[U-Boot] [PATCH 1/1] efi_loader: assign HII protocols to root node
We should not install the HII protocols on every loaded image. It is sufficient to install them once on the root node.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_loader/efi_boottime.c | 20 -------------------- lib/efi_loader/efi_root_node.c | 20 ++++++++++++++++++++ 2 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index b215bd7723..31d11b8678 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1569,26 +1569,6 @@ efi_status_t efi_setup_loaded_image(struct efi_device_path *device_path, if (ret != EFI_SUCCESS) goto failure;
-#if CONFIG_IS_ENABLED(EFI_LOADER_HII) - ret = efi_add_protocol(&obj->header, - &efi_guid_hii_string_protocol, - (void *)&efi_hii_string); - if (ret != EFI_SUCCESS) - goto failure; - - ret = efi_add_protocol(&obj->header, - &efi_guid_hii_database_protocol, - (void *)&efi_hii_database); - if (ret != EFI_SUCCESS) - goto failure; - - ret = efi_add_protocol(&obj->header, - &efi_guid_hii_config_routing_protocol, - (void *)&efi_hii_config_routing); - if (ret != EFI_SUCCESS) - goto failure; -#endif - *info_ptr = info; *handle_ptr = obj;
diff --git a/lib/efi_loader/efi_root_node.c b/lib/efi_loader/efi_root_node.c index b056ba3ee8..b58d9d8c96 100644 --- a/lib/efi_loader/efi_root_node.c +++ b/lib/efi_loader/efi_root_node.c @@ -74,6 +74,26 @@ efi_status_t efi_root_node_register(void) if (ret != EFI_SUCCESS) goto failure;
+#if CONFIG_IS_ENABLED(EFI_LOADER_HII) + /* Install HII string protocol */ + ret = efi_add_protocol(root, &efi_guid_hii_string_protocol, + (void *)&efi_hii_string); + if (ret != EFI_SUCCESS) + goto failure; + + /* Install HII database protocol */ + ret = efi_add_protocol(root, &efi_guid_hii_database_protocol, + (void *)&efi_hii_database); + if (ret != EFI_SUCCESS) + goto failure; + + /* Install HII configuration routing protocol */ + ret = efi_add_protocol(root, &efi_guid_hii_config_routing_protocol, + (void *)&efi_hii_config_routing); + if (ret != EFI_SUCCESS) + goto failure; +#endif + failure: return ret; } -- 2.20.1
First time I submitted HII patch, we didn't have root node :) Anyhow, why not use efi_install_multiple_protocol_interfaces()? It would make the code smart.
Thanks, -Takahiro Akashi
goto failure;
goto failure;
goto failure;
-#endif
- /* Install HII string protocol */
- ret = efi_add_protocol(root, &efi_guid_hii_string_protocol,
goto failure;
- /* Install HII database protocol */
- ret = efi_add_protocol(root, &efi_guid_hii_database_protocol,
goto failure;
- /* Install HII configuration routing protocol */
- ret = efi_add_protocol(root, &efi_guid_hii_config_routing_protocol,
goto failure;
I fully agree. This should also involve other protocols. I suggest to do such a change in a follow up patch. This makes reviewing much easier.
We also should think about moving the console IO protocols and the GOP protocol to the root node and using the root device path to initialize the ConIn, ConInDev, ConOut, ConOutDev variables. Currently the console IO protocols and the GOP protocol are installed on handles without device path.
Best regards
Heinrich
goto failure;
goto failure;
goto failure;
-#endif
goto failure;
goto failure;
goto failure;
- failure: return ret; }
-- 2.20.1
AKASHI Takahiro
