prepare for read only OP-TEE variables efi_loader: display RO attribute in printenv -e efi_loader: separate UEFI variable API from implemementation efi_loader: OsIndicationsSupported, PlatformLangCodes efi_loader: simplify boot manager efi_loader: keep attributes in efi_set_variable_int efi_loader: value of VendorKeys efi_loader: read-only AuditMode and DeployedMode efi_loader: secure boot flag efi_loader: UEFI variable persistence efi_loader: export efi_convert_pointer() efi_loader: optional pointer for ConvertPointer efi_loader: new function efi_memcpy_runtime() efi_loader: memory buffer for variables efi_loader: use memory based variable storage efi_loader: enable UEFI variables at runtime efi_selftest: adjust runtime test for variables
Ilias Apalodimas (1): efi_loader: cleanup for tee backed variables
cmd/nvedit_efi.c | 24 +- doc/api/efi.rst | 2 + fs/fat/fat_write.c | 9 +- include/crypto/pkcs7_parser.h | 2 +- include/efi_api.h | 2 + include/efi_loader.h | 21 +- include/efi_variable.h | 198 ++++++ include/u-boot/rsa.h | 3 + lib/efi_loader/Kconfig | 8 + lib/efi_loader/Makefile | 3 + lib/efi_loader/efi_bootmgr.c | 28 +- lib/efi_loader/efi_boottime.c | 12 +- lib/efi_loader/efi_image_loader.c | 164 +++-- lib/efi_loader/efi_runtime.c | 38 +- lib/efi_loader/efi_setup.c | 59 +- lib/efi_loader/efi_signature.c | 435 ++++++------ lib/efi_loader/efi_var_common.c | 140 ++++ lib/efi_loader/efi_var_file.c | 239 +++++++ lib/efi_loader/efi_var_mem.c | 266 +++++++ lib/efi_loader/efi_variable.c | 830 +++++----------------- lib/efi_loader/efi_variable_tee.c | 138 +--- lib/efi_selftest/efi_selftest_variables_runtime.c | 13 +- lib/rsa/rsa-verify.c | 8 +- test/py/tests/test_efi_secboot/conftest.py | 104 +-- test/py/tests/test_efi_secboot/defs.py | 14 +- test/py/tests/test_efi_secboot/test_authvar.py | 92 +-- test/py/tests/test_efi_secboot/test_signed.py | 206 +++++- test/py/tests/test_efi_secboot/test_unsigned.py | 66 +- 28 files changed, 1867 insertions(+), 1257 deletions(-) create mode 100644 include/efi_variable.h create mode 100644 lib/efi_loader/efi_var_common.c create mode 100644 lib/efi_loader/efi_var_file.c create mode 100644 lib/efi_loader/efi_var_mem.c
NAK. This is reliably failing here: https://gitlab.denx.de/u-boot/u-boot/-/jobs/122018
I see it passed Azure, and hasn't run through Travis yet. Maybe it needs to be run repeatedly to fail and we just got "lucky" ?
Hello Tom,
you saw unreproducible results with multiple runs failing and one run succeeding. The reason is that when signing with sign-efi-sig-list in out Python tests without passing a timestamp two signatures may be in the same second or not.
When using the signed files to set UEFI variables a variable can only be overwritten by a file with a newer timestamp. But without setting timestamps explicitly using parameter -t passed to sign-efi-sig-list we have no control.
I already fixed this for some elder tests but missed to fix this for the merged patches from Takahiro.
Best regards
Heinrich
Hello Tom,
Ah, thanks for the explanation.
Hello Tom,
Hello Tom,
what I still do not understand why tests are sometimes skipped and sometimes not for the same source code:
https://gitlab.denx.de/u-boot/u-boot/-/jobs/122018 Commit 7068e523
140 test/py/tests/test_efi_secboot/test_authvar.py ..... 141 test/py/tests/test_efi_secboot/test_signed.py .....F 142 test/py/tests/test_efi_secboot/test_unsigned.py ...
https://gitlab.denx.de/u-boot/custodians/u-boot-efi/-/jobs/122155 Commit 7068e523
148 test/py/tests/test_efi_secboot/test_authvar.py sssss 149 test/py/tests/test_efi_secboot/test_signed.py ssssss 150 test/py/tests/test_efi_secboot/test_unsigned.py sss
Both runs used the same Docker image trini/u-boot-gitlab-ci-runner:bionic-20200526-18Jun2020
What influence have different versions of the Gitlab runner?
gitlab-runner 13.1.1 gitlab-runner 12.2.0
Some of our tests create and delete files in /tmp. How are parallel jobs separated in Gitlab?
Best regards
Heinrich
Hello Tom,
Hello Tom,
Best regards
Heinrich
This information I received on the #gitlab IRC channel:
Q: When using Gitlab CI for building the U-Boot project many jobs run in parallel. Some results are irreproducible. How are parallel jobs separated in Gitlab. E.g. if parallel jobs write and delete files in /tmp are these in separate Docker containers or are they in the same Docker container accessing the same directory?
A: Yes, each job is a distinct docker container on a transient VM . Nothing is shared unless you use the https://docs.gitlab.com/ee/ci/yaml/#cache capability, but that wouldn't help for parallel jobs. At least: on gitlab.com, that's how it's implemented. On self-managed: depends a little on how you choose to operate your runners (e.g. shell-executor vs docker etc).
Best regards
Heinrich
Heinrich,
Hello Tom,
Hello Tom,
No longer true. You fixed it with the commit b32ac16f9a32 ("test/py: fix test_efi_secboot/conftest.py").
-Takahiro Akashi
Best regards
Heinrich
AKASHI Takahiro
